  4. Cheapest platform on which to run MSR
27 Posts 7 Posters 11.5k Views 7 Watching
  • Black CatB Offline
    Black CatB Offline
    Black Cat
    @Alan_F , thanks for the reply.
    The difficulty I have is not running it but setting MSR configuration.
    I haven't been able to locate where the config files reside. @toggledbits, could MSR have a goto button for setting the configs in the Tools page?
    That would make setting configs extremely easy.
    aka Zedrally
    • Black CatB Black Cat
      @black-cat said in Cheapest platform on which to run MSR:
      They live in the config subdirectory of the directory you created. You're using Portainer? Should be in the configuration of the existing container (it's a binding to /var/reactor inside the container).
      R 1 Reply Last reply
        retireditguy
        Love your printed case, but it is not tall or deep enough to add the PCIE adapter for an m2 SSD. Have you come across any oversized cases for the CM4 IO boards that would accommodate use of the PCI slot.
          If you tell me how much more clearance you need, I'd be happy to model a roomier version.
            retireditguy
            @toggledbits I have the CM4IO currently installed in a Waveshare CM4-IO-Board- Case-A metal case. The board is mounted to standoffs inside the case. I was able to remove enough of the front rim of the case to be able to mount the board without the cover, so depth is no longer an issue (There was already a small cutout area in the rim.) Overall the case is 6 7/8" wide x 4 1/8" deep x 1 1/8" high. It needs about another 1 1/2" in height, making the total height 2 1/2". I appreciate your offer to model a roomier case, but I don't have a 3D printer so it would be of little use to me. I guess that I will have to run it without a cover until the market catches up, assuming that the CM4 on CM4 IO is selling well.
              retireditguy
              • R retireditguy
                @retireditguy your question is OT for this thread and belongs in its own topic. Please start a new topic for your question. Also, please refer to the posting guidelines before (re)asking your question.
                  376
                  151.4k
