  3. Vera/openLuup plugins
  4. Ezlo bridge error from new broadlink device
Logic Programming
Fork Mios VERASECURE
On start up the log indicates the following: 2023-12-19 10:17:12.588 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelTarget","",209) old value "" 2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelTarget","",209) old value "" 2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelStatus","",209) old value "" 2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelLast","",209) old value "" 2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","TurnOnBeforeDim","",209) old value "" 2023-12-19 10:17:12.590 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","AllowZeroLevel","",209) old value "" 2023-12-19 10:17:12.590 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:bochicchio-com:serviceId:VirtualBinaryLight1","SetBrightnessURL","",209) old value "" 2023-12-19 10:17:12.590 luup_log:209: VirtualDevices[3.0-beta7@209](initializeMqtt@421):initializeMqtt(209,{ PowerStatusOff={ Value="0", Service="urn:upnp-org:serviceId:SwitchPower1", Variable="Status" }, BrightnessValue={ Variable="LoadLevelStatus", Service="urn:upnp-org:serviceId:Dimming1" }, PowerStatusOn={ Value="1", Service="urn:upnp-org:serviceId:SwitchPower1", Variable="Status" } }) - openLuup: true 2023-12-19 10:17:12.591 luup_log:209: VirtualDevices[3.0-beta7@209](subscribeToMqtt@414):subscribeToMqtt(209,nil,{ deviceID=209, opts={ Value="0", Service="urn:upnp-org:serviceId:SwitchPower1", Variable="Status" } }) 2023-12-19 10:17:12.591 openLuup.context_switch:: ERROR: [dev #209] ./L_VirtualLibrary.lua:415: attempt to concatenate field 'topic' (a nil value) 2023-12-19 10:17:12.591 openLuup.scheduler:: job aborted : ./L_VirtualLibrary.lua:415: attempt to concatenate field 'topic' (a nil value) The MQTT variables are all set to "skip": MQTT_BrightnessValue MQTT_PowerStatusOff MQTT_PowerStatusOn However it looks like the code doesn't check for "skip" and executes the functions initializeMqtt() and subscribeToMqtt() disappearing into the weeds at that point as there is nothing to subscribe to. It would also be good if the code treated an empty string in the same way as it uses the key word "skip". It's not obvious that "skip" needs to be explicitly used.
RulesEngine
E
Netatmo – Oath2 login
Vera Alexa down?
Anyone else seeing issues with Vera TTS? All was working fine. I assumed the cookie had expired, but even having replaced it, and seeing that the .alexa.login file is aging (as I'd expect) No speech. I seem to be getting an odd timeout but no idea from where. Debian Bullseye, bare metal Good call from this morning: 2023-01-18 08:22:51.657 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a2345e8 2023-01-18 08:22:51.667 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e89df13d8 2023-01-18 08:22:51.668 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=31085221&MinimumDelay=50&output_format=json&_r=1674030171666 HTTP/1.1 tcp{client}: 0x563e89df13d8 2023-01-18 08:22:58.223 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a4ab388 2023-01-18 08:22:58.223 openLuup.server:: GET /data_request?Text=Rachel%20has%20arrived%20at%20Washtec&Language=en-GB&GroupZones=Everywhere&Volume=50&DeviceNum=22&id=action&serviceId=urn%3Abochicchio-com%3AserviceId%3AVeraAlexa1&action= Say&output_format=json&_r=1674030178221 HTTP/1.1 tcp{client}: 0x563e8a4ab388 2023-01-18 08:22:58.224 luup.call_action:: 22.urn:bochicchio-com:serviceId:VeraAlexa1.Say 2023-01-18 08:22:58.224 luup_log:22: VeraAlexa: addToQueue: added to queue for 22 2023-01-18 08:23:09.379 luup.variable_set:: 22.urn:bochicchio-com:serviceId:VeraAlexa1.LatestResponse was: sending cmd:speak:<s><lang xml:lang="en-UK"><amazon:domain name="conversational">The temperature outside is -3 degr... now: sendi ng cmd:speak:<s>Rachel has arrived at Washtec</s><break time="0s" /> to dev:Everywhere type:A3C9PE6TNYLTCH ser... #hooks:0 2023-01-18 08:23:09.381 openLuup.server:: request completed (29 bytes, 1 chunks, 11156 ms) tcp{client}: 0x563e8a4ab388 2023-01-18 08:23:09.391 luup.variable_set:: 25001.urn:micasaverde-com:serviceId:SecuritySensor1.Tripped was: 0 now: 1 #hooks:0 2023-01-18 08:23:09.391 luup.variable_set:: 25001.urn:micasaverde-com:serviceId:SecuritySensor1.LastTrip was: 1674030032 now: 1674030189 #hooks:0 2023-01-18 08:23:09.394 openLuup.server:: request completed (1389 bytes, 1 chunks, 31782 ms) tcp{client}: 0x563e897eefd8 2023-01-18 08:23:09.395 openLuup.server:: request completed (1389 bytes, 1 chunks, 31662 ms) tcp{client}: 0x563e8a7c5248 2023-01-18 08:23:09.396 openLuup.server:: request completed (1389 bytes, 1 chunks, 17728 ms) tcp{client}: 0x563e89df13d8 2023-01-18 08:23:09.396 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a4ab388 2023-01-18 08:23:09.411 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a13f3c8 2023-01-18 08:23:09.412 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a79f3c8 2023-01-18 08:23:09.412 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e89df13d8 2023-01-18 08:23:09.413 openLuup.server:: GET /data_request?newTargetValue=1&DeviceNum=20330&id=action&serviceId=urn%3Aupnp-org%3AserviceId%3ASwitchPower1&action=SetTarget&output_format=json&_r=1674030189410 HTTP/1.1 tcp{client}: 0x563e 8a13f3c8 2023-01-18 08:23:09.413 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=31085224&MinimumDelay=50&output_format=json&_r=1674030189411 HTTP/1.1 tcp{client}: 0x563e8a79f3c8 2023-01-18 08:23:09.413 luup.call_action:: 20330.urn:upnp-org:serviceId:SwitchPower1.SetTarget 2023-01-18 08:23:09.413 luup.call_action:: action will be handled by parent: 37 2023-01-18 08:23:09.413 luup.variable_set:: 20330.urn:upnp-org:serviceId:SwitchPower1.Target was: 1 now: 1 #hooks:0 2023-01-18 08:23:09.449 openLuup.server:: request completed (35 bytes, 1 chunks, 36 ms) tcp{client}: 0x563e8a13f3c8 2023-01-18 08:23:09.461 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a13f3c8 2023-01-18 08:23:09.564 openLuup.server:: request completed (819 bytes, 1 chunks, 151 ms) tcp{client}: 0x563e8a79f3c8 2023-01-18 08:23:09.569 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a79f3c8 2023-01-18 08:23:09.581 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a32bf28 Bad request from just now: 2023-01-18 18:29:26.695 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x557239889e58 2023-01-18 18:29:26.696 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=66503545&MinimumDelay=50&output_format=json&_r=1674066566691 HTTP/1.1 tcp{client}: 0x557239889e58 2023-01-18 18:29:26.799 openLuup.server:: request completed (833 bytes, 1 chunks, 2249 ms) tcp{client}: 0x557239a62f78 2023-01-18 18:29:26.911 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=66503545&Timeout=60&MinimumDelay=1500&_=1674030721531 HTTP/1.1 tcp{client}: 0x5572385f78d8 2023-01-18 18:29:27.028 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x557238b98c58 2023-01-18 18:29:27.029 openLuup.server:: GET /data_request?Text=Testing...1...2...3&Language=en-GB&GroupZones=Everywhere&Volume=50&DeviceNum=22&id=action&serviceId=urn%3Abochicchio-com%3AserviceId%3AVeraAlexa1&action=Say&output_format=json&_r=1674066567027 HTTP/1.1 tcp{client}: 0x557238b98c58 2023-01-18 18:29:27.029 luup.call_action:: 22.urn:bochicchio-com:serviceId:VeraAlexa1.Say 2023-01-18 18:29:27.029 luup_log:22: VeraAlexa: addToQueue: added to queue for 22 2023-01-18 18:29:43.149 openLuup.server:: error 'closed' sending 4 bytes to tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.150 openLuup.server:: ...only 0 bytes sent 2023-01-18 18:29:43.150 openLuup.server:: error 'closed' sending 29 bytes to tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.150 openLuup.server:: ...only 0 bytes sent 2023-01-18 18:29:43.150 openLuup.server:: error 'closed' sending 2 bytes to tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.150 openLuup.server:: ...only 0 bytes sent 2023-01-18 18:29:43.150 openLuup.server:: error 'closed' sending 5 bytes to tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.150 openLuup.server:: ...only 0 bytes sent 2023-01-18 18:29:43.150 openLuup.server:: request completed (29 bytes, 1 chunks, 16121 ms) tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.153 luup_log:63: BroadLink_Mk2 debug: RM3 Mini - IR 1: device is not a sensor or if a sensor; is not coded for 2023-01-18 18:29:43.153 luup_log:63: BroadLink_Mk2 debug: RM3 Mini - IR 1: veraId: 64, blId: a0:43:b0:8b:e0:e5, altId: a0:43:b0:8b:e0:e5_ir 2023-01-18 18:29:43.153 luup_log:63: BroadLink_Mk2 debug: RM3 Mini - IR 1: urn:schemas-micasaverde-com:device:IrTransmitter:1 2023-01-18 18:29:43.154 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=66503545&Timeout=60&MinimumDelay=1500&_=1674066518681 HTTP/1.1 tcp{client}: 0x557239a62f78 2023-01-18 18:29:43.155 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.157 openLuup.server:: request completed (591 bytes, 1 chunks, 16460 ms) tcp{client}: 0x557239889e58 2023-01-18 18:29:43.161 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x557239889e58 2023-01-18 18:29:43.175 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x5572399f30e8 2023-01-18 18:29:43.176 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=66503545&MinimumDelay=50&output_format=json&_r=1674066583172 HTTP/1.1 tcp{client}: 0x5572399f30e8 2023-01-18 18:29:57.979 luup.variable_set:: 20380.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 22 now: 21 #hooks:0 Any thoughts? Cheers C
Device issues in Open Luup
Broadlink setup
Virtual Sensor Polling
10 Posts 2 Posters 2.5k Views 1 Watching
  • ElcidE Offline
    ElcidE Offline
    Elcid
    wrote on last edited by Elcid
    Hi Rene @mrFarmer just thought i would let you know that the new broadlink app from Ezlo causes an error in log, It does not stop the bridge.
    here is the log
    luup.variable_set:: 24.urn:rboer-com:serviceId:EzloBridge1.Ezlo_deviceMap was: {"603a8896122335165e686cb3":29,"5fe26c71122335120f05323e":23,"603a8896122335165e686cb7":30,"5fd354fc12233516e1e0c3b... now: {"603a8896122335165e686cb3":29,"5fe26c71122335120f05323e":23,"603a8896122335165e686cb7":30,"603a869b122335165e686cb... #hooks:0
    2021-04-14 20:15:47.641   luup_log:24: EzloBridge_error: No device found for device id 32.
    2021-04-14 20:15:47.642   luup_log:24: EzloBridge_error: No device found for device id 32.
    2021-04-14 20:15:47.643   luup_log:24: var.SetString: wrong data type (number) for variable TamperAlarm
    2021-04-14 20:15:47.644   luup_log:24: creating device numbers: [20016,20029,20023,20009,20021,20030,20031]
    2021-04-14 20:15:47.645   luup_log:24: linking to remote scenes...
    2021-04-14 20:15:47.645   luup.variable_set:: 24.urn:upnp-org:serviceId:altui1.DisplayLine1 was: Getting devices and scenes... now: 7 devices, 4 scenes #hooks:0
    2021-04-14 20:15:47.646   luup.variable_set:: 24.urn:upnp-org:serviceId:altu
    Tried excluding the device but not sure what number to put tried 32 and the longer ezlo device id, but caused ezlo bridge to fail.
      mrFarmer
      Hi @Elcid,
      As the broadlink is a plugin I have no idea what it looks like or supports. Can you send me the hub.data.list output from the api tool? You can scrub it for all your other devices if you want. The full command is :
      {"method":"hub.data.list","id":"552919ee943241","params":{"items":{"fields":{"include":["name","deviceId","hasGetter","hasSetter","valueType","scale","value","valueFormatted"]}},"rooms":{"fields":{"include":["name","parent_id"]}},"scenes":{"fields":{"include":["name"]}},"devices":{"fields":{"include":["name","category","subcategory","info","batteryPowered","parentDeviceId","roomId","armed","status","reachable"]}}}}
      BTW, If you go into the Android app, and open the device 'details' do you then see some settings (lock/unlock I expect looking at the code)? I try to get that to work for my own plugins and the Ezlo FW team says it is because of the app it does not work, and the app team does not seem to know what I am talking about.
      • ElcidE Offline
        ElcidE Offline
        Elcid
        Hi
          "api": "1.0",
          "error": null,
          "id": "552919ee943241",
          "method": "hub.data.list",
          "result": {
            "devices":
              "6059aab5122335123a08b973": {
                "batteryPowered": false,
                "category": "ir_tx",
                "info": {
                  "device_type": "10026",
                  "mac": "34:ea:34:c7:84:35",
                  "manufacturer": "Broadlink",
                  "name": "智能遥控"
                "name": "RM pro lounge",
                "parentDeviceId": "",
                "reachable": true,
                "roomId": "5ef5af2412233516de1adb91",
                "status": "idle",
                "subcategory": "irt"
            "items":
              "6059aab5122335123a08b974": {
                "deviceId": "6059aab5122335123a08b973",
                "hasGetter": false,
                "hasSetter": true,
                "name": "learn_ir_code",
                "value": 0,
                "valueFormatted": "0",
                "valueType": "int"
              "6059aab5122335123a08b975": {
                "hasGetter": false,
                "hasSetter": true,
                "name": "send_ir_code",
                "value": "",
                "valueFormatted": "",
                "valueType": "string"
            "rooms": {
              "5ef5af2412233516de1adb91": {
                "name": "lounge"
            "scenes": {
              "6059add11223351287ebc34f": {
                "name": "open lounge blind"
              "6059ae021223351287ebc350": {
                "name": "close lounge blind"
              "6059c4db1223351287ebc357": {
                "name": "lounge colour on"
              "6059c5001223351287ebc358": {
                "name": "lounge colour off"
        all the scenes are from broadlink plugin
        @mrfarmer said in Ezlo bridge error from new broadlink device:
        No sign of any lock/unlock, if i am looking in correct place.
          mrFarmer
          Thanks. The category ir_tx is not supported by the bridge, so it does not store the device ID. When processing the items, it finds the two, but the device ID is not stored, hence the log messages. Not sure what I can/should make of the device. Replicating what the app does for it is probably not trivial, especially as I have no idea what it does. Do you get a scene for each IR code you learned? You can bridge the scenes and run those from openLuup. (al though it has been a while I tested that)
          Not seeing the setting aligns with what the Ezlo FW team is saying that the app is not yet supporting it. I'll tease them a bit with that. Maybe it helps getting the app inline with the FW. For some odd reason they see them as independent and own development priorities.
          Cheers Rene
          ElcidE 1 Reply Last reply
          • M mrFarmer
            Cheers Rene
            ElcidE Offline
            ElcidE Offline
            Elcid
            No, I may have confused you there. You get a code in the broadlink device. In the device you can add more codes. I then created scenes with no triggers to run The codes. You would think that the broadlink app should create scenes for you on the fly, but I donn'tt think Ezlo upper manmagement think outside the box.
            I just updated the vera app as i was behind but still no lock unlock in the device settings.
            As to error in log, not really an issue as it does not break the bridge and error only occurs at startup.
            Do you know why when I tried excluding device 32 in the bridge variables that it caused the bridge to crash. I forgot to to save the log entry, so if you want it I can exclude device 32 again.
            "I'll tease them a bit with that."
            Not to much there are some sensitive types in the company.
              mrFarmer
              Aha. I did have the idea it was not a very complete functional plugin. There is simply no functionality for that yet.
              The plugin should not crash if you exclude a device, maybe it does because it is not storing the device as it does not know how to handle. I must admit I did not spend a lot of time testing the include/exclude devices as I should have. If a day only had 48 hours 😉
              I do the teasing in the direct skype groups with the developers. I typically get ignored when I do, but they have not kicked me out (yet).
              Cheers Rene
              • ElcidE Offline
                ElcidE Offline
                Elcid
                Here is the error from excluding device 32
                1-04-15 18:11:05.670   openLuup.scheduler:: [5] VeraBridge device startup completed: status=true, msg=OK, name=VeraBridge
                2021-04-15 18:11:05.670   openLuup.scheduler:: [24] Ezlo Bridge device startup
                2021-04-15 18:11:05.683   luup_log:24: var.GetSet: empty data value for variable IncludeDevices
                2021-04-15 18:11:05.684   openLuup.context_switch::  ERROR: [dev #24] [string "L_EzloBridge.lua"]:227: attempt to index global 's' (a nil value)
                2021-04-15 18:11:05.684   openLuup.scheduler:: job aborted : [string "L_EzloBridge.lua"]:227: attempt to index global 's' (a nil value)
                2021-04-15 18:11:05.685   openLuup.scheduler:: [4] Alternate App Store device startup
                  mrFarmer
                  Thx, I'll add it to the backlog 🙂
                    mrFarmer
                    Hi @Elcid,
                    Just uploaded V2.6 of the EzloBridge. There is a new tab where you can select the devices to bridge by either a whitelist or blacklist. The first you can use to bridge only a few, the latter to bridge most but a few. After upgrade it defaults to bridging all. On a new install it will default to whitelist with no devices selected. I.e. you first have to configure bridging before devices get created.
                    Let me know what you think.
                    Cheers Rene
                    • ElcidE Offline
                      ElcidE Offline
                      Elcid
                      Hi just installed, the exclude is working fine, no errors and device 32 error has gone.
                      Typo on new Bridge tab (missing d).
                      Nice that name and device Id are there, makes it easy to find device id's.
                      Cheers.
                      p.s. Hopefully Ezlo will Add functionality for the new broad link, as would be nice to get direct access to action the remote code direct from OpenLuup. No need to then set up scenes.(but as you say only if 48hours in a days)
                      Once again thank You.
                      [edit]
                      looking for error on new openluup i see this
                      2021-04-26 21:39:40.835   openLuup.server:: request completed (1 bytes, 1 chunks, 148 ms) tcp{client}: 0xfbb4878
                      2021-04-26 21:39:41.139   luup_log:24: EzloBridge_error: Unknown Ezlo device 603a8896122335165e686cb7.
                      2021-04-26 21:39:41.141   luup.variable_set:: 24.urn:rboer-com:serviceId:EzloBridge1.Ezlo_sceneMap was: {"6080413e122335172526162a":18,"6059c4db1223351287ebc357":14,"6059c5001223351287ebc358":15,"6080416a122335172526162... now: {"6059c5001223351287ebc358":15,"6059c4db1223351287ebc357":14,"6080413e122335172526162a":18,"6080416a122335172526162... #hooks:0
                      2021-04-26 21:39:41.142   luup_log:24: var.SetString: wrong data type (number) for variable TamperAlarm
                      2021-04-26 21:39:41.143   luup_log:24: creating device numbers: [20016,20023,20009,20021]
                      2021-04-26 21:39:41.144   luup_log:24: linking to remote scenes...
                      the device number matches one of the excluded devices, which is a child device of a motion sensor, specifically a light sensor.
                      21-04-26 21:46:27.389   openLuup.server:: request completed (12682 bytes, 1 chunks, 112 ms) tcp{client}: 0xffb3ea8
                      2021-04-26 21:46:28.274   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=469583451&Timeout=60&MinimumDelay=1500&_=1619469578508 HTTP/1.1 tcp{client}: 0xffb3ea8
                      2021-04-26 21:46:35.332   luup_log:24: EzloBridge_error: Device 6059aab5122335123a08b973 is not mapped to Vera device.
                      2021-04-26 21:46:37.534   openLuup.server:: request completed (3601 bytes, 1 chunks, 9254 ms) tcp{client}: 0xffb3ea8
                      2021-04-26 21:46:38.275   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=469583452&Timeout=60&MinimumDelay=1500&_=1619469578509 HTTP/1.1 tcp{client}: 0xffb3ea8
                      2021-04-26 21:46:53.029   openLuup.server:: request completed (3601 bytes, 1 chunks, 14750 ms) tcp{client}: 0xffb3ea8
                      Which is the excluded broadlink device.
                        147.1k
