  3. Vera/openLuup plugins
  4. Domoticz Bridge
Logic Programming
Fork Mios VERASECURE
On start up the log indicates the following: 2023-12-19 10:17:12.588 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelTarget","",209) old value "" 2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelTarget","",209) old value "" 2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelStatus","",209) old value "" 2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelLast","",209) old value "" 2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","TurnOnBeforeDim","",209) old value "" 2023-12-19 10:17:12.590 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","AllowZeroLevel","",209) old value "" 2023-12-19 10:17:12.590 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:bochicchio-com:serviceId:VirtualBinaryLight1","SetBrightnessURL","",209) old value "" 2023-12-19 10:17:12.590 luup_log:209: VirtualDevices[3.0-beta7@209](initializeMqtt@421):initializeMqtt(209,{ PowerStatusOff={ Value="0", Service="urn:upnp-org:serviceId:SwitchPower1", Variable="Status" }, BrightnessValue={ Variable="LoadLevelStatus", Service="urn:upnp-org:serviceId:Dimming1" }, PowerStatusOn={ Value="1", Service="urn:upnp-org:serviceId:SwitchPower1", Variable="Status" } }) - openLuup: true 2023-12-19 10:17:12.591 luup_log:209: VirtualDevices[3.0-beta7@209](subscribeToMqtt@414):subscribeToMqtt(209,nil,{ deviceID=209, opts={ Value="0", Service="urn:upnp-org:serviceId:SwitchPower1", Variable="Status" } }) 2023-12-19 10:17:12.591 openLuup.context_switch:: ERROR: [dev #209] ./L_VirtualLibrary.lua:415: attempt to concatenate field 'topic' (a nil value) 2023-12-19 10:17:12.591 openLuup.scheduler:: job aborted : ./L_VirtualLibrary.lua:415: attempt to concatenate field 'topic' (a nil value) The MQTT variables are all set to "skip": MQTT_BrightnessValue MQTT_PowerStatusOff MQTT_PowerStatusOn However it looks like the code doesn't check for "skip" and executes the functions initializeMqtt() and subscribeToMqtt() disappearing into the weeds at that point as there is nothing to subscribe to. It would also be good if the code treated an empty string in the same way as it uses the key word "skip". It's not obvious that "skip" needs to be explicitly used.
RulesEngine
E
Netatmo – Oath2 login
Vera Alexa down?
Anyone else seeing issues with Vera TTS? All was working fine. I assumed the cookie had expired, but even having replaced it, and seeing that the .alexa.login file is aging (as I'd expect) No speech. I seem to be getting an odd timeout but no idea from where. Debian Bullseye, bare metal Good call from this morning: 2023-01-18 08:22:51.657 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a2345e8 2023-01-18 08:22:51.667 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e89df13d8 2023-01-18 08:22:51.668 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=31085221&MinimumDelay=50&output_format=json&_r=1674030171666 HTTP/1.1 tcp{client}: 0x563e89df13d8 2023-01-18 08:22:58.223 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a4ab388 2023-01-18 08:22:58.223 openLuup.server:: GET /data_request?Text=Rachel%20has%20arrived%20at%20Washtec&Language=en-GB&GroupZones=Everywhere&Volume=50&DeviceNum=22&id=action&serviceId=urn%3Abochicchio-com%3AserviceId%3AVeraAlexa1&action= Say&output_format=json&_r=1674030178221 HTTP/1.1 tcp{client}: 0x563e8a4ab388 2023-01-18 08:22:58.224 luup.call_action:: 22.urn:bochicchio-com:serviceId:VeraAlexa1.Say 2023-01-18 08:22:58.224 luup_log:22: VeraAlexa: addToQueue: added to queue for 22 2023-01-18 08:23:09.379 luup.variable_set:: 22.urn:bochicchio-com:serviceId:VeraAlexa1.LatestResponse was: sending cmd:speak:<s><lang xml:lang="en-UK"><amazon:domain name="conversational">The temperature outside is -3 degr... now: sendi ng cmd:speak:<s>Rachel has arrived at Washtec</s><break time="0s" /> to dev:Everywhere type:A3C9PE6TNYLTCH ser... #hooks:0 2023-01-18 08:23:09.381 openLuup.server:: request completed (29 bytes, 1 chunks, 11156 ms) tcp{client}: 0x563e8a4ab388 2023-01-18 08:23:09.391 luup.variable_set:: 25001.urn:micasaverde-com:serviceId:SecuritySensor1.Tripped was: 0 now: 1 #hooks:0 2023-01-18 08:23:09.391 luup.variable_set:: 25001.urn:micasaverde-com:serviceId:SecuritySensor1.LastTrip was: 1674030032 now: 1674030189 #hooks:0 2023-01-18 08:23:09.394 openLuup.server:: request completed (1389 bytes, 1 chunks, 31782 ms) tcp{client}: 0x563e897eefd8 2023-01-18 08:23:09.395 openLuup.server:: request completed (1389 bytes, 1 chunks, 31662 ms) tcp{client}: 0x563e8a7c5248 2023-01-18 08:23:09.396 openLuup.server:: request completed (1389 bytes, 1 chunks, 17728 ms) tcp{client}: 0x563e89df13d8 2023-01-18 08:23:09.396 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a4ab388 2023-01-18 08:23:09.411 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a13f3c8 2023-01-18 08:23:09.412 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a79f3c8 2023-01-18 08:23:09.412 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e89df13d8 2023-01-18 08:23:09.413 openLuup.server:: GET /data_request?newTargetValue=1&DeviceNum=20330&id=action&serviceId=urn%3Aupnp-org%3AserviceId%3ASwitchPower1&action=SetTarget&output_format=json&_r=1674030189410 HTTP/1.1 tcp{client}: 0x563e 8a13f3c8 2023-01-18 08:23:09.413 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=31085224&MinimumDelay=50&output_format=json&_r=1674030189411 HTTP/1.1 tcp{client}: 0x563e8a79f3c8 2023-01-18 08:23:09.413 luup.call_action:: 20330.urn:upnp-org:serviceId:SwitchPower1.SetTarget 2023-01-18 08:23:09.413 luup.call_action:: action will be handled by parent: 37 2023-01-18 08:23:09.413 luup.variable_set:: 20330.urn:upnp-org:serviceId:SwitchPower1.Target was: 1 now: 1 #hooks:0 2023-01-18 08:23:09.449 openLuup.server:: request completed (35 bytes, 1 chunks, 36 ms) tcp{client}: 0x563e8a13f3c8 2023-01-18 08:23:09.461 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a13f3c8 2023-01-18 08:23:09.564 openLuup.server:: request completed (819 bytes, 1 chunks, 151 ms) tcp{client}: 0x563e8a79f3c8 2023-01-18 08:23:09.569 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a79f3c8 2023-01-18 08:23:09.581 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a32bf28 Bad request from just now: 2023-01-18 18:29:26.695 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x557239889e58 2023-01-18 18:29:26.696 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=66503545&MinimumDelay=50&output_format=json&_r=1674066566691 HTTP/1.1 tcp{client}: 0x557239889e58 2023-01-18 18:29:26.799 openLuup.server:: request completed (833 bytes, 1 chunks, 2249 ms) tcp{client}: 0x557239a62f78 2023-01-18 18:29:26.911 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=66503545&Timeout=60&MinimumDelay=1500&_=1674030721531 HTTP/1.1 tcp{client}: 0x5572385f78d8 2023-01-18 18:29:27.028 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x557238b98c58 2023-01-18 18:29:27.029 openLuup.server:: GET /data_request?Text=Testing...1...2...3&Language=en-GB&GroupZones=Everywhere&Volume=50&DeviceNum=22&id=action&serviceId=urn%3Abochicchio-com%3AserviceId%3AVeraAlexa1&action=Say&output_format=json&_r=1674066567027 HTTP/1.1 tcp{client}: 0x557238b98c58 2023-01-18 18:29:27.029 luup.call_action:: 22.urn:bochicchio-com:serviceId:VeraAlexa1.Say 2023-01-18 18:29:27.029 luup_log:22: VeraAlexa: addToQueue: added to queue for 22 2023-01-18 18:29:43.149 openLuup.server:: error 'closed' sending 4 bytes to tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.150 openLuup.server:: ...only 0 bytes sent 2023-01-18 18:29:43.150 openLuup.server:: error 'closed' sending 29 bytes to tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.150 openLuup.server:: ...only 0 bytes sent 2023-01-18 18:29:43.150 openLuup.server:: error 'closed' sending 2 bytes to tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.150 openLuup.server:: ...only 0 bytes sent 2023-01-18 18:29:43.150 openLuup.server:: error 'closed' sending 5 bytes to tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.150 openLuup.server:: ...only 0 bytes sent 2023-01-18 18:29:43.150 openLuup.server:: request completed (29 bytes, 1 chunks, 16121 ms) tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.153 luup_log:63: BroadLink_Mk2 debug: RM3 Mini - IR 1: device is not a sensor or if a sensor; is not coded for 2023-01-18 18:29:43.153 luup_log:63: BroadLink_Mk2 debug: RM3 Mini - IR 1: veraId: 64, blId: a0:43:b0:8b:e0:e5, altId: a0:43:b0:8b:e0:e5_ir 2023-01-18 18:29:43.153 luup_log:63: BroadLink_Mk2 debug: RM3 Mini - IR 1: urn:schemas-micasaverde-com:device:IrTransmitter:1 2023-01-18 18:29:43.154 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=66503545&Timeout=60&MinimumDelay=1500&_=1674066518681 HTTP/1.1 tcp{client}: 0x557239a62f78 2023-01-18 18:29:43.155 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.157 openLuup.server:: request completed (591 bytes, 1 chunks, 16460 ms) tcp{client}: 0x557239889e58 2023-01-18 18:29:43.161 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x557239889e58 2023-01-18 18:29:43.175 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x5572399f30e8 2023-01-18 18:29:43.176 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=66503545&MinimumDelay=50&output_format=json&_r=1674066583172 HTTP/1.1 tcp{client}: 0x5572399f30e8 2023-01-18 18:29:57.979 luup.variable_set:: 20380.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 22 now: 21 #hooks:0 Any thoughts? Cheers C
Device issues in Open Luup
Broadlink setup
Virtual Sensor Polling
Domoticz Bridge
41 Posts 6 Posters 22.7k Views 6 Watching
    While i wait for MSR to arrive, i'm trying to get better control over my zigbee devices. Looked over the fence to Domoticz, and they have a really good plugin for Zigate, and as there was a domoticz bridge here, i thought i'd use that instead..
    This plugin have bben abandoned for some years though, and when I installed it, it won't start properly.. looking at the startup log, it looks like OpenLuup might have had some changes that needs to be handled in the plugin? (@akbooer ?)
    2021-01-26 22:31:37.457   luup.create_device:: [833] D_DomoticzBridge.xml / I_DomoticzBridge.xml / D_DomoticzBridge.json   (DomoticzBridge)
    2021-01-26 22:31:37.457   openLuup.chdev:: [string "L_DomoticzBridge.lua"]:59: module 'openLuup.rooms' not found:
    	no field package.preload['openLuup.rooms']
    	no file './openLuup/rooms.lua'
    	no file '/usr/local/share/lua/5.1/openLuup/rooms.lua'
    	no file '/usr/local/share/lua/5.1/openLuup/rooms/init.lua'
    	no file '/usr/local/lib/lua/5.1/openLuup/rooms.lua'
    	no file '/usr/local/lib/lua/5.1/openLuup/rooms/init.lua'
    	no file '/usr/share/lua/5.1/openLuup/rooms.lua'
    	no file '/usr/share/lua/5.1/openLuup/rooms/init.lua'
    	no file '../cmh-lu/openLuup/rooms.lua'
    	no file 'files/openLuup/rooms.lua'
    	no file 'openLuup/openLuup/rooms.lua'
    	no file './openLuup/rooms.so'
    	no file '/usr/local/lib/lua/5.1/openLuup/rooms.so'
    	no file '/usr/lib/x86_64-linux-gnu/lua/5.1/openLuup/rooms.so'
    	no file '/usr/lib/lua/5.1/openLuup/rooms.so'
    	no file '/usr/local/lib/lua/5.1/loadall.so'
    	no file './openLuup.so'
    	no file '/usr/local/lib/lua/5.1/openLuup.so'
    	no file '/usr/lib/x86_64-linux-gnu/lua/5.1/openLuup.so'
    	no file '/usr/lib/lua/5.1/openLuup.so'
      Indeed, there is no openLuup.rooms module, and has not been for a long while. It’s an old internal architecture which should never have been required by a plugin.
        Does all this, which is no longer usable:
        local chdev		= require "openLuup.chdev"
        local json		= require "openLuup.json"
        local rooms		= require "openLuup.rooms"
        local userdata	= require "openLuup.userdata"
        local loader	= require "openLuup.loader" -- thank @akbooer for the hint about device file info
          I'll probably start from scratch ans just save the communication part, if I was you. Take a look at how the current vera/Ezlo/uzb bridges are done. this is the way to go.
            Yes. I took a quick look, and I see that it’s based on an old VeraBridge version and has loads of stuff which is really not relevant or useful.
              Ok. Seems like a good place to learn some plugin programming for me then. 🙂
                Bridges are tricky.
                  A quick solution could be to install my own Virtual Devices plug-in and just map some HTTP calls. I'm using it to map MQTT-based things, my own virtual devices and to group them (ie: to sync dimmers or blinds). If my memory is till working, domoticz has a simple HTTP api and you could update variables very easily.
                    Allready dug my feet in. 😉
                    One thing i'm struggling with is - Isn't usually (coming from VB and C++) interfaces to GUI and core more pronounced in the code layup? I.e the "variables" table for devices - this would in my head be defined as a set of variables defined one place in the code with a notation that that is where they get input/can be read/manipulated?
                    The panels underneath the "Control panel" tab are defined in the I_...xml, but again i don't se an overview of the variables used there in the .Lua?
                    I'm by no means a professional programmer, but this makes the learning curve a bit steep. 🙂
                      Bizarrely, the variables don’t appear in the .lua file and aren’t directly accessible by the plugin itself. You have to resort to using the same luup.variable_get() function as any other code would to access the device. This is something I fixed when writing openLuup.
                        Ok, but where is the list of variables (variable tab on device in GUI) defined then?
                          Partly in the service files which the device/implementation .xml files use, and partly dynamically. Anything, anywhere , can create a new serviceId/variable on any device. That's why the 'documentation' here:
                          http://wiki.micasaverde.com/index.php/Luup_Lua_extensions#function:_device_supports_service
                          says:
                          "Setting UPnP variables is unrestricted and free form, and the engine doesn't really know if a device actually uses it or does anything with it."
                            mrFarmer
                            I started with the latest VeraBridge and rebuild that to an EzloBridge (with some help from ak). VeraBridge has only a .lua file and all other files are sort of build in the openLuup virtual file system. You will have to make your own copies just as for a normal plugin. You can look at EzloBridge for some ideas https://github.com/reneboer/EzloBridge/tree/master/src
                            I can tell you it is tricky to do, but doable.
                            Cheers Rene
                              I got the domoticz bridge up and running, though still with many flaws to iron out..
                              @akbooer: Is x_BarometerSensor1.x definition a part of Openluup installation?
                              I got it with the Zigate plugin I think.. If not, mabye add it?
                              I can push it with the domoticz update as well, but it might as well be with OpenLuup?
                              • PerHP PerH
                                @perh said in Domoticz Bridge:
                                BarometerSensor1
                                No, it’s not. For the Netatmo weather station, I chose to use the GenericSensor1 serviceId.
                                It barely matters, since apps wouldn’t recognise it anyway?
                                  Don't remember where it mattered, so your'e probably right.. But it opens for a nice icon at least? and an identifier for future apps?
                                  Not a big thing, but as the files are made.. 😉
                                    I actually created one such device class with a specific icon based on the generic sensor. I probably posted here somewhere as I used it to bridge zigbee devices from home-assistant....
                                    https://smarthome.community/topic/213/another-transition-from-vera-to-openluup-perh/82?_=1612141449125
                                      It's getting ready now, and I uploaded a "release" to github in a fork from the original. Do I have to upload to the original repository to make it available in AppStore?
                                      @akbooer: This plugin has a script that is run in domoticz to get async updates. How is that done in zway/vera bridge? (in short, and laymans terms please)
                                        About Zerobrane: Sometimes the output shows "The syntax of the command is incorrect", how do i find where precisely that is?
                                        • PerHP PerH
                                          Sorry, not quite clear what you're asking here. Can you expand on this?
