  3. Vera
  4. Vera firmware 7.32 beta
Oh the joy of pairing
Vera
Vera
Free to a new home
Vera
MiOS is Winning the X10 Wars
Vera
Let's assume you have done the following: Downloaded and installed Z-Way following these instructions. No Zway license is required to do the following. The software is now all up and running with your UZB stick (whole other post). Dial up this Zway web page: http://<Zway_server_IP_address>:8083/expert/#/network/controller Under the heading "Firmware" take note of the "SDK version" and the "Serial API Version". Say they equal 6.71.01 & 05.23 respectively like it shows here. Now on to Vera: Go to the Vera UI --> Z-Wave Settings and taken note of the "Version" shown for Vera's internal Zwave IC. For example purposes, say it equals "6.01". You plug your UZB stick into Vera. In the Z-Wave Settings you set the port to "/dev/ttyACM0" You've rebooted Vera, so that it starts using the UZB stick. OK, so what "Version" will Vera now display and the version of what? The version shown by Vera is the "Z-Wave protocol" version or the "Serial API" version - it's unclear which but I suspect the former. However on most occasions the numbers are the same. It's not the Software Developers Kit (SDK) version number. Knowing the UZB firmware version you can identify what Vera will show with the following table. From the example above: Zway stated the version as 5.23. It will show in Vera as version 4.61 - see table. However the Vera internals showed up as 6.01. So using this method to copy the Zwave configuration to the stick will not work, as the stick represents a downgrade and you can only do same to same or upgrades. So in this case you need to update the stick firmware from 5.23 to 5.32 as a minimum. Then the stick will show up in Vera with version of 6.01. Which is great. So you then use the Zway software to upgrade the stick firmware. And that's the last you hear from it because this happens: "Sorry to inform you, but there is a known issue in some UZB manufactured by our partners on license base that after upgrade they become bricked." And you have to do this to unbrick it. So time to try someone else's stick. Sigh. ZWay UZB version Vera version SDK version 5.39 6.09 6.82.01 6.08 6.82.00 6.07 6.81.06 6.06 6.81.05 6.05 6.81.04 6.04 6.81.03 6.03 6.81.02 5.37 6.02 6.81.01 5.36 6.02??? 6.81.00 ???? 5.33 6.02??? 6.81.00 ???? 5.32 6.01 6.81.00 5.03 6.71.03 5.02 6.71.02 5.27 BL 48059 4.61 6.71.0? 5.26 4.61 6.71.0? 5.23 4.61 6.71.01 4.6 6.71.00 5.2 4.6? 6.7?.00 5.16 4.6? 6.70.00 4.62 6.61.01 4.33 6.61.00 4.54 6.51.10 5.07 4.38 6.51.09 4.34 6.51.08 4.24 6.51.07 4.05 6.51.06 5.06 4.01 6.51.04 3.99 6.51.03 3.95 6.51.02 3.92 6.51.01 3.83 6.51.00 3.79 6.50.01 3.71 6.50.00 3.67 3.35 6.10.00 3.41 6.02.00 3.37 6.01.03 2.78 The table is based on page 434 of silabs app INS13954 and the UZB firmware revision information found here. The table may have errors!
Vera
Vera
floor heating automation
Vera
Nuke Vera Script
Vera
Vera
Vera
Vera
Vera
Power monitoring options
Vera
Vera
Vera to zwavejs
Vera
Vera
Vera
Vera
Vera
Vera
86 Posts 14 Posters 55.4k Views 14 Watching
    When you add the device to Hubs, @wmarcolin, you'll add it into Maker API app. Bounce MSR using Restart Reactor under Tools in MSR. When it reconnects it will see the new devices from Hubs as long as you have that integration configured in reactor.yaml.
      @wmarcolin , @gwp1 describes the correct procedure. The key is that Hubitat's Maker API doesn't automatically publish new devices, so when you add devices, you have to remember to go into Maker API and tell it to publish them, so that Reactor can then see them. As I get more familiar with Hubitat's developer environment, I may look into doing a custom API for Reactor to avoid that, but at the moment, I regard it as a minor annoyance one quickly adapts to.
      wmarcolinW 1 Reply Last reply
        @toggledbits and @gwp1 THANKS!!!!
        • LibraSunL LibraSun
          Not to go too off-topic here, but are you guys telling me that I could (in theory) buy a Hubitat and pair all of my Philips Hue bulbs directly with that controller instead of having to keep the Hue bridge in my lineup? I'm always looking for garbage to get rid of!
          @librasun https://docs.hubitat.com/index.php?title=Hue_Bridge_Integration
            #85
            Did the upgrade to beta 4 and so far so good, everything seems to work ok. Decoupling also in use. Btw, after fw upgrade, is it necessary to disable nightly heal again, although I had it disabled?
            luup.attr_set("EnableNightlyHeal",0,0)
            Eventually, and especially if Vera fails, I'm also going to migrate to Hubitat (Elevation).
              I do it in startup Lua, so I don't forget. It also makes it easy to go in and change it when I want it back on (my feeble memory doesn't have to remember the precise spelling of the setting).
                152.5k
