  3. OpenLuup unavailable
Set up: a) Many many many many kms from home: laptop connected to modem router. Router running wireguard client to create a virtual network. b) Home: modem router running wireguard server. openLuup pi4 connect to router and also a PC and other stuff, etc. The problem: When accessing charts, AltUI or the openLupp console the web pages are returned OK up to the point where they are truncated and therefore fail to display anything useful. Note this all works fine over short distances eg around a major city (I tested it) but not seemingly at world wide distances. ie network delays seem to be the issue here? Windows TeamViewer works fine overy the exact same network/wireguard set up. That's how I was able to get the openLuup logs shown below. Here is any example of openLuup trying to return a chart: 2023-09-04 21:31:20.463 openLuup.io.server:: HTTP:3480 connection from 10.0.0.2 tcp{client}: 0x55aed35038 2023-09-04 21:31:20.464 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=316885191&Timeout=60&MinimumDelay=1500&_=1692128389970 HTTP/1.1 tcp{client}: 0x55ae538348 2023-09-04 21:31:20.465 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=316885191&Timeout=60&MinimumDelay=1500&_=1692129024374 HTTP/1.1 tcp{client}: 0x55addbe1e8 2023-09-04 21:31:20.477 openLuup.server:: GET /data_request?id=lr_render&target={temp_first_floor.w,temp_ground_floor.w,temp_back_wall_of_office.w,temp_inside_roof.w,temp_jps_bedrm_north.w,temp_outside.w}&title=Temperatures&height=750&from=-y&yMin=0&yMax=40 HTTP/1.1 tcp{client}: 0x55aed35038 2023-09-04 21:31:20.478 luup_log:6: DataGraph: drawing mode: connected, draw nulls as: null 2023-09-04 21:31:20.502 luup_log:6: DataGraph: Whisper query: CPU = 23.122 mS for 2016 points 2023-09-04 21:31:20.532 luup_log:6: DataGraph: Whisper query: CPU = 22.952 mS for 2016 points 2023-09-04 21:31:20.561 luup_log:6: DataGraph: Whisper query: CPU = 22.738 mS for 2016 points 2023-09-04 21:31:20.575 luup_log:6: DataGraph: Whisper query: CPU = 9.547 mS for 2016 points 2023-09-04 21:31:20.587 luup_log:6: DataGraph: Whisper query: CPU = 9.569 mS for 2016 points 2023-09-04 21:31:20.598 luup_log:6: DataGraph: Whisper query: CPU = 9.299 mS for 2016 points 2023-09-04 21:31:20.654 luup_log:6: visualization: LineChart(2016x7) 196kB in 51mS 2023-09-04 21:31:20.655 luup_log:6: DataGraph: render: CPU = 51.219 mS for 6x2016=12096 points 2023-09-04 21:31:20.755 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 2 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:20.855 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 6 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.037 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 2 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.138 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 6 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.332 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 2 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.432 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 6 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.507 openLuup.server:: error 'closed' sending 196367 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.507 openLuup.server:: ...only 144000 bytes sent 2023-09-04 21:31:21.507 openLuup.server:: error 'closed' sending 2 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.507 openLuup.server:: ...only 0 bytes sent 2023-09-04 21:31:21.507 openLuup.server:: error 'closed' sending 5 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.507 openLuup.server:: ...only 0 bytes sent 2023-09-04 21:31:21.507 openLuup.server:: request completed (196367 bytes, 10 chunks, 1030 ms) tcp{client}: 0x55aed35038 2023-09-04 21:31:21.517 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55aed35038 2023-09-04 21:31:22.824 openLuup.io.server:: HTTP:3480 connection from 10.0.0.2 tcp{client}: 0x55aea22c88 Re: socket.select() not ready to send Is there some sort of timeout I change; to see if this can make this work? Note that openLuup is still running everything flawlessly for ages now, including the more recent addtions of ZigBee stuff. Much appreciated.
Currently I have a Vera and Hue hub all reliably controlled by openLuup with AltUI, plus any number of plugins. Been working really well for a few years now. However would like to head for a more MQTT based set up. Eliminate the Hue hub and hopefully eliminate Vera by using ZWAVE JS UI. Noting that Zwavejs2mqtt has been renamed to Z-Wave JS UI. Probably also run the stuff using Docker. Just because. Everything would end up on the one computer for easier management. Erhhh that's the hope. Some of the new Zigbee Aqara stuff is very good and inexpensive plus it fits in with HomeKit. Also the Aqara battery powered stuff looks to have a good battery lifetime: ie suggested up to five years. The battery operated Hue buttons I have; have lasted for ages. Would like to use zigbee2mqtt with a SonOff dongle, which would allow access to the over two and half thousand devices zigbee2mqtt now supports: https://www.zigbee2mqtt.io/supported-devices/ AK has the MQTT stuff working in openLuup. Have played around with it and it works well, as one would expect. Love the UDP to MQTT code. Shellys are great and also very inexpensive and they spit out & accept MQTT but I would prefer to stay away from WiFi. Not meshed and higher power consumption. Horses for courses. Now here's the query: Got about forty or more ZWave twin light switches, plus a few other ZWave bits & pieces such as blind controllers. Then there are the Hue devices on top of that. That's a lot of virtual devices to set up in openLuup. What's an appropriate way to do this? It seems there is no "auto magic bridge set up". Do I need to use say @therealdb's Virtual Devices plugin that supports MQTT or is there some other approach? I have to confess I still don't understand the master child approach in that plugin. Seems one light switch would have all the other light switches hanging off it? Helps Vera but not a problem with openLuup - why is that? Suspect AK's good coding beats Vera's? https://github.com/dbochicchio/vera-VirtualDevices Setting up manually say 100 virtual devices is a bit much to ask. I had a look at hacking the user_data.json file. Good approach till you see all the UIDs and the individually numbered ControlURL and EventURLs that need to be set up. I need some way of say of creating about 80 light switches in "No room" or in say the "ZWave upgrade" room. Or say some sort of code that could go through all my existing bridged ZWAVE devices in openLuup and create virtual devices for each one. I caould then use the openLuup console to name them and place them in their rooms: openLuup_IP_address:3480/console?page=devices_table At that point I could hack the user_data.json file to insert the MQTT topics fairly easily for each? Plus any other fine tuning needed. Then the old ZWave stuff could be swapped over to ZWAVE JS UI and all the virtual MQTT devices would be ready to go or am I dreaming? Then delete all the old Vera bridged stuff. I'm not too fussed about scene code and the like, as a I have all my code in one block, that is set up in the openLuup start up. It seems that with ZWay you can create all the ZWave device by doing some sort of interrogation of ZWay's API? Seems also to be the case with the Shelleys? So any ideas, suggestions or code snippets are welcome on how to move towards MQTT and in particular ZWAVE JS UI and zigbee2mqtt. I'm in no hurry as openLuup is performing nicely, with the old Vera handling all my ZWave devices.
Every now and then my openLuup stops responding. This is the LuaUPnP.log when it happens: 2021-08-20 14:59:39.827 :: openLuup LOG ROTATION :: (runtime 11.0 days) 2021-08-20 14:59:39.831 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6023b8088 2021-08-20 14:59:39.853 openLuup.server:: request completed (49215 bytes, 4 chunks, 22 ms) tcp{client}: 0x55b6023b8088 2021-08-20 14:59:39.854 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6023b8088 2021-08-20 14:59:40.826 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600f46ab8 2021-08-20 14:59:40.829 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600f46ab8 2021-08-20 14:59:40.846 openLuup.server:: request completed (49215 bytes, 4 chunks, 16 ms) tcp{client}: 0x55b600f46ab8 2021-08-20 14:59:40.847 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600f46ab8 2021-08-20 14:59:41.827 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600d1ad98 2021-08-20 14:59:41.829 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600d1ad98 2021-08-20 14:59:41.838 openLuup.server:: request completed (49215 bytes, 4 chunks, 8 ms) tcp{client}: 0x55b600d1ad98 2021-08-20 14:59:41.838 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600d1ad98 2021-08-20 14:59:42.827 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6016b9848 2021-08-20 14:59:42.829 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6016b9848 2021-08-20 14:59:42.847 openLuup.server:: request completed (49215 bytes, 4 chunks, 17 ms) tcp{client}: 0x55b6016b9848 2021-08-20 14:59:42.876 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6016b9848 2021-08-20 14:59:43.054 luup.watch_callback:: 30003.DS18B20.Temperature called [37]virtualSensorWatchCallback() function: 0x55b600c2fff0 2021-08-20 14:59:43.054 luup.variable_set:: 38.urn:toggledbits-com:serviceId:VirtualSensor1.PreviousRawValue was: 28.3 now: 28.5 #hooks:0 2021-08-20 14:59:43.054 luup.variable_set:: 38.urn:toggledbits-com:serviceId:VirtualSensor1.RawValue was: 28.5 now: 28.4 #hooks:0 2021-08-20 14:59:43.054 luup.variable_set:: 38.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 28.5 now: 28.4 #hooks:0 2021-08-20 14:59:43.054 luup.variable_set:: 38.urn:toggledbits-com:serviceId:VirtualSensor1.PreviousValue was: 28.3 now: 28.5 #hooks:0 2021-08-20 14:59:43.054 luup.variable_set:: 38.urn:toggledbits-com:serviceId:VirtualSensor1.LastUpdate was: 1629464323 now: 1629464383 #hooks:0 2021-08-20 14:59:43.265 openLuup.server:: request completed (3193 bytes, 1 chunks, 5550 ms) tcp{client}: 0x55b60162e488 2021-08-20 14:59:43.267 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b60162e488 2021-08-20 14:59:43.278 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6023c8458 2021-08-20 14:59:43.278 openLuup.server:: GET /data_request?id=status&DataVersion=516611499&Timeout=15&MinimumDelay=100&output_format=json&_r=1629464383277 HTTP/1.1 tcp{client}: 0x55b6023c8458 2021-08-20 14:59:43.381 openLuup.server:: request completed (1091 bytes, 1 chunks, 102 ms) tcp{client}: 0x55b6023c8458 2021-08-20 14:59:43.381 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6023c8458 2021-08-20 14:59:43.392 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6013d6cc8 2021-08-20 14:59:43.393 openLuup.server:: GET /data_request?id=status&DataVersion=516611500&Timeout=15&MinimumDelay=100&output_format=json&_r=1629464383391 HTTP/1.1 tcp{client}: 0x55b6013d6cc8 2021-08-20 14:59:43.496 openLuup.server:: request completed (3196 bytes, 1 chunks, 4981 ms) tcp{client}: 0x55b601a37db8 2021-08-20 14:59:43.826 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601d05a08 2021-08-20 14:59:43.828 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b601d05a08 2021-08-20 14:59:43.844 openLuup.server:: request completed (49215 bytes, 4 chunks, 15 ms) tcp{client}: 0x55b601d05a08 2021-08-20 14:59:43.844 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b601d05a08 2021-08-20 14:59:44.524 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=516611500&Timeout=60&MinimumDelay=1500&_=1629292536029 HTTP/1.1 tcp{client}: 0x55b601a37db8 2021-08-20 14:59:44.828 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6023a7d18 2021-08-20 14:59:44.831 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6023a7d18 2021-08-20 14:59:44.844 openLuup.server:: request completed (49215 bytes, 4 chunks, 12 ms) tcp{client}: 0x55b6023a7d18 2021-08-20 14:59:44.844 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6023a7d18 2021-08-20 14:59:45.514 openLuup.server:: GET /data_request?id=variableget&DeviceNum=0&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&Variable=Mode&_=1629292536030 HTTP/1.1 tcp{client}: 0x55b601ab8228 2021-08-20 14:59:45.617 openLuup.server:: request completed (1 bytes, 1 chunks, 102 ms) tcp{client}: 0x55b601ab8228 2021-08-20 14:59:45.827 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600b8de38 2021-08-20 14:59:45.828 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600b8de38 2021-08-20 14:59:45.834 openLuup.server:: request completed (49215 bytes, 4 chunks, 5 ms) tcp{client}: 0x55b600b8de38 2021-08-20 14:59:45.836 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600b8de38 2021-08-20 14:59:46.828 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6018a53f8 2021-08-20 14:59:46.830 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6018a53f8 2021-08-20 14:59:46.841 openLuup.server:: request completed (49215 bytes, 4 chunks, 11 ms) tcp{client}: 0x55b6018a53f8 2021-08-20 14:59:46.842 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6018a53f8 2021-08-20 14:59:47.829 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600d2d938 2021-08-20 14:59:47.832 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600d2d938 2021-08-20 14:59:47.854 openLuup.server:: request completed (49215 bytes, 4 chunks, 21 ms) tcp{client}: 0x55b600d2d938 2021-08-20 14:59:47.855 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600d2d938 2021-08-20 14:59:47.962 luup.variable_set:: 10086.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 28.3 now: 28.5 #hooks:0 2021-08-20 14:59:48.370 openLuup.server:: request completed (1359 bytes, 1 chunks, 4977 ms) tcp{client}: 0x55b6013d6cc8 2021-08-20 14:59:48.372 openLuup.server:: request completed (1359 bytes, 1 chunks, 3847 ms) tcp{client}: 0x55b601a37db8 2021-08-20 14:59:48.373 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6013d6cc8 2021-08-20 14:59:48.384 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601e62df8 2021-08-20 14:59:48.385 openLuup.server:: GET /data_request?id=status&DataVersion=516611502&Timeout=15&MinimumDelay=100&output_format=json&_r=1629464388383 HTTP/1.1 tcp{client}: 0x55b601e62df8 2021-08-20 14:59:48.813 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=516611502&Timeout=60&MinimumDelay=1500&_=1629292536031 HTTP/1.1 tcp{client}: 0x55b601a37db8 2021-08-20 14:59:48.829 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600c44bf8 2021-08-20 14:59:48.832 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600c44bf8 2021-08-20 14:59:48.854 openLuup.server:: request completed (49215 bytes, 4 chunks, 21 ms) tcp{client}: 0x55b600c44bf8 2021-08-20 14:59:48.856 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600c44bf8 2021-08-20 14:59:49.829 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600e1fea8 2021-08-20 14:59:49.830 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600e1fea8 2021-08-20 14:59:49.835 openLuup.server:: request completed (49215 bytes, 4 chunks, 5 ms) tcp{client}: 0x55b600e1fea8 2021-08-20 14:59:49.835 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600e1fea8 2021-08-20 14:59:50.831 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601cfa118 2021-08-20 14:59:50.832 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b601cfa118 2021-08-20 14:59:50.837 openLuup.server:: request completed (49215 bytes, 4 chunks, 4 ms) tcp{client}: 0x55b601cfa118 2021-08-20 14:59:50.838 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b601cfa118 2021-08-20 14:59:51.833 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601462bb8 2021-08-20 14:59:51.835 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b601462bb8 2021-08-20 14:59:51.852 openLuup.server:: request completed (49215 bytes, 4 chunks, 17 ms) tcp{client}: 0x55b601462bb8 2021-08-20 14:59:51.854 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b601462bb8 2021-08-20 14:59:52.834 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6016b1c98 2021-08-20 14:59:52.836 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6016b1c98 2021-08-20 14:59:52.847 openLuup.server:: request completed (49215 bytes, 4 chunks, 11 ms) tcp{client}: 0x55b6016b1c98 2021-08-20 14:59:52.848 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6016b1c98 2021-08-20 14:59:53.193 luup.variable_set:: 10005.urn:micasaverde-com:serviceId:SceneController1.sl_SceneActivated was: 255 now: 255 #hooks:0 2021-08-20 14:59:53.193 luup.variable_set:: 10006.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.193 luup.variable_set:: 10094.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.193 luup.variable_set:: 10096.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 10 now: 10 #hooks:0 2021-08-20 14:59:53.193 luup.variable_set:: 10098.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 10 now: 10 #hooks:0 2021-08-20 14:59:53.193 luup.variable_set:: 10104.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 10 now: 10 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10106.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10109.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10112.urn:micasaverde-com:serviceId:DoorLock1.sl_UserCode was: UserID="4" UserName="Ella" now: UserID="4" UserName="Ella" #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10112.urn:micasaverde-com:serviceId:DoorLock1.sl_LockButton was: 1 now: 1 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10112.urn:micasaverde-com:serviceId:DoorLock1.sl_PinFailed was: 1 now: 1 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10112.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10131.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10132.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10133.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10165.urn:micasaverde-com:serviceId:HaDevice1.sl_Alarm was: SMOKE now: SMOKE #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10165.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10188.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 1 now: 1 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10188.urn:micasaverde-com:serviceId:HaDevice1.sl_Alarm was: TAMPER_ALARM now: TAMPER_ALARM #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10191.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 10 now: 10 #hooks:0 2021-08-20 14:59:53.299 openLuup.server:: request completed (5449 bytes, 1 chunks, 4485 ms) tcp{client}: 0x55b601a37db8 2021-08-20 14:59:53.505 openLuup.server:: request completed (5449 bytes, 1 chunks, 5119 ms) tcp{client}: 0x55b601e62df8 2021-08-20 14:59:53.511 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b601e62df8 2021-08-20 14:59:53.513 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=516611523&Timeout=60&MinimumDelay=1500&_=1629292536032 HTTP/1.1 tcp{client}: 0x55b601a37db8 2021-08-20 14:59:53.522 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600bc7068 2021-08-20 14:59:53.524 openLuup.server:: GET /data_request?id=status&DataVersion=516611523&Timeout=15&MinimumDelay=100&output_format=json&_r=1629464393521 HTTP/1.1 tcp{client}: 0x55b600bc7068 2021-08-20 14:59:53.834 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601b8cbe8 2021-08-20 14:59:53.835 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b601b8cbe8 2021-08-20 14:59:53.840 openLuup.server:: request completed (49215 bytes, 4 chunks, 5 ms) tcp{client}: 0x55b601b8cbe8 2021-08-20 14:59:53.841 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b601b8cbe8 2021-08-20 14:59:54.834 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6013dacd8 2021-08-20 14:59:54.836 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6013dacd8 2021-08-20 14:59:54.849 openLuup.server:: request completed (49215 bytes, 4 chunks, 12 ms) tcp{client}: 0x55b6013dacd8 2021-08-20 14:59:54.850 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6013dacd8 2021-08-20 14:59:55.835 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b602316198 2021-08-20 14:59:55.836 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b602316198 2021-08-20 14:59:55.841 openLuup.server:: request completed (49215 bytes, 4 chunks, 5 ms) tcp{client}: 0x55b602316198 2021-08-20 14:59:55.842 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b602316198 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601547598 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6016c7cf8 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600b75158 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60187d188 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6011a5bf8 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60115ecd8 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601018c18 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60175d068 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60224ced8 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6017869d8 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601ab40e8 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601914178 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60100a228 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60197a998 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601103238 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600c62438 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601eaabf8 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6017c95b8 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600d6e508 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601dd2168 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b60155eb68 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6016ddcd8 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b602384ca8 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b60230cc78 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6017e3338 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600965de8 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601e23608 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6018da2f8 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600c9aa08 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600bbf0f8 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601334518 2021-08-20 15:00:10.958 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b60183b5f8 2021-08-20 15:00:10.958 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6015682a8 2021-08-20 15:00:10.958 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6018869e8 2021-08-20 15:00:10.958 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6008839c8 2021-08-20 15:00:10.958 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b60154ed58 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601a259e8 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600f617c8 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6015884c8 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601c85fe8 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b602275ae8 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b60190ab88 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601692038 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601fcea78 2021-08-20 15:00:10.960 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601ca7f28 2021-08-20 15:00:10.960 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601fd37f8 2021-08-20 15:00:10.960 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6020ec968 2021-08-20 15:00:10.961 openLuup.server:: GET /data_request?id=variableget&DeviceNum=0&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&Variable=Mode&_=1629292536033 HTTP/1.1 tcp{client}: 0x55b601ab8228 2021-08-20 15:00:10.967 luup_log:0: 32Mb, 3.3%cpu, 11.0days 2021-08-20 15:00:10.972 openLuup.server:: request completed (3361 bytes, 1 chunks, 17459 ms) tcp{client}: 0x55b601a37db8 2021-08-20 15:00:10.973 openLuup.server:: request completed (3361 bytes, 1 chunks, 17449 ms) tcp{client}: 0x55b600bc7068 2021-08-20 15:00:10.990 luup.variable_set:: 10116.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 21.8 now: 21.9 #hooks:0 2021-08-20 15:00:10.990 luup.variable_set:: 10129.urn:micasaverde-com:serviceId:HumiditySensor1.CurrentLevel was: 58.8 now: 58.7 #hooks:0 2021-08-20 15:00:10.991 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600ba45a8 2021-08-20 15:00:10.991 openLuup.mqtt:: closed tcp{client}: 0x55b600ba45a8 2021-08-20 15:00:10.992 openLuup.mqtt:: mqttthing_Klimat kllaren_838dee2e UNSUBSCRIBE from tele/Källartemp/SENSOR tcp{client}: 0x55b600ba45a8 2021-08-20 15:00:10.992 openLuup.mqtt:: ERROR publishing application message for mqtt:tele/Källartemp/SENSOR : closed 2021-08-20 15:00:10.992 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601c8c288 2021-08-20 15:00:10.992 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600bc7068 2021-08-20 15:00:10.992 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b601547598 2021-08-20 15:00:10.993 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600a62818 2021-08-20 15:00:10.993 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600a62818 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Uttag garaget_6f4265a1 UNSUBSCRIBE from openLuup/update/10149/SwitchPower1/Status tcp{client}: 0x55b600a62818 2021-08-20 15:00:10.994 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600ba8428 2021-08-20 15:00:10.994 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600ba8428 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Takflkt hallen_6da387bf UNSUBSCRIBE from tele/TakfläktHall/LWT tcp{client}: 0x55b600ba8428 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Takflkt hallen_6da387bf UNSUBSCRIBE from stat/TakfläktHall/POWER2 tcp{client}: 0x55b600ba8428 2021-08-20 15:00:10.994 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600e59b88 2021-08-20 15:00:10.994 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600e59b88 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Klimat sovrummet_0d664e41 UNSUBSCRIBE from openLuup/update/20010/HumiditySensor1/CurrentLevel tcp{client}: 0x55b600e59b88 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Klimat sovrummet_0d664e41 UNSUBSCRIBE from openLuup/update/20021/TemperatureSensor1/CurrentTemperature tcp{client}: 0x55b600e59b88 2021-08-20 15:00:10.994 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600bd02d8 2021-08-20 15:00:10.994 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600bd02d8 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Entrdrr_6acda58a UNSUBSCRIBE from openLuup/update/10095/SecuritySensor1/Tripped tcp{client}: 0x55b600bd02d8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600bb6cf8 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600bb6cf8 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Temperatur poolen_a589d192 UNSUBSCRIBE from tele/Pooltemp/SENSOR tcp{client}: 0x55b600bb6cf8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b6009ff868 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b6009ff868 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Rrelsesensor hallen_cf7c8293 UNSUBSCRIBE from openLuup/update/20013/SecuritySensor1/Tripped tcp{client}: 0x55b6009ff868 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600a23e28 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600a23e28 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Luftfuktighet badrum_d79a0ffb UNSUBSCRIBE from openLuup/update/10190/HumiditySensor1/CurrentLevel tcp{client}: 0x55b600a23e28 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600bb33b8 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600bb33b8 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Ljussensor hallen_19569c17 UNSUBSCRIBE from openLuup/update/20006/LightSensor1/CurrentLevel tcp{client}: 0x55b600bb33b8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600a136b8 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600a136b8 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Ljussensor trningsrum_ebf319c5 UNSUBSCRIBE from openLuup/update/20004/LightSensor1/CurrentLevel tcp{client}: 0x55b600a136b8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600babaa8 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600babaa8 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Solceller watt_e351a23b UNSUBSCRIBE from openLuup/update/10163/LightSensor1/CurrentLevel tcp{client}: 0x55b600babaa8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b6004a9de8 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b6004a9de8 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Luftfuktighet dusch_91df9a58 UNSUBSCRIBE from openLuup/update/20008/HumiditySensor1/CurrentLevel tcp{client}: 0x55b6004a9de8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600b84628 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600b84628 2021-08-20 15:00:10.996 openLuup.mqtt:: mqttthing_Altandrr kk_db6d3edd UNSUBSCRIBE from openLuup/update/10097/SecuritySensor1/Tripped tcp{client}: 0x55b600b84628 2021-08-20 15:00:10.996 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600be6548 2021-08-20 15:00:10.996 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600be6548 2021-08-20 15:00:10.996 openLuup.mqtt:: mqttthing_Test datarum_adbe85e6 UNSUBSCRIBE from openLuup/update/20007/Dimming1/LoadLevelTarget tcp{client}: 0x55b600be6548 2021-08-20 15:00:10.996 openLuup.mqtt:: mqttthing_Test datarum_adbe85e6 UNSUBSCRIBE from openLuup/update/20007/SwitchPower1/Status tcp{client}: 0x55b600be6548 And then in syslog: Aug 20 15:00:11 username systemd[1]: openluup.service: Control process exited, code=exited status=7 Aug 20 15:00:11 username systemd[1]: openluup.service: Failed with result 'exit-code'.
88 Posts 6 Posters 59.8k Views 6 Watching
  • A ArcherS
    @akbooer yes Homewave works as it should. At times it is a bit slow to connect, usually quite ok.
    I have enabled Historian and have connected it to Grafana in which I have some graphs.
    @rafale77 I tried to switch between cellular&vpn and wifi with Homewave and it seems to work without crashing OpenLuup. I am using Qvpn from Qnap.
    #61
    @archers
    Any update?
    I just inadvertently stress tested openLuup's socket after all the updates this morning:
    I went working in the yard cutting wood this morning which trips my ipcam motion sensor which then trips HomeAssistant object detection which then scans my camera stream using a deep learning model and when it detects a person sends an http call to openLuup to trip a security sensor on which I run a scene to do other things ranging from notifications to announcement depending on housemode etc... This happens at a rate of 5Hz (one call every 200ms)... You can see that the high frequency of http calls on top of the regular polling (I poll z-way at rate of 2Hz for example) made openLuup's CPU utilization jump! yet no crash...
    Edit: And I checked the log to discover a lot more errors of sending bytes to a closed connection but as I said, it handled like a champ.
      5% peak load? Shameful!
      I’ve been stress testing too, and haven’t been able to make anything crash recently. I’m crafting a new Docker to take over from my main, and ageing, BeagleBone Black system, and the I/O there just whistles along with cpu at under 0.2%. I also see that RapidJson is available as a standard install of Alpine, so I may include that.
      My conclusion, following yours, is that this is low-level LuaSocket issues on out of date libraries, which only show a problem when moderately stressed. I don’t think there’s anything more I can do at the openLuup coding level.
        @akbooer said in OpenLuup unavailable:
        I know! right? lol! As you know I optimize things to the edge... running on luajit, having turned JIT back on and rapidjson which I highly recommend over cjson because it enables not having to failover to dkjson if you so desire. I also regularly look at library updates which admittedly for lua, are sadly rare. I even tested a number of forks of luajit and found nothing worth the trouble at this point.
          @archers
          Any update?
          ArcherS
          #64
          @rafale77 @akbooer two days ago the system was quite slow and non-responsive. I then decided to disable the Mqtt server in OpenLuup to see what would happen. Now after two days no crash, so it seems as if this is somehow casing the crashes. Small progress perhaps.
          Edit:
          What I still have noticed is that the system has been quite slow on v21.3.25b and v2.3.24b with at times very long response times. Much worse that what it was 3-4 days ago for some reason, before updating from v2.3.21 to v2.3.24b.
          On 2.3.21 the system was quite snappy, but after some time crashed without warning.
          Now I updated to 21.3.26 and so far it seems much more responsive that on v2.3.24b / v21.3.25b.
          I thought I would updated the Lua sockets libraries, LuaFileSystem etc to the latest versions, but now I cannot find the openLuup > System > Required list list.
          This is what I had alst time I checked a week ago:
          Hints on what to update and how to do it much appreciated. 🙂
          Edit: The update to 21.3.26 initially seems to have made the system more repsonsive for whatevere reason. Good news, let's see if it stays like that.
          I see that I am on LuaFileSystem 1.6.3 that seems to be from 2015 and @rafale77 you are on 1.8.0 that is from 2020. This seems like something that could need updating.
          rafale77R akbooerA 2 Replies Last reply
          • A ArcherS
            Edit:
            #65
            @archers
            Yeah @akbooer has moved that section under tables/luup files
            I know that only because I checked the code changes...
            A akbooerA 2 Replies Last reply
              @archers
              ArcherS
              @rafale77 yepp, still on the same versions:
                Just in case you would want to know how to update these libraries:
                Need to install luarocks. This depends on what machine you are using but assuming you are on a debian base,
                sudo apt-get install luarocks
                will do it. then you can start upgrading things:
                LuaFileSystem - LuaRocks
                  ArcherS
                  @rafale77 I am on Ubuntu 18.04 so googling says:
                  sudo apt update
                  sudo apt install luarocks
                    @archers
                    @rafale77 said in OpenLuup unavailable:
                    Sorry! Yes, in fact they were duplicates (almost) and Files seemed a better place than System.
                    • A ArcherS
                      Edit:
                      @archers said in OpenLuup unavailable:
                      Much worse that what it was 3-4 days ago for some reason. Then the system was quite snappy, but after some time. This was on v21.3.25b, now I updated to 21.3.26, I will see if ot continues to be slow.
                      OK, I have a possible answer to that. The system wait for up to a specified period of time if it fins that a socket is not ready to send. Initially, I used a timeout of zero (v21.3.24) bad choice, since most things timed out. Changed it to 0.2 seconds (v21.3.24b) , and later, then to 1.0 seconds (v21.3.26).
                      I will rever to something smaller, perhaps 0.1s. But you can change this (for the HTTP server) with:
                      luup.attr_set ("openLuup.HTTP.SelectWait", 0.1)
                      Again, apologies, but your excellent reporting of the effect of these changes is a very efficient way for me to zero in on issues, for which, thanks.
                        ArcherS
                        @akbooer thanks! I see that my text above got a bit incomplete.
                        This is how it should be ( I think, many updates lately 🙂 ) :
                        For clarity I edited the post above also.
                          ArcherS
                          @rafale77 LuaFileSystem 1.8.0 Installed:
                          What I did was:
                          sudo apt update
                          sudo luarocks install luafilesystem
                          I will keep it running without eabling Mqtt for a while and see if it seems stable.
                            While you are at it, I would recommend you upgrade luasec (ssl) as well.
                              No harm in that, although we're not using SSL in this exercise, AFAIK.
                              • A ArcherS
                                What I did was:
                                sudo apt update
                                ArcherS
                                A short status update.
                                Yesterday evening I updated OpenLupp to v21.3.26 and LuaFileSystem to 1.8.0.
                                I have since then left the system up and running as-is, i.e. without Mqtt re-enabled and with most of the http updates from my various Tasmota devices turned off.
                                So far so good, the system seems as responsive as it has been earlier for the past approx 20 hours.
                                I have not changed the http server waiting time, it is at the default value for v21.3.26.
                                When looking in the logs, it looks ok. Usually quite fast responses and no errors.
                                I found two similar lines that had a bit longer response time:
                                2002 lines, 0 errors, max gap 41s @ 2021-03-28 17:30:00.131
                                2021-03-28 17:29:18.910   luup.variable_set:: 10909.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 0 now: 0 #hooks:0
                                2021-03-28 17:30:00.131   luup_log:0: 40Mb, 3.5%cpu, 0.8days
                                2021-03-28 17:30:00.646   luup.variable_set:: 68.urn:toggledbits-com:serviceId:ReactorSensor.cstate was: {"cond0":{"evaledge":[],"stateedge":[],"valuestamp":1615722020,"id":"cond0","statestamp":0,"lastvalue":0},"vars":{"... now: {"cond0":{"evaledge":[],"stateedge":[],"valuestamp":1615722020,"id":"cond0","statestamp":0,"lastvalue":0},"vars":{"... #hooks:0
                                2002 lines, 0 errors, max gap 65s @ 2021-03-28 16:54:07.724
                                2021-03-28 16:53:02.682   luup.variable_set:: 244.urn:toggledbits-com:serviceId:VirtualSensor1.LastUpdate was: 1616943122 now: 1616943182 #hooks:0
                                2021-03-28 16:54:07.724   luup_log:0: 44Mb, 1.5%cpu, 0.7days
                                2021-03-28 16:54:07.755   luup.variable_set:: 122.urn:toggledbits-com:serviceId:DelayLightTimer.Message was: Delay Off 9m now: Delay Off 8m #hooks:0
                                I will keep off the system until tomorrow to see that it is stable over time before I restart the Mqtt server.
                                  Nothing to worry about with those logs. Anything under 120s is fine.
                                  • A ArcherS
                                    ArcherS
                                    #77
                                    I looked in the logs again after I had some slow responses in the system and found some errors. The IP address 192.168.1.127 this my iPhone and Homewave. I tested with Homewave on my iPad and got a similar set of errors for that IP address. These errors seem to be in the direction of what @rafale77 mentioned.
                                    Edit: Still had some errors so I changed it to 0.1 which seems to give even fewer errors.
                                    I changed the http server wait to 0.2 0.1 from 1.0 with luup.attr_set ("openLuup.HTTP.SelectWait", 0.1) and it seems as if it may have helped removing the errors. I will check some more later on and see if the errors return.
                                    From the log file:
                                    2021-03-28 19:58:23.148   openLuup.server:: error 'closed' sending 2 bytes to tcp{client}: 0x55979ef92ba8
                                    2021-03-28 19:58:23.148   openLuup.server:: error 'closed' sending 6 bytes to tcp{client}: 0x55979ef92ba8
                                    2021-03-28 19:58:23.148   openLuup.server:: error 'closed' sending 858578 bytes to tcp{client}: 0x55979ef92ba8
                                    2021-03-28 19:58:23.149   openLuup.server:: error 'closed' sending 5 bytes to tcp{client}: 0x55979ef92ba8
                                    2021-03-28 20:01:02.561   openLuup.server:: error 'closed' sending 4 bytes to tcp{client}: 0x55979f3f9768
                                    2021-03-28 20:01:02.561   openLuup.server:: error 'closed' sending 104 bytes to tcp{client}: 0x55979f3f9768
                                    2021-03-28 20:01:02.561   openLuup.server:: error 'closed' sending 2 bytes to tcp{client}: 0x55979f3f9768
                                    2021-03-28 19:58:21.155   openLuup.io.server:: HTTP:3480 connection from 192.168.1.127 tcp{client}: 0x55979ef92ba8
                                    2021-03-28 20:01:00.882   openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55979f3f9768
                                    2021-03-28 19:58:22.954   luup_log:203: VirtualBinaryLight[2.40@203]:[updateMeters] Watts Path: "meters[1].power" - Value: 0
                                    2021-03-28 19:58:23.148   openLuup.server:: ...only 0 bytes sent
                                    2021-03-28 19:58:23.148   openLuup.server:: ...only 64000 bytes sent
                                    2021-03-28 19:58:23.149   openLuup.server:: ...only 0 bytes sent
                                    2021-03-28 19:58:23.149   openLuup.server:: request completed (858578 bytes, 5 chunks, 446 ms) tcp{client}: 0x55979ef92ba8
                                    • A ArcherS
                                      From the log file:
                                      ArcherS
                                      I have now had the Mqtt server up and running for approx 30 hours without any crashes so far, a step in the right direction as it seems.
                                      I am still on OpenLuup version: v21.3.26 and LuaFileSystem v1.8.0 (luasec not updated), want to keep the setup as-is to see what happens over longer time.
                                      So far only one Tasmota device connected via Mqtt reporting every minute.
                                      No errors in the log files (except for Homewave, see below), max response time usually approx 16 seconds. Changing the http wait to 0.1 was a big change. With 1.0 OpenLuup was sluggish and there is a noticable difference also when comparing to 0.2.
                                      With 0.1 the system is much better.
                                      Messages as displayed by MqttExplorer:
                                      I have noticed two brief Mqtt disconnects during this time.
                                      Log file:
                                      1575 lines, 0 errors, max gap 75s @ 2021-03-29 13:35:48.179
                                      2021-03-29 13:34:33.581   luup.variable_set:: 216.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 25.3 now: 25.4 #hooks:0
                                      2021-03-29 13:34:33.582   luup.variable_set:: 228.urn:micasaverde-com:serviceId:HumiditySensor1.CurrentLevel was: 36.1 now: 36.1 #hooks:0
                                      2021-03-29 13:35:48.179   openLuup.io.server:: MQTT:1883 connection from 192.168.1.60 tcp{client}: 0x5652106f2f48
                                      2021-03-29 13:35:48.180   openLuup.io.server:: HTTP:3480 connection closed EXPIRED tcp{client}: 0x56520e9d91c8
                                      2021-03-29 13:35:48.180   openLuup.io.server:: MQTT:1883 connection closed EXPIRED tcp{client}: 0x565210622978
                                      2021-03-29 13:35:48.180   openLuup.mqtt:: mqtt-explorer-22233d66 UNSUBSCRIBE from # tcp{client}: 0x565210622978
                                      2021-03-29 13:35:48.180   openLuup.mqtt:: mqtt-explorer-22233d66 UNSUBSCRIBE from $SYS/# tcp{client}: 0x565210622978
                                      Log from the Tasmota device console:
                                      12:43:08 MQT: tele/tasmota_test/SENSOR = {"Time":"2021-03-29T12:43:08","AM2301":{"Temperature":25.4,"Humidity":36.1,"DewPoint":9.3},"TempUnit":"C"}
                                      12:43:33 MQT: Attempting connection...
                                      12:43:48 MQT: Connect failed to 192.168.1.107:1883, rc -4. Retry in 10 sec
                                      12:43:59 MQT: Attempting connection...
                                      12:44:10 MQT: Connected
                                      12:44:10 MQT: tele/tasmota_test/LWT = Online (retained)
                                      12:44:10 MQT: cmnd/tasmota_test/POWER =
                                      12:44:33 MQT: tele/tasmota_test/STATE = {"Time":"2021-03-29T12:44:33","Uptime":"0T01:05:15","UptimeSec":3915,"Heap":26,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":4,"Wifi":{"AP":1,"SSId":"BeachAC","BSSId":"FC:EC:DA:D1:7A:64","Channel":11,"RSSI":100,"Signal":-50,"LinkCount":1,"Downtime":"0T00:00:03"}}
                                      It reconnected without problem quite fast, so that seems to be fine.
                                      I have not used Homewave very much during this time, but it also seems to work ok. However I do see errors for it when I use it. So something is not 100% right there perhaps. I got more errors with a longer http wait (1.0 >> 0.2 > 0.1).
                                      Log file:
                                      2021-03-30 20:10:47.908   openLuup.server:: request completed (5907 bytes, 1 chunks, 194 ms) tcp{client}: 0x565210f173b8
                                      2021-03-30 20:10:48.260   openLuup.server:: GET /data_request?output_format=json&id=lu_status HTTP/1.1 tcp{client}: 0x5652108936d8
                                      2021-03-30 20:10:48.484   openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x5652108936d8' sending 2 bytes to tcp{client}: 0x5652108936d8
                                      2021-03-30 20:10:48.563   openLuup.server:: request completed (858554 bytes, 54 chunks, 302 ms) tcp{client}: 0x5652108936d8
                                      2021-03-30 20:10:48.932   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=14594009&Timeout=60&MinimumDelay=1500&_=1617014398016 HTTP/1.1 tcp{client}: 0x565210f173b8
                                      2021-03-30 20:10:49.068   openLuup.server:: request completed (5909 bytes, 1 chunks, 135 ms) tcp{client}: 0x565210f173b8
                                        #79
                                        Well, that seems like a step in the right direction.
                                        I, too, have been pressing on MQTT, and all seems well. Disconnects happen when the iMac that I’m using to run Explorer goes to sleep, but reconnects when it wakes up, as expected. Current stats look like this:
                                          ArcherS
                                          @akbooer today I got another crash unfortunately.
                                          I had it up and running with two Mqtt devices reporting during approx 24 hours before the crash. Before that approx 2 days with one device.
                                          This morning 4 hours before the crash it looked like this:
                                          When looking through the log I can find the a lot of errors building up the last 2.5 hours before the crash.
                                          2021-04-01 10:10:20.698   openLuup.io.server:: MQTT:1883 connection closed  tcp{client}: 0x55d8bb5a9b48
                                          2021-04-01 10:10:20.698   openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55d8bb5a9b48
                                          2021-04-01 10:10:20.698   openLuup.mqtt:: TasmotaUterum UNSUBSCRIBE from cmnd/TasmotaUterum_fb/# tcp{client}: 0x55d8bb5a9b48
                                          2021-04-01 10:10:20.698   openLuup.mqtt:: TasmotaUterum UNSUBSCRIBE from cmnd/TasmotaUterum/# tcp{client}: 0x55d8bb5a9b48
                                          2021-04-01 10:10:20.698   openLuup.mqtt:: TasmotaUterum UNSUBSCRIBE from cmnd/tasmotas/# tcp{client}: 0x55d8bb5a9b48
                                          2021-04-01 10:10:20.707   openLuup.io.server:: MQTT:1883 connection closed  tcp{client}: 0x55d8bae0e948
                                          2021-04-01 10:10:20.707   openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55d8bae0e948
                                          2021-04-01 10:10:20.709   openLuup.io.server:: MQTT:1883 connection closed  tcp{client}: 0x55d8bb8a48a8
                                          2021-04-01 10:10:20.709   openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55d8bb8a48a8
                                          2021-04-01 10:10:20.709   openLuup.mqtt:: tasmota_test UNSUBSCRIBE from cmnd/tasmota_test_fb/# tcp{client}: 0x55d8bb8a48a8
                                          2021-04-01 10:10:20.709   openLuup.mqtt:: tasmota_test UNSUBSCRIBE from cmnd/tasmotas/# tcp{client}: 0x55d8bb8a48a8
                                          2021-04-01 10:10:20.709   openLuup.mqtt:: tasmota_test UNSUBSCRIBE from cmnd/tasmota_test/# tcp{client}: 0x55d8bb8a48a8
                                          2021-04-01 10:10:20.741   openLuup.io.server:: MQTT:1883 connection from 192.168.1.50 tcp{client}: 0x55d8bad50918
                                          2021-04-01 10:10:20.744   openLuup.mqtt:: tasmota_test SUBSCRIBE to cmnd/tasmota_test/# tcp{client}: 0x55d8bb53f518
                                          2021-04-01 10:10:20.746   openLuup.mqtt:: tasmota_test SUBSCRIBE to cmnd/tasmotas/# tcp{client}: 0x55d8bb53f518
                                          2021-04-01 10:10:20.752   openLuup.mqtt:: tasmota_test SUBSCRIBE to cmnd/tasmota_test_fb/# tcp{client}: 0x55d8bb53f518
                                          2021-04-01 10:10:20.770   openLuup.mqtt:: TasmotaUterum SUBSCRIBE to cmnd/TasmotaUterum/# tcp{client}: 0x55d8bad50918
                                          2021-04-01 10:10:20.770   openLuup.mqtt:: TasmotaUterum SUBSCRIBE to cmnd/tasmotas/# tcp{client}: 0x55d8bad50918
                                          2021-04-01 10:10:20.771   openLuup.mqtt:: TasmotaUterum SUBSCRIBE to cmnd/TasmotaUterum_fb/# tcp{client}: 0x55d8bad50918
                                          2021-04-01 10:13:26.365   openLuup.io.server:: MQTT:1883 connection closed  tcp{client}: 0x55d8bb6e71e8
                                          2021-04-01 10:13:26.365   openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55d8bb6e71e8
                                          2021-04-01 10:13:26.365   openLuup.io.server:: MQTT:1883 connection closed  tcp{client}: 0x55d8bab0a8d8
                                          2021-04-01 10:13:26.365   openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55d8bab0a8d8
                                          2021-04-01 10:13:26.368   openLuup.io.server:: MQTT:1883 connection closed  tcp{client}: 0x55d8bad50918
                                          2021-04-01 10:13:26.368   openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55d8bad50918
                                          2021-04-01 10:13:26.368   openLuup.mqtt:: TasmotaUterum UNSUBSCRIBE from cmnd/TasmotaUterum_fb/# tcp{client}: 0x55d8bad50918
                                          2021-04-01 10:13:26.368   openLuup.mqtt:: TasmotaUterum UNSUBSCRIBE from cmnd/TasmotaUterum/# tcp{client}: 0x55d8bad50918
                                          2021-04-01 10:13:26.368   openLuup.mqtt:: TasmotaUterum UNSUBSCRIBE from cmnd/tasmotas/# tcp{client}: 0x55d8bad50918
                                          2021-04-01 10:13:26.368   openLuup.io.server:: MQTT:1883 connection closed  tcp{client}: 0x55d8bb53f518
                                          2021-04-01 10:13:26.368   openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55d8bb53f518
                                          2021-04-01 10:13:26.368   openLuup.mqtt:: tasmota_test UNSUBSCRIBE from cmnd/tasmota_test_fb/# tcp{client}: 0x55d8bb53f518
                                          2021-04-01 10:13:26.368   openLuup.mqtt:: tasmota_test UNSUBSCRIBE from cmnd/tasmotas/# tcp{client}: 0x55d8bb53f518
                                          2021-04-01 10:13:26.368   openLuup.mqtt:: tasmota_test UNSUBSCRIBE from cmnd/tasmota_test/# tcp{client}: 0x55d8bb53f518
                                          2021-04-01 10:13:26.374   openLuup.mqtt:: TasmotaUterum SUBSCRIBE to cmnd/TasmotaUterum/# tcp{client}: 0x55d8bacf35d8
                                          2021-04-01 10:13:26.379   openLuup.mqtt:: TasmotaUterum SUBSCRIBE to cmnd/tasmotas/# tcp{client}: 0x55d8bacf35d8
                                          2021-04-01 10:13:26.386   openLuup.mqtt:: TasmotaUterum SUBSCRIBE to cmnd/TasmotaUterum_fb/# tcp{client}: 0x55d8bacf35d8
                                          2021-04-01 10:13:26.397   openLuup.mqtt:: tasmota_test SUBSCRIBE to cmnd/tasmota_test/# tcp{client}: 0x55d8bad3fc48
                                          2021-04-01 10:13:26.400   openLuup.mqtt:: tasmota_test SUBSCRIBE to cmnd/tasmotas/# tcp{client}: 0x55d8bad3fc48
                                          2021-04-01 10:13:26.406   openLuup.mqtt:: tasmota_test SUBSCRIBE to cmnd/tasmota_test_fb/# tcp{client}: 0x55d8bad3fc48
                                          2021-04-01 10:35:23.058   openLuup.io.server:: MQTT:1883 connection closed  tcp{client}: 0x55d8bacf35d8
                                          2021-04-01 10:35:23.059   openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55d8bacf35d8
                                          2021-04-01 10:35:23.059   openLuup.mqtt:: TasmotaUterum UNSUBSCRIBE from cmnd/TasmotaUterum_fb/# tcp{client}: 0x55d8bacf35d8
                                          2021-04-01 10:35:23.059   openLuup.mqtt:: TasmotaUterum UNSUBSCRIBE from cmnd/TasmotaUterum/# tcp{client}: 0x55d8bacf35d8
                                          2021-04-01 10:35:23.059   openLuup.mqtt:: TasmotaUterum UNSUBSCRIBE from cmnd/tasmotas/# tcp{client}: 0x55d8bacf35d8
                                          2021-04-01 10:35:23.088   openLuup.io.server:: MQTT:1883 connection closed  tcp{client}: 0x55d8bb736018
                                          2021-04-01 10:35:23.088   openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55d8bb736018
                                          2021-04-01 10:35:23.088   openLuup.io.server:: MQTT:1883 connection closed  tcp{client}: 0x55d8bb7380c8
                                          2021-04-01 10:35:23.089   openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55d8bb7380c8
                                          2021-04-01 10:35:23.096   openLuup.io.server:: MQTT:1883 connection closed  tcp{client}: 0x55d8bad3fc48
                                          2021-04-01 10:35:23.096   openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55d8bad3fc48
                                          2021-04-01 10:35:23.096   openLuup.mqtt:: tasmota_test UNSUBSCRIBE from cmnd/tasmota_test_fb/# tcp{client}: 0x55d8bad3fc48
                                          2021-04-01 10:35:23.096   openLuup.mqtt:: tasmota_test UNSUBSCRIBE from cmnd/tasmotas/# tcp{client}: 0x55d8bad3fc48
                                          2021-04-01 10:35:23.096   openLuup.mqtt:: tasmota_test UNSUBSCRIBE from cmnd/tasmota_test/# tcp{client}: 0x55d8bad3fc48
                                          2021-04-01 10:35:25.955   openLuup.io.server:: MQTT:1883 connection from 192.168.1.50 tcp{client}: 0x55d8b9bd4838
                                          2021-04-01 10:35:25.973   openLuup.mqtt:: TasmotaUterum SUBSCRIBE to cmnd/TasmotaUterum/# tcp{client}: 0x55d8b9bd4838
                                          2021-04-01 10:35:25.977   openLuup.mqtt:: TasmotaUterum SUBSCRIBE to cmnd/tasmotas/# tcp{client}: 0x55d8b9bd4838
                                          2021-04-01 10:35:25.977   openLuup.mqtt:: TasmotaUterum SUBSCRIBE to cmnd/TasmotaUterum_fb/# tcp{client}: 0x55d8b9bd4838
                                          2021-04-01 10:35:29.040   openLuup.io.server:: MQTT:1883 connection from 192.168.1.60 tcp{client}: 0x55d8bb605448
                                          2021-04-01 10:35:29.058   openLuup.mqtt:: tasmota_test SUBSCRIBE to cmnd/tasmota_test/# tcp{client}: 0x55d8bb605448
                                          2021-04-01 10:35:29.062   openLuup.mqtt:: tasmota_test SUBSCRIBE to cmnd/tasmotas/# tcp{client}: 0x55d8bb605448
                                          2021-04-01 10:35:29.063   openLuup.mqtt:: tasmota_test SUBSCRIBE to cmnd/tasmota_test_fb/# tcp{client}: 0x55d8bb605448
                                          2021-04-01 10:39:23.441   openLuup.io.server:: MQTT:1883 connection closed  tcp{client}: 0x55d8b9bd4838
                                          2021-04-01 10:39:23.441   openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55d8b9bd4838
                                          2021-04-01 10:39:23.441   openLuup.mqtt:: TasmotaUterum UNSUBSCRIBE from cmnd/TasmotaUterum_fb/# tcp{client}: 0x55d8b9bd4838
                                          2021-04-01 10:39:23.441   openLuup.mqtt:: TasmotaUterum UNSUBSCRIBE from cmnd/TasmotaUterum/# tcp{client}: 0x55d8b9bd4838
                                          2021-04-01 10:39:23.441   openLuup.mqtt:: TasmotaUterum UNSUBSCRIBE from cmnd/tasmotas/# tcp{client}: 0x55d8b9bd4838
                                          2021-04-01 10:39:29.585   openLuup.io.server:: MQTT:1883 connection from 192.168.1.60 tcp{client}: 0x55d8b8fedf68
                                          2021-04-01 10:39:29.585   openLuup.io.server:: MQTT:1883 connection closed  tcp{client}: 0x55d8baee2da8
                                          2021-04-01 10:39:29.585   openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55d8baee2da8
                                          2021-04-01 10:39:29.585   openLuup.io.server:: MQTT:1883 connection closed  tcp{client}: 0x55d8baacc308
                                          2021-04-01 10:39:29.585   openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55d8baacc308
                                          2021-04-01 10:39:35.729   openLuup.io.server:: MQTT:1883 connection closed  tcp{client}: 0x55d8bb605448
                                          2021-04-01 10:39:35.729   openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55d8bb605448
                                          2021-04-01 10:39:35.729   openLuup.mqtt:: tasmota_test UNSUBSCRIBE from cmnd/tasmota_test_fb/# tcp{client}: 0x55d8bb605448
                                          2021-04-01 10:40:49.043   openLuup.context_switch::  ERROR: [dev #106] table: 0x55d8bb856790
                                          2021-04-01 10:40:49.043   luup.incoming_callback:: function: 0x55d8bacaad00 ERROR: table: 0x55d8bb856790
                                          2021-04-01 10:43:20.159   openLuup.io.server:: MQTT:1883 connection closed  tcp{client}: 0x55d8bb0f87b8
                                          2021-04-01 10:43:20.159   openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55d8bb0f87b8
                                          2021-04-01 10:43:20.161   openLuup.io.server:: MQTT:1883 connection closed  tcp{client}: 0x55d8b8fedf68
                                          2021-04-01 10:43:20.161   openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55d8b8fedf68
                                          2021-04-01 10:43:20.161   openLuup.mqtt:: tasmota_test UNSUBSCRIBE from cmnd/tasmota_test_fb/# tcp{client}: 0x55d8b8fedf68
                                          2021-04-01 10:43:20.161   openLuup.mqtt:: tasmota_test UNSUBSCRIBE from cmnd/tasmotas/# tcp{client}: 0x55d8b8fedf68
                                          2021-04-01 10:43:20.161   openLuup.mqtt:: tasmota_test UNSUBSCRIBE from cmnd/tasmota_test/# tcp{client}: 0x55d8b8fedf68
                                          2021-04-01 10:43:20.161   openLuup.io.server:: MQTT:1883 connection closed  tcp{client}: 0x55d8bb46f488
                                          2021-04-01 10:43:20.161   openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55d8bb46f488
                                          2021-04-01 10:43:20.161   openLuup.mqtt:: TasmotaUterum UNSUBSCRIBE from cmnd/TasmotaUterum_fb/# tcp{client}: 0x55d8bb46f488
                                          2021-04-01 10:43:20.162   openLuup.mqtt:: TasmotaUterum UNSUBSCRIBE from cmnd/TasmotaUterum/# tcp{client}: 0x55d8bb46f488
                                          2021-04-01 10:43:20.162   openLuup.mqtt:: TasmotaUterum UNSUBSCRIBE from cmnd/tasmotas/# tcp{client}: 0x55d8bb46f488
                                          2021-04-01 10:43:20.254   openLuup.mqtt:: TasmotaUterum SUBSCRIBE to cmnd/TasmotaUterum/# tcp{client}: 0x55d8ba375f28
                                          2021-04-01 10:43:20.258   openLuup.mqtt:: TasmotaUterum SUBSCRIBE to cmnd/tasmotas/# tcp{client}: 0x55d8ba375f28
                                          2021-04-01 10:43:20.258   openLuup.mqtt:: TasmotaUterum SUBSCRIBE to cmnd/TasmotaUterum_fb/# tcp{client}: 0x55d8ba375f28
                                          2021-04-01 10:43:20.260   openLuup.mqtt:: tasmota_test SUBSCRIBE to cmnd/tasmota_test/# tcp{client}: 0x55d8bb83d468
                                          2021-04-01 10:43:20.260   openLuup.mqtt:: tasmota_test SUBSCRIBE to cmnd/tasmotas/# tcp{client}: 0x55d8bb83d468
                                          2021-04-01 10:43:20.260   openLuup.mqtt:: tasmota_test SUBSCRIBE to cmnd/tasmota_test_fb/# tcp{client}: 0x55d8bb83d468
                                          2021-04-01 10:51:25.662   openLuup.io.server:: MQTT:1883 connection closed  tcp{client}: 0x55d8baaa6608
                                          2021-04-01 10:51:25.662   openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55d8baaa6608
                                          2021-04-01 10:51:25.663   openLuup.io.server:: MQTT:1883 connection closed  tcp{client}: 0x55d8badfb488
                                          2021-04-01 10:51:25.663   openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55d8badfb488
                                          2021-04-01 10:51:25.665   openLuup.io.server:: MQTT:1883 connection closed  tcp{client}: 0x55d8bb83d468
                                          2021-04-01 10:51:25.665   openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55d8bb83d468
                                          2021-04-01 10:51:25.665   openLuup.mqtt:: tasmota_test UNSUBSCRIBE from cmnd/tasmota_test_fb/# tcp{client}: 0x55d8bb83d468
                                          2021-04-01 10:51:25.665   openLuup.mqtt:: tasmota_test UNSUBSCRIBE from cmnd/tasmotas/# tcp{client}: 0x55d8bb83d468
                                          2021-04-01 10:51:25.665   openLuup.mqtt:: tasmota_test UNSUBSCRIBE from cmnd/tasmota_test/# tcp{client}: 0x55d8bb83d468
                                          2021-04-01 10:51:25.665   openLuup.io.server:: MQTT:1883 connection closed  tcp{client}: 0x55d8ba375f28
                                          2021-04-01 10:51:25.665   openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55d8ba375f28
                                          2021-04-01 10:51:25.665   openLuup.mqtt:: TasmotaUterum UNSUBSCRIBE from cmnd/TasmotaUterum_fb/# tcp{client}: 0x55d8ba375f28
                                          2021-04-01 10:51:25.665   openLuup.mqtt:: TasmotaUterum UNSUBSCRIBE from cmnd/TasmotaUterum/# tcp{client}: 0x55d8ba375f28
                                          2021-04-01 10:51:25.665   openLuup.mqtt:: TasmotaUterum UNSUBSCRIBE from cmnd/tasmotas/# tcp{client}: 0x55d8ba375f28
                                          2021-04-01 10:51:25.735   openLuup.mqtt:: TasmotaUterum SUBSCRIBE to cmnd/TasmotaUterum/# tcp{client}: 0x55d8ba738ad8
                                          2021-04-01 10:51:25.739   openLuup.mqtt:: TasmotaUterum SUBSCRIBE to cmnd/tasmotas/# tcp{client}: 0x55d8ba738ad8
                                          2021-04-01 10:51:25.739   openLuup.mqtt:: TasmotaUterum SUBSCRIBE to cmnd/TasmotaUterum_fb/# tcp{client}: 0x55d8ba738ad8
                                          2021-04-01 10:51:25.844   openLuup.mqtt:: tasmota_test SUBSCRIBE to cmnd/tasmota_test/# tcp{client}: 0x55d8baf3baa8
                                          2021-04-01 10:51:25.847   openLuup.mqtt:: tasmota_test SUBSCRIBE to cmnd/tasmotas/# tcp{client}: 0x55d8baf3baa8
                                          2021-04-01 10:51:25.851   openLuup.mqtt:: tasmota_test SUBSCRIBE to cmnd/tasmota_test_fb/# tcp{client}: 0x55d8baf3baa8
                                          2021-04-01 10:54:32.113   openLuup.io.server:: MQTT:1883 connection closed  tcp{client}: 0x55d8baf3baa8
                                          2021-04-01 10:54:32.113   openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55d8baf3baa8
                                          2021-04-01 10:54:32.113   openLuup.mqtt:: tasmota_test UNSUBSCRIBE from cmnd/tasmota_test_fb/# tcp{client}: 0x55d8baf3baa8
                                          2021-04-01 10:54:32.113   openLuup.mqtt:: tasmota_test UNSUBSCRIBE from cmnd/tasmotas/# tcp{client}: 0x55d8baf3baa8
                                          2021-04-01 10:54:32.113   openLuup.mqtt:: tasmota_test UNSUBSCRIBE from cmnd/tasmota_test/# tcp{client}: 0x55d8baf3baa8
                                          2021-04-01 10:54:32.113   openLuup.io.server:: MQTT:1883 connection closed  tcp{client}: 0x55d8ba738ad8
                                          2021-04-01 10:54:32.113   openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55d8ba738ad8
                                          2021-04-01 10:54:32.113   openLuup.mqtt:: TasmotaUterum UNSUBSCRIBE from cmnd/TasmotaUterum_fb/# tcp{client}: 0x55d8ba738ad8
                                          2021-04-01 10:54:32.113   openLuup.mqtt:: TasmotaUterum UNSUBSCRIBE from cmnd/TasmotaUterum/# tcp{client}: 0x55d8ba738ad8
                                          2021-04-01 10:54:32.113   openLuup.mqtt:: TasmotaUterum UNSUBSCRIBE from cmnd/tasmotas/# tcp{client}: 0x55d8ba738ad8
                                          2021-04-01 10:54:32.175   openLuup.mqtt:: TasmotaUterum SUBSCRIBE to cmnd/TasmotaUterum/# tcp{client}: 0x55d8ba6ce668
                                          2021-04-01 10:54:32.178   openLuup.mqtt:: tasmota_test SUBSCRIBE to cmnd/tasmota_test/# tcp{client}: 0x55d8bb6b8028
                                          2021-04-01 10:54:32.185   openLuup.mqtt:: tasmota_test SUBSCRIBE to cmnd/tasmotas/# tcp{client}: 0x55d8bb6b8028
                                          2021-04-01 10:54:32.185   openLuup.mqtt:: tasmota_test SUBSCRIBE to cmnd/tasmota_test_fb/# tcp{client}: 0x55d8bb6b8028
                                          2021-04-01 10:54:32.190   openLuup.mqtt:: TasmotaUterum SUBSCRIBE to cmnd/tasmotas/# tcp{client}: 0x55d8ba6ce668
                                          2021-04-01 10:54:32.190   openLuup.mqtt:: TasmotaUterum SUBSCRIBE to cmnd/TasmotaUterum_fb/# tcp{client}: 0x55d8ba6ce668
                                          <<<<repeats itself every 3rd minute or so>>>>
                                          2021-04-01 12:42:40.786   openLuup.io.server:: MQTT:1883 connection closed  tcp{client}: 0x55d8bb0f87b8
                                          2021-04-01 12:42:40.786   openLuup.mqtt:: closed tcp{client}: 0x55d8bb0f87b8
                                          2021-04-01 12:42:40.786   openLuup.mqtt:: tasmota_test UNSUBSCRIBE from cmnd/tasmota_test_fb/# tcp{client}: 0x55d8bb0f87b8
                                          2021-04-01 12:42:40.786   openLuup.mqtt:: tasmota_test UNSUBSCRIBE from cmnd/tasmotas/# tcp{client}: 0x55d8bb0f87b8
                                          2021-04-01 12:42:40.786   openLuup.mqtt:: tasmota_test UNSUBSCRIBE from cmnd/tasmota_test/# tcp{client}: 0x55d8bb0f87b8
                                          2021-04-01 12:42:40.786   openLuup.mqtt:: ERROR publishing application message for mqtt:cmnd/tasmota_test/POWER : closed
                                          2021-04-01 12:42:40.786   openLuup.io.server:: MQTT:1883 connection closed  tcp{client}: 0x55d8bab88d38
                                          2021-04-01 12:42:40.786   openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55d8bab88d38
                                          2021-04-01 12:42:40.786   openLuup.mqtt:: TasmotaUterum UNSUBSCRIBE from cmnd/TasmotaUterum_fb/# tcp{client}: 0x55d8bab88d38
                                          2021-04-01 12:42:40.786   openLuup.mqtt:: TasmotaUterum UNSUBSCRIBE from cmnd/TasmotaUterum/# tcp{client}: 0x55d8bab88d38
                                          2021-04-01 12:42:40.786   openLuup.mqtt:: TasmotaUterum UNSUBSCRIBE from cmnd/tasmotas/# tcp{client}: 0x55d8bab88d38
                                          <<<<crashed>>>>
                                          In addition to the above I also found the following in the log, during one period (approx 20 times during a few minutes, two hours before the crash) "no route to host" for the Zway server (it is not on the same server as OpenLuup) and another error (only once), see below.
                                          2021-04-01 10:39:23.440   luup_log:106: ZWay ASYNC request: No route to host
                                          Now I have disabled the Mqtt and restarted the server to see what happens.
                                            164.2k
