  4. Have the lights turn on - don't work
7 Posts 3 Posters 1.5k Views 3 Watching
  • F Offline
    Hi!
    If I use the "before sunset" with a -30 min offset, it won't trigger my lights to turn on at that time. It says "SET since HH:MM". But it didn't. If I trigger it manually, it works as expected. Is there something I'm missing?
      Change before to after like this:
      • toggledbitsT Online
        toggledbitsT Online
        Click on the rule to open its status and watch what it's doing.
        It also looks like you have some option set on your sunset condition. What is that?
        F 1 Reply Last reply
          @toggledbits. I also have a virtual switch connected, as a trigger. If I want to activate the reaction sooner than the sunset condition, I tell the Google assistant to activate the virtual switch (as part of a routine). Therefore the condtion is "OR" and not "AND".
          • F Fanan
            toggledbitsT Online
            toggledbitsT Online
            @fanan That's not what I'm asking. This yellow highlight (see below) indicates that you have an option set on the condition. Open the options pane and describe what setting you are using.
            And to reiterate, you should be looking at the status view for the rule as your first diagnostic action when your logic isn't performing as expected. Click the icon next to the rule name as shown here:
              wrote on last edited by Fanan
              @toggledbits. I see that I've at some point, tried to use the Pulse function:
              I have now changed that, to "Follow (default)". I was grasping...
              Looking forward to see if it works tonight.
              /Fanan
              • F Offline
                I just want to update you guys, that all worked well last night. My lights turned on as expected!
                  159.5k
