announcements
152 Posts 2 Posters 151.6k Views 13 Watching
    #141
    Reactor build 26150
    If you are upgrading to this build from 26011 or earlier, please read the cautions for build 26116!
    • A new Router notification method is now available. This method allows a single notification action to send a message to multiple notification targets. Configurable routes allow the selection and filtering of messages for different destinations. See docs
    • In support of the new Router notification method, configured Notifier profiles other than default are considered children of default. If a configuration value is not specified in such a profile, the value will be inherited from the default profile. This allows, for example, the default profile for SMTP to contain the host and authentication information, while additional profiles may contain only different recipient addresses — the additional profiles will use the default profile's host/auth info to connect to the same mail server, without the need to repeat that information in each profile. If an additional profile needs to connect to a different mail server, it may specify its own host and authentication parameters as before.
    • DynamicGroupController: improve response to changes in groups using filter_expression in configuration;
    • Expressions: fix an error in the runReaction() function that may cause it to crash on an attempted dereference through undefined.
    • Make the system more resilient to startup failures caused by hard errors in configuration files. When a (syntactically) valid configuration file is successfully loaded, it is copied to a last-known-good shadow file in the config directory. If the YAML configuration is later edited and contains errors that would prevent it being loaded, Reactor will load the last-known-good configuration, log the error, and display an alert in the Current Alerts widget on the Status page. The alert will clear itself when the file is fixed and later successfully loaded. To be clear, "valid" in this context means parseable (syntactically correct YAML). It does not mean that the keys and values given in the configuration will do what you expect/want or contain values or structures that Reactor can't recognize.
    • Fix a compatibility issue with node version 18. This version of node is only supported in the armv7l docker image (for 32-bit Raspberry Pis).
    • A new backup script backup_reactor_gfs.sh has been added to the tools directory; this script uses the grandfather-father-son backup strategy. If run daily, it will keep 30 daily backups, monthly backups (i.e. the first daily backup of each month), and quarterly backups (i.e. the first monthly backup of each quarter). Command line options suppress the backups of the logs directory and/or the transient/temporary state data for smaller backup size.
      Reactor build 26174
      IF YOU ARE UPGRADING FROM A REACTOR BUILD EARLIER THAN 26116, PLEASE READ THE RELEASE NOTES FOR THAT BUILD. THERE WERE IMPORTANT CHANGES MADE ON THAT BUILD THAT MAY AFFECT HOW YOU BACK UP AND RESTORE REACTOR DATA.
      NOTE TO DEVELOPERS: An upcoming build of Reactor will be published after code base conversion to ES modules. Current Reactor core modules are CommonJS (CJS). Many dependent packages are only getting new features in their ESM versions (i.e. the world is moving to ESMs), so Reactor must follow. Instructions for converting your Reactor Controller and Plugin subclasses are published in the Building Controllers page of the Reactor documentation (under Developer Info). If you send me a DM in this community, I can send you an early release of ESM Reactor for your development and testing. This 26174 build is still CJS-based, so your conversion applies only to that future Reactor release and beyond.
      • Entities list: fix a bug in entity filtering where a group filter would be ignored when an entity's name matched the name filter (both should be enforced).
      • Hubitat: Fixed a problem where a scene controller button would report tapped at every Reactor startup.
      • HTTP API: A new endpoint /api/v1/notify has been added so that external applications can use Reactor's configured notifiers to send messages. docs
      • VirtualEntityController: New ping-driven binary sensor reflects the (ICMP) reachability of a target network host. see docs
      • VirtualEntityController: Virtual entities may now be added to system room/location groups by including room: <string> in the virtual entity configuration.
      • HassController: Bless HA to 2026.6.4
        Reactor build 26177
        • Notify via Telegram: fix application of default chat_id when not specified on individual notification action.
        • Hubitat: fix an error in handling data POST from MakerAPI (affects house modes, HSM)
          Nodejs v24.17 Not Compatible
          Users on bare-metal installs... a security fix in nodejs v24.17 inadvertently broke a dependency of Reactor. This version of nodejs is therefore not compatible with Reactor. If you are using it, please upgrade to v24.18.
            Reactor build 26193
            BARE-METAL USERS: nodejs v24.17 had a regression/injection that breaks HTTP connections, which has broad negative effect in Reactor. This version specifically is excluded from support, and users on that version are advised to upgrade to v24.18 (or higher).
            BREAKING CHANGE: I'm guessing this will affect very few people, maybe none: the include_attributes selector for DynamicGroupController now requires that all listed attributes match when tested against an entity. Previously, if any listed attribute matched, the entity would be added to group eligibility. This forced users to use a filter expression if all attributes had to be matched together, which carries a greater performance impact and has other side-effects. The old behavior can be obtained by separating each attribute under its own include_attributes selector individually.
            • DynamicGroupController: the include_attributes selector now requires all listed attributes to match, rather than any of the listed attributes, for the entity to be selected. See note above.
            • A new lexp-cli.js utility in the tools subdirectory allows users to experiment with lexp expressions outside of Reactor. This tool doesn't have Reactor context, so functions like getEntity() and isRuleSet() are not available; nor are Reactor's global variables. It is strictly an environment to help with familiarization.
            • Reaction Editor: when editing the Set or Reset reaction of a Rule, the Copy From... button will now list the contra-reaction at the top of the list, making it easier to find and copy the reaction within the current Rule.
            • UI: The condition and action editors now support a right-click context menu on conditions and actions. The menu provides copy-paste of individual conditions and actions. Other menu actions are added where they make sense. Thank @therealdb for this power-user feature!
            • UI: On dialogs, the Enter key will not perform any action if a modal dialog contains two or more buttons (i.e. where the meaning of Enter is ambiguous).
            • nodejs version 26 is now explicitly supported, with v26.4.0 being the current version used for development (testing still occurs on v22 and v24).
            • HassController: Bless HA to 2026.7.2
              Reactor build 26193
              @toggledbits said in Reactor (Multi-System/Multi-Hub) Announcements:
              Oh My! That is very cool indeed!
                Reactor build 26214
                ALL USERS: This build is strictly to address a problem for bare-metal installs only running on nodejs v22.0 through v22.11. Use node -v to show your version, or look at the startup messages in reactor.log. If your nodejs is v22.12.0 or higher, or you are running a docker image, you do not need to update to this build.
                • Workaround for module load problem in nodejs versions from 22.0 through 22.11.
                Only a bare-metal package is distributed for this build. The latest docker images are still build 26193.
                  Reactor build 26221
                  SECURITY! - BARE-METAL USERS: It is always recommended that you update package dependencies whenever installing Reactor updates. After unpacking the Reactor archive, go into the reactor directory (where app.js lives) and run npm run deps to update package dependencies. This is particularly important to address security updates for many packages.
                  • DynamicGroupController: Fix an issue where a filter_expression-controlled group would miss an attribute update.
                  • Engine/Reactions: The log level for the result of Group and While action predicates (i.e. the conditions) has been raised to INFO (4) from DEBUG0 (5). This may help users more easily identify logic bugs in their actions without the need to change the Engine log level (the Engine is dauntingly verbose even at DEBUG0 level).
                  • HassController: Bless HA to 2026.7.4
                    Reactor build 26242
                    • DynamicGroupController: Custom attributes (calculated) see docs;
                    • Expressions: new map() and reduce() array functions see docs;
                    • HassController: Bless HA to 2026.8.3
                      wrote last edited by toggledbits
                      #150
                      Reactor build 26284
                      NOTE: Your first startup on this build may log some odd-looking errors while rebuilding entities from various controllers, and that's expected. A second restart should be noticeably cleaner.
                      • New Access Control settings for operation behind reverse proxies. These new settings should enable easier reverse proxy configuration while maintaining local access (i.e. access UI via LAN). DISCLAIMER: Opening your system/network to a public IP address is not something to be trifled with, and if you don't know what you're doing, you will likely regret it at some point. Proceed entirely at your own risk. See further discussion here.
                      • HassController: now recognizes HA's fan service with capabilities (including new capabilities: preset_mode, speed, direction and oscillate) extended by matching the source device's advertised supported features (i.e. not all capabilities will be present on all devices).
                      • HassController: extend media_source capability to media_player devices that support it.
                      • HubitatController: Improve behavior when new devices are added to the hub and published by Maker API. It should now not be necessary to restart Reactor to have the entity fully configured and responsive.
                      • HubitatController: Default polling action is now Refresh (was Poll). On newer firmware, this more reliably produces a device change message when the state has updated (e.g. a switch without instant status was operated manually). Polled devices now allow an action config to override the default action.
                      • HassController: Store HA unique_id and platform on extended attributes (e.g. for use in filtering).
                      • HassController: Bless HA to 2026.10.1
                        #151
                        Reactor build 26287
                        • Tighten tests for proxied requests so that proxy-handling behavior isn't triggered when proxy configuration has not been established.
                          #152
                          Reactor build 26298
                          SECURITY: Recent discovery of compromised intermediate certificates has been addressed with updated docker images for arm64 and amd64/x86_64. Bare-metal Reactor users are advised to upgrade their node install to at least (within each major version) 22.23.4, 24.22.1, or 26.12.1, and further update their CA certificates on the underlying operating system, as well as any affected packages (e.g. potentially python, OpenSSL, curl, wget, etc.). Any of the popular AIs should be able to provide useful specific guidance if you adequately describe your system configuration. Note that armv7l images cannot be fully patched at this time due to limitations in underlying packages. Upgrading to 64-bit is currently the only path.
                          • Security: Reactor Access Control now supports Multi-factor (Two-Factor) Authentication. Configuring MFA is highly recommended for users granting access to Reactor from outside their LANs (e.g. via reverse proxy or tunnel). See docs
                          • Security: Reactor Access Control now blocks host IP addresses for consecutive login failures (configurable, default: 4 failures within 3 hours gets blocked for 48 hours). See docs
                          • Security: docker images have an updated node version to address recent discovery of compromised eMudhra intermediate certificates, and others. The image OS certificate store has also been updated accordingly. ref ref ref
                          • HubitatController: New x_hubitat_sys.restart and x_hubitat_sys.reboot actions (on system entity); see docs
                          • HassController: Bless HA to 2026.10.4
                            151.6k
