  4. Creating Rules with Conditional Logic
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
12 Posts 6 Posters 3.5k Views 6 Watching
  • K Offline
    K Offline
    kidhasmoxy
    How are folks handling situations where they want to have Conditional Actions or Branching Logic in their Set Reactions for a rule? Are you creating Duplicating the same trigger and setting different conditions and Actions?
    Is there an approach where you combine a main rule with your entity triggers with sub rules that trigger off Expressions? You then could write your conditions as Set Variable actions in the Main Rule for the Expressions that evaluate to true or false. Each sub rule would trigger based on the expression changing to true and then could also change it back to false after.
    Not sure if that's worth the complexity for the reusability and control over duplicate triggers.
      Maybe an example? I'll try to offer one, and a solution.
      Motion controlled light. When there's motion during the day, light A on 100%, light B on 100%. When there's motion during the night, light A on 100%, light B on 50%. So you might think "if motion then do A=100 and then if day do B=100 otherwise do B=50"
      Rule "Motion":
      • Entity Attribute condition checks motion sensor is tripped.
      Rule "Day Motion":
      • Rule condition check "Motion" rule set/true
      • Entity Attribute condition checks reactor_system.suninfo.period == "day"
      • ACTION: Turn on light A 100%
      • ACTION: Turn on light B 100%
      Rule "Night Motion"
      • Entity Attribute condition checks reactor_system.suninfo.period <> "day"
      • ACTION: Turn on light B 50%
      The suninfo checks could also be seen as Constraints.
        This ties into (possibly) nicely to something I was just wondering about, having taking note of some of this thread:
        I have a security set up that we arm at night as part of our house shutdown process. When it arms it announces on all Alexas that this is happening. Likewise in the morning when we tell the house to wake up it announces on all Veras that the system is disarmed.
        So far so good
        However new behaviour from Mrs C's cat is to wake me up every 30 minutes from about 0130 until 0500 to be let out.
        This necessitated a new control for the security system (sans everything else that the wake up does) but of course that then screams from every Alexa both the arm and disarm.
        Soooo.
        I have changed things. Removed the announcement from the arm and disarm and use those to trigger 4 more rules:
        Armed in hours > loud Vera everywhere
        Armed OOH > very quiet Vera in the kitchen only
        Disarmed in hours > loud Vera everywhere
        Disarmed OOH > very quiet Vera in the kitchen only.
        All is well with the world but I now have 12 rules in Reactor (6 of which are unused being the 'false' sate)
        Is there a better way of doing this?
        Cheers
        F K 2 Replies Last reply
          So far so good
          Soooo.
          Cheers
          @catmanv2 . I have solved this by the color of a Hue lamp. If the house is armed, this light goes red, otherwise it´s bright white light. Then it only needs to be 1 rule; true/false = red/white light.
          The only trouble is where to put the light in the house... 🙂
            So far so good
            Soooo.
            Cheers
            K Offline
            K Offline
            kidhasmoxy
            @catmanv2 this is the exact type of situation that I’m thinking of. Also have an automation that alerts me when the power sensor for my washer goes between different ranges so I know what stage it’s in.
            @toggledbits are you thinking of making a native condition action? I don’t know about Vera, but the automation engines in Hubitat and Home Assistant both have this capability and it makes a big difference.
            cw-kidC toggledbitsT 2 Replies Last reply
            • F Fanan
              @fanan said in Creating Rules with Conditional Logic:
              Thanks 🙂 Won't quite solve my issue though as armed is not the false of 'disarmed' There's some sensors to check and so on as well
              • K kidhasmoxy
                @kidhasmoxy said in Creating Rules with Conditional Logic:
                Plus one here for this.
                Currently I've used LUA code called in the Reaction / action to then do further conditional checks of things.
                • K kidhasmoxy
                  I don't know what this means
                  K 1 Reply Last reply
                    K Offline
                    K Offline
                    kidhasmoxy
                    @toggledbits The 3 graphical rules engines I've use the most are Home Assistant Automations, Hubitat Rule Machine, and webcore (supports SmartThings and Hubitat.)
                    All have the notion of using conditions to decide which actions execute after the rule is triggered. This allows you to reduce the number of rules you need and avoid dealing with managing rule dependencies.
                    Supporting this approach makes it easier to migrate from any one (or in this case, all) of those solutions.
                    Documentation from Hubitat:
                    https://docs.hubitat.com/index.php?title=Rule-4.0#Rule-4.0_Conditional_Actions_and_Logical_Expressions
                    Here's an example from Home Assistant:
                    Example from Webcore
                    Example from Hubitat:
                      For me the Rule sets Contraints are the main conditions of the rule.
                      If those conditions are met then the Reaction / actions should be fired.
                      However within those actions there are some scenarios where further conditional checks need to be made.
                      Only way to do this currently in MSR is to create two or more rules or have LUA code on the single rules Reaction carry out those further conditions.
                          I think this topic gets addressed nicely by the new CONSTRAINT GROUPS feature introduced back in rev. 21117.
                            163.9k
