  3. Vera/openLuup plugins
  4. OpenSprinkler Plugin Timer Keeps Resetting
Logic Programming
Fork Mios VERASECURE
On start up the log indicates the following: 2023-12-19 10:17:12.588 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelTarget","",209) old value "" 2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelTarget","",209) old value "" 2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelStatus","",209) old value "" 2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelLast","",209) old value "" 2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","TurnOnBeforeDim","",209) old value "" 2023-12-19 10:17:12.590 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","AllowZeroLevel","",209) old value "" 2023-12-19 10:17:12.590 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:bochicchio-com:serviceId:VirtualBinaryLight1","SetBrightnessURL","",209) old value "" 2023-12-19 10:17:12.590 luup_log:209: VirtualDevices[3.0-beta7@209](initializeMqtt@421):initializeMqtt(209,{ PowerStatusOff={ Value="0", Service="urn:upnp-org:serviceId:SwitchPower1", Variable="Status" }, BrightnessValue={ Variable="LoadLevelStatus", Service="urn:upnp-org:serviceId:Dimming1" }, PowerStatusOn={ Value="1", Service="urn:upnp-org:serviceId:SwitchPower1", Variable="Status" } }) - openLuup: true 2023-12-19 10:17:12.591 luup_log:209: VirtualDevices[3.0-beta7@209](subscribeToMqtt@414):subscribeToMqtt(209,nil,{ deviceID=209, opts={ Value="0", Service="urn:upnp-org:serviceId:SwitchPower1", Variable="Status" } }) 2023-12-19 10:17:12.591 openLuup.context_switch:: ERROR: [dev #209] ./L_VirtualLibrary.lua:415: attempt to concatenate field 'topic' (a nil value) 2023-12-19 10:17:12.591 openLuup.scheduler:: job aborted : ./L_VirtualLibrary.lua:415: attempt to concatenate field 'topic' (a nil value) The MQTT variables are all set to "skip": MQTT_BrightnessValue MQTT_PowerStatusOff MQTT_PowerStatusOn However it looks like the code doesn't check for "skip" and executes the functions initializeMqtt() and subscribeToMqtt() disappearing into the weeds at that point as there is nothing to subscribe to. It would also be good if the code treated an empty string in the same way as it uses the key word "skip". It's not obvious that "skip" needs to be explicitly used.
RulesEngine
E
Netatmo – Oath2 login
Vera Alexa down?
Anyone else seeing issues with Vera TTS? All was working fine. I assumed the cookie had expired, but even having replaced it, and seeing that the .alexa.login file is aging (as I'd expect) No speech. I seem to be getting an odd timeout but no idea from where. Debian Bullseye, bare metal Good call from this morning: 2023-01-18 08:22:51.657 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a2345e8 2023-01-18 08:22:51.667 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e89df13d8 2023-01-18 08:22:51.668 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=31085221&MinimumDelay=50&output_format=json&_r=1674030171666 HTTP/1.1 tcp{client}: 0x563e89df13d8 2023-01-18 08:22:58.223 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a4ab388 2023-01-18 08:22:58.223 openLuup.server:: GET /data_request?Text=Rachel%20has%20arrived%20at%20Washtec&Language=en-GB&GroupZones=Everywhere&Volume=50&DeviceNum=22&id=action&serviceId=urn%3Abochicchio-com%3AserviceId%3AVeraAlexa1&action= Say&output_format=json&_r=1674030178221 HTTP/1.1 tcp{client}: 0x563e8a4ab388 2023-01-18 08:22:58.224 luup.call_action:: 22.urn:bochicchio-com:serviceId:VeraAlexa1.Say 2023-01-18 08:22:58.224 luup_log:22: VeraAlexa: addToQueue: added to queue for 22 2023-01-18 08:23:09.379 luup.variable_set:: 22.urn:bochicchio-com:serviceId:VeraAlexa1.LatestResponse was: sending cmd:speak:<s><lang xml:lang="en-UK"><amazon:domain name="conversational">The temperature outside is -3 degr... now: sendi ng cmd:speak:<s>Rachel has arrived at Washtec</s><break time="0s" /> to dev:Everywhere type:A3C9PE6TNYLTCH ser... #hooks:0 2023-01-18 08:23:09.381 openLuup.server:: request completed (29 bytes, 1 chunks, 11156 ms) tcp{client}: 0x563e8a4ab388 2023-01-18 08:23:09.391 luup.variable_set:: 25001.urn:micasaverde-com:serviceId:SecuritySensor1.Tripped was: 0 now: 1 #hooks:0 2023-01-18 08:23:09.391 luup.variable_set:: 25001.urn:micasaverde-com:serviceId:SecuritySensor1.LastTrip was: 1674030032 now: 1674030189 #hooks:0 2023-01-18 08:23:09.394 openLuup.server:: request completed (1389 bytes, 1 chunks, 31782 ms) tcp{client}: 0x563e897eefd8 2023-01-18 08:23:09.395 openLuup.server:: request completed (1389 bytes, 1 chunks, 31662 ms) tcp{client}: 0x563e8a7c5248 2023-01-18 08:23:09.396 openLuup.server:: request completed (1389 bytes, 1 chunks, 17728 ms) tcp{client}: 0x563e89df13d8 2023-01-18 08:23:09.396 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a4ab388 2023-01-18 08:23:09.411 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a13f3c8 2023-01-18 08:23:09.412 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a79f3c8 2023-01-18 08:23:09.412 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e89df13d8 2023-01-18 08:23:09.413 openLuup.server:: GET /data_request?newTargetValue=1&DeviceNum=20330&id=action&serviceId=urn%3Aupnp-org%3AserviceId%3ASwitchPower1&action=SetTarget&output_format=json&_r=1674030189410 HTTP/1.1 tcp{client}: 0x563e 8a13f3c8 2023-01-18 08:23:09.413 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=31085224&MinimumDelay=50&output_format=json&_r=1674030189411 HTTP/1.1 tcp{client}: 0x563e8a79f3c8 2023-01-18 08:23:09.413 luup.call_action:: 20330.urn:upnp-org:serviceId:SwitchPower1.SetTarget 2023-01-18 08:23:09.413 luup.call_action:: action will be handled by parent: 37 2023-01-18 08:23:09.413 luup.variable_set:: 20330.urn:upnp-org:serviceId:SwitchPower1.Target was: 1 now: 1 #hooks:0 2023-01-18 08:23:09.449 openLuup.server:: request completed (35 bytes, 1 chunks, 36 ms) tcp{client}: 0x563e8a13f3c8 2023-01-18 08:23:09.461 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a13f3c8 2023-01-18 08:23:09.564 openLuup.server:: request completed (819 bytes, 1 chunks, 151 ms) tcp{client}: 0x563e8a79f3c8 2023-01-18 08:23:09.569 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a79f3c8 2023-01-18 08:23:09.581 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a32bf28 Bad request from just now: 2023-01-18 18:29:26.695 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x557239889e58 2023-01-18 18:29:26.696 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=66503545&MinimumDelay=50&output_format=json&_r=1674066566691 HTTP/1.1 tcp{client}: 0x557239889e58 2023-01-18 18:29:26.799 openLuup.server:: request completed (833 bytes, 1 chunks, 2249 ms) tcp{client}: 0x557239a62f78 2023-01-18 18:29:26.911 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=66503545&Timeout=60&MinimumDelay=1500&_=1674030721531 HTTP/1.1 tcp{client}: 0x5572385f78d8 2023-01-18 18:29:27.028 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x557238b98c58 2023-01-18 18:29:27.029 openLuup.server:: GET /data_request?Text=Testing...1...2...3&Language=en-GB&GroupZones=Everywhere&Volume=50&DeviceNum=22&id=action&serviceId=urn%3Abochicchio-com%3AserviceId%3AVeraAlexa1&action=Say&output_format=json&_r=1674066567027 HTTP/1.1 tcp{client}: 0x557238b98c58 2023-01-18 18:29:27.029 luup.call_action:: 22.urn:bochicchio-com:serviceId:VeraAlexa1.Say 2023-01-18 18:29:27.029 luup_log:22: VeraAlexa: addToQueue: added to queue for 22 2023-01-18 18:29:43.149 openLuup.server:: error 'closed' sending 4 bytes to tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.150 openLuup.server:: ...only 0 bytes sent 2023-01-18 18:29:43.150 openLuup.server:: error 'closed' sending 29 bytes to tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.150 openLuup.server:: ...only 0 bytes sent 2023-01-18 18:29:43.150 openLuup.server:: error 'closed' sending 2 bytes to tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.150 openLuup.server:: ...only 0 bytes sent 2023-01-18 18:29:43.150 openLuup.server:: error 'closed' sending 5 bytes to tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.150 openLuup.server:: ...only 0 bytes sent 2023-01-18 18:29:43.150 openLuup.server:: request completed (29 bytes, 1 chunks, 16121 ms) tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.153 luup_log:63: BroadLink_Mk2 debug: RM3 Mini - IR 1: device is not a sensor or if a sensor; is not coded for 2023-01-18 18:29:43.153 luup_log:63: BroadLink_Mk2 debug: RM3 Mini - IR 1: veraId: 64, blId: a0:43:b0:8b:e0:e5, altId: a0:43:b0:8b:e0:e5_ir 2023-01-18 18:29:43.153 luup_log:63: BroadLink_Mk2 debug: RM3 Mini - IR 1: urn:schemas-micasaverde-com:device:IrTransmitter:1 2023-01-18 18:29:43.154 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=66503545&Timeout=60&MinimumDelay=1500&_=1674066518681 HTTP/1.1 tcp{client}: 0x557239a62f78 2023-01-18 18:29:43.155 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.157 openLuup.server:: request completed (591 bytes, 1 chunks, 16460 ms) tcp{client}: 0x557239889e58 2023-01-18 18:29:43.161 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x557239889e58 2023-01-18 18:29:43.175 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x5572399f30e8 2023-01-18 18:29:43.176 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=66503545&MinimumDelay=50&output_format=json&_r=1674066583172 HTTP/1.1 tcp{client}: 0x5572399f30e8 2023-01-18 18:29:57.979 luup.variable_set:: 20380.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 22 now: 21 #hooks:0 Any thoughts? Cheers C
Device issues in Open Luup
Broadlink setup
Virtual Sensor Polling
15 Posts 2 Posters 3.3k Views 2 Watching
    Hello @therealdb with your OpenSprinkler plugin occasionally when I set a zone for an amount of time lets say 10 minutes, something happens and the counter for 10 minutes counts down 5 seconds to 9:55 then it resets back to 10 minutes. This continues to repeat so the zone will stay on for an infinite amount of time. In my experience this usually happens once the plugin has been running for about a day (ie no recent Luup reloads). I grabbed some logs but it doesn't seem to show anything weird happening. This issue does not happen when I set a zone timer through the OpenSprinkler app. Oddly enough when I stop the zone through the OpenSprinkler app when the timer keeps resetting, the same zone gets queued right away. It seems that the plugin is sending the start zone command every 5 ish seconds.
    50	06/07/21 19:19:00.469	luup_log:1304: VeraOpenSprinkler[1.50](setVar@135): setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelTarget","9",1310) old value "11" <0x6b8fe520>
    06	06/07/21 19:19:00.469	Device_Variable::m_szValue_set device: 1310 service: urn:upnp-org:serviceId:Dimming1 variable: LoadLevelTarget was: 11 now: 9 #hooks: 0 upnp: 0 skip: 0 v:0x16fabd8/NONE duplicate:0 <0x6b8fe520>
    50	06/07/21 19:19:00.480	luup_log:1304: VeraOpenSprinkler[1.50](setVar@135): setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelLast","9",1310) old value "11" <0x6b8fe520>
    06	06/07/21 19:19:00.481	Device_Variable::m_szValue_set device: 1310 service: urn:upnp-org:serviceId:Dimming1 variable: LoadLevelLast was: 11 now: 9 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x6b8fe520>
    50	06/07/21 19:19:00.482	luup_log:1304: VeraOpenSprinkler[1.50](setVar@135): setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelStatus","9",1310) old value "11" <0x6b8fe520>
    06	06/07/21 19:19:00.482	Device_Variable::m_szValue_set device: 1310 service: urn:upnp-org:serviceId:Dimming1 variable: LoadLevelStatus was: 11 now: 9 #hooks: 0 upnp: 0 skip: 0 v:0x16fac40/NONE duplicate:0 <0x6b8fe520>
    50	06/07/21 19:19:00.494	luup_log:1304: VeraOpenSprinkler[1.50](setVar@135): setVar("urn:upnp-org:serviceId:SwitchPower1","Target","1",1310) old value "1" <0x6b8fe520>
    50	06/07/21 19:19:00.495	luup_log:1304: VeraOpenSprinkler[1.50](actionPowerInternal@785): [actionPower] #1310 - 5 <0x6b8fe520>
    50	06/07/21 19:19:00.495	luup_log:1304: VeraOpenSprinkler[1.50](sendDeviceCommand@254): sendDeviceCommand("cm",{ 1="en=1", 2="t=540", 3="sid=5", 4="pid=-1", 5="uwt=0" },1304) <0x6b8fe520>
    50	06/07/21 19:19:00.496	luup_log:1304: VeraOpenSprinkler[1.50](sendDeviceCommand@276): sendDeviceCommand - url: "http://192.168.8.225:80/cm?en=1&t=540&sid=5&pid=-1&uwt=0&pw=a6d82bced638de3def1e9bbb4983225c" <0x6b8fe520>
    50	06/07/21 19:19:00.556	luup_log:1304: VeraOpenSprinkler[1.50](nil@214): [HttpGet] "http://192.168.8.225:80/cm?en=1&t=540&sid=5&pid=-1&uwt=0&pw=a6d82bced638de3def1e9bbb4983225c" - "{\"result\":1}" <0x6b8fe520>
    50	06/07/21 19:19:00.557	luup_log:1304: VeraOpenSprinkler[1.50](setVar@135): setVar("urn:upnp-org:serviceId:SwitchPower1","Status","1",1310) old value "1" <0x6b8fe520>
    50	06/07/21 19:19:00.557	luup_log:1304: VeraOpenSprinkler[1.50](deviceMessage@244): deviceMessage(1310,"Turning on for 540 seconds",false,15) <0x6b8fe520>```
      @pabla what firmware are you running? I’ve never tested with 7.32 and maybe I need to further debug it. I’m sorry for the problem you’ll seeing.
      PablaP 1 Reply Last reply
        @therealdb running the latest 7.32 beta. I’ve had this problem I think since the beginning of this plug-in, reported it once but at the time it happened too randomly. It’s still hard to figure out when it happens exactly
          Hi @therealdb have you gotten a chance to see if you can reproduce the same issue I am having?
          therealdbT 2 Replies Last reply
            @pabla not yet. I’m busy atm, but I’ll look at this over the weekend.
              @pabla I can't repro at the moment, but I'll leave my test Vera plugged in for a day or two and try again.
              I've tracked the room part, and it should be fixed by setting "Configured" variable on the master to 0 and wait for reload. I've also found that programs are re-created in this condition, so I'll investigate this part.
                @therealdb Hm that's odd you're not able to reproduce this, I can continually reproduce it now. What model OpenSprinkler are you running?
                  @pabla latest one, I’m not sure about the exact model. Please send me some variables (dms are ok) and more logs. It should be something related to your setup and I could replicate it with the exact code. Also, are you running it on the latest 7.32 beta build?
                    wrote on last edited by Pabla
                    @therealdb Here are the variables, I will probably send you the logs via Github or something since I can't attach a file in PM on the forums. Yes I am on the latest 7.32 build. c211e229-c392-4a9c-81d6-18b571b6ea0f-image.png
                      I have also been seeing this in the logs when the Opensprinkler controller isnt responding to any commands from the Vera
                      50 06/21/21 8:45:48.103 luup_log:1304: VeraOpenSprinkler[1.50]: [updateFromController] error: false - nil - nil <0x72581520>
                        @pabla the error is just giving a notice that the controller is not reachable. I’ll take a deeper look tomorrow and see what’s possible to fix.
                          Okay so aside from the counter resetting issue, I have also noticed that the first zone that I start it will default to a 1 minute run no matter what I do. Then once that 1 min run is complete the zone is queued to complete the remaining amount of the run. Ie if I set the zone to 25 mins, it will first run for 1 minute then queue to run 24 mins a bit later. After that the all the zones are unresponsive. This is all happening on the plug-in side, the OpenSprinkler app works just fine even when all this weird stuff is happening. I can definitely pull some logs later today, hoping a reload doesn’t happen in between since that is what usually temporarily fixes the issue.
                            Attached some logs on a new issue on Github, the logs show two zones with the counter resetting after 5 seconds. One small thing I have noticed in the OpenSprinkler app is when the counter set at XX:59 seconds it doesn't reset but when it set at XX:00 it resets
                              @pabla sorry for the long wait, I've been very busy at work lately. Anyway, I've just released hotfix 2, with an attempt to fix it. The problem maybe related to the fact that I was resetting the load level to 0 when less than 1 minute was left, and this may cause something strange with the device on the Vera. It seems to work OK on my test Vera Edge, but it's not easy to replicate this bug, so please try this new version and let me know. only the lua file was changed.
                                So I have been testing the plugin and seems like the issue has been resolved, will update if I catch it happening again. Thanks again 🙂
                                  152.5k
