  4. Vera reload detected where there does not appear to be one.
3 Posts 2 Posters 901 Views 2 Watching
    I may have posted this in the wrong section. MSR running on Bare metal Debian bullseye. Both Openluup and MSR are on the same device (an Intel NUC) at IP 192.168.70.249. Any suggestions as to where I go to resolve?
    TIA
    Happy new year, everyone! Hope all are well!
    Looking for some pointers troubleshooting a slightly puzzling to me issue. When digging around on a different issue I noticed this happening regularly in the MSR logs:
    [latest-24366]2025-01-10T19:50:07.630Z <Engine:NOTICE> Starting reaction Garden lights on when the doors are open<SET> (rule-lb2h69nb:S)
    [latest-24366]2025-01-10T19:50:07.630Z <VeraController:INFO> VeraController#vera perform action power_switch.on on Switch#vera>device_20060 with [Object]{  }
    [latest-24366]2025-01-10T19:50:07.630Z <VeraController:INFO> VeraController#vera perform action power_switch.set on Switch#vera>device_20060 with [Object]{ "state": true }
    [latest-24366]2025-01-10T19:50:07.670Z <VeraController:NOTICE> VeraController#vera action power_switch.set([Object]{ "state": true }) on Switch#vera>device_20060 succeeded
    [latest-24366]2025-01-10T19:50:07.671Z <Engine:INFO> Resuming reaction Garden lights on when the doors are open<SET> (rule-lb2h69nb:S) from step 1
    [latest-24366]2025-01-10T19:50:07.672Z <Engine:NOTICE> Garden lights on when the doors are open<SET> delaying until 1736538787672<10/01/2025, 19:53:07>
    [latest-24366]2025-01-10T19:50:19.595Z <Rule:INFO> Garden lights on when the doors are open (rule-lb2h69nb in Outside Lights) evaluated; rule state transition from SET to RESET!
    [latest-24366]2025-01-10T19:52:16.506Z <Rule:INFO> Garden lights on when the doors are open (rule-lb2h69nb in Outside Lights) evaluated; rule state transition from RESET to SET!
    [latest-24366]2025-01-10T19:52:16.515Z <Engine:INFO> [Engine]Engine#1 not enqueueing rule-lb2h69nb:S: already in queue with status 2
    [latest-24366]2025-01-10T19:52:20.823Z <Rule:INFO> Garden lights on when the doors are open (rule-lb2h69nb in Outside Lights) evaluated; rule state transition from SET to RESET!
    [latest-24366]2025-01-10T19:53:07.676Z <Engine:INFO> Resuming reaction Garden lights on when the doors are open<SET> (rule-lb2h69nb:S) from step 2
    [latest-24366]2025-01-10T19:53:07.677Z <VeraController:INFO> VeraController#vera perform action power_switch.off on Switch#vera>device_20060 with [Object]{  }
    [latest-24366]2025-01-10T19:53:07.678Z <VeraController:INFO> VeraController#vera perform action power_switch.set on Switch#vera>device_20060 with [Object]{ "state": false }
    [latest-24366]2025-01-10T19:53:07.719Z <VeraController:NOTICE> VeraController#vera action power_switch.set([Object]{ "state": false }) on Switch#vera>device_20060 succeeded
    [latest-24366]2025-01-10T19:53:07.720Z <Engine:INFO> Resuming reaction Garden lights on when the doors are open<SET> (rule-lb2h69nb:S) from step 3
    [latest-24366]2025-01-10T19:53:07.721Z <Engine:INFO> Garden lights on when the doors are open<SET> all actions completed.
    [latest-24366]2025-01-10T19:55:04.468Z <VeraController:ERR> VeraController#vera update request failed: [FetchError] network timeout at: http://192.168.70.249:3480/data_request?id=status&Timeout=15&DataVersion=416912953&MinimumDelay=50&output_format=json&_r=1736538886459 [-]
    [latest-24366]2025-01-10T19:55:09.646Z <VeraController:WARN> VeraController#vera failed to apply attribute scene_activation.scene_id to Entity#vera>device_20050: [TypeError] Can't set NaN on attribute scene_activation.scene_id (vera>device_20050) [-]
    [latest-24366]2025-01-10T19:55:09.646Z <VeraController:INFO> VeraController#vera class scene_controller meta [Object]{ "source": "urn:micasaverde-com:serviceId:SceneController1/sl_SceneActivated", "expr": "int(value)" } orig  final NaN
    [latest-24366]2025-01-10T19:55:09.646Z <VeraController:CRIT> *Entity#vera>device_20050
    [latest-24366]2025-01-10T19:55:09.656Z <VeraController:WARN> VeraController#vera failed to apply attribute scene_activation.scene_id to Entity#vera>device_20570: [TypeError] Can't set NaN on attribute scene_activation.scene_id (vera>device_20570) [-]
    [latest-24366]2025-01-10T19:55:09.656Z <VeraController:INFO> VeraController#vera class scene_controller meta [Object]{ "source": "urn:micasaverde-com:serviceId:SceneController1/sl_SceneActivated", "expr": "int(value)" } orig  final NaN
    [latest-24366]2025-01-10T19:55:09.656Z <VeraController:CRIT> *Entity#vera>device_20570
    [latest-24366]2025-01-10T19:55:09.678Z <VeraController:WARN> VeraController#vera failed to apply attribute scene_activation.scene_id to Entity#vera>device_20610: [TypeError] Can't set NaN on attribute scene_activation.scene_id (vera>device_20610) [-]
    [latest-24366]2025-01-10T19:55:09.679Z <VeraController:INFO> VeraController#vera class scene_controller meta [Object]{ "source": "urn:micasaverde-com:serviceId:SceneController1/sl_SceneActivated", "expr": "int(value)" } orig  final NaN
    [latest-24366]2025-01-10T19:55:09.679Z <VeraController:CRIT> *Entity#vera>device_20610
    [latest-24366]2025-01-10T19:55:09.744Z <VeraController:WARN> VeraController#vera failed to apply attribute scene_activation.scene_id to Entity#vera>device_20631: [TypeError] Can't set NaN on attribute scene_activation.scene_id (vera>device_20631) [-]
    [latest-24366]2025-01-10T19:55:09.744Z <VeraController:INFO> VeraController#vera class scene_controller meta [Object]{ "source": "urn:micasaverde-com:serviceId:SceneController1/sl_SceneActivated", "expr": "int(value)" } orig  final NaN
    [latest-24366]2025-01-10T19:55:09.744Z <VeraController:CRIT> *Entity#vera>device_20631
    [latest-24366]2025-01-10T19:55:09.889Z <VeraController:NOTICE> VeraController#vera reload detected!
    [latest-24366]2025-01-10T19:55:09.910Z <VeraController:WARN> VeraController#vera failed to apply attribute scene_activation.scene_id to Entity#vera>device_20050: [TypeError] Can't set NaN on attribute scene_activation.scene_id (vera>device_20050) [-]
    [latest-24366]2025-01-10T19:55:09.910Z <VeraController:INFO> VeraController#vera class scene_controller meta [Object]{ "source": "urn:micasaverde-com:serviceId:SceneController1/sl_SceneActivated", "expr": "int(value)" } orig  final NaN
    [latest-24366]2025-01-10T19:55:09.910Z <VeraController:CRIT> *Entity#vera>device_20050
    [latest-24366]2025-01-10T19:55:09.935Z <VeraController:WARN> VeraController#vera failed to apply attribute scene_activation.scene_id to Entity#vera>device_20570: [TypeError] Can't set NaN on attribute scene_activation.scene_id (vera>device_20570) [-]
    [latest-24366]2025-01-10T19:55:09.936Z <VeraController:INFO> VeraController#vera class scene_controller meta [Object]{ "source": "urn:micasaverde-com:serviceId:SceneController1/sl_SceneActivated", "expr": "int(value)" } orig  final NaN
    [latest-24366]2025-01-10T19:55:09.936Z <VeraController:CRIT> *Entity#vera>device_20570
    [latest-24366]2025-01-10T19:55:09.937Z <VeraController:WARN> VeraController#vera failed to apply attribute scene_activation.scene_id to Entity#vera>device_20610: [TypeError] Can't set NaN on attribute scene_activation.scene_id (vera>device_20610) [-]
    [latest-24366]2025-01-10T19:55:09.937Z <VeraController:INFO> VeraController#vera class scene_controller meta [Object]{ "source": "urn:micasaverde-com:serviceId:SceneController1/sl_SceneActivated", "expr": "int(value)" } orig  final NaN
    [latest-24366]2025-01-10T19:55:09.937Z <VeraController:CRIT> *Entity#vera>device_20610
    [latest-24366]2025-01-10T19:55:09.939Z <VeraController:WARN> VeraController#vera failed to apply attribute scene_activation.scene_id to Entity#vera>device_20631: [TypeError] Can't set NaN on attribute scene_activation.scene_id (vera>device_20631) [-]
    [latest-24366]2025-01-10T19:55:09.939Z <VeraController:INFO> VeraController#vera class scene_controller meta [Object]{ "source": "urn:micasaverde-com:serviceId:SceneController1/sl_SceneActivated", "expr": "int(value)" } orig  final NaN
    [latest-24366]2025-01-10T19:55:09.939Z <VeraController:CRIT> *Entity#vera>device_20631
    [latest-24366]2025-01-10T19:55:09.968Z <Controller:INFO> VeraController#vera 0 dead entities older than 86400000s purged
    [latest-24366]2025-01-10T19:55:10.037Z <VeraController:NOTICE> VeraController#vera reload detected!
    That repeats until something like this:
    [latest-24366]2025-01-10T19:55:10.049Z <VeraController:WARN> VeraController#vera failed to apply attribute scene_activation.scene_id to Entity#vera>device_20050: [TypeError] Can't set NaN on attribute scene_activation.scene_id (vera>device_20050) [-]
    [latest-24366]2025-01-10T19:55:10.049Z <VeraController:INFO> VeraController#vera class scene_controller meta [Object]{ "source": "urn:micasaverde-com:serviceId:SceneController1/sl_SceneActivated", "expr": "int(value)" } orig  final NaN
    [latest-24366]2025-01-10T19:55:10.049Z <VeraController:CRIT> *Entity#vera>device_20050
    [latest-24366]2025-01-10T19:55:10.053Z <VeraController:WARN> VeraController#vera failed to apply attribute scene_activation.scene_id to Entity#vera>device_20570: [TypeError] Can't set NaN on attribute scene_activation.scene_id (vera>device_20570) [-]
    [latest-24366]2025-01-10T19:55:10.053Z <VeraController:INFO> VeraController#vera class scene_controller meta [Object]{ "source": "urn:micasaverde-com:serviceId:SceneController1/sl_SceneActivated", "expr": "int(value)" } orig  final NaN
    [latest-24366]2025-01-10T19:55:10.053Z <VeraController:CRIT> *Entity#vera>device_20570
    [latest-24366]2025-01-10T19:55:10.062Z <VeraController:WARN> VeraController#vera failed to apply attribute scene_activation.scene_id to Entity#vera>device_20610: [TypeError] Can't set NaN on attribute scene_activation.scene_id (vera>device_20610) [-]
    [latest-24366]2025-01-10T19:55:10.062Z <VeraController:INFO> VeraController#vera class scene_controller meta [Object]{ "source": "urn:micasaverde-com:serviceId:SceneController1/sl_SceneActivated", "expr": "int(value)" } orig  final NaN
    [latest-24366]2025-01-10T19:55:10.062Z <VeraController:CRIT> *Entity#vera>device_20610
    [latest-24366]2025-01-10T19:55:10.112Z <VeraController:WARN> VeraController#vera failed to apply attribute scene_activation.scene_id to Entity#vera>device_20631: [TypeError] Can't set NaN on attribute scene_activation.scene_id (vera>device_20631) [-]
    [latest-24366]2025-01-10T19:55:10.112Z <VeraController:INFO> VeraController#vera class scene_controller meta [Object]{ "source": "urn:micasaverde-com:serviceId:SceneController1/sl_SceneActivated", "expr": "int(value)" } orig  final NaN
    [latest-24366]2025-01-10T19:55:10.113Z <VeraController:CRIT> *Entity#vera>device_20631
    [latest-24366]2025-01-10T20:00:05.003Z <Engine:INFO> [Engine]Engine#1 master timer tick, local time "10/01/2025 20:00:05" (TZ offset 0 mins from UTC)
    [latest-24366]2025-01-10T20:13:51.872Z <Rule:INFO> No motion in Cinema (rule-m4ocglke in Cinema Environment) evaluated; rule state transition from SET to RESET!
    [latest-24366]2025-01-10T20:13:51.882Z <Rule:INFO> Cinema Heater On (rule-m4ocf1di in Cinema Environment) evaluated; rule state transition from RESET to SET!
    [latest-24366]2025-01-10T20:13:51.888Z <Engine:INFO> Enqueueing "Cinema Heater On<SET>" (rule-m4ocf1di:S)
    And the errors / reloads just stop.
    From Openluup:
    2025-01-10 19:49:56.379   luup_log:63: BroadLink_Mk2 debug: RM3 Mini - IR 1: urn:schemas-micasaverde-com:device:IrTransmitter:1
    2025-01-10 19:50:00.085   luup_log:0: 14Mb, 1.7%cpu, 36.1days
    2025-01-10 19:50:07.591   luup.variable_set:: 20160.urn:micasaverde-com:serviceId:EnergyMetering1.KWH was: 18.6793008 now: 18.6805008 #hooks:0
    2025-01-10 19:50:07.591   luup.variable_set:: 20160.urn:micasaverde-com:serviceId:EnergyMetering1.KWHReading was: 1736538000 now: 1736538600 #hooks:0
    2025-01-10 19:50:07.591   luup.variable_set:: 20160.urn:micasaverde-com:serviceId:EnergyMetering1.Watts was: 7.4 now: 7.3 #hooks:0
    2025-01-10 19:50:07.591   luup.variable_set:: 20170.urn:micasaverde-com:serviceId:EnergyMetering1.KWH was: 32.2417984 now: 32.2470016 #hooks:0
    2025-01-10 19:50:07.591   luup.variable_set:: 20170.urn:micasaverde-com:serviceId:EnergyMetering1.KWHReading was: 1736538000 now: 1736538600 #hooks:0
    2025-01-10 19:50:07.591   luup.variable_set:: 20330.urn:micasaverde-com:serviceId:EnergyMetering1.KWHReading was: 1736538000 now: 1736538600 #hooks:0
    2025-01-10 19:50:07.592   luup.variable_set:: 20770.urn:micasaverde-com:serviceId:SecuritySensor1.Tripped was: 0 now: 1 #hooks:0
    2025-01-10 19:50:07.592   luup.variable_set:: 20770.urn:micasaverde-com:serviceId:SecuritySensor1.LastTrip was: 1736534850 now: 1736538607 #hooks:0
    2025-01-10 19:50:07.593   openLuup.server:: request completed (3392 bytes, 1 chunks, 12875 ms) tcp{client}: 0x55c3299a9cf8
    2025-01-10 19:50:07.618   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55c3299a9cf8
    2025-01-10 19:50:07.624   openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x55c329d0a5b8
    2025-01-10 19:50:07.624   openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=416912906&MinimumDelay=50&output_format=json&_r=1736538607623 HTTP/1.1 tcp{client}: 0x55c329d0a5b8
    2025-01-10 19:50:07.632   openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x55c3292ed678
    2025-01-10 19:50:07.633   openLuup.server:: GET /data_request?newTargetValue=1&DeviceNum=20060&id=action&serviceId=urn%3Aupnp-org%3AserviceId%3ASwitchPower1&action=SetTarget&output_format=json&_r=1736538607631 HTTP/1.1 tcp{client}: 0x55c3
    292ed678
    2025-01-10 19:50:07.633   luup.call_action:: 20060.urn:upnp-org:serviceId:SwitchPower1.SetTarget
    2025-01-10 19:50:07.633   luup.call_action:: action will be handled by parent: 37
    2025-01-10 19:50:07.633   luup.variable_set:: 20060.urn:upnp-org:serviceId:SwitchPower1.Target was: 0 now: 1 #hooks:0
    2025-01-10 19:50:07.669   openLuup.server:: request completed (35 bytes, 1 chunks, 35 ms) tcp{client}: 0x55c3292ed678
    2025-01-10 19:50:07.673   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55c3292ed678
    2025-01-10 19:50:07.776   openLuup.server:: request completed (821 bytes, 1 chunks, 151 ms) tcp{client}: 0x55c329d0a5b8
    2025-01-10 19:50:07.784   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55c329d0a5b8
    2025-01-10 19:50:07.795   openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x55c3287bc8f8
    2025-01-10 19:50:07.796   openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=416912907&MinimumDelay=50&output_format=json&_r=1736538607794 HTTP/1.1 tcp{client}: 0x55c3287bc8f8
    2025-01-10 19:50:08.644   luup.variable_set:: 20060.urn:upnp-org:serviceId:SwitchPower1.Status was: 0 now: 1 #hooks:0
    2025-01-10 19:50:08.950   openLuup.server:: request completed (821 bytes, 1 chunks, 1154 ms) tcp{client}: 0x55c3287bc8f8
    2025-01-10 19:50:08.958   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55c3287bc8f8
    2025-01-10 19:50:08.969   openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x55c3297e95a8
    2025-01-10 19:50:08.970   openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=416912908&MinimumDelay=50&output_format=json&_r=1736538608969 HTTP/1.1 tcp{client}: 0x55c3297e95a8
    2025-01-10 19:50:19.181   luup.variable_set:: 20770.urn:micasaverde-com:serviceId:SecuritySensor1.Tripped was: 1 now: 0 #hooks:0
    2025-01-10 19:50:19.585   openLuup.server:: request completed (832 bytes, 1 chunks, 10615 ms) tcp{client}: 0x55c3297e95a8
    2025-01-10 19:50:19.602   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55c3297e95a8
    2025-01-10 19:50:19.605   openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x55c328d298a8
    2025-01-10 19:50:19.605   openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=416912909&MinimumDelay=50&output_format=json&_r=1736538619604 HTTP/1.1 tcp{client}: 0x55c328d298a8
    2025-01-10 19:50:34.950   openLuup.server:: request completed (593 bytes, 1 chunks, 15344 ms) tcp{client}: 0x55c328d298a8
    2025-01-10 19:50:34.953   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55c328d298a8
    2025-01-10 19:50:34.965   openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x55c328c48a58
    2025-01-10 19:50:34.966   openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=416912909&MinimumDelay=50&output_format=json&_r=1736538634964 HTTP/1.1 tcp{client}: 0x55c328c48a58
    2025-01-10 19:50:34.989   luup.variable_set:: 25019.urn:micasaverde-com:serviceId:SecuritySensor1.Tripped was: 0 now: 1 #hooks:0
    2025-01-10 19:50:34.990   luup.variable_set:: 25019.urn:micasaverde-com:serviceId:SecuritySensor1.LastTrip was: 1736534437 now: 1736538634 #hooks:0
    2025-01-10 19:50:35.094   openLuup.server:: request completed (975 bytes, 1 chunks, 127 ms) tcp{client}: 0x55c328c48a58
    2025-01-10 19:50:35.101   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55c328c48a58
    2025-01-10 19:50:35.113   openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x55c32985e298
    2025-01-10 19:50:35.113   openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=416912911&MinimumDelay=50&output_format=json&_r=1736538635111 HTTP/1.1 tcp{client}: 0x55c32985e298
    2025-01-10 19:50:40.255   luup.variable_set:: 25021.urn:micasaverde-com:serviceId:LightSensor1.CurrentLevel was: 0 now: 30 #hooks:1
    2025-01-10 19:50:40.256   scheduler.watch_callback:: 25021.urn:micasaverde-com:serviceId:LightSensor1.CurrentLevel called [20]DataWatcherCallback() function: 0x55c3288a8d20
    2025-01-10 19:50:40.460   openLuup.server:: request completed (835 bytes, 1 chunks, 5346 ms) tcp{client}: 0x55c32985e298
    2025-01-10 19:50:40.472   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55c32985e298
    2025-01-10 19:50:40.478   openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x55c329b28238
    2025-01-10 19:50:40.479   openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=416912912&MinimumDelay=50&output_format=json&_r=1736538640478 HTTP/1.1 tcp{client}: 0x55c329b28238
    2025-01-10 19:50:44.471   luup.variable_set:: 25007.urn:micasaverde-com:serviceId:SecuritySensor1.Tripped was: 0 now: 1 #hooks:1
    2025-01-10 19:50:44.472   luup.variable_set:: 25007.urn:micasaverde-com:serviceId:SecuritySensor1.LastTrip was: 1736538400 now: 1736538644 #hooks:0
    2025-01-10 19:50:44.472   scheduler.watch_callback:: 25007.urn:micasaverde-com:serviceId:SecuritySensor1.Tripped called [20]DataWatcherCallback() function: 0x55c3288a8d20
    2025-01-10 19:50:44.775   openLuup.server:: request completed (975 bytes, 1 chunks, 4296 ms) tcp{client}: 0x55c329b28238
    2025-01-10 19:50:44.782   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55c329b28238
    2025-01-10 19:50:44.793   openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x55c328f1e968
    2025-01-10 19:50:44.793   openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=416912914&MinimumDelay=50&output_format=json&_r=1736538644791 HTTP/1.1 tcp{client}: 0x55c328f1e968
    2025-01-10 19:51:00.122   openLuup.server:: request completed (593 bytes, 1 chunks, 15328 ms) tcp{client}: 0x55c328f1e968
    2025-01-10 19:51:00.125   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55c328f1e968
    2025-01-10 19:51:00.136   openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x55c32995b318
    2025-01-10 19:51:00.136   openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=416912914&MinimumDelay=50&output_format=json&_r=1736538660134 HTTP/1.1 tcp{client}: 0x55c32995b318
    2025-01-10 19:51:15.481   openLuup.server:: request completed (593 bytes, 1 chunks, 15344 ms) tcp{client}: 0x55c32995b318
    2025-01-10 19:51:15.484   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55c32995b318
    2025-01-10 19:51:15.495   openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x55c32998b068
    2025-01-10 19:51:15.497   openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=416912914&MinimumDelay=50&output_format=json&_r=1736538675493 HTTP/1.1 tcp{client}: 0x55c32998b068
    2025-01-10 19:51:30.869   openLuup.server:: request completed (593 bytes, 1 chunks, 15371 ms) tcp{client}: 0x55c32998b068
    2025-01-10 19:51:30.872   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55c32998b068
    2025-01-10 19:51:30.884   openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x55c32905bda8
    2025-01-10 19:51:30.885   openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=416912914&MinimumDelay=50&output_format=json&_r=1736538690882 HTTP/1.1 tcp{client}: 0x55c32905bda8
    2025-01-10 19:51:32.886   luup.variable_set:: 20380.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 21 now: 22 #hooks:0
    2025-01-10 19:51:33.090   openLuup.server:: request completed (841 bytes, 1 chunks, 2205 ms) tcp{client}: 0x55c32905bda8
    2025-01-10 19:51:33.100   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55c32905bda8
    2025-01-10 19:51:33.112   openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x55c328de0d58
    2025-01-10 19:51:33.112   openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=416912915&MinimumDelay=50&output_format=json&_r=1736538693111 HTTP/1.1 tcp{client}: 0x55c328de0d58
    2025-01-10 19:51:36.064   luup.variable_set:: 25007.urn:micasaverde-com:serviceId:SecuritySensor1.Tripped was: 1 now: 0 #hooks:1
    2025-01-10 19:51:36.065   scheduler.watch_callback:: 25007.urn:micasaverde-com:serviceId:SecuritySensor1.Tripped called [20]DataWatcherCallback() function: 0x55c3288a8d20
    2025-01-10 19:51:36.369   openLuup.server:: request completed (832 bytes, 1 chunks, 3256 ms) tcp{client}: 0x55c328de0d58
    2025-01-10 19:51:36.377   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55c328de0d58
    2025-01-10 19:51:36.387   openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x55c329054188
    2025-01-10 19:51:36.388   openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=416912916&MinimumDelay=50&output_format=json&_r=1736538696386 HTTP/1.1 tcp{client}: 0x55c329054188
    2025-01-10 19:51:37.134   luup.variable_set:: 20380.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 22 now: 21 #hooks:0
    2025-01-10 19:51:37.540   openLuup.server:: request completed (841 bytes, 1 chunks, 1152 ms) tcp{client}: 0x55c329054188
    2025-01-10 19:51:37.553   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55c329054188
    2025-01-10 19:51:37.566   openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x55c328d97568
    2025-01-10 19:51:37.566   openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=416912917&MinimumDelay=50&output_format=json&_r=1736538697564 HTTP/1.1 tcp{client}: 0x55c328d97568
    2025-01-10 19:51:41.367   luup.variable_set:: 20380.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 21 now: 22 #hooks:0
    2025-01-10 19:51:41.874   openLuup.server:: request completed (841 bytes, 1 chunks, 4307 ms) tcp{client}: 0x55c328d97568
    2025-01-10 19:51:41.884   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55c328d97568
    2025-01-10 19:51:41.895   openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x55c329385678
    2025-01-10 19:51:41.896   openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=416912918&MinimumDelay=50&output_format=json&_r=1736538701894 HTTP/1.1 tcp{client}: 0x55c329385678
    2025-01-10 19:51:57.168   openLuup.server:: request completed (593 bytes, 1 chunks, 15272 ms) tcp{client}: 0x55c329385678
    2025-01-10 19:51:57.171   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55c329385678
    2025-01-10 19:51:57.183   openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x55c329b092b8
    2025-01-10 19:51:57.184   openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=416912918&MinimumDelay=50&output_format=json&_r=1736538717182 HTTP/1.1 tcp{client}: 0x55c329b092b8
    2025-01-10 19:52:00.124   luup_log:0: 14Mb, 1.6%cpu, 36.1days
    2025-01-10 19:52:00.476   openLuup.server:: request completed (1841 bytes, 1 chunks, 3292 ms) tcp{client}: 0x55c329b092b8
    2025-01-10 19:52:00.483   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55c329b092b8
    2025-01-10 19:52:00.495   openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x55c3297be088
    2025-01-10 19:52:00.495   openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=416912929&MinimumDelay=50&output_format=json&_r=1736538720494 HTTP/1.1 tcp{client}: 0x55c3297be088
    2025-01-10 19:52:09.867   luup.variable_set:: 25021.urn:micasaverde-com:serviceId:LightSensor1.CurrentLevel was: 30 now: 0 #hooks:1
    2025-01-10 19:52:09.868   scheduler.watch_callback:: 25021.urn:micasaverde-com:serviceId:LightSensor1.CurrentLevel called [20]DataWatcherCallback() function: 0x55c3288a8d20
    2025-01-10 19:52:10.071   openLuup.server:: request completed (834 bytes, 1 chunks, 9575 ms) tcp{client}: 0x55c3297be088
    2025-01-10 19:52:10.079   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55c3297be088
    2025-01-10 19:52:10.088   openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x55c329c16a08
    2025-01-10 19:52:10.089   openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=416912930&MinimumDelay=50&output_format=json&_r=1736538730087 HTTP/1.1 tcp{client}: 0x55c329c16a08
    2025-01-10 19:52:16.194   luup.variable_set:: 20770.urn:micasaverde-com:serviceId:SecuritySensor1.Tripped was: 0 now: 1 #hooks:0
    2025-01-10 19:52:16.195   luup.variable_set:: 20770.urn:micasaverde-com:serviceId:SecuritySensor1.LastTrip was: 1736538607 now: 1736538736 #hooks:0
    2025-01-10 19:52:16.498   openLuup.server:: request completed (976 bytes, 1 chunks, 6409 ms) tcp{client}: 0x55c329c16a08
    2025-01-10 19:52:16.515   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55c329c16a08
    2025-01-10 19:52:16.516   openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x55c328dbad18
    Nothing I can see indicating that Openluup is reloading?
    .249 IP address is the internal IP of the NUC that hosts both Openluup and MSR.
    Any thoughts as to how I can troubleshoot this? It's not a big deal, but would like to get to the bottom of it.
    I should add that all the devices listed in entries like this:
    Are the tamper switches on Fibaro FGMS001 multifunction detectors, of which I have 4, and they correspond exactly to the devices listed.
    TIA
      OpenLuup is not Vera. There are differences in the way it operates, and I don't make any representation that I will address those differences in Reactor, and in my view it's better that openLuup addresses them if needed.
      The "reload detected" message is emitted when the "loadtime" value in a user_data or status API response is different from the prior value. On Vera, this indicates that Luup has reloaded (the value is the timestamp of the reload); it remains stable otherwise. If you are seeing this message on openLuup when it hasn't reloaded, that is different from Vera Luup's native behavior.
      That said, the message is informational only. The only action taken is it updates a counter that drives the x_vera_sys.reloads attribute on the system entity for the VeraController instance. Unless you are using this attribute for some purpose, it has no effect on anything and can be safely ignored.
        That's fabulously clear. Thanks, as ever
          1.1k
          158.3k
