  4. Stumbling toward a working MSR...
Edit: Fixed in re-spun 26328. (I just gave my old Ezlo Plus a new chance so it's running my z-wave devices in my garage, for evaluation, as my even older Vera Secure had issues reaching that far when some router nodes gave up). Bare metal latest-26328 Issue 1: Nodes don't update in Reactor after update from 26318. Issue 2: Also present in earlier builds, rooms don't add to DGC and throws error at start. Notice: No device mapping matches Intrusion Sensor. I don't know if you still support EzloController but seems like an easy fix? Let me know if you need more info! [latest-26328]2026-11-25T11:18:31.310Z <Controller:NOTICE> Controller HassController#hass is now online. [latest-26328]2026-11-25T11:18:31.313Z <EzloController:ERR> [TypeError] Cannot read properties of undefined (reading 'clear') [-] failed to process rooms: [undefined2] [latest-26328]2026-11-25T11:18:31.313Z <EzloController:CRIT> TypeError: Cannot read properties of undefined (reading 'clear') [-] TypeError: Cannot read properties of undefined (reading 'clear') at EzloController._process_hub_rooms (/home/homebridge/reactor/server/lib/EzloController.js:1558:153) at /home/homebridge/reactor/server/lib/EzloController.js:1388:48 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.314Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.452Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.585Z <EzloController:ERR> EzloController#ezlo error creating entity Switch#ezlo>device_6b02d1d9129e0715b720f005: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.585Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.588Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d41d129e0715b720f012: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.588Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.590Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d41e129e0715b720f01c") -- skipped [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d9d9129e0715b720f01f: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.591Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d9da129e0715b720f029") -- skipped [latest-26328]2026-11-25T11:18:31.682Z <EzloController:INFO> EzloController#ezlo hub inventory complete/successful; 2159ms [latest-26328]2026-11-25T11:18:31.684Z <Controller:NOTICE> Controller EzloController#ezlo is now online.
Edit: Fixed in 26328. Bare metal latest-26318. I tried to add the group "ArmedSensors" but it would not show in UI. "ArmedSensors": name: Armed Sensors select: - include_capability: arming filter_expression: entity.attributes.arming.state The log: [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Nothing related before or after that I could find. I then copied an existing group to exclude type errors in the new group. "OKforLarm": name: OK för Larm select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state "OKforLarm2": name: "OK för Larm 2" select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state Same error in log. [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group OKforLarm2: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Let me know if I missed something or you need more info.
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
13 Posts 2 Posters 3.1k Views 3 Watching
  • Tom_DT Offline
    Tom_DT Offline
    Tom_D
    I have some experience with Linux from about 30 years ago and my first thought was to install MSR in a QNAP TS-251+ Debian container. That did not go well as at every step it seemed I needed to add components to the OS to move forward one step. I got so frustrated I ordered a RPi which comes tomorrow. I have tried a few container Linux versions and gotten the furthest with CentOS.
    MSR is running but complains about the system time being different from the MSR time. MSR is at my correct local time but the container OS is not. All the searching says that datetimectl is the program to run but I get an error about file or folder being incorrect. As long as MSR is at the correct time is that enough?
    latest-25082-3c348de6
      Trying to decode... did you not just use the pre-built generic amd64 container? You probably should not be building an OS container and then trying to run Reactor within it.
      • Tom_DT Offline
        Tom_DT Offline
        Tom_D
        There is an import button with the QNAP Container Station but it only imports from the NAS or the local computer and I could not figure out how to get the toggledbits/reactor:latest-generic-amd64 file to my local computer so I tried the Bare-Metal build on containers running various Linux versions.
          I'm not a QNAP user/owner but from what I was able to see in some searching, where you search for packages in Container Station (at Create Container), if you do a search for "Reactor" it should give you a list of QNAP-recommended results, which will be nothing of course because they nothing about MSR, but there should be a "Docker Hub" tab you can click, and it should be listed there as toggledbits/reactor.
          Ref: https://youtu.be/yblN8XabE1M?t=201 (watch from marked start to 3:57)
            After that, your next challenge is to get all the container settings right. For the container to work, it needs:
            1. Network operating mode
            2. Environment variables
            3. Volumes mounted
            Working from the Create Container dialog, leave Auto Start on and most of the other defaults; it doesn't appear like anything needs to be changed (we'll find out if that's right or not)... click Advanced Settings to get to the good stuff.
            In Advanced Settings, go to Network and select "Bridge" "Host".
            On the Environment tab, you will need to set TZ to your timezone, selecting from this list (try not to use the red ones). You may find some other environment variables already set up (e.g. REACTOR_HOME=/opt/reactor, REACTOR_DATA_PREFIX=/var/reactor) -- DO NOT change these (ever). The only one you should set/change is TZ.
            On the Shared Folder tab, you will need to map the container's /var/reactor directory to a subdirectory on the NAS (which you must create) to store MSR's configuration and data files. So the "Volume from host" is the directory you create, and the "Mount Point" must be exactly /var/reactor, and both read and write must be enabled.
            You should then be able to start the container. You should immediately observe that the directory you created for config and data is populated with some folders and files. You should then be able to access the UI by going to http://assigned-ip-address:8111/
            • Tom_DT Offline
              Tom_DT Offline
              Tom_D
              It is a good thing containers don't cost anything.
              I tried TZ=-800 and TZ=America/Los_Angeles and neither worked so I checked the QNAP box time and it was off by a bit and not updating so I fixed that and the Reactor status error is gone.
              The network setting for the container is Host. NAT and Bridge did not work.
              The top file share line did not work but the second one did.
              All seems to be working now so I can start learning MSR.
              Thanks for the help.
              • Tom_DT Tom_D
                @tom_d said in Stumbling toward a working MSR...:
                Not sure what you mean here. I think you are seeing things that I cannot (no QNAP, just working from docs and YT vids).
                Can you screen shot and post all of your "Advanced Settings"? I'll use that info to update the docs.
                Tom_DT 3 Replies Last reply
                  Tom_DT Offline
                  Tom_DT Offline
                  Tom_D
                  2-Reactor  Pick the correct reactor.png 3-amd64  Get this version.png 4-noliability.png 1-Create Search for reactor.png 2-Reactor  Pick the correct reactor.png 3-amd64  Get this version.png 4-noliability.png Step1-Create shared folder.png
                    Tom_DT Offline
                    Tom_DT Offline
                    Tom_D
                    @toggledbits 5b-create  Select Advanced settings before hitting create.png 6-ENV Add TZ.png 7-Device No changes..png 5a-create  Select Advanced settings before hitting create.png 5b-create  Select Advanced settings before hitting create.png 6-ENV Add TZ.png 7-Device No changes..png 8-Share  Create shared folder before starting container creation.  See Step1.png
                      Tom_DT Offline
                      Tom_DT Offline
                      Tom_D
                      @toggledbits OK. I think all the images are here. They are numbered with comments as part of the names. I can send you a zip file if that helps at all.
                      10-Summary - hit OK.png 11-Overview.png 9-Share  hit the create button.png 10-Summary - hit OK.png 11-Overview.png 12-container.png
                      • Tom_DT Offline
                        Tom_DT Offline
                        Tom_D
                        Updating MSR in a QNAP container is a bit of a process. The container needs to be stopped and then the image deleted in GUI. Create a new container will all the same settings as the original and you should get the new image.
                          Yes, seems to be a limitation of the QNAP GUI. On Synology, for example, one can re-download the image, "clear" the existing container, and then restart it, and the container starts from the updated image. The QNAP limitation seems to be widely discussed (lots of search results), but little in terms of solutions other than what you are doing. There is one reference I found to the GUI creating a docker-compose file in a special location on the NAS, which would theoretically make it possible to do command line update using docker pull and some other (unknown) commands, but not having a QNAP NAS, it's not something I can dig into. A later part of the discussion suggested this compose file is no longer created/used, but again, I can't verify any of that.
                          Ref: https://github.com/qnap-dev/container-apps/issues/53
                          • Tom_DT Offline
                            Tom_DT Offline
                            Tom_D
                            Once you have been through the process a few times it goes pretty fast. I'll get more practice as versions of MSR are released.
                              165.5k
