  3. Plugins
  4. openLuup: Tasmota MQTT Bridge
Plugins
openweather plugin ?
Plugins
Openluup: Datayours
Plugins
Plugins
zigbee2mqtt and openLuup
Plugins
Plugins
Sonos system alerts truncated
Well pretty sure I didn't change or touch anything! I've turned everything on and off again as one might hope. Excepting a total reboot of the Pi3 that's running all my stuff very reliably in openLuup. It's all been working well for years and now all of sudden 6 second alerts are truncated to about 4 seconds. Occasionally it works as it should. I see this in the log - does it help? 2023-02-20 09:39:06.662 luup_log:0: My Lua ver 0.50 debug: executing scene 63: "Check windows doors" in room: "Watchers" 2023-02-20 09:39:06.663 luup.call_action:: 217.urn:micasaverde-com:serviceId:Sonos1.Alert 2023-02-20 09:39:06.663 luup.call_action:: action will be handled by parent: 214 2023-02-20 09:39:06.663 luup_log:0: My Lua ver 0.50 debug: rest of scene 63 was executed 2023-02-20 09:39:06.663 luup.scenes:: scene 63, Check windows doors, initiated by AltUI 2023-02-20 09:39:06.665 luup_log:214: Sonos: Alert action on device 217 URI "http://redacted:3480/www/sounds/AllClosed.mp3" duration "6" 2023-02-20 09:39:06.758 luup_log:214: Sonos: UPnP_request (Pause, urn:schemas-upnp-org:service:AVTransport:1): status=1 statusMsg=500 result=[<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns="urn:schemas-upnp-org:control-1-0"><errorCode>701</errorCode></UPnPError></detail></s:Fault></s:Body></s:Envelope>] 2023-02-20 09:39:06.759 luup_log:214: stack traceback: ./L_SonosSystem1.lua:265: in function 'error' ./L_SonosUPnP.lua:289: in function <./L_SonosUPnP.lua:169> (tail call): ? ./L_SonosSystem1.lua:3390: in function 'sayOrAlert' ./L_SonosSystem1.lua:3452: in function 'queueAlert' ./L_SonosSystem1.lua:3843: in function <./L_SonosSystem1.lua:3839> (tail call): ? [C]: in function 'pcall' ./openLuup/scheduler.lua:204: in function 'context_switch' ./openLuup/scheduler.lua:366: in function 'dispatch' ./openLuup/scheduler.lua:588: in function 'task_callbacks' ./openLuup/scheduler.lua:699: in function 'start' openLuup/init.lua:354: in main chunk [C]: ? 2023-02-20 09:39:06.888 luup.variable_set:: 214.urn:toggledbits-com:serviceId:SonosSystem1.zoneInfo was: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... now: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... #hooks:0 2023-02-20 09:39:06.895 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.TransportState was: STOPPED now: TRANSITIONING #hooks:0 2023-02-20 09:39:06.901 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentPlayMode was: SHUFFLE_NOREPEAT now: NORMAL #hooks:0 2023-02-20 09:39:06.913 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTransportActions was: Set, Stop, Pause, Play, X_DLNA_SeekTime, Next, X_DLNA_SeekTrackNr now: Set, Stop, Pause, Play, X_DLNA_SeekTime, X_DLNA_SeekTrackNr #hooks:0 2023-02-20 09:39:06.921 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.NumberOfTracks was: 10 now: 1 #hooks:0 2023-02-20 09:39:06.922 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.AVTransportURI was: x-rincon-queue:RINCON_000E58DC7BBE01400#0 now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.929 luup_log:214: Sonos: UPnP_request() "urn:schemas-upnp-org:service:AVTransport:1"#"GetPositionInfo" action took 5.0073010921478s (long) 2023-02-20 09:39:11.932 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackDuration was: 0:02:22 now: 0:00:00 #hooks:0 2023-02-20 09:39:11.933 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackURI was: x-file-cifs://ELEPHANT1/Multimedia/My%20Music/Music%20JP/The%20Smiths/The%20Queen%20Is%20Dead/08%20Vicar%20in%20a%2... now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.934 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackMetaData was: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... now: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... #hooks:0 2023-02-20 09:39:11.936 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentStatus was: Vicar in a Tutu: (The Smiths, The Queen Is Dead) now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTitle was: Vicar in a Tutu now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentArtist was: The Smiths now: #hooks:0 2023-02-20 09:39:11.938 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentAlbum was: The Queen Is Dead now: #hooks:0 Also see these: 2023-02-24 16:12:13.576 openLuup.server:: GET /www/sounds/YouRang.mp3 HTTP/1.1 tcp{client}: 0x17e96f0 2023-02-24 16:12:13.579 openLuup.server:: error 'closed' sending 43102 bytes to tcp{client}: 0x17e96f0 So any clues?
Plugins
Generic support for vacuums
Plugins
Switchboard plugin
Plugins
Plugins
Plugins
Reactor scope issues
Plugins
Plugins
This topic has come up before but I haven't seen an answer. Symptom: AltuUI says there is a new update available, so you tell it to do the update but the update does not happen. AltUI remains stuck on it's old version. On other occasions it works OK. So my version is: AltUI v2.49.2546, © 2019 AltUI says this: a newer version #2551 of ALTUI is available, do you want to upgrade ? add scrollable dialog for long boxes bugfix: clock display on safari remote url update ( @olov ) update jquery and bootstrap versions credential to camera device url ( @rafale77 ) ignore Ezlo hub ( @reneboer) Track through the JavaScript and find that this issues the update command: function _triggerAltUIUpgrade(newversion,newtracnum) { var url = '?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version={1}&TracRev={0}'.format(newversion,newtracnum); return _httpGet(url,{}).always( function() { PageMessage.message(_T("Upgrade Request succeeded, a Luup reload will happen"),"success"); }); }; And the url variable equals: url: "?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551" All looks good so far. I manually issue the same url complete with my openLuup ip_address in a local browser. Update fails - looks like AltUI is doing as it should: http://ip_address:3480/data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551 In openLuup I see: 2021-12-06 13:56:14.821 luup_log:3: ALTUI: startupDeferred, called on behalf of device:3 2021-12-06 13:56:14.838 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.Version was: v2.49 now: v2.49 #hooks:0 And then later: 2021-12-06 13:55:58.256 openLuup.server:: GET /data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551 HTTP/1.1 tcp{client}: 0x25712a8 2021-12-06 13:55:58.257 luup.call_action:: 0.urn:micasaverde-com:serviceId:HomeAutomationGateway1.CreatePlugin 2021-12-06 13:55:58.259 luup.call_action:: 4.urn:upnp-org:serviceId:AltAppStore1.update_plugin 2021-12-06 13:55:58.260 luup_log:4: AltAppStore : starting <run> phase... 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : downloading amg0/ALTUI [2551] to trash/AltAppStore/ 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents?ref=2551 2021-12-06 13:55:58.760 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents/blockly?ref=2551 2021-12-06 13:55:59.543 luup_log:4: AltAppStore : getting contents of version: 2551 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine1 was: AltAppStore now: Downloading... #hooks:0 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: now: Alternate UI #hooks:0 2021-12-06 13:55:59.544 luup_log:4: AltAppStore : scheduling <job> phase... 2021-12-06 13:55:59.544 openLuup.requests:: 2021-12-06 13:55:59.545 openLuup.server:: request completed (148 bytes, 1 chunks, 1288 ms) tcp{client}: 0x25712a8 2021-12-06 13:55:59.554 openLuup.server:: request completed (6233 bytes, 1 chunks, 16442 ms) tcp{client}: 0x255e680 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : ...final <job> phase 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : Total size 0.000 (kB) 2021-12-06 13:55:59.555 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: Alternate UI now: Alternate UI 100% #hooks:0 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating icons in icons/ ... 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating device files in ./ ... 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 icon files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 device files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : Alternate UI update completed 2021-12-06 13:55:59.556 openLuup.luup:: device 4 'Alternate App Store' requesting reload 2021-12-06 13:55:59.556 luup.reload:: saving user_data 2021-12-06 13:56:00.262 openLuup.luup:: exiting with code 42 - after 0.3 hours All looks OK. Then I check GitHub. It shows the latest changes to the version 2551. However this page says the latest version is 2550. So I wondering what's going on. Seems the latest version number is not being picked by the installer? (not sure how it works.) Is it possible for openLuup to log a bit more about the version it's trying to install. As this call returns. https://api.github.com/repos/amg0/ALTUI/contents?ref=2551 message "No commit found for the ref 2551" documentation_url "https://docs.github.com/v3/repos/contents/" But this works fine: https://api.github.com/repos/amg0/ALTUI/contents?ref=2550 So it looks like AMG0 doesn't always update the repository with whatever is needed to get this to work (I imagine that's easy to forget). But could openLuup send back a fail result to AltUI and AltUI pick that up? Currently it looks like AltUI always assumes everything went OK. Or somehow; could openLuup log and/or notify the user what went wrong?
Plugins
Reactor: double click action
Plugins
Virtual Pronto Remote plugin
Plugins
openLuup: SmartSwitch plugin
Plugins
Reactor icons for local lan
Plugins
Plugins
AltUi
Plugins
127 Posts 5 Posters 99.0k Views 4 Watching
    ATM the bridge doesn't solicit any response from the devices. Indeed, it would have to discover them first in order to do so. So at this time, if the device does not sent regular tele/ updates, then it won't be seen. This is early days for the bridge.
    ElcidE Offline
    ElcidE Offline
    Elcid
    wrote on last edited by Elcid
    #21
    @akbooer
    There is a tele topic. Sorry about the image as the App would not let me copy the text.
    Screenshot_20210414-225131.png and there is also a -
    tasmota/tele/name/LWT with message "Online"
      OK, well that will work if I add configuration for your optional ‘Tasmota’ prefix.
      • ElcidE Offline
        ElcidE Offline
        Elcid
        I added the prefix for future use so i could group devices by type (sensor/switch/dimmer/etc) as i will filter topics by type of device i want to subscribe to. So it would be nice to have a list of prefixes, if it is possible.
          B Offline
          B Offline
          Buxton
          @akbooer Good start on my end. Here's a pic of one device that shows three Bluetooth temp/humidity sensors (LYWSD...) that connect to a Tasmota relay:
          You may need to decode a layer deeper for the "table" entries....
          I do have a bunch of error messages in the log, but I will have to get into that on the weekend as I'm currently buried with work work....
          Here's a snippet though:
          2021-04-14 20:11:13.634   openLuup.context_switch::  ERROR: [dev #262] openLuup/L_TasmotaBridge.lua:188: table index is nil
          2021-04-14 20:11:13.634   openLuup.mqtt:: ERROR publishing application message for mqtt:tele/power_BedroomTV/BLE : openLuup/L_TasmotaBridge.lua:188: table index is nil
          2021-04-14 20:11:14.044   openLuup.server:: request completed (1490 bytes, 1 chunks, 1280 ms) tcp{client}: 0x5619338130b8
          2021-04-14 20:11:14.642   openLuup.context_switch::  ERROR: [dev #262] openLuup/L_TasmotaBridge.lua:188: table index is nil
          2021-04-14 20:11:14.642   openLuup.mqtt:: ERROR publishing application message for mqtt:tele/power_BedroomTV/STATE : openLuup/L_TasmotaBridge.lua:188: table index is nil
          2021-04-14 20:11:14.662   openLuup.context_switch::  ERROR: [dev #0] attempt to call a string value
          2021-04-14 20:11:14.663   openLuup.mqtt:: ERROR publishing application message for mqtt:tele/power_BedroomTV/SENSOR : attempt to call a string value
          2021-04-14 20:11:14.701   openLuup.context_switch::  ERROR: [dev #262] openLuup/L_TasmotaBridge.lua:188: table index is nil
            Ok, I've added support for command based on MQTT in version 3.0-beta1.
            Variable updated on messages coming soon. Feedback much appreciated!
            GitHub - dbochicchio/vera-VirtualDevices: Virtual HTTP Devices plug-in for Vera and openLuup
            Virtual HTTP Devices plug-in for Vera and openLuup - dbochicchio/vera-VirtualDevices
              B Offline
              B Offline
              Buxton
              @akbooer I did some debug on the error messages above and came up with the following. I placed some debug entries in the "L_TasmotaBridge.lua" to try to see what was causing the errors. First the code: under function _G.Tasmota_MQTT_Handler (topic, message)
                local myMessage = ""
                if message == nil then
                   myMessage = "Message is null"
                else
              	if message == "" then
              	 myMessage = "Message is empty"
              	else
              	 myMessage = message
                _log ("JSON error info " .. myMessage)
              Which produced the following log errors and their context:
              2021-04-16 20:48:01.335   openLuup.io.server:: MQTT:1882 connection from 10.17.2.28 tcp{client}: 0x55fac42317b8
              2021-04-16 20:48:01.355   luup.tasmota:262: JSON error info Online
              2021-04-16 20:48:01.356   luup.tasmota:262: JSON error: ?
              2021-04-16 20:48:01.366   luup.tasmota:262: JSON error info Message is empty
              2021-04-16 20:48:01.367   luup.tasmota:262: JSON error: ?
              2021-04-16 20:48:01.423   openLuup.mqtt:: BedroomTV SUBSCRIBE to cmnd/power_BedroomTV/# tcp{client}: 0x55fac42317b8
              2021-04-16 20:48:01.432   openLuup.mqtt:: BedroomTV SUBSCRIBE to cmnd/tasmotas/# tcp{client}: 0x55fac42317b8
              2021-04-16 20:48:01.433   openLuup.mqtt:: BedroomTV SUBSCRIBE to cmnd/BedroomTV_fb/# tcp{client}: 0x55fac42317b8
              B 1 Reply Last reply
                B Offline
                B Offline
                Buxton
                @akbooer Then further down the log file I was getting errors in the "function init_device (altid, info)" function. Error code is:
                	local myaltid = ""
                	local myinfo = ""
                	if altid == nil then
                		myaltid = "altid is null"
                		else
                		myaltid = altid
                	if info == nil then
                		myinfo = "info is null"
                		else
                		if info == " " then
                			myinfo = "info is empty"
                		else
                			myinfo = unpack(info)
                	_log ("Find info " ..  myinfo )
                	_log ("Find altid " .. myaltid )
                  local dno = luup.openLuup.find_device {altid = altid}
                                or
                                  create_device (altid, info)
                	_log ("Find DNO " .. dno)
                Which yields:
                2021-04-16 21:37:06.773   openLuup.io.server:: MQTT:1882 connection closed  tcp{client}: 0x556c246bb0f8
                2021-04-16 21:37:06.773   openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x556c246bb0f8
                2021-04-16 21:37:06.815   luup.io.incoming:: bytes received: 51, status: OK tcp{client}: 0x556c24620fb8
                2021-04-16 21:37:09.516   luup.tasmota:262: JSON error info {"Time":"2021-04-17T05:37:09","Uptime":"0T02:24:57","UptimeSec":8697,"Heap":125,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":13,"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"CD","BSSId":"FE:9F:DB:F5:A0:11","Channel":1,"RSSI":94,"Signal":-53,"LinkCount":1,"Downtime":"0T00:00:06"}}
                2021-04-16 21:37:09.517   luup.tasmota:262: Find info info is null
                2021-04-16 21:37:09.517   luup.tasmota:262: Find altid altid is null
                2021-04-16 21:37:09.517   luup.tasmota:262: Find DNO 1
                2021-04-16 21:37:09.518   openLuup.context_switch::  ERROR: [dev #262] openLuup/L_TasmotaBridge.lua:215: table index is nil
                2021-04-16 21:37:09.518   openLuup.mqtt:: ERROR publishing application message for mqtt:tele/power_BedroomTV/STATE : openLuup/L_TasmotaBridge.lua:215: table index is nil
                2021-04-16 21:37:09.605   openLuup.context_switch::  ERROR: [dev #0] attempt to call a string value
                2021-04-16 21:37:09.605   openLuup.mqtt:: ERROR publishing application message for mqtt:tele/power_BedroomTV/SENSOR : attempt to call a string value
                2021-04-16 21:37:09.605   luup.tasmota:262: JSON error info {"Time":"2021-04-17T05:37:09","Switch1":"ON","Switch2":"ON","ENERGY":{"TotalStartTime":"2021-04-04T05:29:11","Total":0.000,"Yesterday":0.000,"Today":0.000,"Period":0,"Power":[0,0],"ApparentPower":[0,0],"ReactivePower":[0,0],"Factor":[0.00,0.00],"Frequency":60,"Voltage":121,"Current":[0.000,0.000]}}
                2021-04-16 21:37:09.606   luup.tasmota:262: Find info info is null
                2021-04-16 21:37:09.606   luup.tasmota:262: Find altid power_BedroomTV
                2021-04-16 21:37:09.606   luup.tasmota:262: Find DNO 30001
                2021-04-16 21:37:09.618   luup.tasmota:262: JSON error info {"Time":"2021-04-17T05:37:09","BLEDevices":{"total":3,"A4C138EB4F4F":{"i":0,"r":-73},"A4C13838EB2E":{"i":1,"r":-87},"A4C138A59E0C":{"i":2,"r":-92}}}
                2021-04-16 21:37:09.619   luup.tasmota:262: Find info info is null
                2021-04-16 21:37:09.619   luup.tasmota:262: Find altid altid is null
                2021-04-16 21:37:09.619   luup.tasmota:262: Find DNO 1
                2021-04-16 21:37:09.619   openLuup.context_switch::  ERROR: [dev #262] openLuup/L_TasmotaBridge.lua:215: table index is nil
                2021-04-16 21:37:09.619   openLuup.mqtt:: ERROR publishing application message for mqtt:tele/power_BedroomTV/BLE : openLuup/L_TasmotaBridge.lua:215: table index is nil
                2021-04-16 21:37:09.620   luup.tasmota:262: JSON error info {"Time":"2021-04-17T05:37:09","BLE":{"scans":483,"adverts":23232,"devices":3,"resets":0}}
                2021-04-16 21:37:09.620   luup.tasmota:262: Find info info is null
                2021-04-16 21:37:09.620   luup.tasmota:262: Find altid altid is null
                2021-04-16 21:37:09.620   luup.tasmota:262: Find DNO 1
                Hope that's of some use.
                • B Buxton
                  	local myaltid = ""
                  	local myinfo = ""
                  		else
                  		myaltid = altid
                  	if info == nil then
                  		else
                  		if info == " " then
                  		else
                                  or
                  Which yields:
                  B Offline
                  B Offline
                  Buxton
                  @buxton In the above, I'm seeing an extra closing right hand bracket in the JSON string.
                    And I've also added handlers to get status from a generic MQTT message. It's done on lights, dimmers, roller shutters and rgb/rgbw.
                    Just use the format topic/=/payload, where * for payload means "pass the value to the variable".
                    Color and white temp are supported, but I'll need to write a converter (or link to the existing one). If anyone is still interested, I could port it to alarm, heaters, door locks and sensors.
                      @Elcid
                      The latest development version v21.4.17 has added and additional subscription to the tasmota/tele/# topic. I will make it configurable later.
                      @Buxton
                      I've refactored the bridge a bit, but haven't yet addressed the nested table issue... don't know if this has fixed any of the other errors you've seen, but I didn't do anything explicitly to address those. Still very much work in progress.
                      • ElcidE Offline
                        ElcidE Offline
                        Elcid
                        #31
                        Has installed tasmota bridge and the child devices have been added with the following varaiables
                        LastUpdate
                        17/04/2021, 12:43:57
                        Switch1
                        OFF
                        Time
                        2021-04-17T12:43:57
                        tasmota/tele
                        {"Time":"2021-04-17T12:43:57","Switch1":"OFF"}
                        • A ArcherS
                          @akbooer I have "AsyncPoll" true on the Zway Bridge, I assume that means that it is in asynchronuous mode? Or should I check something else?
                          No, I have yet to install cjson. This was actually intentional since I wanted to test it without this first and see if it works. On my main OpenLuup server that has experienced crashes I have cjson installed so I wanted to test without cjson first. But I should test this later on and see what happens to the cpu load.
                          Regarding cpu load it has not gone up that much when comparing running one Tasmota vs running seven which is promising.
                          I am not sure what message that causes the error, do you have any ideas what I should look for in the log or elsewhere? It mentions "TasmotaBridge.Lua:188 table index is nil" in all errors for the devices.
                          The errors always says:
                          2021-04-14 21:19:10.214   openLuup.context_switch::  ERROR: [dev #14] openLuup/L_TasmotaBridge.lua:188: table index is nil
                          2021-04-14 21:19:10.214   openLuup.mqtt:: ERROR publishing application message for mqtt:tele/TasmotaTest/STATE : openLuup/L_TasmotaBridge.lua:188: table index is nil
                          and it seems to cycle through my Tasmota devices reporting the same two rows but for each device:
                          2021-04-14 21:35:10.064   openLuup.context_switch::  ERROR: [dev #14] openLuup/L_TasmotaBridge.lua:188: table index is nil
                          2021-04-14 21:35:10.065   openLuup.mqtt:: ERROR publishing application message for mqtt:tele/TasmotaTest/STATE : openLuup/L_TasmotaBridge.lua:188: table index is nil
                          2021-04-14 21:35:42.864   openLuup.context_switch::  ERROR: [dev #14] openLuup/L_TasmotaBridge.lua:188: table index is nil
                          2021-04-14 21:35:42.865   openLuup.mqtt:: ERROR publishing application message for mqtt:tele/TasmotaUterum/STATE : openLuup/L_TasmotaBridge.lua:188: table index is nil
                          2021-04-14 21:35:44.637   openLuup.context_switch::  ERROR: [dev #14] openLuup/L_TasmotaBridge.lua:188: table index is nil
                          2021-04-14 21:35:44.637   openLuup.mqtt:: ERROR publishing application message for mqtt:tele/TasmotaCO2An/STATE : openLuup/L_TasmotaBridge.lua:188: table index is nil
                          2021-04-14 21:35:44.844   openLuup.context_switch::  ERROR: [dev #14] openLuup/L_TasmotaBridge.lua:188: table index is nil
                          2021-04-14 21:35:44.844   openLuup.mqtt:: ERROR publishing application message for mqtt:tele/TasmotaCO2Ax/STATE : openLuup/L_TasmotaBridge.lua:188: table index is nil
                          Yes I agree, it seems to be going well. 🙂
                          No, I think it is quite good the way it is, creating Virtual Sensors and then linking them to the devices/variables is very easy. It only takes a few minutes to add a new Tasmota device from scratch without any coding at all.
                          In fact I think it is better this way since typically you do not want all of the reported values as a child device, e.g. you do not want "Dew point" or "Time", the useless MHZ19B temperature etc. This way you can select only what you want, not getting OpenLuup cluttered by a lot of "useless" child devices.
                          ArcherS
                          I have now updated to v21.4.17 and also installed cjson.
                          The cpu load on my test Pi went down from 10.5% to 4-4.5%, so that is a good step better.
                          The server has been running with my Zway bridge with 64 zNodes and 165 vDevs and five Tasmota devices.
                          Data this morning after 2.5 days run time:
                          bc93653b-66cf-4b4f-bade-9aeb4c6a7968-image.png I have added one more Tasmota device, in total 6 are now pushing data over Mqtt to OpenLuup.
                          @akbooer what is changed in v21.4.17, I could not see any changes to be honest. 🙂
                          What I did notice however was that the old error messages I posted above have disappeared. I will see if I get any new, so far I have not seen any.
                          • A ArcherS
                            @archers said in openLuup: Tasmota MQTT Bridge:
                            Well, I think you answered your own question...
                            • B Buxton
                              @buxton said in openLuup: Tasmota MQTT Bridge:
                              Version 21.4.17c does just that (I hope.)
                              Would be interesting in seeing the variables which result...
                              • ElcidE Offline
                                ElcidE Offline
                                Elcid
                                #35
                                Just reporting that the variables in the tasmota devices are not updating correctly
                                tasmota/tele
                                {"Time":"2021-04-17T19:28:59","Switch1":"ON"}
                                The time stamp updates, but not the value of Switch1.
                                [edit] after deleteing the 4 devices and reloading luup I found these errors in log
                                2021-04-17 19:59:39.142   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=685929357&Timeout=60&MinimumDelay=1500&_=1618685858944 HTTP/1.1 tcp{client}: 0xff56978
                                2021-04-17 19:59:39.145   openLuup.mqtt:: localhost.bridge-01 SUBSCRIBE to # tcp{client}: 0xff593e0
                                2021-04-17 19:59:39.147   luup.tasmota:47: JSON error: Expected value but found invalid token at character 1
                                2021-04-17 19:59:39.148   luup.tasmota:47: JSON error: Expected value but found invalid token at character 1
                                2021-04-17 19:59:39.153   luup.tasmota:47: JSON error: Expected value but found invalid token at character 1
                                2021-04-17 19:59:39.154   luup.tasmota:47: JSON error: Expected value but found invalid token at character 1
                                  ArcherS
                                  #36
                                  @akbooer I have now discovered a few new error messages:
                                  2021-04-17 19:52:02.446   openLuup.io.server:: MQTT:1883 connection from 192.168.1.56 tcp{client}: 0x2654a78
                                  2021-04-17 19:52:02.464   luup.tasmota:14: JSON error: Expected value but found invalid token at character 1
                                  2021-04-17 19:52:02.477   openLuup.io.server:: MQTT:1883 connection closed  tcp{client}: 0x20aeec0
                                  2021-04-17 19:52:02.477   openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x20aeec0
                                  2021-04-17 19:52:02.477   openLuup.mqtt:: TasmotaBLE UNSUBSCRIBE from cmnd/tasmotas/# tcp{client}: 0x20aeec0
                                  2021-04-17 19:52:02.478   openLuup.mqtt:: TasmotaBLE UNSUBSCRIBE from cmnd/TasmotaBLE/# tcp{client}: 0x20aeec0
                                  2021-04-17 19:52:02.478   openLuup.mqtt:: TasmotaBLE UNSUBSCRIBE from cmnd/TasmotaBLE_fb/# tcp{client}: 0x20aeec0
                                  2021-04-17 19:52:02.482   openLuup.mqtt:: TasmotaBLE SUBSCRIBE to cmnd/TasmotaBLE/# tcp{client}: 0x2654a78
                                  2021-04-17 19:52:02.561   openLuup.mqtt:: TasmotaBLE SUBSCRIBE to cmnd/tasmotas/# tcp{client}: 0x2654a78
                                  2021-04-17 19:52:02.859   openLuup.mqtt:: TasmotaBLE SUBSCRIBE to cmnd/TasmotaBLE_fb/# tcp{client}: 0x2654a78
                                  I seem to get it on an irregular basis now and then in the log.
                                  It is coming from my ESP32 Tasmota that has three BLE devices connected to it (device #20005). It typically sends the following every 5 minutes:
                                  tele/TasmotaBLE/SENSOR = {"Time":"2021-04-17T19:12:04","ATC-f159bf":{"Temperature":24.0,"Humidity":44.0,"DewPoint":11.0,"Battery":63,"RSSI":-84},"ATC-9446bf":{"Temperature":23.1,"Humidity":62.0,"DewPoint":15.4,"Battery":80,"RSSI":-82},"ATC-6d5d44":{"Temperature":14.8,"Humidity":43.0,"DewPoint":2.3,"Battery":54,"RSSI":-89},"TempUnit":"C"}
                                  I have seen in the log that the device works, i.e. the data for the three devices get updated between the errors.
                                  I tried to capture what is going on and I think it is the device restarting or something when the errors occur. I will check some more on that, perhaps to try and update to a newer firmware.
                                  At the time for the error I got the following in the Tasmota Console:
                                  19:50:09.833 MQT: tele/TasmotaBLE/INFO1 = {"Module":"ESP32-DevKit","Version":"9.2.0.3(tasmota)","FallbackTopic":"cmnd/TasmotaBLE_fb/","GroupTopic":"cmnd/tasmotas/"}
                                  19:50:09.841 MQT: tele/TasmotaBLE/INFO2 = {"WebServerMode":"Admin","Hostname":"TasmotaBLE-0476","IPAddress":"192.168.1.56"}
                                  19:50:09.852 MQT: tele/TasmotaBLE/INFO3 = {"RestartReason":"Software reset CPU"}
                                  19:50:10.911 QPC: Reset
                                  19:50:13.901 MQT: tele/TasmotaBLE/STATE = {"Time":"2021-04-17T19:50:13","Uptime":"0T00:00:10","UptimeSec":10,"Heap":110,"SleepMode":"Normal","Sleep":50,"LoadAvg":37,"MqttCount":1,"Wifi":{"AP":1,"SSId":"BeachAC","BSSId":"FC:EC:DA:D1:7A:64","Channel":11,"RSSI":86,"Signal":-57,"LinkCount":1,"Downtime":"0T00:00:04"}}
                                  19:50:13.924 MQT: tele/TasmotaBLE/SENSOR = {"Time":"2021-04-17T19:50:13","ATC-f159bf":{"Temperature":24.0,"Humidity":43.0,"DewPoint":10.6,"Battery":63,"RSSI":-81},"TempUnit":"C"}
                                  Maybee it is the OpenLuup Mqtt server reacting to the startup messages?
                                  Edit: Yes it is an error from when a Tasmota device starts, I restarted one of my other devices and got the same error in the log. It also recovered as it should after rebooted.
                                  2021-04-17 22:01:05.433   openLuup.io.server:: MQTT:1883 connection from 192.168.1.50 tcp{client}: 0x25fcc50
                                  2021-04-17 22:01:05.440   luup.tasmota:14: JSON error: Expected value but found invalid token at character 1
                                  2021-04-17 22:01:05.447   openLuup.mqtt:: TasmotaUterum SUBSCRIBE to cmnd/TasmotaUterum/# tcp{client}: 0x25fcc50
                                  2021-04-17 22:01:05.452   openLuup.mqtt:: TasmotaUterum SUBSCRIBE to cmnd/tasmotas/# tcp{client}: 0x25fcc50
                                  2021-04-17 22:01:05.454   openLuup.mqtt:: TasmotaUterum SUBSCRIBE to cmnd/TasmotaUterum_fb/# tcp{client}: 0x25fcc50
                                  2021-04-17 22:01:05.455   openLuup.io.server:: MQTT:1883 connection closed  tcp{client}: 0x24ae758
                                  2021-04-17 22:01:05.455   openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x24ae758
                                  2021-04-17 22:01:05.456   openLuup.mqtt:: TasmotaUterum UNSUBSCRIBE from cmnd/TasmotaUterum/# tcp{client}: 0x24ae758
                                  2021-04-17 22:01:05.456   openLuup.mqtt:: TasmotaUterum UNSUBSCRIBE from cmnd/tasmotas/# tcp{client}: 0x24ae758
                                  2021-04-17 22:01:05.456   openLuup.mqtt:: TasmotaUterum UNSUBSCRIBE from cmnd/TasmotaUterum_fb/# tcp{client}: 0x24ae758
                                    @ArcherS
                                    Version 21.4.17d adds an additional error message to see what is causing the JSON error. However, this should be totally recoverable, the message is simply ignored.
                                    B A 4 Replies Last reply
                                      @ArcherS
                                      B Offline
                                      B Offline
                                      Buxton
                                      @akbooer My log is much calmer with the oL update. Thanks for that. I still have the following error though:
                                      2021-04-17 13:41:37.079   luup.tasmota:262: JSON error: ?
                                      2021-04-17 13:41:37.080   luup.tasmota:262: Received message causing error was: Online
                                      This happens only on a LUUP reload. If I were to guess, the JSON decoder is seeing a single text string, so it doesn't/can't really decode, but throws an error instead. Maybe trap for strings before being sent to the decoder.... They are valid messages and should not throw receive errors or decode errors.
                                        @ArcherS
                                        ArcherS
                                        #39
                                        @akbooer good to know it is recoverable, it seemed so also. I updated and will check the log and see what shows up. 🙂
                                          @ArcherS
                                          B Offline
                                          B Offline
                                          Buxton
                                          @akbooer And the below error is probably related to the string error:
                                          2021-04-17 13:48:51.407   openLuup.context_switch::  ERROR: [dev #0] attempt to call a string value
                                          2021-04-17 13:48:51.407   openLuup.mqtt:: ERROR publishing application message for mqtt:tele/power_BedroomTV/SENSOR : attempt to call a string value
                                            148.6k
