  4. [SOLVED]Zwavejs2mqtt log no longer updating
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
zwave-js
3 Posts 2 Posters 983 Views 2 Watching
  • V Offline
    V Offline
    @toggledbits Did the upgrade to 22051 yesterday evening but before I could start testing, I noticed something not quite right with the logs.
    Maybe this is intended. Zwavejs2mqtt is having 2 set of logs.
    -One for the zwavejs2mqtt, this one is fine.
    -One for the zwavejs. When MSR-zw is running that log is no longer updating. IF I restart zwavejs2mqtt, the log will update for the booting information but as soon as this is done, nothing update anymore. If I stop MSR-zw and restart zwavejs2mqtt all is fine again until MSR-zw is restarted.
    As for the MSR log we have a dedicated set of logs for the Zwavejs info but zwave information is also in the regular Reactor.log. Is that the intended behaviur?
    EDIT: After looking a bit more I change the wording a little.
      Nothing has changed since the original release. ZWaveJSController does ask zwave-js-server to echo log information, which it captures and logs to Reactor's log conduit. It is a surprise to me that that request to zwavejs would, however, completely redirect its normal logging rather than make it an additional destination. Fortunately, that was just for initial debugging, and I think it's not as useful as I thought it might be, so you can turn it off by adding listen_zwavejs_logs: false to the config section.
      • V Offline
        V Offline
        Yup, all back to normal now. Personnaly I preffer the reactor and Zwavejs logs without the serial interface info leaving that to the server log if needed. It is much cleaner.
          163.7k
