  3. Vera
  4. Vera firmware 7.32 beta
Oh the joy of pairing
Vera
Vera
Free to a new home
Vera
MiOS is Winning the X10 Wars
Vera
Let's assume you have done the following: Downloaded and installed Z-Way following these instructions. No Zway license is required to do the following. The software is now all up and running with your UZB stick (whole other post). Dial up this Zway web page: http://<Zway_server_IP_address>:8083/expert/#/network/controller Under the heading "Firmware" take note of the "SDK version" and the "Serial API Version". Say they equal 6.71.01 & 05.23 respectively like it shows here. Now on to Vera: Go to the Vera UI --> Z-Wave Settings and taken note of the "Version" shown for Vera's internal Zwave IC. For example purposes, say it equals "6.01". You plug your UZB stick into Vera. In the Z-Wave Settings you set the port to "/dev/ttyACM0" You've rebooted Vera, so that it starts using the UZB stick. OK, so what "Version" will Vera now display and the version of what? The version shown by Vera is the "Z-Wave protocol" version or the "Serial API" version - it's unclear which but I suspect the former. However on most occasions the numbers are the same. It's not the Software Developers Kit (SDK) version number. Knowing the UZB firmware version you can identify what Vera will show with the following table. From the example above: Zway stated the version as 5.23. It will show in Vera as version 4.61 - see table. However the Vera internals showed up as 6.01. So using this method to copy the Zwave configuration to the stick will not work, as the stick represents a downgrade and you can only do same to same or upgrades. So in this case you need to update the stick firmware from 5.23 to 5.32 as a minimum. Then the stick will show up in Vera with version of 6.01. Which is great. So you then use the Zway software to upgrade the stick firmware. And that's the last you hear from it because this happens: "Sorry to inform you, but there is a known issue in some UZB manufactured by our partners on license base that after upgrade they become bricked." And you have to do this to unbrick it. So time to try someone else's stick. Sigh. ZWay UZB version Vera version SDK version 5.39 6.09 6.82.01 6.08 6.82.00 6.07 6.81.06 6.06 6.81.05 6.05 6.81.04 6.04 6.81.03 6.03 6.81.02 5.37 6.02 6.81.01 5.36 6.02??? 6.81.00 ???? 5.33 6.02??? 6.81.00 ???? 5.32 6.01 6.81.00 5.03 6.71.03 5.02 6.71.02 5.27 BL 48059 4.61 6.71.0? 5.26 4.61 6.71.0? 5.23 4.61 6.71.01 4.6 6.71.00 5.2 4.6? 6.7?.00 5.16 4.6? 6.70.00 4.62 6.61.01 4.33 6.61.00 4.54 6.51.10 5.07 4.38 6.51.09 4.34 6.51.08 4.24 6.51.07 4.05 6.51.06 5.06 4.01 6.51.04 3.99 6.51.03 3.95 6.51.02 3.92 6.51.01 3.83 6.51.00 3.79 6.50.01 3.71 6.50.00 3.67 3.35 6.10.00 3.41 6.02.00 3.37 6.01.03 2.78 The table is based on page 434 of silabs app INS13954 and the UZB firmware revision information found here. The table may have errors!
Vera
Vera
floor heating automation
Vera
Nuke Vera Script
Vera
Vera
Vera
Vera
Vera
Power monitoring options
Vera
Vera
Vera to zwavejs
Vera
Vera
Vera
Vera
Vera
Vera
86 Posts 14 Posters 57.4k Views 14 Watching
      I’m running it since the first alpha. Never been so happy.
      To be honest, I asked for a couple of things to be fixed and they did. Specifically, I had problems with mongoose crashing and now I’m at 5-6 days of luup uptime. I still have a load of virtual devices and most of the lua logic running on my Vera (now plus, edge before). They also changed the disk partition and I must say it’s really night and day.
      I’m running decoupled and all is good, so I could just improve my setup with others systems.
        Have always respected your viewpoints so will likely follow suit soon. Thanks!
        • MatohlM Offline
          MatohlM Offline
          Matohl
          I guess this is the last update for the Vera so when it is out of Beta I will update my production units and decouple them.
            @therealdb, so you first did recouple, then upgrade and decouple again? I'm also running decouple by @toggledbits and liking it a lot.
              @tunnus I've update various builds while decoupled, it'll work. after the update, you'll need to decouple again. it's probably better to just recouple, update and then decouple again, because after each update the apps will need to get restored from the app store. I'm working on completely remove them (and copy the files by hand, when needed) to further improve my setup and completely avoid anything from their cloud just in case they'll eventually turn it off/remove something. My system has never been so stable, partially thanks to no unneeded services running in the background, and the updated they did to all the components. It's really a huge release and it's a shame they took almost 6 months to release it, but I'm starting to think it's all calculated. But I digress.
              tl;dr; go for it, it's better than 7.31 even if in beta 🙂
                mrFarmer
                I have been running this 7.32 version for some time, but only with plugins to assure they still work. Normally it runs for weeks on end without a reload. The upgrade went just fine as well. As always YMMV.
                Cheers Rene
                  Is it only when you edit a scene the sunrise/sunset bug appears or are all scenes containing that trigger affected regardless of editing?
                  • CrilleC Crille
                    @crille only on edit, or fw upgrade. I’ll probably just remove them and move to my own engine for that too.
                    CrilleC 1 Reply Last reply
                      I have been waiting for 7.32 to try out @therealdb 's alexa plugin to finally use Alexa in multiple rooms for synced TTS. WIll install fingers crossed it goes well!
                      CatmanV2C therealdbT 2 Replies Last reply
                        I am heartened to see the pivot MCV had made, back on the old Foum, with regard to corporate responsiveness. Never expected to see staff answering questions, trouble tickets being written up quickly, much less talk of a new firmware for <gasp> Vera!
                        Then again, I'll believe it once it leaves beta... something I've never seen an ezlo product yet achieve.
                          @pabla said in Vera firmware 7.32 beta:
                          Works A1 on Openluup 😉
                            @pabla I’ve just tested it again and it’s still working on beta, so we’re quite there.
                              Going to be a long day.. more keep coming lol
                                @therealdb Ok, thank you. I’ll wait till that one is squished then.
                                  Too bad Pabla and Crille (and I plus a dozen others) can't participate on the MCV forum where feedback like that would be invaluable. Are you both still on their Jira bug tracker, though?
                                  PablaP CrilleC 2 Replies Last reply
                                    Classic...
                                    For one minute I was thinking of testing it for kicks. well...
                                    I have no idea why it is trying to reconfigure every device. There is no situation where this should ever be automated unless the database is wiped and even then it should be trying to get configurations from the devices, not configuring them. The logic is just broken. Vera at its best.
                                    PablaP 1 Reply Last reply
                                    • LibraSunL LibraSun
                                      @librasun Never joined the bug tracker, unfortunate for them. I can figure it out here though thankfully
                                        Same old?
                                          Classic...
                                          @rafale77 its all the same Zooz devices having this issue, weirdly this is the variable thats not configuring. Every time I try to delete it or set it to 0 after a reload it comes back. I have never even set this device config before either
                                            160.0k
