  3. Is Hubitat to HA Bridge possible?
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
8 Posts 5 Posters 2.0k Views 4 Watching
  • ? Offline
    ? Offline
    A Former User
    Greetings,
    I’m researching a migration from Vera+ to Hubitat C7 and want to know if anyone has successfully connected the Hubitat to the “HA Bridge” for local Alexia calls.
    The HA Bridge does not callout Hubitat natively from what I see.
    Thanks for your assistance.
    G wmarcolinW 2 Replies Last reply
      If Hubitat has URLs to be called to activate scenes/devices, it will work. Supported hubs has only a nice gui to create the calls, but you can define any device you want. I have calls that translate to mqtt messages, others that are directly running MSR reactions or calling my own endpoints. It just requests an URL to call and it supports post or put requests as well as get ones.
      • ? A Former User
        Greetings,
        @droy@droy If you're looking to connect Hubitat to Alexa, I've had much success using the Echo Speaks app available in the HPM.
        • ? A Former User
          Greetings,
          @droy
          I have just integrated Alexa to Hubitat, very simple to do. First add the APP to Hubitat, then search in the App top right corner, the video that very simply explains how to do the integration. Easy and fast.
          • ? Offline
            ? Offline
            A Former User
            Thanks for the responses but I was hoping to keep the system local (not Amazon cloud) by using the HA Bridge like I have connected to Vera (https://www.bwssystems.com/#/habridge).
            The developers of the HA-Bridge added Hubs such as Vera and Home Assistant + others but left out Hubitat.
            I have it running on a Pi 3B and it acts as a bridge between to Alexia exposing the devices on Vera and making calls to the Hub based on voice commands.
              • ? Offline
                ? Offline
                A Former User
                @therealdb Good point, I'll look into Hubitat's interfacing option more closely. I know that MSR is using a Hubitat "Maker" API to call device changes.
                • System has marked this topic as solved on
                • ? A Former User
                  @droy you could definitely call MSR http endpoint to achieve the same result. At this point, MSR will perform the call for you.
                  • X Offline
                    X Offline
                    xAPPO
