  3. Vera
  4. Power monitoring options
Oh the joy of pairing
Vera
Vera
Free to a new home
Vera
MiOS is Winning the X10 Wars
Vera
Let's assume you have done the following: Downloaded and installed Z-Way following these instructions. No Zway license is required to do the following. The software is now all up and running with your UZB stick (whole other post). Dial up this Zway web page: http://<Zway_server_IP_address>:8083/expert/#/network/controller Under the heading "Firmware" take note of the "SDK version" and the "Serial API Version". Say they equal 6.71.01 & 05.23 respectively like it shows here. Now on to Vera: Go to the Vera UI --> Z-Wave Settings and taken note of the "Version" shown for Vera's internal Zwave IC. For example purposes, say it equals "6.01". You plug your UZB stick into Vera. In the Z-Wave Settings you set the port to "/dev/ttyACM0" You've rebooted Vera, so that it starts using the UZB stick. OK, so what "Version" will Vera now display and the version of what? The version shown by Vera is the "Z-Wave protocol" version or the "Serial API" version - it's unclear which but I suspect the former. However on most occasions the numbers are the same. It's not the Software Developers Kit (SDK) version number. Knowing the UZB firmware version you can identify what Vera will show with the following table. From the example above: Zway stated the version as 5.23. It will show in Vera as version 4.61 - see table. However the Vera internals showed up as 6.01. So using this method to copy the Zwave configuration to the stick will not work, as the stick represents a downgrade and you can only do same to same or upgrades. So in this case you need to update the stick firmware from 5.23 to 5.32 as a minimum. Then the stick will show up in Vera with version of 6.01. Which is great. So you then use the Zway software to upgrade the stick firmware. And that's the last you hear from it because this happens: "Sorry to inform you, but there is a known issue in some UZB manufactured by our partners on license base that after upgrade they become bricked." And you have to do this to unbrick it. So time to try someone else's stick. Sigh. ZWay UZB version Vera version SDK version 5.39 6.09 6.82.01 6.08 6.82.00 6.07 6.81.06 6.06 6.81.05 6.05 6.81.04 6.04 6.81.03 6.03 6.81.02 5.37 6.02 6.81.01 5.36 6.02??? 6.81.00 ???? 5.33 6.02??? 6.81.00 ???? 5.32 6.01 6.81.00 5.03 6.71.03 5.02 6.71.02 5.27 BL 48059 4.61 6.71.0? 5.26 4.61 6.71.0? 5.23 4.61 6.71.01 4.6 6.71.00 5.2 4.6? 6.7?.00 5.16 4.6? 6.70.00 4.62 6.61.01 4.33 6.61.00 4.54 6.51.10 5.07 4.38 6.51.09 4.34 6.51.08 4.24 6.51.07 4.05 6.51.06 5.06 4.01 6.51.04 3.99 6.51.03 3.95 6.51.02 3.92 6.51.01 3.83 6.51.00 3.79 6.50.01 3.71 6.50.00 3.67 3.35 6.10.00 3.41 6.02.00 3.37 6.01.03 2.78 The table is based on page 434 of silabs app INS13954 and the UZB firmware revision information found here. The table may have errors!
Vera
Vera
floor heating automation
Vera
Nuke Vera Script
Vera
Vera
Vera
Vera
Vera
Vera
Vera
Vera to zwavejs
Vera
Vera firmware 7.32 beta
Vera
Vera
Vera
Vera
Vera
9 Posts 6 Posters 2.8k Views 4 Watching
    @tamorgen said in Another Vera --> Home Assistant migration question:
    The biggest headache was waiting for Vera to reload itself every time I removed a node
    I've just removed a bunch of devices from an old VeraLite, running UI5. On that system, at least, it allowed you to select the option to remove multiple devices before rebooting. But too late now!!
    At this point, I've pretty much migrated off of Vera. It's kind of bittersweet.
    Yes, absolutely. Feeling the same thing here, been running with them (or, rather, falling over) for around a decade. My current configuration is as described here.
    The only thing left on Vera is now electricity meter readers, and I simply can't find any suitable WiFi replacement. Have applied for a smart meter installation and hoping that I can get ethernet access to the Consumer Device Interface.
    @akbooer said in
      … that would be nice, but I need a “whole house” solution and can’t see that I can get this connected in to the main power feed.
      I’m also keen to have a result which mirrors the actual utility meter reading.
      But I’ll think this through again with the Shelly in mind. .
        I've been looking at this:
        Apr 15, 2019
        Expandable 6 Channel ESP32 Energy Meter Main Board
        Introducing the CircuitSetup Expandable 6 Channel Energy Meter – the ultimate tool for monitoring and analyzing energy consumption in your home or workspace. This cutting-edge meter provides …
        Trying to get them to answer if my 200A CTs will work with it, so far no reply. But it looks interesting.
          RogerO
          Here is another interesting option. He says it supports MQTT though haven't installed it yet. https://lanternpowermonitor.com/
            @akbooer they’re clamp based, so you could attach them to anything. As I’ve said, I’m into 9 months with Shelly em monitoring my solar and two for the main line. I’ve added them to my Vera to keep some automations regarding the electricity that I had before, but I’m using MSR for the logic. It truly was a plug & play change.
            I’ve stopped to pollute my Zwave network with frequent updates and my mesh is more reliable. Give it a try: https://shelly.cloud/products/shelly-em-smart-home-automation-device/
              @therealdb
              You know I’m a Shelly fan! I am really after a total KWH reading, which you could approximate by integrating Watts, but it will always diverge from the actual meter reading. If I can’t find anything else (or get a smart meter) then I’ll give it a go.
              CrilleC therealdbT 2 Replies Last reply
                @therealdb
                I'm using an older version of this https://www.zuidwijk.com/product/slimmelezer-plus/ flashed with this firmware https://github.com/Beaky2000/esphome-p1mini connected to the HAN/P1 consumer port of the meter. The meter outputs data every 10s and the values are published over MQTT.
                  @therealdb
                  @akbooer in my case it’s really near the exact value, so I’m happy. I’m using influxdb to query and aggregate data. It’s more accurate than my aeotec hem. We don’t have data ports on the meter, so that’s the only way for me in Italy to measure kWh and watts.
                    ArcherS
                    Like @Crille I have an electrical meter with a P1 data port. I use a DIY ESP8266 reader that I described some time ago in this thread. Since writing my post I have changed the software on the ESP, the version I am using now publishes the meter data approx every 10s as a json.
                    A good wifi solution for the whole house if lacking a dataport is to use a Shelly 3EM. It is a three clamp meter that can measure all three incoming phases, assuming you have that. I have a few of these for measuring both single and multiple phase consumers, e.g. a two-phase water heater. It reports both energy, power, voltage and current per phase.
                    The only downside I can see is that the clamps are a bit big, so some space is required to get them in place around the incoming power lines.
                      157.4k
