  4. MSR in Alpine Docker
32 Posts 7 Posters 12.2k Views 7 Watching
  • B Offline
    B Offline
    Buxton
    Hi Patrick,
    Do you have a compose file that you're happy with. I'd like to try this on my HA machine which has several other containers, and runs on an Intel Atom with 4gb ram.
    • B Offline
      B Offline
      Buxton
      To those dreading ssh into their machine, try using WinSCP and setting the file editor to Notepad ++. Makes editing linux files a breeze and you can set up your folder structures and permissions with the winscp gui.
      • B Buxton
        Hi Patrick,
        #23
        @buxton said in MSR in Alpine Docker:
        Here's what I last used:
        version: '3'
        services:
          web:
            container_name: reactor
            environment:
            image: toggledbits/reactor:latest
            restart: always
            network_mode: "bridge"
            expose:
              - 8111
            ports:
              - 8111:8111
            volumes:
              - .data:/var/reactor
            tmpfs: /tmp
        If you're on an RPi (or really anything, but RPi was a breeze), setting up Samba and being able to open the files directly on the host via the share is a great time saver, too. Choices.
        • PerHP PerH
          Just updated the first post.
          I just noticed that Reactor time wasn't correct, and its probably because of daylight savings time here in Norway.
          I put a Bind mount for /etc/localtime in the docker-compose, and noW it will follow the host machines time.
          @perh said in MSR in Alpine Docker:
          and not it will follow the host machines time.
          @PerH I'm re-reading this... the bind mount fixes it, right? You meant "now"?
            Yes.
            My MSR Container clock was one hour off, and the bind fixed it. 🙂
            • B Offline
              B Offline
              Buxton
              Ok got the following error:
              Pulling MSR (toggledbits/reactor:latest)...
              ERROR: pull access denied for toggledbits/reactor, repository does not exist or may require 'docker login': denied: requested access to the resource is denied
                It's not a published image. The only image I make available is for Synology NAS x86. You'll need to build your own image using the generic package download (which you can get from the download button in the MantisBT bug tracker).
                Have you built docker images before?
                • B Offline
                  B Offline
                  Buxton
                  Yes, I've built some simple ones. I'll need a Mantis login though. Let me know what kind of info you need to set up my credentials.
                    OK. Just PM me your full name and email address.
                      wrote on last edited by PerH
                      #30
                      I'm happy to see an official docker image for MSR!
                      Just thought i'd share my docker-compose.yaml, which is only different in that i use docker volume instead of bind to host folder
                      Not sure if it's better, but i've done this to all dockers in my system.
                      This came up working well immediately, next is to stop the container and add my storage and config data. 🙂
                      version: "3.9"
                      services:
                        MSR:
                          container_name: MSReactor
                          restart: always
                          image: toggledbits/reactor:latest-generic-amd64
                          ports:
                            - "8111:8111"
                          networks:                            # Optional for use of static IP inside the docker network.
                            HAnett:                            # You could replace this and the subsequent lines with " network_mode: "bridge" "
                              ipv4_address: 192.168.0.8
                          volumes:
                            - type: volume
                              source: MSR
                              target: /var/reactor
                            - "/etc/localtime:/etc/localtime:ro"
                          environment:
                            - TZ=Europe/Oslo
                            - REACTOR_DATA_PREFIX=/var/reactor
                          tmpfs: /tmp
                          logging:
                              driver: "json-file"
                              options:
                                max-file: "5"
                                max-size: 2m
                      networks:    #Optional
                          HAnett:
                              driver: bridge
                              ipam:
                                  config:
                                      - subnet: 192.168.0.0/16
                                        gateway: 192.168.0.254
                      volumes:
                        MSR:
                        Nice work there! I'm going to save a copy even though I routinely use the Docker GUI (perhaps not available to all Synology NAS users) to set up MSR.
                        I, too, have been mulling the difference between bind and volume and Googling a while back did not seem to settle it for me. Surely it must make some difference?!
                        Also, I gotta ask: Do you have any Sunrise/Sunset-based Rules? Only asking b/c for me, in 21117, my only Sunset/offset routine somehow failed to launch itself last night, but I'm uncertain whether that constitutes a 'bug' or just a misfire of some other kind.
                          I think the main advantage of volumes is that location is controlled by docker, and these locations aren't as easy to screw up if you mess around with the folder structure.. It also puts all volumes in a common folder (var/lib/docker/volumes) that can be copied to a tar or backup folder using one line, but thats just as easy if you organize bind folders the same way.. Let me know if you find other advatages. 🙂
                          I have no sunrise/sunset rules, i use light sensors for i.e. outside lighting.. I think about 90% of my "MSR bugs" have been PEBCAC, so check your logic. 😁
                            141.2k
