  4. [SOLVED] Hubitat type guessing and extra attributes v21336-Synology Docker
7 Posts 3 Posters 1.7k Views 3 Watching
    In version 21336 the HubitatController: can't assign x_hubitat_extra_attributes value as primary attribute issue that was previously fixed (Mantis 261) has returned. If I remove the local_hubitat_devices.yaml and restart, the experimental "type guessing" feature does a pretty good job of assigning the primary attributes on most devices. I wouldn't expect MSR to guess an extra attribute but setting it manually causes the error again.
    [latest-21336]2021-12-03T17:29:05.399Z <Structure:INFO> Starting controller HubitatController#hubitat
    [latest-21336]2021-12-03T17:29:05.430Z <Structure:INFO> Starting controller OWMWeatherController#weather
    [latest-21336]2021-12-03T17:29:05.461Z <Structure:INFO> Starting controller SystemController#reactor_system
    [latest-21336]2021-12-03T17:29:05.462Z <SystemController:NOTICE> Controller SystemController#reactor_system is now online.
    [latest-21336]2021-12-03T17:29:05.487Z <app:INFO> Structure running; pausing for controllers' initial ready
    [latest-21336]2021-12-03T17:29:05.517Z <HubitatController:NOTICE> HubitatController#hubitat not ready; performing initial connect/query
    [latest-21336]2021-12-03T17:29:05.534Z <HassController:NOTICE> HassController#hass connected, starting protocol
    [latest-21336]2021-12-03T17:29:05.540Z <HassController:INFO> HassController#hass successful authentication with ws://192.168.1.21:8123; fetching initial data...
    [latest-21336]2021-12-03T17:29:05.544Z <HassController:INFO> HassController#hass Hass reports version "2021.11.5" location Home timezone America/Chicago state RUNNING safe_mode false
    [latest-21336]2021-12-03T17:29:05.632Z <HassController:NOTICE> Controller HassController#hass is now online.
    [latest-21336]2021-12-03T17:29:05.799Z <Entity:ERR> Entity#hubitat>568 attempt to set primary to x_hubitat_extra_attributes.Status invalid: capability not extended
    [latest-21336]2021-12-03T17:29:05.800Z <HubitatController:WARN> HubitatController#hubitat can't set local primary attribute x_hubitat_extra_attributes.Status on Entity#hubitat>568: Error: Invalid primary attribute assignment; capability not assigned (x_hubitat_extra_attributes.Status)
    [latest-21336]2021-12-03T17:29:05.817Z <Entity:ERR> Entity#hubitat>481 attempt to set primary to x_hubitat_extra_attributes.dbSize invalid: capability not extended
    [latest-21336]2021-12-03T17:29:05.818Z <HubitatController:WARN> HubitatController#hubitat can't set local primary attribute x_hubitat_extra_attributes.dbSize on Entity#hubitat>481: Error: Invalid primary attribute assignment; capability not assigned (x_hubitat_extra_attributes.dbSize)
    [latest-21336]2021-12-03T17:29:05.825Z <HubitatController:INFO> HubitatController#hubitat connecting to hub's eventsocket WebSocket API at ws://192.168.1.70/eventsocket
    [latest-21336]2021-12-03T17:29:05.842Z <HubitatController:INFO> HubitatController#hubitat successful connection to ws://192.168.1.70/eventsocket
    [latest-21336]2021-12-03T17:29:05.856Z <HubitatController:NOTICE> HubitatController#hubitat current mode is Day (1)
    [latest-21336]2021-12-03T17:29:05.859Z <HubitatController:NOTICE> Controller HubitatController#hubitat is now online.
    [latest-21336]2021-12-03T17:29:06.088Z <OWMWeatherController:INFO> OWMWeatherController#weather done; 1 locations, 0 failed
    [latest-21336]2021-12-03T17:29:06.089Z <OWMWeatherController:NOTICE> Controller OWMWeatherController#weather is now online.
    [latest-21336]2021-12-03T17:29:06.090Z <app:NOTICE> Starting HTTP server and API...
      Thanks for reporting. Good info/post content. A little tension between trying to make data more deterministic and trying to keep it flexible; always an uphill battle. Just doing a little more testing. New build shortly.
        Build 21337 fixed the issue. Thanks!
        I do not know how to mark the post Solved.
          Good news.
          Just edit the title (by editing your original post) and put [SOLVED] in front.
          S 1 Reply Last reply
            Good news.
            @toggledbits said in Hubitat type guessing and extra attributes v21336-Synology Docker:
            Smh, I thought about that but thought there must be a way to mark it. I tend to make things more complicated than it need to me. Thanks
            • S SweetGenius
              @sweetgenius I'm not sure there is in this forum software, but I'm no expert at it. Paging @DesT -- is there a way to mark an issue solved other than editing the title?
              DesTD 1 Reply Last reply
                DesTD Offline
                DesTD Offline
                DesT
                @toggledbits Let me check in the plugin 😉
