  3. Vera
  4. Why is VERA+ making calls to facebook.com?
Oh the joy of pairing
Vera
Vera
Free to a new home
Vera
MiOS is Winning the X10 Wars
Vera
Let's assume you have done the following: Downloaded and installed Z-Way following these instructions. No Zway license is required to do the following. The software is now all up and running with your UZB stick (whole other post). Dial up this Zway web page: http://<Zway_server_IP_address>:8083/expert/#/network/controller Under the heading "Firmware" take note of the "SDK version" and the "Serial API Version". Say they equal 6.71.01 & 05.23 respectively like it shows here. Now on to Vera: Go to the Vera UI --> Z-Wave Settings and taken note of the "Version" shown for Vera's internal Zwave IC. For example purposes, say it equals "6.01". You plug your UZB stick into Vera. In the Z-Wave Settings you set the port to "/dev/ttyACM0" You've rebooted Vera, so that it starts using the UZB stick. OK, so what "Version" will Vera now display and the version of what? The version shown by Vera is the "Z-Wave protocol" version or the "Serial API" version - it's unclear which but I suspect the former. However on most occasions the numbers are the same. It's not the Software Developers Kit (SDK) version number. Knowing the UZB firmware version you can identify what Vera will show with the following table. From the example above: Zway stated the version as 5.23. It will show in Vera as version 4.61 - see table. However the Vera internals showed up as 6.01. So using this method to copy the Zwave configuration to the stick will not work, as the stick represents a downgrade and you can only do same to same or upgrades. So in this case you need to update the stick firmware from 5.23 to 5.32 as a minimum. Then the stick will show up in Vera with version of 6.01. Which is great. So you then use the Zway software to upgrade the stick firmware. And that's the last you hear from it because this happens: "Sorry to inform you, but there is a known issue in some UZB manufactured by our partners on license base that after upgrade they become bricked." And you have to do this to unbrick it. So time to try someone else's stick. Sigh. ZWay UZB version Vera version SDK version 5.39 6.09 6.82.01 6.08 6.82.00 6.07 6.81.06 6.06 6.81.05 6.05 6.81.04 6.04 6.81.03 6.03 6.81.02 5.37 6.02 6.81.01 5.36 6.02??? 6.81.00 ???? 5.33 6.02??? 6.81.00 ???? 5.32 6.01 6.81.00 5.03 6.71.03 5.02 6.71.02 5.27 BL 48059 4.61 6.71.0? 5.26 4.61 6.71.0? 5.23 4.61 6.71.01 4.6 6.71.00 5.2 4.6? 6.7?.00 5.16 4.6? 6.70.00 4.62 6.61.01 4.33 6.61.00 4.54 6.51.10 5.07 4.38 6.51.09 4.34 6.51.08 4.24 6.51.07 4.05 6.51.06 5.06 4.01 6.51.04 3.99 6.51.03 3.95 6.51.02 3.92 6.51.01 3.83 6.51.00 3.79 6.50.01 3.71 6.50.00 3.67 3.35 6.10.00 3.41 6.02.00 3.37 6.01.03 2.78 The table is based on page 434 of silabs app INS13954 and the UZB firmware revision information found here. The table may have errors!
Vera
Vera
floor heating automation
Vera
Nuke Vera Script
Vera
Vera
Vera
Vera
Vera
Power monitoring options
Vera
Vera
Vera to zwavejs
Vera
Vera firmware 7.32 beta
Vera
Vera
Vera
Vera
Vera
7 Posts 3 Posters 2.3k Views 3 Watching
  • ? Offline
    ? Offline
    A Former User
      It's just probing to see if the Internet is accessible. That's one of its default targets for that purpose.
      • ? Offline
        ? Offline
        A Former User
        Thanks for the quick reply.
        I have facebook blocked (not a fan) and I see google.com so that must be the back up.
        I don't see any option to change under the main reactor variables tab but I can live with google getting pinged.
          The default targets are 8.8.8.8, 8.8.4.4, 1.1.1.1, and www.facebook/google/amazon.com
          It's not just Reactor that does this, Vera/Luup itself does it. Unless, of course, you've run my decouple script on the unit. You said you "disconnected from the cloud services". Is that what you meant?
          You can turn off Reactor's Internet probe by setting InternetCheckInterval to 0 in the Reactor master device. Reload Luup after making changes.
          You can also change the servers pinged, if you want to keep the check running but just use different targets. Set InternetCheckSites on the Reactor master device to a comma-separated list of sites to check.
          Ref: Network Status in Reactor docs
          • ? Offline
            ? Offline
            A Former User
            Yes, decoupled and loving it. I'm running Syslog now and have the VERA logs and backups ftp'd locally now so many thanks. I had no idea how busy the VERA device was until you look at the logs. Actually its sad to see it checking to rotate logs every minute and scanning for network devices... but I digress.
            I'll go back to the docs. I do recall you writing about it, thanks again.
              Is there a similar check in MSR?
                I've been working on a mechanism for this, but unfortunately, there are many cross-platform issues (e.g. how WIndows does it vs Linux, whether it's doable in a docker container or not, etc). Every environment is a little different.
                As a workaround for bare-metal Linux, there is a script in tools called msr_inet_check.sh that can be run by cron (as a non-root user). It will ping various sites and create/update x_reactor_system_extra.inet_ok on the Reactor System (reactor>system) entity.
                I have no such solution at the moment for Windows or Docker. In my own house configuration, I just use the flag from the entity for the Vera's Reactor master device.
                  165.4k
