  4. Support for Ezlo Atom controllers?
(I just gave my old Ezlo Plus a new chance so it's running my z-wave devices in my garage, for evaluation, as my even older Vera Secure had issues reaching that far when some router nodes gave up). Bare metal latest-26328 Issue 1: Nodes don't update in Reactor after update from 26318. Issue 2: Also present in earlier builds, rooms don't add to DGC and throws error at start. Notice: No device mapping matches Intrusion Sensor. I don't know if you still support EzloController but seems like an easy fix? Let me know if you need more info! [latest-26328]2026-11-25T11:18:31.310Z <Controller:NOTICE> Controller HassController#hass is now online. [latest-26328]2026-11-25T11:18:31.313Z <EzloController:ERR> [TypeError] Cannot read properties of undefined (reading 'clear') [-] failed to process rooms: [undefined2] [latest-26328]2026-11-25T11:18:31.313Z <EzloController:CRIT> TypeError: Cannot read properties of undefined (reading 'clear') [-] TypeError: Cannot read properties of undefined (reading 'clear') at EzloController._process_hub_rooms (/home/homebridge/reactor/server/lib/EzloController.js:1558:153) at /home/homebridge/reactor/server/lib/EzloController.js:1388:48 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.314Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.452Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.585Z <EzloController:ERR> EzloController#ezlo error creating entity Switch#ezlo>device_6b02d1d9129e0715b720f005: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.585Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.588Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d41d129e0715b720f012: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.588Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.590Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d41e129e0715b720f01c") -- skipped [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d9d9129e0715b720f01f: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.591Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d9da129e0715b720f029") -- skipped [latest-26328]2026-11-25T11:18:31.682Z <EzloController:INFO> EzloController#ezlo hub inventory complete/successful; 2159ms [latest-26328]2026-11-25T11:18:31.684Z <Controller:NOTICE> Controller EzloController#ezlo is now online.
Edit: Fixed in 26328. Bare metal latest-26318. I tried to add the group "ArmedSensors" but it would not show in UI. "ArmedSensors": name: Armed Sensors select: - include_capability: arming filter_expression: entity.attributes.arming.state The log: [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Nothing related before or after that I could find. I then copied an existing group to exclude type errors in the new group. "OKforLarm": name: OK för Larm select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state "OKforLarm2": name: "OK för Larm 2" select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state Same error in log. [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group OKforLarm2: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Let me know if I missed something or you need more info.
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
51 Posts 3 Posters 20.6k Views 3 Watching
    Fix the case on your NODE_PATH value so it matches the actual case of every element of the directory path and give it a try.
    F 1 Reply Last reply
      wrote on last edited by Fanan
      #22
      I've tried and tried - but I can't get it to work (getting the Ezlo Plus to work in MSR). I've several times tried every step. I use the Windows 10 bare metal install (reactor-latest-21221-4a447cb).
      I have repeatedly used:
      npm install --loglevel error --no-save
      set NODE_PATH=D:\reactor
      All cases are correct.
      This is what I get:
      2021-08-12T17:45:38.541Z <Controller:CRIT> Controller: failed to load ezlo implementation file:///D:/reactor/server/lib/EzloController.js: Error: Cannot find module 'server/lib/Configuration'
      Require stack:
      - D:\reactor\server\lib\EzloController.js
      2021-08-12T17:45:38.542Z <Controller:CRIT> Error: Cannot find module 'server/lib/Configuration'
      Require stack:
      Require stack:
          at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:15)
          at Function.Module._load (node:internal/modules/cjs/loader:778:27)
          at Module.require (node:internal/modules/cjs/loader:1005:19)
          at require (node:internal/modules/cjs/helpers:94:18)
          at Object.<anonymous> (D:\reactor\server\lib\EzloController.js:506:144)
          at Module._compile (node:internal/modules/cjs/loader:1101:14)
          at Object.Module._extensions..js (node:internal/modules/cjs/loader:1153:10)
          at Module.load (node:internal/modules/cjs/loader:981:32)
          at Function.Module._load (node:internal/modules/cjs/loader:822:12)
          at ModuleWrap.<anonymous> (node:internal/modules/esm/translators:201:29)
      Require stack:
          at ModuleWrap.<anonymous> (node:internal/modules/esm/translators:201:29) {
        code: 'MODULE_NOT_FOUND',
        requireStack: [ 'D:\\reactor\\server\\lib\\EzloController.js' ]
      I do have the files that's MSR is asking for (eg. D:\reactor\server\lib\EzloController.js). So it's so strange! Do you know what could be wrong?
      Best regards,
      /Fanan
        Working for me:
        C:\Users\Patrick\Documents\MSR>set NODE_PATH=C:\Users\Patrick\Documents\MSR
        C:\Users\Patrick\Documents\MSR>node app.js
        basedir C:\Users\Patrick\Documents\MSR
        confdir C:\Users\Patrick\Documents\MSR\config
        datadir C:\Users\Patrick\Documents\MSR\storage
        logsdir C:\Users\Patrick\Documents\MSR\logs
        plugindir C:\Users\Patrick\Documents\MSR\ext
        module.paths [
          'C:\\Users\\Patrick\\Documents\\MSR\\node_modules',
          'C:\\Users\\Patrick\\Documents\\node_modules',
          'C:\\Users\\Patrick\\node_modules',
          'C:\\Users\\node_modules',
          'C:\\node_modules'
        NODE_PATH C:\Users\Patrick\Documents\MSR
        2021-08-12T18:39:38.096Z <app:null> Reactor ###BUILDVERSION### starting on v14.15.5
        2021-08-12T18:39:38.097Z <app:INFO> Process ID 26416; platform win32/x64 Windows 10 Pro
        2021-08-12T18:39:38.099Z <app:INFO> Basedir C:\Users\Patrick\Documents\MSR; data in C:\Users\Patrick\Documents\MSR\storage
        2021-08-12T18:39:38.099Z <app:INFO> NODE_PATH C:\Users\Patrick\Documents\MSR; module paths [ "C:\\Users\\Patrick\\Documents\\MSR\\node_modules", "C:\\Users\\Patrick\\Documents\\node_modules", "C:\\Users\\Patrick\\node_modules", "C:\\Users\\node_modules", "C:\\node_modules" ]
        2021-08-12T18:39:38.100Z <app:INFO> process.env=[object Object]
        2021-08-12T18:39:38.100Z <app:INFO> process.env.TEST=(undefined)
        2021-08-12T18:39:38.145Z <Plugin:null> Module Plugin v21173
        2021-08-12T18:39:38.152Z <default:INFO> Module Entity v21177
        2021-08-12T18:39:38.155Z <Controller:null> Module Controller v21191
        2021-08-12T18:39:38.156Z <default:null> Module Structure v21216
        2021-08-12T18:39:38.162Z <default:null> Module Ruleset v21096
        2021-08-12T18:39:38.162Z <default:null> Module Rulesets v21096
        2021-08-12T18:39:38.181Z <default:null> Module Rule v21221
        2021-08-12T18:39:38.185Z <default:null> Module Engine v21213
        2021-08-12T18:39:38.186Z <default:null> Module httpapi v21215
        2021-08-12T18:39:38.189Z <default:null> Module httpproxy v21054
        2021-08-12T18:39:38.209Z <default:null> Module wsapi v21196
        2021-08-12T18:39:38.212Z <app:NOTICE> Starting Structure...
        2021-08-12T18:39:38.214Z <Structure:NOTICE> Structure#1 plugin ID influx disabled; skipping
        2021-08-12T18:39:38.216Z <Structure:INFO> Structure#1 starting controller interface ezlo (EzloController)
        2021-08-12T18:39:38.220Z <Structure:INFO> Structure#1 starting controller interface reactor_system (SystemController)
        2021-08-12T18:39:38.249Z <default:null> Module EzloController v21218
        2021-08-12T18:39:38.251Z <default:null> Module SystemController v21102
        2021-08-12T18:39:38.254Z <EzloController:null> EzloController#ezlo created, config { "source": "wss://192.168.0.67:17000", "serial": "900xxxxx", "username": "xxxxx", "password": "xxxxx", "auto_rediscover": false }
        2021-08-12T18:39:38.255Z <EzloController:null> EzloController#ezlo instance log level (null) (4)
        2021-08-12T18:39:38.269Z <Controller:INFO> EzloController#ezlo device mapping data loaded; checking...
        2021-08-12T18:39:38.272Z <Controller:INFO> EzloController#ezlo performing cloud auth to get local access token
        2021-08-12T18:39:38.324Z <Controller:NOTICE> Controller SystemController#reactor_system is now online.
        2021-08-12T18:39:38.395Z <app:INFO> Structure running; pausing for controllers' initial ready
        2021-08-12T18:39:39.934Z <Controller:INFO> EzloController#ezlo cloud auth phase complete (local access token acquired)
        2021-08-12T18:39:39.936Z <Controller:INFO> EzloController#ezlo opening local hub connection to "900xxxxx" at wss://192.168.0.67:17000
        2021-08-12T18:39:39.938Z <Controller:NOTICE> EzloController#ezlo configured to ignore host ("900xxxxx") certificate
        2021-08-12T18:39:39.940Z <Controller:NOTICE> EzloController#ezlo connecting via WS to wss://192.168.0.67:17000
        2021-08-12T18:39:40.038Z <Controller:NOTICE> EzloController#ezlo successful hub login; performing inventory
        2021-08-12T18:39:40.227Z <Controller:INFO> EzloController#ezlo data load complete; 21 devices received, 26 entities registered; 66 items.
        2021-08-12T18:39:40.227Z <Controller:INFO> EzloController#ezlo hub inventory complete/successful; 187ms
        2021-08-12T18:39:40.229Z <Controller:NOTICE> Controller EzloController#ezlo is now online.
        2021-08-12T18:39:40.231Z <app:NOTICE> Starting Reaction Engine...
        2021-08-12T18:39:40.233Z <Engine:INFO> Reaction Engine starting
        2021-08-12T18:39:40.234Z <Engine:INFO> Checking rule sets...
        2021-08-12T18:39:40.237Z <Engine:INFO> Checking rules...
        2021-08-12T18:39:40.237Z <Engine:INFO> Data check complete; no corrections.
        2021-08-12T18:39:40.240Z <Engine:NOTICE> Reaction Engine running!
        2021-08-12T18:39:40.241Z <app:NOTICE> Starting HTTP server and API...
        2021-08-12T18:39:40.245Z <app:NOTICE> Startup complete
        2021-08-12T18:39:40.249Z <httpapi:NOTICE> HTTP API v1 21215 base URL http://192.168.0.164:8111; listening
        2021-08-12T18:39:40.258Z <app:NOTICE> HTTP server running; registering proxy endpoints.
        2021-08-12T18:39:40.259Z <app:NOTICE> Starting WSAPI...
        2021-08-12T18:39:40.260Z <wsapi:NOTICE> wsapi: starting version 21196
        2021-08-12T18:39:40.343Z <Engine:INFO> Engine#1 master timer tick, local time "8/12/2021, 2:39:40 PM" (TZ offset -240 mins from UTC)
        Your snippets don't show the current startup information, which would be useful. Make sure that NODE_PATH appears with the correct value in the startup messages, as shown in the log above.
        Also works under PowerShell:
        PS C:\Users\Patrick\Documents\MSR> $env:NODE_PATH = 'C:\Users\Patrick\Documents\MSR'
        PS C:\Users\Patrick\Documents\MSR> node app.js
        module.paths [
          'C:\\node_modules'
        2021-08-12T18:45:56.225Z <app:null> Reactor ###BUILDVERSION### starting on v14.15.5
        2021-08-12T18:45:56.226Z <app:INFO> Process ID 25296; platform win32/x64 Windows 10 Pro
        2021-08-12T18:45:56.227Z <app:INFO> Basedir C:\Users\Patrick\Documents\MSR; data in C:\Users\Patrick\Documents\MSR\storage
        2021-08-12T18:45:56.227Z <app:INFO> NODE_PATH C:\Users\Patrick\Documents\MSR; module paths [ "C:\\Users\\Patrick\\Documents\\MSR\\node_modules", "C:\\Users\\Patrick\\Documents\\node_modules", "C:\\Users\\Patrick\\node_modules", "C:\\Users\\node_modules", "C:\\node_modules" ]
        2021-08-12T18:45:56.228Z <app:INFO> process.env=[object Object]
        2021-08-12T18:45:56.228Z <app:INFO> process.env.TEST=(undefined)
        2021-08-12T18:45:56.271Z <Plugin:null> Module Plugin v21173
        2021-08-12T18:45:56.279Z <default:INFO> Module Entity v21177
        2021-08-12T18:45:56.282Z <Controller:null> Module Controller v21191
        2021-08-12T18:45:56.283Z <default:null> Module Structure v21216
        2021-08-12T18:45:56.287Z <default:null> Module Ruleset v21096
        2021-08-12T18:45:56.287Z <default:null> Module Rulesets v21096
        2021-08-12T18:45:56.303Z <default:null> Module Rule v21221
        2021-08-12T18:45:56.310Z <default:null> Module Engine v21213
        2021-08-12T18:45:56.310Z <default:null> Module httpapi v21215
        2021-08-12T18:45:56.312Z <default:null> Module httpproxy v21054
        2021-08-12T18:45:56.332Z <default:null> Module wsapi v21196
        2021-08-12T18:45:56.334Z <app:NOTICE> Starting Structure...
        2021-08-12T18:45:56.338Z <Structure:NOTICE> Structure#1 plugin ID influx disabled; skipping
        2021-08-12T18:45:56.339Z <Structure:INFO> Structure#1 starting controller interface ezlo (EzloController)
        2021-08-12T18:45:56.344Z <Structure:INFO> Structure#1 starting controller interface reactor_system (SystemController)
        2021-08-12T18:45:56.370Z <default:null> Module EzloController v21218
        2021-08-12T18:45:56.372Z <default:null> Module SystemController v21102
        2021-08-12T18:45:56.375Z <EzloController:null> EzloController#ezlo created, config { "source": "wss://192.168.0.67:17000", "serial": "900xxxxx", "username": "xxxxx", "password": "xxxxx", "auto_rediscover": false }
        2021-08-12T18:45:56.375Z <EzloController:null> EzloController#ezlo instance log level (null) (4)
        2021-08-12T18:45:56.385Z <Controller:INFO> EzloController#ezlo device mapping data loaded; checking...
        2021-08-12T18:45:56.386Z <Controller:INFO> EzloController#ezlo performing cloud auth to get local access token
        2021-08-12T18:45:56.441Z <Controller:NOTICE> Controller SystemController#reactor_system is now online.
        2021-08-12T18:45:56.518Z <app:INFO> Structure running; pausing for controllers' initial ready
        2021-08-12T18:45:59.726Z <Controller:INFO> EzloController#ezlo cloud auth phase complete (local access token acquired)
        2021-08-12T18:45:59.727Z <Controller:INFO> EzloController#ezlo opening local hub connection to "900xxxxx" at wss://192.168.0.67:17000
        2021-08-12T18:45:59.727Z <Controller:NOTICE> EzloController#ezlo configured to ignore host ("900xxxxx") certificate
        2021-08-12T18:45:59.729Z <Controller:NOTICE> EzloController#ezlo connecting via WS to wss://192.168.0.67:17000
        2021-08-12T18:45:59.823Z <Controller:NOTICE> EzloController#ezlo successful hub login; performing inventory
        2021-08-12T18:46:00.006Z <Controller:INFO> EzloController#ezlo data load complete; 21 devices received, 26 entities registered; 66 items.
        2021-08-12T18:46:00.006Z <Controller:INFO> EzloController#ezlo hub inventory complete/successful; 182ms
        2021-08-12T18:46:00.007Z <Controller:NOTICE> Controller EzloController#ezlo is now online.
        2021-08-12T18:46:00.008Z <app:NOTICE> Starting Reaction Engine...
        2021-08-12T18:46:00.009Z <Engine:INFO> Reaction Engine starting
        2021-08-12T18:46:00.009Z <Engine:INFO> Checking rule sets...
        2021-08-12T18:46:00.012Z <Engine:INFO> Checking rules...
        2021-08-12T18:46:00.012Z <Engine:INFO> Data check complete; no corrections.
        2021-08-12T18:46:00.016Z <Engine:NOTICE> Reaction Engine running!
        2021-08-12T18:46:00.017Z <app:NOTICE> Starting HTTP server and API...
        2021-08-12T18:46:00.022Z <app:NOTICE> Startup complete
        2021-08-12T18:46:00.026Z <httpapi:NOTICE> HTTP API v1 21215 base URL http://192.168.0.164:8111; listening
        2021-08-12T18:46:00.039Z <app:NOTICE> HTTP server running; registering proxy endpoints.
        2021-08-12T18:46:00.040Z <app:NOTICE> Starting WSAPI...
        2021-08-12T18:46:00.042Z <wsapi:NOTICE> wsapi: starting version 21196
        2021-08-12T18:46:00.123Z <Engine:INFO> Engine#1 master timer tick, local time "8/12/2021, 2:46:00 PM" (TZ offset -240 mins from UTC)
          Working for me:
          module.paths [
            'C:\\node_modules'
          module.paths [
            'C:\\node_modules'
          #24
          Thanks! I now seem to have overcome the NODE_PATH.... So the next problem arise. I now get a message related to the Ezlo plus: "... ezlo failed to authenticate: Error: Request failed: 404 NOT FOUND."
          I did a screenshot, so that I could easily hide my credentials. I have used my username as I use for both my Vera and Ezlo. I have checked them over and over - and they are correct. Is it something connected to the " "? Or what could it be?
          The last lines are:
          2021-08-13T12:04:13.950Z <Controller:ERR> EzloController#ezlo failed to authenticate: Error: Request failed: 404 NOT FOUND
          2021-08-13T12:04:13.951Z <Controller:ERR> EzloController#ezlo failed to log in: auth failed
          2021-08-13T12:04:15.034Z <VeraController:NOTICE> Controller VeraController#vera is now online.
          2021-08-13T12:04:18.963Z <Controller:INFO> EzloController#ezlo performing cloud auth to get local access token
          2021-08-13T12:04:19.460Z <Controller:ERR> EzloController#ezlo failed to authenticate: Error: Request failed: 404 NOT FOUND
          2021-08-13T12:04:19.461Z <Controller:ERR> EzloController#ezlo failed to log in: auth failed
          2021-08-13T12:04:24.470Z <Controller:INFO> EzloController#ezlo performing cloud auth to get local access token
          2021-08-13T12:04:24.955Z <Controller:ERR> EzloController#ezlo failed to authenticate: Error: Request failed: 404 NOT FOUND
          2021-08-13T12:04:24.956Z <Controller:ERR> EzloController#ezlo failed to log in: auth failed
            #25
            Username or password is incorrect. The "NOT FOUND" it is referring to is you.
              I also thought so. But it's not incorrect. I even tried to create another user profile. The profile is able to log in to Vera/Ezlo. But when I use the profiles credentials, I get the same error. I changed between my true profile and the test profile - and always get the same result. So it's more to the story.
              This is from my yaml file. I guess it looks alright?
                #27
                Are there any special characters in the password, like international characters? Also what region are you in?
                • F Offline
                  #28
                  Yes, there is a @ in my password. I'm in Europe/Sweden.
                  Vera/Ezlo has these demands on the passwords:
                  Password must be at least 8 characters long and include:
                  • at least one lowercase letter;
                  • at least one special character;
                  • uppercase letters or numbers.
                    Is your username capitalized?
                      Yes. Everywhere.
                        OK. That's probably it. Try creating an account with an all lower-case username. Password is fine.
                        • F Offline
                          Thanks! It worked! Finally after so many hours.... 😊 It was the low-case username that did the trick!
                          Have a great weekend Patrick!
                          /Fanan
                            Excellent news. That's a bug I can fix, so I'll make sure that's in the next build and you can use your username the way you want it to be.
                              #34
                              "Note that Generation 1 Atoms are supported in this version, but only through the remote access API (so it's cloud-dependent). Gen2 and later Atoms/PlugHubs can run with local/LAN access (no cloud dependency)."
                              Did you hear back from the Ezlo devs with the needed information for this? Or have you just gone ahead and used the learned knowledge from the forum ?
                              My Atom is now at firmware version 0.8.539. However I am not totally sure if its a gen1 or gen2 Atom? I think its gen2 but not sure.
                              Its still not appearing in the MSR Entities area however.
                              I have tried with "set_anonymous_access: true" commented out and not commented out in the reactor.yaml file.
                              I can't see anything in the MSR log to do with the Atom controller only the Ezlo Plus controller.
                                I have heard nothing from the eZLO devs on anything. That's business as usual. Everything I've done, everything that everyone has done, in this respect has been done based on hearsay and tribal knowledge, no specifications or documentation from eZLO. May stop working at any time.
                                Sounds like you have a Gen1 atom. You have to configure for cloud/remote access, it doesn't switch back and forth automatically. That involves just commenting out the source field. If the source field is not present, then the EzloController uses remote access to get to the device. But, there's bug that leaked in the remote access login that I just fixed. Are you on a docker container or bare metal install?
                                The set_anonymous_access field is not available for Atom and PlugHub; it is not supported on these platforms.
                                  #36
                                  Bare metal Linux Debian install.
                                  I did try to comment out the source line earlier. I just tried again now. I also have set_anonymous_access commented out.
                                  The serial number of the Atom and the username and password look OK. Restarted MSR but still nothing in entities.
                                  If I login to https://home.getvera.com/ with same username and password I can see that Atom listed in the controllers.
                                  - id: ezlo-atom
                                    enabled: false
                                    implementation: EzloController
                                    config:
                                      # source: "wss://192.168.0.243:17000"  # change the IP address
                                      serial: "70060304"    # put your hub's serial here
                                      username: "myusername"  # put your username here between quotes
                                      password: "mypassword"  # and password
                                      # set_anonymous_access: true
                                  In the MSR log I see no mention of the word "atom"
                                  Maybe I need your bug fix first then.
                                  Cheers.
                                  EDIT:
                                  Bugger just spotted it says enabled "false" maybe that's why.
                                    #37
                                    OK its listed now in Entities
                                    Still not sure if this is gen 1 or 2 ? It was sent to me by Ezlo as part of their beta program.
                                    Also not seeing the one Z-Wave device that is currently paired to that Atom a TKB Home RGBW module.
                                      #38
                                      It says:
                                      sys_system.state=false
                                      Which I assume means its a gen 1 Atom ?
                                        #39
                                        Looking in the log I now see this, I have changed some sensitive items:
                                        2021-08-25T14:54:50.826Z <EzloController:null> EzloController#ezlo-atom account server replied { "PK_Device": "70060304", "NMAControllerStatus": 1, "NMAUuid": "a12bgd83-96b3-22d9-ad44-533df5564f44", "firmware_upgrade_progress": 100, "firmware_upgrade_status": "finished", "public_key_android": "", "public_key_ios": "", "Server_Relay": "wss://nma-server6-ui-cloud.ezlo.com:443", "MacAddress": "54:F5:4E:A4:5E:E5", "FK_Branding": "1", "HasWifi": "0", "HasAlarmPanel": "0", "UI": "4", "EngineStatus": "0", "LinuxFirmware": 1 }
                                        2021-08-25T14:54:50.828Z <EzloController:INFO> EzloController#ezlo-atom cloud auth succeeded
                                        2021-08-25T14:54:50.829Z <EzloController:6:EzloController.js:660> EzloController#ezlo-atom authinfo {  }
                                        2021-08-25T14:54:50.830Z <EzloController:INFO> EzloController#ezlo-atom opening hub connection to "70060304" at wss://nma-server6-ui-cloud.ezlo.com:443
                                        2021-08-25T14:54:50.832Z <EzloController:NOTICE> EzloController#ezlo-atom connecting via WS to wss://nma-server6-ui-cloud.ezlo.com:443
                                        2021-08-25T14:54:50.834Z <EzloController:5:Controller.js:537> EzloController#ezlo-atom websocket options { "maxPayload": 268435456, "followRedirects": true, "pingInterval": 60000, "agent": [object Object], "handshakeTimeout": 30000 }
                                        2021-08-25T14:54:51.518Z <EzloController:6:Controller.js:554> EzloController#ezlo-atom websocket connected to wss://nma-server6-ui-cloud.ezlo.com:443; starting ping check timer Timer#ezlo-atom-ping
                                        2021-08-25T14:54:51.519Z <EzloController:INFO> EzloController#ezlo-atom hub websocket connected (wss://nma-server6-ui-cloud.ezlo.com:443)
                                        2021-08-25T14:54:51.520Z <EzloController:INFO> EzloController#ezlo-atom sending remote hub login
                                        2021-08-25T14:54:51.522Z <EzloController:7:EzloController.js:1848> EzloController#ezlo-atom sending tracked request "17c8dcd8491" payload { "api": "1.0", "id": "17b7dce8481", "method": "loginUserMios", "params": { "MMSAuth": --undef--, "MMSAuthSig": --undef-- } }
                                        2021-08-25T14:54:51.523Z <EzloController:5:EzloController.js:1856> EzloController#ezlo-atom created tracked request "17c8dcd8491" with payload { "api": "1.0", "id": "17b7dce8481", "method": "loginUserMios", "params": { "MMSAuth": --undef--, "MMSAuthSig": --undef-- } }
                                        2021-08-25T14:54:51.675Z <EzloController:5:EzloController.js:1419> EzloController#ezlo-atom received message 144 bytes
                                        2021-08-25T14:54:51.676Z <EzloController:5:EzloController.js:1419> EzloController#ezlo-atom message data {"id":"17b7dce8481","method":"loginUserMios","error":{"code":2,"data":"cloud.error.failed_to_get_mms_autha_token","description":""},"result":{}}
                                        2021-08-25T14:54:51.678Z <EzloController:7:EzloController.js:1423> EzloController#ezlo-atom tracked request result slot { "req_id": "17c8dcd8491", "req_method": "loginUserMios", "expires": 1629903306521, "resolve": --function--, "reject": --function--, "promise": [object Promise] }
                                        2021-08-25T14:54:51.679Z <EzloController:ERR> EzloController#ezlo-atom request "17c8dcd8491" (loginUserMios) failed: { "code": 2, "data": "cloud.error.failed_to_get_mms_autha_token", "description": "" }
                                        2021-08-25T14:54:51.680Z <EzloController:7:EzloController.js:1855> EzloController#ezlo-atom removing resolved tracked request "17c8dcd8491"
                                        2021-08-25T14:54:51.681Z <EzloController:ERR> EzloController#ezlo-atom hub login failed: { "code": 2, "data": "cloud.error.failed_to_get_mms_autha_token", "description": "" }
                                        2021-08-25T14:54:51.685Z <EzloController:5:Controller.js:560> EzloController#ezlo-atom got websocket close
                                        2021-08-25T14:54:51.686Z <EzloController:NOTICE> EzloController#ezlo-atom websocket closing, 1006
                                        And as I said no devices from the Atom are being pulled in to MSR. Maybe at this stage I need your bug fix then..
                                          #40
                                          OK. Since it's a minor change, I just patched the build. Re-download the build package and reinstall it for the update. Then, you should be able to start with source commented out and get remote access.
                                          Once you have it connected, look at the system entity (the one with ID "system" matching the controller ID, like atom>system), and there is a hardware attribute that tells you the generation of Atom.
                                            164.7k
