  3. SiteSensor triggered my both sirens
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
4 Posts 4 Posters 962 Views 4 Watching
    swiddy
    Installed Sitesensor yesterday. Defined a http request towards yr.no for the weather.
    Default it only sends requests when the device is armed. When I armed the sensor both of my sirens started bleeping. Not funny with at night with two kids asleep.
    Simultaneous with arming the device, the first http request probably is send and my first http request did not have the Useragent http header so the result was a 403; this probably made the sitesensor device being triggered.
    I unchecked the box "only send requests when armed" and disarmed the sitesensor. This works ok but only one slight mistake with thick fingers and I have armed it again.
    I see the sitesensor device is being configured as a SecuritySensor (as it implements the securitysensor serivce?). This makes that sirens react when the sitesensor trips. I have a leakage sensor as well and I know this one triggers the sirens as well. Do not have any doorsensors right now but hope these will not trigger sirens as well.
    Is there a way to tell Sirens to ignore Sitesensor and/or other specific devices. Or should sitesensor not be configured as a security device?
    Is there an easy solution?
    Grtz Swiddy
    Some details:
    -Vera Secure box with built in siren (siren is a separate device)
    -POPP Smokedetector with siren
    -Upto-date with Vera firmware and Not on Openluup yet but don't think this would make a difference here
    therealdbT rafale77R CrilleC 3 Replies Last reply
    • S swiddy
      Grtz Swiddy
      Some details:
      @swiddy said in SiteSensor triggered my both sirens:
      Any security sensors will trigger your siren when armed and triggered. That's why I don't use armed/disarmed, but my own logic and my own notifications when triggered.
      The easy solution is to disarm your sensors, if you don't need them as security sensors.
      • S swiddy
        Grtz Swiddy
        Some details:
        @swiddy
        That's not fun
        A potential solution:
        This doesn't sound fun. I wrote my own scene in openLuup to determine when to trigger the siren to avoid this problem. I used the category/subcategory number of sensors to trigger the alarm in different mode only for specific categories of security sensors and I have a ton of sitesensors... which obviously won't trigger the alarm. I also setup a very loud TTS warning through my SONOS speakers before the sirens turn off. I also arm and disarm security sensors depending on the mode according to their subcategory.
        • S swiddy
          Grtz Swiddy
          Some details:
          @swiddy
          In Configure presets for house modes there is “What to do if an armed sensor trips”.
          Select “off” for your sirens in preferred modes.
          If you want the sirens to go off for specific sensors, create a scene with these sensors as trigger and the action to turn on the sirens.
            146.0k
