  3. Plugins
  4. openLuup: Tasmota MQTT Bridge
Plugins
openweather plugin ?
Plugins
Openluup: Datayours
Plugins
Plugins
zigbee2mqtt and openLuup
Plugins
Plugins
Sonos system alerts truncated
Well pretty sure I didn't change or touch anything! I've turned everything on and off again as one might hope. Excepting a total reboot of the Pi3 that's running all my stuff very reliably in openLuup. It's all been working well for years and now all of sudden 6 second alerts are truncated to about 4 seconds. Occasionally it works as it should. I see this in the log - does it help? 2023-02-20 09:39:06.662 luup_log:0: My Lua ver 0.50 debug: executing scene 63: "Check windows doors" in room: "Watchers" 2023-02-20 09:39:06.663 luup.call_action:: 217.urn:micasaverde-com:serviceId:Sonos1.Alert 2023-02-20 09:39:06.663 luup.call_action:: action will be handled by parent: 214 2023-02-20 09:39:06.663 luup_log:0: My Lua ver 0.50 debug: rest of scene 63 was executed 2023-02-20 09:39:06.663 luup.scenes:: scene 63, Check windows doors, initiated by AltUI 2023-02-20 09:39:06.665 luup_log:214: Sonos: Alert action on device 217 URI "http://redacted:3480/www/sounds/AllClosed.mp3" duration "6" 2023-02-20 09:39:06.758 luup_log:214: Sonos: UPnP_request (Pause, urn:schemas-upnp-org:service:AVTransport:1): status=1 statusMsg=500 result=[<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns="urn:schemas-upnp-org:control-1-0"><errorCode>701</errorCode></UPnPError></detail></s:Fault></s:Body></s:Envelope>] 2023-02-20 09:39:06.759 luup_log:214: stack traceback: ./L_SonosSystem1.lua:265: in function 'error' ./L_SonosUPnP.lua:289: in function <./L_SonosUPnP.lua:169> (tail call): ? ./L_SonosSystem1.lua:3390: in function 'sayOrAlert' ./L_SonosSystem1.lua:3452: in function 'queueAlert' ./L_SonosSystem1.lua:3843: in function <./L_SonosSystem1.lua:3839> (tail call): ? [C]: in function 'pcall' ./openLuup/scheduler.lua:204: in function 'context_switch' ./openLuup/scheduler.lua:366: in function 'dispatch' ./openLuup/scheduler.lua:588: in function 'task_callbacks' ./openLuup/scheduler.lua:699: in function 'start' openLuup/init.lua:354: in main chunk [C]: ? 2023-02-20 09:39:06.888 luup.variable_set:: 214.urn:toggledbits-com:serviceId:SonosSystem1.zoneInfo was: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... now: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... #hooks:0 2023-02-20 09:39:06.895 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.TransportState was: STOPPED now: TRANSITIONING #hooks:0 2023-02-20 09:39:06.901 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentPlayMode was: SHUFFLE_NOREPEAT now: NORMAL #hooks:0 2023-02-20 09:39:06.913 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTransportActions was: Set, Stop, Pause, Play, X_DLNA_SeekTime, Next, X_DLNA_SeekTrackNr now: Set, Stop, Pause, Play, X_DLNA_SeekTime, X_DLNA_SeekTrackNr #hooks:0 2023-02-20 09:39:06.921 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.NumberOfTracks was: 10 now: 1 #hooks:0 2023-02-20 09:39:06.922 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.AVTransportURI was: x-rincon-queue:RINCON_000E58DC7BBE01400#0 now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.929 luup_log:214: Sonos: UPnP_request() "urn:schemas-upnp-org:service:AVTransport:1"#"GetPositionInfo" action took 5.0073010921478s (long) 2023-02-20 09:39:11.932 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackDuration was: 0:02:22 now: 0:00:00 #hooks:0 2023-02-20 09:39:11.933 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackURI was: x-file-cifs://ELEPHANT1/Multimedia/My%20Music/Music%20JP/The%20Smiths/The%20Queen%20Is%20Dead/08%20Vicar%20in%20a%2... now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.934 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackMetaData was: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... now: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... #hooks:0 2023-02-20 09:39:11.936 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentStatus was: Vicar in a Tutu: (The Smiths, The Queen Is Dead) now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTitle was: Vicar in a Tutu now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentArtist was: The Smiths now: #hooks:0 2023-02-20 09:39:11.938 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentAlbum was: The Queen Is Dead now: #hooks:0 Also see these: 2023-02-24 16:12:13.576 openLuup.server:: GET /www/sounds/YouRang.mp3 HTTP/1.1 tcp{client}: 0x17e96f0 2023-02-24 16:12:13.579 openLuup.server:: error 'closed' sending 43102 bytes to tcp{client}: 0x17e96f0 So any clues?
Plugins
Generic support for vacuums
Plugins
Switchboard plugin
Plugins
Plugins
Plugins
Reactor scope issues
Plugins
Plugins
This topic has come up before but I haven't seen an answer. Symptom: AltuUI says there is a new update available, so you tell it to do the update but the update does not happen. AltUI remains stuck on it's old version. On other occasions it works OK. So my version is: AltUI v2.49.2546, © 2019 AltUI says this: a newer version #2551 of ALTUI is available, do you want to upgrade ? add scrollable dialog for long boxes bugfix: clock display on safari remote url update ( @olov ) update jquery and bootstrap versions credential to camera device url ( @rafale77 ) ignore Ezlo hub ( @reneboer) Track through the JavaScript and find that this issues the update command: function _triggerAltUIUpgrade(newversion,newtracnum) { var url = '?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version={1}&TracRev={0}'.format(newversion,newtracnum); return _httpGet(url,{}).always( function() { PageMessage.message(_T("Upgrade Request succeeded, a Luup reload will happen"),"success"); }); }; And the url variable equals: url: "?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551" All looks good so far. I manually issue the same url complete with my openLuup ip_address in a local browser. Update fails - looks like AltUI is doing as it should: http://ip_address:3480/data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551 In openLuup I see: 2021-12-06 13:56:14.821 luup_log:3: ALTUI: startupDeferred, called on behalf of device:3 2021-12-06 13:56:14.838 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.Version was: v2.49 now: v2.49 #hooks:0 And then later: 2021-12-06 13:55:58.256 openLuup.server:: GET /data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551 HTTP/1.1 tcp{client}: 0x25712a8 2021-12-06 13:55:58.257 luup.call_action:: 0.urn:micasaverde-com:serviceId:HomeAutomationGateway1.CreatePlugin 2021-12-06 13:55:58.259 luup.call_action:: 4.urn:upnp-org:serviceId:AltAppStore1.update_plugin 2021-12-06 13:55:58.260 luup_log:4: AltAppStore : starting <run> phase... 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : downloading amg0/ALTUI [2551] to trash/AltAppStore/ 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents?ref=2551 2021-12-06 13:55:58.760 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents/blockly?ref=2551 2021-12-06 13:55:59.543 luup_log:4: AltAppStore : getting contents of version: 2551 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine1 was: AltAppStore now: Downloading... #hooks:0 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: now: Alternate UI #hooks:0 2021-12-06 13:55:59.544 luup_log:4: AltAppStore : scheduling <job> phase... 2021-12-06 13:55:59.544 openLuup.requests:: 2021-12-06 13:55:59.545 openLuup.server:: request completed (148 bytes, 1 chunks, 1288 ms) tcp{client}: 0x25712a8 2021-12-06 13:55:59.554 openLuup.server:: request completed (6233 bytes, 1 chunks, 16442 ms) tcp{client}: 0x255e680 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : ...final <job> phase 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : Total size 0.000 (kB) 2021-12-06 13:55:59.555 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: Alternate UI now: Alternate UI 100% #hooks:0 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating icons in icons/ ... 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating device files in ./ ... 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 icon files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 device files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : Alternate UI update completed 2021-12-06 13:55:59.556 openLuup.luup:: device 4 'Alternate App Store' requesting reload 2021-12-06 13:55:59.556 luup.reload:: saving user_data 2021-12-06 13:56:00.262 openLuup.luup:: exiting with code 42 - after 0.3 hours All looks OK. Then I check GitHub. It shows the latest changes to the version 2551. However this page says the latest version is 2550. So I wondering what's going on. Seems the latest version number is not being picked by the installer? (not sure how it works.) Is it possible for openLuup to log a bit more about the version it's trying to install. As this call returns. https://api.github.com/repos/amg0/ALTUI/contents?ref=2551 message "No commit found for the ref 2551" documentation_url "https://docs.github.com/v3/repos/contents/" But this works fine: https://api.github.com/repos/amg0/ALTUI/contents?ref=2550 So it looks like AMG0 doesn't always update the repository with whatever is needed to get this to work (I imagine that's easy to forget). But could openLuup send back a fail result to AltUI and AltUI pick that up? Currently it looks like AltUI always assumes everything went OK. Or somehow; could openLuup log and/or notify the user what went wrong?
Plugins
Reactor: double click action
Plugins
Virtual Pronto Remote plugin
Plugins
openLuup: SmartSwitch plugin
Plugins
Reactor icons for local lan
Plugins
Plugins
AltUi
Plugins
127 Posts 5 Posters 99.0k Views 4 Watching
    @archers
    Because there’s infinite variety, I’ve not implemented any command/control from the Tasmota bridge.
    I could certainly add a device action to send a generic command with device_name and command parameters, or such like, if that helps.
    Edit: the alternative is to publish an MQTT message directly.
    ArcherS
    #61
    @akbooer I think that I could try publishing an Mqtt message directly first. A generic command could perhaps also be of use.
    The below text is edited after I got it to work by adding \ before the " so that it is passed trough as it should.
    I found this:
    local mqtt = luup.openLuup.mqtt
    mqtt.publish ("My/Topic/Name", "My Application message")
    For my simple test this works from Lua Code Test:
    cmnd/<device_name>/IrSend/ <rest of the message>
    e.g.
    luup.openLuup.mqtt.publish ("cmnd/TasmotaIR/IrSend","{\"Protocol\":\"NEC\",\"Bits\":32,\"Data\":\"0x10EF08F7\",\"DataLSB\":\"0x08F710EF\",\"Repeat\":0}")
    I will continue to try this for the HVAC, something like this:
    cmnd/<device_name>/IRhvac <rest of message>
    e.g.
    cmnd/TasmotaIR/IrSend/ {\"Vendor\":\"LG2\", \"Power\":\"On\",\"Mode\":\"Hot\",\"FanSpeed\":3,\"Temp\":22.5}
    • A ArcherS
      I found this:
      e.g.
      e.g.
      @archers
      Yes, that will work, although two alternatives are available to make the string handling easier...
      '{"Vendor":"LG2", "Power":"On", "Mode":"Hot", "FanSpeed":3, "Temp":22.5}'
      or
      [[{"Vendor":"LG2", "Power":"On", "Mode":"Hot", "FanSpeed":3, "Temp":22.5}]]
        @archers
        or
        ArcherS
        #63
        @akbooer thanks! Yes those do look a bit easier to use, I will try them. 🙂
        • A ArcherS
          @archers if you want virtual device, v3 beta of my Virtual Devices can send MQTT messages under openLuup, for attached and supported devices/actions.
            ArcherS
            #65
            @therealdb that sounds interesting! I will try that. 🙂
            Edit: I do not remember; how do I update to the v3 beta for the Virtual Devices plugin? Also I am a bit unsure how I can see the current version.
            I typed in "development" in the plugins table and it says "GitHub.development", should that do it?
            • A ArcherS
              @archers just download the files from GitHub or use alt appstore. Version should be visible in logs.
                ArcherS
                @therealdb when looking in github I cannot see the development branch. I can only see the master branch with mqtt, beta2.
                Not sure if I am doing something wrong though (quite possible).
                In my log it says "VirtualDevices[3.0-beta2@37]".
                • A ArcherS
                  @archers you’re good. No development branch, as it’s almost stable and only attached to openluup, since I’ll not update the Vera AppStore soon.
                    ArcherS
                    @therealdb I created a simple Virtual Binary Switch and it now has three Mqtt variables:
                    MQTT_BrightnessValue
                    MQTT_PowerStatusOff
                    MQTT_PowerStatusOn
                    I can see the format "topic/=/message" in the instructions, but I am clerarly missing something.
                    Do I need to define IP address etc in some other variable?
                    I tried to get it to work, but I do not get it right, no reaction in the Tasmota device console. How do I put e.g. the following into "MQTT_PowerStatusOn", i.e. to get the device to send this when it is powered on?
                    cmnd/TasmotaIR/IRhvac {"Vendor":"FUJITSU_AC","Model":1,"Mode":"Heat","Power":"On","Celsius":"On","Temp":20,"FanSpeed":"Auto","SwingV":"Off","SwingH":"Off","Quiet":"Off","Turbo":"Off","Econo":"Off","Light":"Off","Filter":"Off","Clean":"Off","Beep":"Off","Sleep":-1}
                    (Where the TasmotaIR has IP 192.168.1.59)
                    Sorry for the stupid questions. 😕
                    • A ArcherS
                      MQTT_PowerStatusOff
                      MQTT_PowerStatusOn
                      @archers no need to put ip or anything. Just push the mqtt message to the broker. In you case
                      cmnd/TasmotaIR/IRhvac/=/{"Vendor":"FUJITSU_AC","Model":1,"Mode":"Heat","Power":"On","Celsius":"On","Temp":20,"FanSpeed":"Auto","SwingV":"Off","SwingH":"Off","Quiet":"Off","Turbo":"Off","Econo":"Off","Light":"Off","Filter":"Off","Clean":"Off","Beep":"Off","Sleep":-1}
                        @archers
                        B Offline
                        B Offline
                        Buxton
                        @akbooer I tried to archive several MQTT values from devices by checking the variable's archive box in the historian cache console. When I reloaded the luup engine, the variables disappeared from the console UI. As well, the variables do not show up in the console UI on the historian database page.
                        • B Buxton
                          @buxton
                          Not obvious, but answered previously here...
                          https://smarthome.community/topic/313/historian/4?_=1620559885357
                          What variables are you trying to archive? From the Tasmota bridge, they’re likely to have special serviceIds. It should be easy enough to set up manually, anyway.
                          B 1 Reply Last reply
                            @buxton
                            B Offline
                            B Offline
                            Buxton
                            @akbooer humidity and temperature from Bluetooth sensors that talk to the tasmota device.
                            I'm saying above that the variables disappear--- completely from the UI-- not just the checkmark.
                              Yes, that’s expected. They won’t appear on that display until their value is updated.
                                ArcherS
                                @akbooer what I have seen is that in the "testing" release it seems as if the checkmarks in the Hstorian disappear, at east for me. When I check a variable the check is gone when I return to the Historian.
                                Despite this I have historical data when looking at a graph, e.g:
                                I have not connected my test Pi to Grafana, but I assume that if the graph in Historian contains data so should a graph in Grafana.
                                @Buxton what I have noticed is that Tasmota for BLE sometimes freezes, at least for me running the beta on an ESP32. It seems that it deliveres the same value every time over Mqtt, I assume that OpenLuup then acts on this and that is why the data is not there in Historian.
                                In fact when I read you report I checked my data for one of the BLE variables and it was gone. A restart of the Tasmota BLE device fixed that and now data is back.
                                  ArcherS
                                  @therealdb said in openLuup: Tasmota MQTT Bridge:
                                  I have tried this, but it seems not to work for some strange reason.
                                  I put the Mqtt message in the "MQTT_PowerStatusOn" variable but I do not get any Mqtt message in either the Tasmota Console or in Mqtt Explorer when toggling the device, I assume that it should react when doing that.
                                  Any ideas on what could be wrong?
                                  Just for comparison, when testing this in the Lua Code Test it works, so the messsage should be ok.
                                  luup.openLuup.mqtt.publish ("cmnd/TasmotaIR/IRhvac","{\"Vendor\":\"FUJITSU_AC\",\"Model\":1,\"Mode\":\"Heat\",\"Power\":\"On\",\"Celsius\":\"On\",\"Temp\":20,\"FanSpeed\":\"Auto\",\"SwingV\":\"Off\",\"SwingH\":\"Off\",\"Quiet\":\"Off\",\"Turbo\":\"Off\",\"Econo\":\"Off\",\"Light\":\"Off\",\"Filter\":\"Off\",\"Clean\":\"Off\",\"Beep\":\"Off\",\"Sleep\":-1}")
                                  therealdbT 2 Replies Last reply
                                  • A ArcherS
                                    @archers oh, my bad. This is to catch an event associated to on. If you want to trigger on, you should use the Standard on variable. Let me go back to my pc and I’ll post a working sample.
                                    • A ArcherS
                                      @archers so, to execute something when you turn a device ON, just add this as the SetPowerURL variable's value:
                                      mqtt://cmnd/TasmotaIR/IRhvac/=/{"Vendor":"FUJITSU_AC","Model":1,"Mode":"Heat","Power":"On","Celsius":"On","Temp":20,"FanSpeed":"Auto","SwingV":"Off","SwingH":"Off","Quiet":"Off","Turbo":"Off","Econo":"Off","Light":"Off","Filter":"Off","Clean":"Off","Beep":"Off","Sleep":-1}
                                      (Notice the mqtt:// prefix that I omitted from the docs - my bad).
                                      I've not implemented thermostats yet, but I could do it easily, grabbing some code from the heaters.
                                      A 2 Replies Last reply
                                        ArcherS
                                        @therealdb thanks, that works! 🙂
                                        A useful addition to the Mqtt setup in OpenLuup for sure.
                                        • A ArcherS
                                          #80
                                          @archers said in openLuup: Tasmota MQTT Bridge:
                                          Yes, this works even if the Historian is not archiving to disk. It maintains an in-memory cache of the 1000, or so, latest values for numeric variables.
                                          Not so. This cache is not available to Grafana, which requires an on-disk archive. This behaviour is described in some detail on pp.12–13 of the User Guide.
                                          @Buxton, you have two options:
                                          1. create the archive files manually (using the correct attributes.) Once they're there, the Historian will continue to write to them.
                                          2. Let me know the variable names (I'm assuming Temperature and Humidity?) and I will add them to the archive defaults.
                                          #2 is obviously the better option.
                                          A B 2 Replies Last reply
                                            148.6k
