  4. Anybody Installed MSR on unRaid Docker
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
11 Posts 4 Posters 2.9k Views 4 Watching
  • ? Offline
    ? Offline
    A Former User
    Greetings,
    I'm not a Docker expert hence the choice of using unRaid but I would like to install MSR in a Docker and I'm looking for details on the settings used as I have not installed one manually yet.
    I have installed MSR on Windows Server 2019 but I'm receiving (3 vulnerabilities (1 low, 2 high)) error messages with 'npm' and the audit fix breaks it ('npm').
    Thanks for any help you can provide.
    David
    3 1 Reply Last reply
      On the Windows side, try doing npm i --no-save --omit dev... it looks like a couple of the development dependencies are the cause of the audit warnings.
      • ? Offline
        ? Offline
        A Former User
        I ran that and now the Reactor Windows Service Terminates unexpectedly.
        *** I was able to install MSR in a Docker on unRaid so the details below are for your reference only as I plan on uninstalling Reactor in Windows. ***
        Event Log Shows - ''Child process [7664 - C:\Program Files\nodejs\node.exe C:\reactor\node_modules\node-windows\lib\wrapper.js --file C:\reactor\app.js --scriptoptions= --log "Reactor wrapper" --grow 0.25 --wait 1 --maxrestarts 3 --abortonerror n --stopparentfirst undefined] finished with 1''
        ''C:\reactor>npm i --no-save --omit dev
        npm WARN EBADENGINE Unsupported engine {
        npm WARN EBADENGINE package: 'jsdoc@0.0.0',
        npm WARN EBADENGINE required: { node: '~v0.4.10' },
        npm WARN EBADENGINE current: { node: 'v16.13.1', npm: '8.1.2' }
        npm WARN EBADENGINE }
        removed 5 packages, and audited 90 packages in 1s
        12 packages are looking for funding
        run npm fund for details
        1 high severity vulnerability
        To address all issues (including breaking changes), run:
        npm audit fix --force
        Run npm audit for details.''
        • ? Offline
          ? Offline
          A Former User
          If anyone else is running Dockers on unRaid and wants instructions for Installing Reactor, see below.
          Installing Multi-system Reactor in a unRaid Docker Notes. 01/22/22
          unRaid Version 6.9.2
          Preparation:
          Based on Generic Notes from:
          Installation - Reactor - Multi-Hub Automation
          Typically for Generic (modify with username below):
          docker run --name reactor -d --restart on-failure -p 8111:8111
          -v /home/username/reactor:/var/reactor
          --mount type=bind,src=/etc/localtime,target=/etc/localtime
          toggledbits/reactor:latest-generic-amd64
          Create a Share called "reactor" and use "Prefer Cache" if cache drive is available.
          Under SMB settings - Export = Yes so that you can edit config files. Set security per your needs.
          Go to the Docker tab click Add Container and click Advanced View for additional settings.
          Enter:
          Name = reactor
          Overview = Reactor (Multi-system, aka MSR) is an automation engine for multiple home automation systems. It allows you to develop automations that respond to and control devices across platforms. For example, you could have a motion sensor on a Hubitat controller used as a trigger for set of lights, some of which are connected through a VeraPlus and some through HomeAssistant.
          Please see https://reactor.toggledbits.com/docs for more information.
          Repository = toggledbits/reactor:latest-generic-amd64
          For Latest otherwise choose a specific version
          Docker Hub URL = https://hub.docker.com/r/toggledbits/reactor
          No icon path has been found
          WebUI = http://[IP]:[PORT:8111]/
          CPU Pinning as you see fit.
          Network Type = Bridge
          Console shell command = Shell
          WebGUI = http://[IP]:[PORT:8111]/
          Extra Parameters = --restart=on-failure
          Click Add another Path, Port, Variable, Label or Device.
          Choose Path -
          Name = data
          Container Path = /var/reactor
          Host Path = /mnt/user/reactor (previous share path)
          Access = Read/Write
          Display = Always
          Required = No
          Password Mask = No
          Choose Port -
          Name = Host Port 1
          Container Port = 8111
          Host Port = 8111
          Default Value = 8111
          Type = TCP
          Description will auto populate with "Container Port: 8111" once Saved
          Display = Yes
          Required = Yes
          Password Mask = No
          Save
          Choose Variable -
          Name Key 1
          Key = UMASK
          Val and Default = 100
          Display = Yes
          Required = No
          Password Mask = No
          Save and repeat adding Variables for below:
          Key 2: Container Variable: PUID = 99
          Key 3: Container Variable: PGID = 100
          Click Apply
          Script should look similar to:
          root@localhost:# /usr/local/emhttp/plugins/dynamix.docker.manager/scripts/docker create --name='reactor' --net='bridge' -e TZ="America/Chicago" -e HOST_OS="Unraid" -e 'UMASK'='000' -e 'PUID'='99' -e 'PGID'='100' -p '8111:8111/tcp' -v '/mnt/user/reactor/':'/var/reactor':'rw' --restart=on-failure 'toggledbits/reactor:latest-generic-amd64'
          The command finished successfully!
          Notes:
          • The docker manager script will add the Time Zone based on unRaid's config.
          • If variables (uid/gid <> 99/100) then you must run the "New Permissions" script under Tools
            and select the User Share reactor otherwise the Reactor files will be R/O except for the Docker container.
          • WebUI Access = "http://[your NAS IP]:8111"
          • Follow the reactor configuration documentation for your Hub(s).
          Regards
            If you're getting an error mentioning jsdoc when using npm with --omit dev, I'm wondering if you are trying to install the latest version (22021) or something older?
            • ? Offline
              ? Offline
              A Former User
              It was the latest version (22021). It was running fine but doing "npm audit fix --force" and the command you requested broke it.
              To get it running again I reinstalled node.js and ran the Reactor setup scripts but I didn't like having the audit issues so I'm off of Windows now, deleted the Service and moved to a Docker.
              Thanks for your quick replies but you can pass on my Windows install issue.
              CrilleC 1 Reply Last reply
              • ? A Former User
                @droy said in Anybody Installed MSR on unRaid Docker:
                This broke my bare metal install on Ubuntu as well. Downgraded and did npm update -- no-save and then upgraded and ran npm i --omit dev then MSR started fine but the vulnerability warning is present. Don't know how to get all packages up to date and have MSR running...
                Edit: Definitely not trying to hijack, just a FYI. Will do more troubleshooting tomorrow and report in an appropriate topic.
                  Make sure you also remove any lockfile (package-lock.json) created by any previous attempts at the command without --no-save --omit dev as well.
                  I've got one of them resolved. Working on the other.
                  • ? A Former User
                    Greetings,
                    David
                    3 Offline
                    3 Offline
                    Yes - I have been running my MSR in my unRAID docker for a long time now. Great details you have noted above @droy. And since a picture is worth a thousand words, I thought I would share my docker setup/UI view. This is the basic view. The only thing I have added within the advance view was an Icon URL. I also run my Reactor on it's own IP and not my unRAID, hence the br0 Network Type.
                    For my Icon URL: I put the following https://smarthome.community/assets/uploads/profile/9-profileavatar.png
                    I suppose if @toggledbits changes his profile icon, my Reactor Docker icon will update too.
                    ? 1 Reply Last reply
                    • 3 3rdStng
                      ? Offline
                      ? Offline
                      A Former User
                      @3rdstng Thanks for the feedback and link to an icon. I'll save that off and put it local.
                      One note - I try to avoid “privileged” mode for containers. It allows it to run containers with (almost) all the capabilities of their host machine, regarding kernel features and device access.
                      Regards
                      • ? A Former User
                        Regards
                        3 Offline
                        3 Offline
                        Yeah. I don't remember why I set it that way. I'll disable it and see if anything breaks.
                          164.1k
