  3. Can't mount CIFS with Vera
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
    So, I'm trying to execute the same code I had for years to mount my synology NAS for datamine (I know, old stuff), but I'm getting this:
    mount -o user=vera,pass=pass //192.168.1.26/Backups/Vera/datamine /datamine
    mount: mounting //192.168.1.26/Backups/Vera/datamine on /datamine failed: No such device
    It used to work until 3 days ago, then I had to factory reset my Vera Plus and now this. Packages are OK:
    opkg update
    opkg --force-depends install kmod-fs-cifs
    opkg --force-depends install kmod-nls-utf8 kmod-nls-base kmod-crypto-hmac kmod-crypto-md5 kmod-crypto-misc
    I've already trying anything, with no luck. Any ideas?
      It’s along time since I used CIFS on Vera. In fact, I think it was under UI5!
      I seem to remember that there were some additional command line options which I found I needed.
        Believe me if I say that I did a lot of times, and this is the first time it's not working. So strange.
          wow, Vera-iness at its best: I removed, added and removed and added it again, and it worked. So weird.
            Happy days.
              376
              151.4k
