  2. Hardware
  3. Vera
  4. Help with Luup Reloads
Oh the joy of pairing
Vera
Vera
Free to a new home
Vera
MiOS is Winning the X10 Wars
Vera
Let's assume you have done the following: Downloaded and installed Z-Way following these instructions. No Zway license is required to do the following. The software is now all up and running with your UZB stick (whole other post). Dial up this Zway web page: http://<Zway_server_IP_address>:8083/expert/#/network/controller Under the heading "Firmware" take note of the "SDK version" and the "Serial API Version". Say they equal 6.71.01 & 05.23 respectively like it shows here. Now on to Vera: Go to the Vera UI --> Z-Wave Settings and taken note of the "Version" shown for Vera's internal Zwave IC. For example purposes, say it equals "6.01". You plug your UZB stick into Vera. In the Z-Wave Settings you set the port to "/dev/ttyACM0" You've rebooted Vera, so that it starts using the UZB stick. OK, so what "Version" will Vera now display and the version of what? The version shown by Vera is the "Z-Wave protocol" version or the "Serial API" version - it's unclear which but I suspect the former. However on most occasions the numbers are the same. It's not the Software Developers Kit (SDK) version number. Knowing the UZB firmware version you can identify what Vera will show with the following table. From the example above: Zway stated the version as 5.23. It will show in Vera as version 4.61 - see table. However the Vera internals showed up as 6.01. So using this method to copy the Zwave configuration to the stick will not work, as the stick represents a downgrade and you can only do same to same or upgrades. So in this case you need to update the stick firmware from 5.23 to 5.32 as a minimum. Then the stick will show up in Vera with version of 6.01. Which is great. So you then use the Zway software to upgrade the stick firmware. And that's the last you hear from it because this happens: "Sorry to inform you, but there is a known issue in some UZB manufactured by our partners on license base that after upgrade they become bricked." And you have to do this to unbrick it. So time to try someone else's stick. Sigh. ZWay UZB version Vera version SDK version 5.39 6.09 6.82.01 6.08 6.82.00 6.07 6.81.06 6.06 6.81.05 6.05 6.81.04 6.04 6.81.03 6.03 6.81.02 5.37 6.02 6.81.01 5.36 6.02??? 6.81.00 ???? 5.33 6.02??? 6.81.00 ???? 5.32 6.01 6.81.00 5.03 6.71.03 5.02 6.71.02 5.27 BL 48059 4.61 6.71.0? 5.26 4.61 6.71.0? 5.23 4.61 6.71.01 4.6 6.71.00 5.2 4.6? 6.7?.00 5.16 4.6? 6.70.00 4.62 6.61.01 4.33 6.61.00 4.54 6.51.10 5.07 4.38 6.51.09 4.34 6.51.08 4.24 6.51.07 4.05 6.51.06 5.06 4.01 6.51.04 3.99 6.51.03 3.95 6.51.02 3.92 6.51.01 3.83 6.51.00 3.79 6.50.01 3.71 6.50.00 3.67 3.35 6.10.00 3.41 6.02.00 3.37 6.01.03 2.78 The table is based on page 434 of silabs app INS13954 and the UZB firmware revision information found here. The table may have errors!
Vera
Vera
floor heating automation
Vera
Nuke Vera Script
Vera
Vera
Vera
Vera
Vera
Power monitoring options
Vera
Vera
Vera to zwavejs
Vera
Vera firmware 7.32 beta
Vera
Vera
H
Vera
Vera
Vera
33 Posts 6 Posters 14.8k Views 6 Watching
    @toggledbits said in Help with Luup Reloads:
    But Luup will try, try and retry forever to start and maintain a connection to that IP.
    Yes, this is, indeed, an issue, although NOT one, I would say, for openLuup. It may well explain why Vera behaves (sort of) when you remove some plugins.
    For some time, now, I had a Vera Edge running without any plugins or Z-wave devices, and, I have to say, it just runs and runs!
    @akbooer said in Help with Luup Reloads:
    Sorry, did I miss that this was openLuup? Or are you just confirming that openLuup is better than real Luup (which everyone already knows)? 🙂
      @toggledbits yep, I will change it in next build. I'm onto it as we speak. On my system I have few plug-ins, no one is using an IP and I'm still experiencing memory leaks. But I will probably just move everything to openLuup and use the Vera as a radio system.
      @therealdb said in Help with Luup Reloads:
      One more thing... some versions of Luup have trouble returning the status from os.execute(). They said they have fixed it in the newer beta builds (5363/4/5), but it's concerning that it could be broken at all (should be straightforward, not unstable), and Edward's response to me when queried was a bit uncertain. So I've started moving away from using the return value under Luup and started doing error detection other ways (e.g. does the file I expect now exist?).
        Oooh, hope not... NO, just checked...
        @pabla said in Help with Luup Reloads:
        Recently I have been getting constant reloads on my Vera Plus
        Er, yes, just that, really. Let's say that this is one feature I chose not to emulate.
          wrote on last edited by Pabla
          So I updated to 1.51 and dont see the files in the /tmp folder being deleted after 3 minsf53f49fd-ff36-4045-8011-702b8c6efd3f-image.png
            @pabla I found a small problem, and I'll fix it in a moment. Please wait for a new release.
            PablaP 1 Reply Last reply
              @therealdb No rush, just reporting back 🙂
                @pabla 1.51-hotfix is on GitHub.
                • programs duplication is now fixed, so a reconfiguration is OK
                • IP is now a variable (and it's automatically migrated - don't worry)
                • temp files are correctly deleted
                • I've tracked the problem with infinite stations - and I'm working on a permanent fix. this seems to be related to reloads and I'll investigate this further in the next days.
                Give it a try!
                  One thing to add here, a possibility: I notice that the plugin is using the 'ip' attribute to store the IP address of the controller. I have found that this causes a lot of instability. Luup has certain automatic things that it does in the background to try to open connections when the IP is stored on that attribute. It's all part of their built-in automatic I/O for serial and IP connections, which this plugin doesn't use. But Luup will try, try and retry forever to start and maintain a connection to that IP. I believe that this is at least one source of a memory leak -- I suspect their error handling on connection failure is not completely cleaning up after itself, so the system leaks memory, and/or possible even sockets. I discovered this some years ago and switched all of my plugins to just use state variables for the IP. My systems do not restart due to memory leaks, and memory usage is generally flat.
                  @toggledbits I found that AltHue by @amg0 is still using IP attr. I'll probably send him a pull request, since it's very popular.
                    Give it a try!
                    @therealdb So I updated to the latest hot fix, and the files still aren't getting deleted. I have a fill from 11:06am local time and its 11:27am. Do they auto delete after a longer time?
                      @pabla nope, this should be performed at every http call. This is weird. I’ve just deleted mine with the plugin and it’s working. Try to delete them by hand for the last time and let’s see if it’s working from now on.
                        @therealdb Manually deleted the files and they aren't auto deleting still. This is really weird
                          @pabla I’ll take a deeper look. Maybe some libs are different between edge and plus.
                            #23
                            Okay good news, so I uploaded the file via WinSCP since I noticed I had doubles of each file type one of the doubles was a .lzo file type. Now the files are deleting properly too. Question for everyone: Does the .lzo compression make a difference? Every time I get Github files I decompress and then drag them into the Luup Files section under Develop Apps. But I have began to notice that I have a lot of files with the .lzo extension
                              #24
                              When you drag them to the Upload button in Apps > Develop apps > Luup files, the uploader will LZO compress them, always. If you use WinSCP and copy uncompressed files, they stay uncompressed. When Luup looks for a file, it will select the uncompressed file before the compressed if both are present, and this is how things get goofed up -- if you have old uncompressed files and try to update via the uploader, Luup still sees/uses the uncompressed files and ignores the newer compressed files (it doesn't check timestamps -- that would be nice!). Personally, I always use the uploader, and I don't keep uncompressed plugin files on my Veras, even during development (I never edit on the Vera so it doesn't matter).
                              PablaP CatmanV2C 2 Replies Last reply
                                #25
                                @toggledbits That makes sense why the plugin wasnt working as expected. That explanation solves so many issues that I have had with plugins lol. Since I would alternate between WinSCP and Uploading via the web UI
                                  @toggledbits blimey that's poor. Don't know why I should be surprised, though!
                                    @pabla great! Let me know if this version is more stable and I’ll eventually release it via the Vera App Store as well.
                                      Erhhh - so it works great when it's doing absolutely nothing - is that it?
                                      Never knew that. I always used the up-loader, so never came across this one. Certainly explains why someone could disappear into the quicksand pretty quickly.
                                      akbooerA therealdbT 2 Replies Last reply
                                      • A a-lurker
                                        @a-lurker said in Help with Luup Reloads:
                                        Yup, exactly so.
                                          Mmmmm - interesting - I've had a very similar experience with a couple of Veras. One of the Veras; I recently turned off the WiFi and I have never heard from it since; even though it has always successfully conversed via a hardwired LAN interface for years.
                                          akbooer I recommend you ditch the Edge - it's costing you money at about 0.24 kW hrs per day. Further still, I recommend you use openLuup. It works well and the developer? - don't stuff around. Please donate as he or she requests.
                                            154.4k
