  4. Aeotec doorbell question
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
6 Posts 3 Posters 1.8k Views 3 Watching
    RogerO
    Hello,
    I have a Aeotec doorbell with a barking dog file on it. In reactor I have a activity like this:
    luup.call_action('urn:micasaverde-com:serviceId:ZWaveNetwork1','SendData',{Node='77',Data='112 4 6 1 8'},1)
    How do I get this to work in MSR?
    There is a SendData action for the doorbell with Node and Data as inputs. Tried a few combinations but not getting ot to play. Anyone have one of these?
    • tunnusT Online
      tunnusT Online
      Just use entity action - runlua?
        There is an entity called "Zwave" associated with your hub (it will have ID device_1, so if your Vera is configured using the default ID Vera, the canonical ID of the entity is vera>device_1. This is the ZWave device parent on Vera, the mother of all ZWave devices (did you know that all of your ZWave devices on Vera are actually child devices of this device #1?)
        You need to use the SendData on that entity. This is exactly the same thing you are doing on Vera. Notice the device number in your call_action() call, at the end... it's 1.
          RogerO
          @toggledbits Thanks for the reply, you have completely lost me. In my set reaction I have an Entity Action pointing at the doorbell and the senddata drop down. That action has a box for Node and data. I assume the Node is 77 and the data is 112 4 6 1 8. Where does the 1 come into play and does the value in Node and Data have to be wrapped in any other punctuation?
            Look at your Vera/Luup action. You are not sending that to the Aeotec door bell, you are sending it to device #1, which is the ZWave network controller, telling it what node and what data to send. You are not sending data directly to the node; you are sending it to the ZWave controller telling it to send it to the node.
            You have to do the same thing in MSR: the action you run is on the ZWave network entity (device_1)
              RogerO
              Thanks for the additional details. That worked.
                163.1k
