  3. Home Automation Serial Server (Raspberry Pi)
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
7 Posts 5 Posters 2.3k Views 5 Watching
  • parkercP Offline
    parkercP Offline
    parkerc
    My quest to build a central usb to serial server (hub) continues 🙂
    The goal is to make a core set of usually local devices available to other HA controllers over the network to use (via Ser2net).
    Current list includes ..
    • Current Cost Energy Monitor
    • Rfxtrx433 Transceiver
    • Bluegiga BLED112 Bluetooth
    Next up is a Z-Wave Module ZMEEUZB1
    What other devices do people think would be a good to add to the ‘hub’ ?
    • Black CatB Offline
      Black CatB Offline
      Black Cat
      Without doubt Homeseer 4.
      Download a free trial version for 30 days, I never looked back.
      aka Zedrally
      • parkercP Offline
        parkercP Offline
        parkerc
        Hi @Black Cat,
        Sorry for any confusion, I’m actually looking for ideas for serial/usb devices that people want to share with their HA controllers from a single central point over the network..
          mrFarmer
          In the Netherlands we have smart energy meters that you can connect to USB via a serial to USB cable. The Vera/openLuup SmartMeter plugin (https://github.com/reneboer/Vera-Dutch-Smartmeter) reads that data and I use it for some scenarios. Expecting more use as the compensation for solar power delivered back to the grid will change in 2 years and smart ways will be needed to use as much of your own solar power.
          Cheers Rene
            @parkerc, I think you could do this using a rPi and ser2net indeed but you would have to setup and write down the specific port broadcasted by ser2net and then pick them back up from the HA controllers. I am using a vera to broadcast the UZB and zigbee signal for example to two different VMs on a remote machine (Home Assistant and z-way-server). It is very manual... but it works well.
            • parkercP Offline
              parkercP Offline
              parkerc
              Hi @rafale77, totally agree, and I’ve had various Pis running Ser2net for years in order to provide device connectivity to Vera from remote locations, such as an alarm panel way up in the loft etc.
              The Ser2net server (which is perhaps another name for it) already has a number of entries in the /etc/Ser2net.conf file ..
              4002:raw:0:/dev/ttyUSB0:57600 8DATABITS NONE 1STOPBIT max-connections=4
              4003:raw:0:/dev/ttyUSB1:38400 8DATABITS NONE 1STOPBIT max-connections=4
              4004:raw:0:/dev/ttyACM0:38400 8DATABITS NONE 1STOPBIT max-connections=4
                sender
                I would like to see a zigbee stick (deconz) announced. Is this usb server works I would like to use it as a hub and connect to the usb devices over ip from home assistant.
                  165.2k
