  3. Vera
  4. MiOS is Winning the X10 Wars
Oh the joy of pairing
Vera
Vera
Free to a new home
Vera
Vera
Let's assume you have done the following: Downloaded and installed Z-Way following these instructions. No Zway license is required to do the following. The software is now all up and running with your UZB stick (whole other post). Dial up this Zway web page: http://<Zway_server_IP_address>:8083/expert/#/network/controller Under the heading "Firmware" take note of the "SDK version" and the "Serial API Version". Say they equal 6.71.01 & 05.23 respectively like it shows here. Now on to Vera: Go to the Vera UI --> Z-Wave Settings and taken note of the "Version" shown for Vera's internal Zwave IC. For example purposes, say it equals "6.01". You plug your UZB stick into Vera. In the Z-Wave Settings you set the port to "/dev/ttyACM0" You've rebooted Vera, so that it starts using the UZB stick. OK, so what "Version" will Vera now display and the version of what? The version shown by Vera is the "Z-Wave protocol" version or the "Serial API" version - it's unclear which but I suspect the former. However on most occasions the numbers are the same. It's not the Software Developers Kit (SDK) version number. Knowing the UZB firmware version you can identify what Vera will show with the following table. From the example above: Zway stated the version as 5.23. It will show in Vera as version 4.61 - see table. However the Vera internals showed up as 6.01. So using this method to copy the Zwave configuration to the stick will not work, as the stick represents a downgrade and you can only do same to same or upgrades. So in this case you need to update the stick firmware from 5.23 to 5.32 as a minimum. Then the stick will show up in Vera with version of 6.01. Which is great. So you then use the Zway software to upgrade the stick firmware. And that's the last you hear from it because this happens: "Sorry to inform you, but there is a known issue in some UZB manufactured by our partners on license base that after upgrade they become bricked." And you have to do this to unbrick it. So time to try someone else's stick. Sigh. ZWay UZB version Vera version SDK version 5.39 6.09 6.82.01 6.08 6.82.00 6.07 6.81.06 6.06 6.81.05 6.05 6.81.04 6.04 6.81.03 6.03 6.81.02 5.37 6.02 6.81.01 5.36 6.02??? 6.81.00 ???? 5.33 6.02??? 6.81.00 ???? 5.32 6.01 6.81.00 5.03 6.71.03 5.02 6.71.02 5.27 BL 48059 4.61 6.71.0? 5.26 4.61 6.71.0? 5.23 4.61 6.71.01 4.6 6.71.00 5.2 4.6? 6.7?.00 5.16 4.6? 6.70.00 4.62 6.61.01 4.33 6.61.00 4.54 6.51.10 5.07 4.38 6.51.09 4.34 6.51.08 4.24 6.51.07 4.05 6.51.06 5.06 4.01 6.51.04 3.99 6.51.03 3.95 6.51.02 3.92 6.51.01 3.83 6.51.00 3.79 6.50.01 3.71 6.50.00 3.67 3.35 6.10.00 3.41 6.02.00 3.37 6.01.03 2.78 The table is based on page 434 of silabs app INS13954 and the UZB firmware revision information found here. The table may have errors!
Vera
Vera
floor heating automation
Vera
Nuke Vera Script
Vera
Vera
Vera
Vera
Vera
Power monitoring options
Vera
Vera
Vera to zwavejs
Vera
Vera firmware 7.32 beta
Vera
Vera
Vera
Vera
Vera
5 Posts 4 Posters 2.7k Views 4 Watching
    With their awesome new X10 switch!
    I'm hopping in my 1980s time machine to go see whether this is exactly what I think it is. 🙂
    (Srsly, tho, I love(d) X10 and did everything humanly possible to keep that old equipment perking along with Vera, and almost succeeded.)
    • Libra
    P.S. Just got banned for the 9th time from Hubitat Forum, so had a little extra time to throw shade.
    P.P.S. The boilerplate 5-star reviews for this brand-new product come from bots with names like Avery, Phoenix and Owen (two from Mateo!). Sheesh.
      nice to see you back LibraSun! You're always welcome here :).
      The path some of these smarthome companys are taking *cough Ezlo is very interesting.
        Yes, thanks for that! X10 is what got me started, then came Zwave, then Bluetooth in the form of Philips Hue, then Shelly.
          I love their posts about getting color patterns on addressable LEDs. So glad they are tackling the biggest customer-requested issues in their ecosystem.
            "Hi, I'm Troy McClure, famous from such posts as 'How to Send Data to Google Sheets from Rule Machine', and 'Creating Zero-CSS Animated SVG Backgrounds for Hubitat Dashboard Tiles Using Hidden iFrames', and other esoteric topics nobody wants to read."
            But srsly, I did expect more response when I recently released my very first full-fledged HE Device Driver which pits you against an AI bot in the game of TicTacToe on a gameboard created out of 12 button Tiles. 😉
            TicBot Game
            @toggledbits sure won't miss my MSR antics, but I do! What's the point of beta testing if you cannot first crush the everlivin' life out of something while probing its deepest, darkest recesses.
            Indeed, first thing I inquired about after joining HE Forum a few years back was "Can this thing tie in with X10?" (A: Yes and, more pointedly, no.)
            I would love to visit here more often, but must confess you guys are so awesome you've left me nothing to BREAK!
