  4. Support for Ezlo Atom controllers?
(I just gave my old Ezlo Plus a new chance so it's running my z-wave devices in my garage, for evaluation, as my even older Vera Secure had issues reaching that far when some router nodes gave up). Bare metal latest-26328 Issue 1: Nodes don't update in Reactor after update from 26318. Issue 2: Also present in earlier builds, rooms don't add to DGC and throws error at start. Notice: No device mapping matches Intrusion Sensor. I don't know if you still support EzloController but seems like an easy fix? Let me know if you need more info! [latest-26328]2026-11-25T11:18:31.310Z <Controller:NOTICE> Controller HassController#hass is now online. [latest-26328]2026-11-25T11:18:31.313Z <EzloController:ERR> [TypeError] Cannot read properties of undefined (reading 'clear') [-] failed to process rooms: [undefined2] [latest-26328]2026-11-25T11:18:31.313Z <EzloController:CRIT> TypeError: Cannot read properties of undefined (reading 'clear') [-] TypeError: Cannot read properties of undefined (reading 'clear') at EzloController._process_hub_rooms (/home/homebridge/reactor/server/lib/EzloController.js:1558:153) at /home/homebridge/reactor/server/lib/EzloController.js:1388:48 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.314Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.452Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.585Z <EzloController:ERR> EzloController#ezlo error creating entity Switch#ezlo>device_6b02d1d9129e0715b720f005: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.585Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.588Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d41d129e0715b720f012: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.588Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.590Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d41e129e0715b720f01c") -- skipped [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d9d9129e0715b720f01f: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.591Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d9da129e0715b720f029") -- skipped [latest-26328]2026-11-25T11:18:31.682Z <EzloController:INFO> EzloController#ezlo hub inventory complete/successful; 2159ms [latest-26328]2026-11-25T11:18:31.684Z <Controller:NOTICE> Controller EzloController#ezlo is now online.
Edit: Fixed in 26328. Bare metal latest-26318. I tried to add the group "ArmedSensors" but it would not show in UI. "ArmedSensors": name: Armed Sensors select: - include_capability: arming filter_expression: entity.attributes.arming.state The log: [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Nothing related before or after that I could find. I then copied an existing group to exclude type errors in the new group. "OKforLarm": name: OK för Larm select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state "OKforLarm2": name: "OK för Larm 2" select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state Same error in log. [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group OKforLarm2: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Let me know if I missed something or you need more info.
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
51 Posts 3 Posters 20.6k Views 3 Watching
    Hi
    I just tried to add a connection for my Ezlo Atom, its added the Atom system in to the MSR Entities, but it has a "false" state and hasn't found my devices that are paired to the Atom.
    Also note that on the Atom controller there is no settings for:
    offlineAnonymousAccess: true or false
    offlineInsecureAccess: true or false
    So this line in the reactor.yaml file won't work for Atom's.
    set_anonymous_access: true
    This was what I added to my reactor.yaml file.
    - id: ezlo-atom
      enabled: true
      implementation: EzloController
      config:
        source: "wss://192.168.0.101:17000"  # change the IP address
        serial: "70060304"    # put your hub's serial here
        username: "myusername"  # put your username here between quotes
        password: "mypassword"  # and password
        # set_anonymous_access: true
      OK. Please do this:
      1. Disable any other EzloController instances (by setting enabled: false in their controller config in reactor.yaml), leaving just the Atom enabled.
      2. Restart MSR. Wait until the restart occurs and your browser/UI reconnect.
      3. Confirm no devices list.
      4. Open a PR and post the nnn_data_list.json, nnn_hub_info.json and nnn_mode_info.json files, where nnn is the ID of the Atom interface (from reactor.yaml). Based on your snip above, that would be ezlo-atom_data_list.;json, etc.
      You can put your other Ezlo instances back after grabbing and posting the files.
        OK. Please do this:
        I've tried that, with the Ezlo Plus controller disabled, then in Entities area for the Ezlo Atom controller and still no devices listed for the Atom.
        I can't see any file called ezlo-atom_data_list.json however or hub and mode info either.
        These one listed have time stamps from several hours ago earlier today.
        EDIT: I've searched in Winscp the entire Reactor folder and there is no .json files of that name with Atom.
          Not sure exactly what I am looking for in the reactor.log file but I can see several errors like these:
          2021-07-22T15:41:45.378Z <EzloController:5:Controller.js:581> EzloController#ezlo-atom ws_open caught TimedPromise timeout
          2021-07-22T15:41:45.383Z <EzloController:WARN> EzloController#ezlo-atom websocket error during open/negotation: Error: WebSocket was closed before the connection was established
          2021-07-22T15:41:45.385Z <EzloController:ERR> EzloController#ezlo-atom failed to connect websocket to wss://192.168.0.243:17000: TimedPromise timeout
          2021-07-22T15:41:45.389Z <EzloController:NOTICE> EzloController#ezlo-atom websocket to wss://192.168.0.243:17000 closed during open/negotiation
          I don't want to post the entire log here or in the ticket system, perhaps I can email it to you if needed?
            No, that's enough for now. Do we know if a local API for the Atom is even possible?
              @toggledbits said in Support for Ezlo Atom controllers?:
              The Ezlo dev just said "We don't have it on Atom" when I asked him why I couldn't see the offlineAnonymousAccess and offlineInsecureAccess settings in the API Tool for the Atom.
                I have Atom working, but it uses an undocumented method of access (not the one described on the eZLO Community, but similar), and I'm still working out some issues.
                  Via a local or cloud Web sockets API?
                  Why is it undocumented, do we need the Ezlo Devs to confirm that type of access will remain open and available.
                    Ezlo dev says
                    "We have local Web sockets API on the Atom and plughub but not the HTTP API"
                      It doesn't much matter what they say if the device doesn't answer (won't answer hub.offline.login.ui) on the published port number they use for the others (like Plus), and they don't tell us what the Atom-specific mechanism is. Or, maybe my Atom is too old, but it is a second-gen unit, so I don't think so. I can't work from "we have it". There needs to be documentation to not only describe it, but memorialize their commitment to supporting it.
                      Remote access is really the same. I can't build on unsupported/undocumented features and functions. It may work today, but if doesn't down the road, I look like the bad guy, and the onus is on me to fix it and restore the feature, which may not even be possible. Poor risk reward, especially for this context.
                        I totally agree.
                        I've asked him on Skype what the port number should be? and if they have any documentation for the Web socket API on the RTOS based controllers, such as the Atom.
                          The port number is right, it connects, it just never answers the usual login request, and doesn't issue any messages of any kind at all. I embellished details in my previous post there, and prompted Oleg in it. In any case, none of this is serviceable until this is documented.
                          Over a year ago on Skype, early on in perhaps March or April, I suggested that all of their PDF documents need to be in a single location/library where they can seen. This business of them posting single PDFs on demand in the forums is the worst possible way to get it done (maybe second worst: they were replying on Skype with them, which was actually worse). Did that ever happen? I know of no such repository. If there were, at least one could research, but as it is, their docs are a hodge-podge of "lucky if you have it" one-offs, a dated web reference site, and an incomplete/dated API tool. And no version control. Ugh. This entire situation is why I didn't want to do this eZLO interface, and I'm really regretting it this morning.
                            I feel your pain.
                            Forgot it for now then.
                            For me personally I don't need my Atom connected to MSR. But I just thought I'd try it and test it if it did connect.
                            As long as Ezlo Plus and Ezlo Secure works, I think most people will be happy with that.
                            That website you mentioned is all I know of and there's a bit of a library section they created on the forum here.
                              There is also this Ezlo Support Site here which has some API stuff in it, but overall it looks lacking in content.
                                Yeah, nothing there either. Cart before the horse. API docs. No docs for how to log in to the API. And enough people have asked, including you, to produce various unofficial mechanisms; that should have been enough prompt/repetition to cause an official document to be produced (and really, together with/as part of the API docs is the perfect place for it).
                                F 1 Reply Last reply
                                  wrote on last edited by Fanan
                                  Might be a bit OT, or not... I can't get my only Ezlo controller (a Plus) to work in MSR. I have the latest version of MSR (21203-9503e5d), and I have added all needed lines to my reactor.yaml. This is the message I get:
                                  2021-07-29T13:13:57.524Z <Structure:ERR> [Structure:start] failed to start controller ezlo: Error: Cannot find module 'server/lib/Configuration'
                                  Require stack:
                                  - D:\msr\server\lib\EzloController.js
                                  2021-07-29T13:13:57.525Z <Structure:CRIT> Error: Cannot find module 'server/lib/Configuration'
                                  Require stack:
                                  Require stack:
                                      at Function.Module._resolveFilename (node:internal/modules/cjs/loader:924:15)
                                      at Function.Module._load (node:internal/modules/cjs/loader:769:27)
                                      at Module.require (node:internal/modules/cjs/loader:996:19)
                                      at require (node:internal/modules/cjs/helpers:92:18)
                                      at Object.<anonymous> (D:\msr\server\lib\EzloController.js:527:157)
                                      at Module._compile (node:internal/modules/cjs/loader:1092:14)
                                      at Object.Module._extensions..js (node:internal/modules/cjs/loader:1121:10)
                                      at Module.load (node:internal/modules/cjs/loader:972:32)
                                      at Function.Module._load (node:internal/modules/cjs/loader:813:14)
                                      at ModuleWrap.<anonymous> (node:internal/modules/esm/translators:201:29)
                                  Require stack:
                                      at ModuleWrap.<anonymous> (node:internal/modules/esm/translators:201:29) {
                                    code: 'MODULE_NOT_FOUND',
                                    requireStack: [ 'D:\\msr\\server\\lib\\EzloController.js' ]
                                  And this is my reactor.yaml:
                                    - id: ezlo
                                      enabled: true
                                      config:
                                        source: "wss://192.168.50.211:17000"  # change the IP address
                                        serial: "90000453"    # put your hub's serial # here
                                        username: "My_secret_name"  # put your username here betw quotes
                                        password: "My_top_secret_password"  # and password
                                  I have restarted MSR several times, with no luck. Any clues?
                                    How is MSR installed, and how are you running/starting it?
                                      MSR is installed on Windows 10, bare metall.
                                      I open up Windows Powershell and navigate to the MSR folder, and then type "node app.js".
                                      Everything else is working. I have a Vera and a Home Assistant up and running since months back... It's just the Ezlo that's not working.
                                        OK. You need to set the shell environment variable NODE_PATH to the install directory where Reactor lives (the directory that contains Reactor's app.js file).
                                          @toggledbits . Thanks. Did that. Sadly it still don't work. Got this instead:
                                          PS D:\msr> node app.js
                                          basedir D:\msr
                                          confdir D:\msr\config
                                          datadir D:\msr\storage
                                          logsdir D:\msr\logs
                                          plugindir D:\msr\ext
                                          module.paths [ 'D:\\msr\\node_modules', 'D:\\node_modules' ]
                                          NODE_PATH D:\MSR
                                          Logging stream path spec may be using pre-21075 form; please remove ./logs/ from the path!
                                          2021-07-30T13:10:38.707Z <app:null> Reactor latest-21203-9503e5d starting on v15.11.0
                                          2021-07-30T13:10:38.708Z <app:INFO> Process ID 16096; platform win32/x64 Windows 10 Pro
                                          2021-07-30T13:10:38.709Z <app:INFO> Basedir D:\msr; data in D:\msr\storage
                                          2021-07-30T13:10:38.709Z <app:INFO> NODE_PATH D:\MSR; module paths [ "D:\\msr\\node_modules", "D:\\node_modules" ]
                                          2021-07-30T13:10:38.751Z <Plugin:null> Module Plugin v21173
                                          2021-07-30T13:10:38.757Z <default:INFO> Module Entity v21177
                                          2021-07-30T13:10:38.760Z <Controller:null> Module Controller v21191
                                          2021-07-30T13:10:38.761Z <default:null> Module Structure v21196
                                          2021-07-30T13:10:38.766Z <default:null> Module Ruleset v21096
                                          2021-07-30T13:10:38.766Z <default:null> Module Rulesets v21096
                                          2021-07-30T13:10:38.781Z <default:null> Module Rule v21168
                                          2021-07-30T13:10:38.786Z <default:null> Module Engine v21197
                                          2021-07-30T13:10:38.787Z <default:null> Module httpapi v21200
                                          2021-07-30T13:10:38.790Z <default:null> Module httpproxy v21054
                                          2021-07-30T13:10:38.806Z <default:null> Module wsapi v21196
                                          2021-07-30T13:10:38.810Z <app:NOTICE> Starting Structure...
                                          2021-07-30T13:10:38.814Z <Structure:INFO> Structure#1 starting controller interface vera (VeraController)
                                          2021-07-30T13:10:38.820Z <Structure:INFO> Structure#1 starting controller interface ezlo (EzloController)
                                          2021-07-30T13:10:38.822Z <Structure:INFO> Structure#1 starting controller interface hass (HassController)
                                          2021-07-30T13:10:38.823Z <Structure:INFO> Structure#1 starting controller interface reactor_system (SystemController)
                                          2021-07-30T13:10:38.860Z <default:null> Module VeraController v21202
                                          2021-07-30T13:10:38.924Z <default:null> Module HassController v21191
                                          2021-07-30T13:10:38.926Z <default:null> Module SystemController v21102
                                          2021-07-30T13:10:38.929Z <VeraController:NOTICE> VeraController#vera starting
                                          2021-07-30T13:10:38.960Z <VeraController:INFO> VeraController#vera loaded mapping ver 21202 rev 1 format 1 notice
                                          2021-07-30T13:10:38.970Z <Controller:CRIT> Controller: failed to load ezlo implementation file:///D:/msr/server/lib/EzloController.js: TypeError: Cannot read property 'getConfig' of undefined
                                          2021-07-30T13:10:38.970Z <Controller:CRIT> TypeError: Cannot read property 'getConfig' of undefined
                                              at Function.getInstance (D:\MSR\server\lib\Configuration.js:128:89)
                                              at Object.<anonymous> (D:\MSR\server\lib\Logger.js:154:49)
                                              at Object.<anonymous> (D:\MSR\server\lib\Capabilities.js:71:99)
                                            164.7k
