reactor.yaml:
trusted_proxy: "192.168.1.12"
users.yaml:
- url: "/api/v1/log"
method: "GET"
source_ip: 172.18.0.0/24
allow: true
x_hass.domain="fan"
x_hass.source="esphome"
x_hass_attr.percentage=50
x_hass_attr.preset_mode=""
x_hass_attr.preset_modes=[]
primary_attribute_value: |
d = false;
d
Edit: Solved in latest-26221.
Bare-metal latest-26193
I have this group:
"OKforLarm":
name: OK för Larm
- include_controller: vera
Haas system call service notify
Posters
560
Views
Watching
MSR 22028 on raspbery pi os with docker.
I have a master rule that call other rules based on a random number (1 to 9). Reaction groups are used to run the proper rule depending on the random number.
I would also like to send a message via the Hass notify service to track which of the rule is being run. Is there a way to use variable substitition in the message body?
I can have different messages added to each group but since I have 9 different rules (group) and the message needs to reach 3 devices a total of 27 notify would be required. This number would go down to 3 if I can define them in the reaction section and not in the group.
the following example return: Scenario $ activated
