  3. Discover IR codes for lost remote
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
49 Posts 5 Posters 38.1k Views 5 Watching
  • parkercP Offline
    parkercP Offline
    parkerc
    Hi all
    Possibly a long shot - but does anyone know of a way, (maybe you have some code or know of an app) that can help you discover the IR codes of a device when you’ve lost the remote?
    Looking online there seems to be a growing number of IR banks, yet I can’t find anything on the market that could cycle through a huge set of different codes (e.g just the power on/off) to let me know which ones are compatible ?
    When you consider so many things these days are made in the same place, and often thing can just be re/badges versions of other items - it’s likely that a sets of codes for one branded product will work in the most part with another ..
      Lost remote? It's probably down the back of the couch.
      While not exactly what you want but have looked at Remote Central or possibly buy a new one on ebay?
      parkercP 1 Reply Last reply
      • A a-lurker
        parkercP Offline
        parkercP Offline
        parkerc
        @a-lurker said in Discover IR codes for lost remote:
        Sadly not, I picked these items up 2nd hand, so they didn’t come with the original remotes.
        Yep, tried that already, along with http://irdb.tk/codes/ too - but neither of the manufacturers/ models I’m looking for are listed..
        Hence I was thinking there must be a high chance something in those code banks will work, at the very least to power on/off..
        Any ideas ?
          I'm not aware of anything like you requested. There are things that could learn codes, but they require a handheld. Have you tried calling the manufacturer? Maybe they will give you instructions about this issue.
            parkercP Offline
            parkercP Offline
            parkerc
            @therealdb said in Discover IR codes for lost remote:
            Yep, tried that I think I’ve tried everything, even have a saved search on eBay. Also as one of them had a RS232 connection, I explored that too, (via the Vera forum) but had to give up in the end as it wouldn’t work .
            So far one manufacturer has stated that the unit in question was discontinued and the other has yet to respond after multiple attempts. 😞 Rather that wait any long, seeing as I have a number of IR sender options, KIra, Harmony and BroadLink it made made me wonder if there was a way to retrieve codes, create a list and cycle through them.
            I mainly use @a-lurker Broadlink, and looking at the IR ‘ProntoCode’ command option, it feels possible (with help?)
            luup.call_action('urn:a-lurker-com:serviceId:IrTransmitter1', 'SendProntoCode', {ProntoCode = '0000 006C 0022 0002 015B 00AD 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 05F7 015B 0057 0016 0E6C'},49)
            it’s just the code bank connection to reduce the manual effort, and some way of recording/reporting which code was sent and if it worked or not. (Ideally all automated)
            • parkercP Offline
              parkercP Offline
              parkerc
              There is a great community/code bank on GitHub.
              GitHub - probonopd/irdb: One of the largest crowd-sourced, manufacturer-independent databases of infrared remote control codes on the web, and aspiring to become the most comprehensive and most...
              One of the largest crowd-sourced, manufacturer-independent databases of infrared remote control codes on the web, and aspiring to become the most comprehensive and most accurate one - probonopd/irdb
              Index of codes is here - https://github.com/probonopd/irdb/blob/master/index
              With their API - http://irdb.tk/api
              And you can retrieve a .csv set for anyone via https://cdn.jsdelivr.net/gh/probonopd/irdb@master/codes/Samsung/TV/7,7.csv
              • parkercP Offline
                parkercP Offline
                parkerc
                I’ve just got an update from the guy behind the irdb - https://github.com/probonopd/irdb/issues/37
                He mentioned..
                Assuming you have the irdb tree locally on $IRDB_BASE, this pseudo code should do it
                for file in $IRDB_BASE/codes/*/*.csv:
                    for line in $file:
                        (cmd_name,protocol,D,S,F) = split $line ','
                         if match('power', $cmd_name):
                               echo "Trying signal $protocol $D $S $F"
                               pronto = $(irptransmogrifier render -n D=$D,S=$D,F=$F $protocol)
                               sendIr $pronto
                               sleep $a_while
                       endif
                   endfor
                endfor
                Please could someone help me to translate this into Lua and then to work with the Broadlink plug-in ?
                • parkercP Offline
                  parkercP Offline
                  parkerc
                  I’d also appreciate any help/advice on how to maybe adjust @rigpapa’s GitHub Lua/plug-in to potentially pull into the irdb database (or would that simply be too much for Vera to take?)
                  GitHub - toggledbits/GitUpdater: A service utility to update Vera plugins from GitHub releases
                  A service utility to update Vera plugins from GitHub releases - toggledbits/GitUpdater
                  • parkercP Offline
                    parkercP Offline
                    parkerc
                    @a-lurker - is there scope here for a possible add-on/enhancement to the Broadlink plug-in 🙏😇😁
                      well, it's possible in LUA as well. I'm not that expert in the file system libs, but Google is your friend 🙂
                      How to get list of directories in Lua
                      I need a list of directory in LUA Suppose I have a directory path as "C:\Program Files" I need a list of all the folders in that particular path and how to search any particular folder i...
                      Just use io to open files, but I think that so many commands will probably crash your luup engine. We're potentially speaking of thousands of calls to try.
                      • parkercP parkerc
                        He mentioned..
                            for line in $file:
                                       sendIr $pronto
                                       sleep $a_while
                               endif
                           endfor
                        endfor
                        @parkerc said in Discover IR codes for lost remote:
                            for line in $file:
                                       sendIr $pronto
                                       sleep $a_while
                               endif
                           endfor
                        endfor
                        becomes, in Lua:
                        local lfs = require "lfs"
                        local dir = "codes/"   -- make this your path to the files
                        local split = "[^,]+,[^,]+,[^,]+,[^,]+,[^,]+"  -- (cmd_name,protocol,D,S,F)
                        for file in lfs.dir(dir) do
                            if file: match "%.csv$" then
                              for line in io.lines(dir .. filename)do
                                local cmd_name,protocol,D,S,F = list: match (split)
                                if 'power' == cmd_name then
                                  print ("$protocol $D $S $F",  protocol,D,S,F)
                        I've just replaced the IR send with a print statement for now.
                        • parkercP Offline
                          parkercP Offline
                          parkerc
                          Thanks @akbooer
                          Some quick questions .
                          1. Where would be the best place to store/sync the .csv files ?
                          2. FYI to help test, here is an example/extract of the Samsung TV .csv
                          [functionname,protocol,device,subdevice,function
                          INPUT SOURCE,NECx2,7,7,1
                          POWER,NECx2,7,7,2
                          1,NECx2,7,7,4
                          2,NECx2,7,7,5
                          3,NECx2,7,7,6
                          VOLUME +,NECx2,7,7,7
                          4,NECx2,7,7,8
                          5,NECx2,7,7,9
                          6,NECx2,7,7,10
                          VOLUME -,NECx2,7,7,11
                          7,NECx2,7,7,12
                          8,NECx2,7,7,13
                          9,NECx2,7,7,14
                          MUTE,NECx2,7,7,15
                          CHANNEL -,NECx2,7,7,16
                          0,NECx2,7,7,17
                          CHANNEL +,NECx2,7,7,18
                          By the looks of it to get the pronto version of the code, you would have to used the IrpTransmogrifier tool - https://github.com/bengtmartensson/IrpTransmogrifier
                          Where would be the best place to install that - is Vera a safe place or should I look elsewhere e.g a Pi ?
                            What were you thinking of using to send the codes?
                            I note that luup has an ir table with a single function in it. Also, thanks to @a-lurker it's implemented in openLuup. IT mentions GC100 in the comments:
                            -- IR module
                            -- thanks to @a-lurker for this.
                            -- see: http://forum.micasaverde.com/index.php/topic,37268.0.html
                            local ir = {
                              pronto_to_gc100 = function (pronto)
                                -- replace the pronto code preamble with the GC100 preamble
                            ...but I have absolutely no idea about its functionality, not ever having used an IR devices at this level. I would have thought that these codes ARE the pronto codes?? (...or are they IRP notation protocols?)
                              -- IR module
                              local ir = {
                              parkercP Offline
                              parkercP Offline
                              parkerc
                              @akbooer said in Discover IR codes for lost remote:
                              I was ideally looking to use my Broadlink RM-Pro device and @a-lurker ‘s Vera plugin
                              I’m getting a bit out of my depth here now too,..
                              which is so often the case when I embark on these kind of HA adventures 🙂 .
                              My interpretation is that when using irdb, you have to convert the code for them them to be Pronto codes. - http://irdb.tk/convert/
                              If I use my Samsung TV as an example, that seems to use the necx2:7.7 protocol - which I’ve also seen written as NECx2, device 7.7. Either way that seems to be a very common TV code set for Samsung, Akai and some other brands.
                              So, looking at their api, I assumed I could at least try to call a specific code.
                              http://irdb.tk/api/code/?brand=Samsung&devicetype=TV
                              And then..
                              http://irdb.tk/api/code/?brand=Samsung&devicetype=TV&protocol=NECx2&device=7&subdevice=7&functionname=POWER
                              but alas no ir code was returned only this json, which perhaps is not surprise... 😞
                                "meta": {
                                  "model": "code",
                                  "next": "",
                                  "page": 1,
                                  "previous": ""
                                "objects": [
                                    "function": "2",
                                    "protocol": "NECx2",
                                    "subdevice": "7",
                                    "devicetype": "TV",
                                    "device": "7",
                                    "functionname": "POWER"
                              Any ideas on their api - http://irdb.tk/api ?
                                parkec
                                You haven't told us what hardware or software (MiOS/openLuup) you are using. If you read AK's code above you would just have to point to where the files are. Presumably the file(s) could be on a USB stick. You want to get AK's coe running first, on just one file first - one step at a time.
                                Later you need this bit:
                                bengtmartensson commented 16 hours ago •
                                Just install IrpTransmogrifier as shell command and call it (as shell program) using (I think) os.execute or io.popen in Lua. No need to call java from lua
                                The database looks like it could be huge and would take a while (who knows - a day?) to cycle around all the IR codes. Are you going to sit there and watch your device all day to catch when it turns on? AK's code needs to get the pronto code and then send it. Something like this (but totally untested):
                                -- Send an IR code every two seconds
                                -- Function needs to be global as it's a delay timeout target
                                function sendProntoCodeToBroadLinkDevice(prontoCode)
                                   local BROADLINK_DEVICE_ID = 49
                                   luup.call_action('urn:a-lurker-com:serviceId:IrTransmitter1', 'SendProntoCode', {ProntoCode = prontoCode}, BROADLINK_DEVICE_ID)
                                function scanIndexFiles ()
                                    local prontoCode = ''
                                          for line in io.lines(dir .. filename) do
                                              local irptransmogrifierPath = "insert path here"
                                              -- this may all need work depending on whatever "irptransmogrifier" does
                                              local command = string.format("%sirptransmogrifier render -n D=%s,S=%s,F=%s protocol",irptransmogrifierPath,D,S,F,protocol)
                                              local handle = assert(io.popen(command))
                                              local prontoCode = handle:read("*a")
                                              handle:close()
                                              local INTERVAL_SECS = 2
                                              luup.call_delay('sendProntoCodeToBroadLinkDevice', INTERVAL_SECS, prontoCode)
                                scanIndexFiles()
                                Note: luup.call_delay only works in the openLuup window test window - I'm still not clear why. But the Vera and AltUI test windows won't run it correctly. You need the delay so the BroadLink device has time to send the code. (the function sleep() is not suitable)
                                • A a-lurker
                                  parkec
                                                handle:close()
                                  scanIndexFiles()
                                  parkercP Offline
                                  parkercP Offline
                                  parkerc
                                  Sorry,, I’m looking first to Vera/MIOS , with the Broadlink RM Pro4, and your plug-in.
                                  To avoid sitting around as the devices in question register for an IP, which I can fix, I was thinking I can watch for that variable to be updated .e.g via ping test or another option could be to place a light sensor right in front of the power LED to react when the light comes on..
                                  Agreed, and here’s an example .csv of the Samsung TV code/set they store. /codes/
                                  POWER,NECx2,7,7,2
                                  1,NECx2,7,7,4
                                  2,NECx2,7,7,5
                                  3,NECx2,7,7,6
                                  4,NECx2,7,7,8
                                  5,NECx2,7,7,9
                                  6,NECx2,7,7,10
                                  7,NECx2,7,7,12
                                  8,NECx2,7,7,13
                                  9,NECx2,7,7,14
                                  MUTE,NECx2,7,7,15
                                  0,NECx2,7,7,17
                                  LAST,NECx2,7,7,19
                                  MENU,NECx2,7,7,26
                                  INFO,NECx2,7,7,31
                                  AD/SUBT,NECx2,7,7,37
                                  EXIT,NECx2,7,7,45
                                  E-MANUAL,NECx2,7,7,63
                                  TOOLS,NECx2,7,7,75
                                  GUIDE,NECx2,7,7,79
                                  RETURN,NECx2,7,7,88
                                  CUSOR UP,NECx2,7,7,96
                                  CURSOR DOWN,NECx2,7,7,97
                                  CURSOR RIGHT,NECx2,7,7,98
                                  CURSOR LEFT,NECx2,7,7,101
                                  ENTER,NECx2,7,7,104
                                  CH LIST,NECx2,7,7,107
                                  SMART HUB,NECx2,7,7,121
                                  3D,NECx2,7,7,159
                                  And overall size wise, I assume - as they are not storing every individual code and Ir format/type, instead it’s just the protocol and some other identifier - the whole irdb/code folder seems reasonably small.
                                    Are you sure you can’t open those devices and look at the electronics? It seems to be simpler than this, to me 😉
                                    Maybe, also, some repair shop could help you. They usually deal with these kind of things and maybe they have something smarter to identify them. May be worth a try.
                                      parkercP Offline
                                      parkercP Offline
                                      parkerc
                                      These items are racked up so it;s not quite as easy as I’d like that option to be - but I am weighing up the hassle of doing that vs doing this 🙂
                                      The benefit of making this code/process work is that a) i will have learnt something new - b) This could then be something g that helps others and c) it would give the Broadlink plug-in access to a huge ir bank of codes for people to use. 🙏🤞
                                      • parkercP Offline
                                        parkercP Offline
                                        parkerc
                                        I’ve been working with the code that was shared (thanks so much), and have trimming it down a bit to work it through in sections, but - here’s my current issue - any ideas ?
                                        (I) if I put the .csv file in the main search folder it does not return any errors, but it also does not print anything out.
                                        /mnt/nas/vera/ircodes/7,7.csv
                                        LuaTest 1.7
                                        Lua file: /etc/cmh-ludl/luatest.lua
                                        Results
                                        No errors
                                        Runtime: 51.4 ms
                                        Code returned: nil
                                        Print output
                                        (none)
                                        Code
                                           2       local lfs = require "lfs"
                                           3       local dir = "mnt/nas/vera/ircodes/"   -- make this your path to the files
                                           4       local split = "[^,]+,[^,]+,[^,]+,[^,]+,[^,]+"  -- (cmd_name,protocol,D,S,F)
                                           6       local prontoCode = ''
                                           8       for file in lfs.dir(dir) do
                                           9           if file: match "%.csv$" then
                                          10             for line in io.lines(dir .. filename) do
                                          11               local cmd_name,protocol,D,S,F = list: match (split)
                                          12               if 'power' == cmd_name then
                                          13                 print ("$protocol $D $S $F",  protocol,D,S,F)
                                          14               end
                                          15             end
                                          16          end
                                          17      end
                                        • When I run it again, I get this, should filename be local or specified ?
                                        LuaTest 1.7
                                        Results
                                        Runtime error: Line 9: attempt to concatenate global 'filename' (a nil value)
                                        Locals
                                        [main]
                                        lfs={ _VERSION="LuaFileSystem 1.6.2", symlinkattributes=function, lock_dir=function, dir=function, _DESCRIPTION="LuaFileSystem is a Lua library developed to complement the set of functions related to file systems offered by the standard Lua distribution", setmode=function, unlock=function, _COPYRIGHT="Copyright (C) 2003-2012 Kepler Project", currentdir=function, touch=function, mkdir=function, lock=function, link=function, attributes=function, chdir=function, rmdir=function }
                                        dir="mnt/nas/vera/ircodes/"
                                        split="[^,]+,[^,]+,[^,]+,[^,]+,[^,]+"
                                        prontoCode=""
                                        Print output
                                        (none)
                                        Code
                                           1       local lfs = require "lfs"
                                           2       local dir = "mnt/nas/vera/ircodes/"   -- make this your path to the files
                                           3       local split = "[^,]+,[^,]+,[^,]+,[^,]+,[^,]+"  -- (cmd_name,protocol,D,S,F)
                                           5       local prontoCode = ''
                                           7       for file in lfs.dir(dir) do
                                           8           if file: match "%.csv$" then
                                           9             for line in io.lines(dir .. filename) do
                                          10               local cmd_name,protocol,D,S,F = list: match (split)
                                          11               if 'POWER' == cmd_name then
                                          12                 print ("$protocol $D $S $F",  protocol,D,S,F)
                                          13               end
                                          14             end
                                          15          end
                                          16      end
                                        II) I know we are doing this in sections, but as there are many layers of manufacturer folders and device type sub folders, will the eventual end code systematically search for all *.csv files within all the levels below? E.g.
                                        /mnt/nas/vera/ircodes/Samsung/TV/7,7.csv
                                        /mnt/nas/vera/ircodes/Panasonic/TV/128,0.csv
                                        /mnt/nas/vera/ircodes/Panasonic/TV/128,1.csv
                                        /mnt/nas/vera/ircodes/Panasonic/TV/128,4.csv
                                        /mnt/nas/vera/ircodes/Panasonic/TV/128,9.csv
                                        /mnt/nas/vera/ircodes/Panasonic/DVD Player/128,0.csv /mnt/nas/vera/ircodes/Panasonic/DVD Player/160,0.csv /mnt/nas/vera/ircodes/Panasonic/DVD Player/160,16.csv
                                        /mnt/nas/vera/ircodes/Panasonic/DVD Player/160,18.csv
                                        /mnt/nas/vera/ircodes/Panasonic/DVD Player/160,28.csv
                                        /mnt/nas/vera/ircodes/Panasonic/DVD Player/160,34.csv
                                        /mnt/nas/vera/ircodes/Panasonic/DVD Player/160,4.csv
                                        /mnt/nas/vera/ircodes/Panasonic/Unknown_EUR7617010/170,3csv
                                        I found this online, is that the sort of thing we will need to factor i later on..
                                        Alex Ewerlöf  /  Jan 12, 2012
                                        Lua function to traverse all files in a folder recursively
                                        Here is a little function that uses Lua File System (lfs module) in order to traverse all the files in a folder and its sub folders (and their sub folders) recursively. DIR_SEP=”\” &#82…
                                        If I remove the ‘filename’ variable call, and specify a file, it then does this.
                                        LuaTest 1.7
                                        Results
                                        Runtime error: Line 10: attempt to index global 'list' (a nil value)
                                        Locals
                                        [main]
                                        prontoCode=""
                                        Print output
                                        (none)
                                        Code
                                           9             for line in io.lines(dir .. '7,7.csv') do
                                          13               end
                                          14             end
                                          15          end
                                          16      end
                                          "list" should be "line"
                                          And /mnt/nas/vera/ircodes/Panasonic/Unknown_EUR7617010/170,3csv files are expected to end in ".csv"
                                          And "file" should probably be changed to "filename"
                                          Refer: https://keplerproject.github.io/luafilesystem/manual.html
                                          Also I see you changed "power" to "POWER", which is correct but it's safer to do this: 'POWER' == cmd_name:upper() to guarantee you get uppercase. You are also using commas in your filenames. While this is allowed in Linux, I'm not so sure it should be encouraged. If that's how they come, so be it.
