  3. Vera
  4. Help with Luup Reloads
Oh the joy of pairing
Vera
Vera
Free to a new home
Vera
MiOS is Winning the X10 Wars
Vera
Let's assume you have done the following: Downloaded and installed Z-Way following these instructions. No Zway license is required to do the following. The software is now all up and running with your UZB stick (whole other post). Dial up this Zway web page: http://<Zway_server_IP_address>:8083/expert/#/network/controller Under the heading "Firmware" take note of the "SDK version" and the "Serial API Version". Say they equal 6.71.01 & 05.23 respectively like it shows here. Now on to Vera: Go to the Vera UI --> Z-Wave Settings and taken note of the "Version" shown for Vera's internal Zwave IC. For example purposes, say it equals "6.01". You plug your UZB stick into Vera. In the Z-Wave Settings you set the port to "/dev/ttyACM0" You've rebooted Vera, so that it starts using the UZB stick. OK, so what "Version" will Vera now display and the version of what? The version shown by Vera is the "Z-Wave protocol" version or the "Serial API" version - it's unclear which but I suspect the former. However on most occasions the numbers are the same. It's not the Software Developers Kit (SDK) version number. Knowing the UZB firmware version you can identify what Vera will show with the following table. From the example above: Zway stated the version as 5.23. It will show in Vera as version 4.61 - see table. However the Vera internals showed up as 6.01. So using this method to copy the Zwave configuration to the stick will not work, as the stick represents a downgrade and you can only do same to same or upgrades. So in this case you need to update the stick firmware from 5.23 to 5.32 as a minimum. Then the stick will show up in Vera with version of 6.01. Which is great. So you then use the Zway software to upgrade the stick firmware. And that's the last you hear from it because this happens: "Sorry to inform you, but there is a known issue in some UZB manufactured by our partners on license base that after upgrade they become bricked." And you have to do this to unbrick it. So time to try someone else's stick. Sigh. ZWay UZB version Vera version SDK version 5.39 6.09 6.82.01 6.08 6.82.00 6.07 6.81.06 6.06 6.81.05 6.05 6.81.04 6.04 6.81.03 6.03 6.81.02 5.37 6.02 6.81.01 5.36 6.02??? 6.81.00 ???? 5.33 6.02??? 6.81.00 ???? 5.32 6.01 6.81.00 5.03 6.71.03 5.02 6.71.02 5.27 BL 48059 4.61 6.71.0? 5.26 4.61 6.71.0? 5.23 4.61 6.71.01 4.6 6.71.00 5.2 4.6? 6.7?.00 5.16 4.6? 6.70.00 4.62 6.61.01 4.33 6.61.00 4.54 6.51.10 5.07 4.38 6.51.09 4.34 6.51.08 4.24 6.51.07 4.05 6.51.06 5.06 4.01 6.51.04 3.99 6.51.03 3.95 6.51.02 3.92 6.51.01 3.83 6.51.00 3.79 6.50.01 3.71 6.50.00 3.67 3.35 6.10.00 3.41 6.02.00 3.37 6.01.03 2.78 The table is based on page 434 of silabs app INS13954 and the UZB firmware revision information found here. The table may have errors!
Vera
Vera
floor heating automation
Vera
Nuke Vera Script
Vera
Vera
Vera
Vera
Vera
Power monitoring options
Vera
Vera
Vera to zwavejs
Vera
Vera firmware 7.32 beta
Vera
Vera
Vera
Vera
Vera
33 Posts 6 Posters 14.4k Views 6 Watching
    @pabla nope, this should be performed at every http call. This is weird. I’ve just deleted mine with the plugin and it’s working. Try to delete them by hand for the last time and let’s see if it’s working from now on.
    @therealdb Manually deleted the files and they aren't auto deleting still. This is really weird
      @pabla I’ll take a deeper look. Maybe some libs are different between edge and plus.
        wrote on last edited by Pabla
        #23
        Okay good news, so I uploaded the file via WinSCP since I noticed I had doubles of each file type one of the doubles was a .lzo file type. Now the files are deleting properly too. Question for everyone: Does the .lzo compression make a difference? Every time I get Github files I decompress and then drag them into the Luup Files section under Develop Apps. But I have began to notice that I have a lot of files with the .lzo extension
          #24
          When you drag them to the Upload button in Apps > Develop apps > Luup files, the uploader will LZO compress them, always. If you use WinSCP and copy uncompressed files, they stay uncompressed. When Luup looks for a file, it will select the uncompressed file before the compressed if both are present, and this is how things get goofed up -- if you have old uncompressed files and try to update via the uploader, Luup still sees/uses the uncompressed files and ignores the newer compressed files (it doesn't check timestamps -- that would be nice!). Personally, I always use the uploader, and I don't keep uncompressed plugin files on my Veras, even during development (I never edit on the Vera so it doesn't matter).
          PablaP CatmanV2C 2 Replies Last reply
            #25
            @toggledbits That makes sense why the plugin wasnt working as expected. That explanation solves so many issues that I have had with plugins lol. Since I would alternate between WinSCP and Uploading via the web UI
              @toggledbits blimey that's poor. Don't know why I should be surprised, though!
                @pabla great! Let me know if this version is more stable and I’ll eventually release it via the Vera App Store as well.
                  @toggledbits said in Help with Luup Reloads:
                  But Luup will try, try and retry forever to start and maintain a connection to that IP.
                  Yes, this is, indeed, an issue, although NOT one, I would say, for openLuup. It may well explain why Vera behaves (sort of) when you remove some plugins.
                  For some time, now, I had a Vera Edge running without any plugins or Z-wave devices, and, I have to say, it just runs and runs!
                  @akbooer said in Help with Luup Reloads:
                  Erhhh - so it works great when it's doing absolutely nothing - is that it?
                  Never knew that. I always used the up-loader, so never came across this one. Certainly explains why someone could disappear into the quicksand pretty quickly.
                  akbooerA therealdbT 2 Replies Last reply
                  • A a-lurker
                    @a-lurker said in Help with Luup Reloads:
                    Yup, exactly so.
                      Mmmmm - interesting - I've had a very similar experience with a couple of Veras. One of the Veras; I recently turned off the WiFi and I have never heard from it since; even though it has always successfully conversed via a hardwired LAN interface for years.
                      akbooer I recommend you ditch the Edge - it's costing you money at about 0.24 kW hrs per day. Further still, I recommend you use openLuup. It works well and the developer? - don't stuff around. Please donate as he or she requests.
                      • A a-lurker
                        I have a quick bash script calling curl to update files via the web interface automatically. It's very handy when developing. I suspect @rigpapa built something similar and much more, since he's also unit testing his plug-ins... 🙂
                          Anyway, I've removed the IP from every device, and I'll report back. The unit is OK ATM, but I'll check when back home from the office.
                          PablaP 1 Reply Last reply
                            @therealdb the files seem to be deleting by themselves. The plug-in itself though is still unstable though, I observed some new behaviours. I will post on the thread I started about the counter.
                              146.9k
