  4. MSR Upgrade from 22119 to 22136 fails, service wont start
(I just gave my old Ezlo Plus a new chance so it's running my z-wave devices in my garage, for evaluation, as my even older Vera Secure had issues reaching that far when some router nodes gave up). Bare metal latest-26328 Issue 1: Nodes don't update in Reactor after update from 26318. Issue 2: Also present in earlier builds, rooms don't add to DGC and throws error at start. Notice: No device mapping matches Intrusion Sensor. I don't know if you still support EzloController but seems like an easy fix? Let me know if you need more info! [latest-26328]2026-11-25T11:18:31.310Z <Controller:NOTICE> Controller HassController#hass is now online. [latest-26328]2026-11-25T11:18:31.313Z <EzloController:ERR> [TypeError] Cannot read properties of undefined (reading 'clear') [-] failed to process rooms: [undefined2] [latest-26328]2026-11-25T11:18:31.313Z <EzloController:CRIT> TypeError: Cannot read properties of undefined (reading 'clear') [-] TypeError: Cannot read properties of undefined (reading 'clear') at EzloController._process_hub_rooms (/home/homebridge/reactor/server/lib/EzloController.js:1558:153) at /home/homebridge/reactor/server/lib/EzloController.js:1388:48 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.314Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.452Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.585Z <EzloController:ERR> EzloController#ezlo error creating entity Switch#ezlo>device_6b02d1d9129e0715b720f005: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.585Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.588Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d41d129e0715b720f012: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.588Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.590Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d41e129e0715b720f01c") -- skipped [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d9d9129e0715b720f01f: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.591Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d9da129e0715b720f029") -- skipped [latest-26328]2026-11-25T11:18:31.682Z <EzloController:INFO> EzloController#ezlo hub inventory complete/successful; 2159ms [latest-26328]2026-11-25T11:18:31.684Z <Controller:NOTICE> Controller EzloController#ezlo is now online.
Edit: Fixed in 26328. Bare metal latest-26318. I tried to add the group "ArmedSensors" but it would not show in UI. "ArmedSensors": name: Armed Sensors select: - include_capability: arming filter_expression: entity.attributes.arming.state The log: [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Nothing related before or after that I could find. I then copied an existing group to exclude type errors in the new group. "OKforLarm": name: OK för Larm select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state "OKforLarm2": name: "OK för Larm 2" select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state Same error in log. [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group OKforLarm2: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Let me know if I missed something or you need more info.
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
6 Posts 2 Posters 1.6k Views 3 Watching
  • W Offline
    W Offline
    wokwon
    Windows Server 2022 Build 20348
    Nodejs v16.14.0
    Currently running Reactor (Multi-hub) stable-22119-ae7212f
    Linked to Hass 2022.0.5.4 (on a different box)
    Windows server is dedicated to MSR and doesn't do anything else.
    I'd like to upgrade to 22136 to take advantage of the SSL feature added recently, and also to bring my current version of Hass into the 'supported' column with MSR.
    Following the instructions here: link text, section "Upgrade Windows Bare Metal"
    • Stop Reactor Service
    • Extract the zip, overwriting the reactor folder in c:\reactor\reactor
    • There is no package-lock.json file so I skip that.
    • Run "npm install --no-save --omit dev"
    Next step is to start the service. I start the service and it immediately stops. "Windows could not start the Reactor service on Local Computer. Error 1067: The process terminated unexpectedly".
    Tried rebooting, service won't stay running.
    I suspect I'm missing something, it's probably obvious but I've not been able to figure it out.
    I rolled back the reactor folder version (Windows Shadow copies) and then the service starts fine.
    Anyone else running Windows and know what I'm missing?
    • Tail of log file from running OK version, before upgrade attempt
    [stable-22119]2022-06-01T22:20:19.081Z <Rule:INFO> Lounge Billy Ambient Lighting - Turn On (Rule#rule-l0ki453b) evaluation complete
    [stable-22119]2022-06-01T22:20:19.082Z <httpapi:NOTICE> HTTP API v1 22021 base URL http://172.16.128.6:8111; listening
    [stable-22119]2022-06-01T22:20:19.228Z <app:NOTICE> HTTP server running; registering proxy endpoints.
    [stable-22119]2022-06-01T22:20:19.228Z <app:NOTICE> Starting WSAPI...
    [stable-22119]2022-06-01T22:20:19.229Z <wsapi:NOTICE> wsapi: starting version 21334
    [stable-22119]2022-06-01T22:20:19.656Z <Engine:INFO> [Engine]Engine#1 master timer tick, local time "6/2/2022, 8:20:19 AM" (TZ offset 600 mins from UTC)
    [stable-22119]2022-06-01T22:27:54.788Z <wsapi:INFO> wsapi: connection from ::ffff:172.16.128.5
    • Tail of log file from failed to start after upgrade (is identical, ii.e. nothing has been appended to it)
    • reactor.wrapper.log (log file the failed to start event points to)
    2022-06-02 08:19:23 - Stopping reactor.exe
    2022-06-02 08:19:23 - ProcessKill 3628
    2022-06-02 08:19:25 - Shutdown exception
    Message:A system shutdown is in progress.
    Stacktrace:   at System.Runtime.InteropServices.Marshal.ThrowExceptionForHRInternal(Int32 errorCode, IntPtr errorInfo)
       at System.Management.ManagementScope.InitializeGuts(Object o)
       at System.Management.ManagementScope.Initialize()
       at System.Management.ManagementObjectSearcher.Initialize()
       at System.Management.ManagementObjectSearcher.Get()
       at winsw.WrapperService.GetChildPids(Int32 pid)
       at winsw.WrapperService.StopProcessAndChildren(Int32 pid)
       at winsw.WrapperService.StopIt()
       at winsw.WrapperService.OnShutdown()
    2022-06-02 08:20:11 - Starting C:\Program Files\nodejs\node.exe  C:\reactor\reactor\node_modules\node-windows\lib\wrapper.js --file C:\reactor\reactor\app.js --scriptoptions= --log "Reactor wrapper" --grow 0.25 --wait 1 --maxrestarts 3 --abortonerror n --stopparentfirst undefined
    2022-06-02 08:20:11 - Started 3272
    2022-06-02 08:30:54 - Stopping reactor.exe
    2022-06-02 08:30:54 - ProcessKill 3272
    2022-06-02 08:30:54 - Found child process: 3280 Name: conhost.exe
    2022-06-02 08:30:54 - Found child process: 3504 Name: node.exe
    2022-06-02 08:30:54 - Stopping process 3280
    2022-06-02 08:30:54 - Send SIGINT 3280
    2022-06-02 08:30:54 - SIGINT to 3280 failed - Killing as fallback
    2022-06-02 08:30:54 - Stopping process 3504
    2022-06-02 08:30:54 - Send SIGINT 3504
    2022-06-02 08:30:54 - SIGINT to 3504 failed - Killing as fallback
    2022-06-02 08:30:54 - Stopping process 3272
    2022-06-02 08:30:54 - Send SIGINT 3272
    2022-06-02 08:30:54 - SIGINT to 3272 failed - Killing as fallback
    2022-06-02 08:30:54 - Finished reactor.exe
    2022-06-02 08:33:41 - Starting C:\Program Files\nodejs\node.exe  C:\reactor\reactor\node_modules\node-windows\lib\wrapper.js --file C:\reactor\reactor\app.js --scriptoptions= --log "Reactor wrapper" --grow 0.25 --wait 1 --maxrestarts 3 --abortonerror n --stopparentfirst undefined
    2022-06-02 08:33:41 - Started 4184
    2022-06-02 08:36:57 - Starting C:\Program Files\nodejs\node.exe  C:\reactor\reactor\node_modules\node-windows\lib\wrapper.js --file C:\reactor\reactor\app.js --scriptoptions= --log "Reactor wrapper" --grow 0.25 --wait 1 --maxrestarts 3 --abortonerror n --stopparentfirst undefined
    2022-06-02 08:36:57 - Started 3100
    • Windows event log event:
    Child process [4184 - C:\Program Files\nodejs\node.exe  C:\reactor\reactor\node_modules\node-windows\lib\wrapper.js --file C:\reactor\reactor\app.js --scriptoptions= --log "Reactor wrapper" --grow 0.25 --wait 1 --maxrestarts 3 --abortonerror n --stopparentfirst undefined] finished with 1
      In your Reactor directory, please do npm ls and post the results.
      W 1 Reply Last reply
        W Offline
        W Offline
        wokwon
        Note this is in the 'rolled back' state, not the 'wont start' state:
        PS C:\reactor\reactor> npm ls
        reactor-multi-system@1.0.3-22041 C:\reactor\reactor
        +-- @influxdata/influxdb-client@1.23.0
        +-- @mdi/font@5.9.55
        +-- @popperjs/core@2.11.2
        +-- body-parser@1.19.2
        +-- bootstrap-icons@1.5.0
        +-- bootstrap@4.6.1
        +-- cookie@0.4.2
        +-- digest-fetch@1.2.1
        +-- diskusage-ng@1.0.2
        +-- express@4.17.3
        +-- feather-icons@4.28.0
        +-- font-awesome@4.7.0
        +-- gridstack@5.0.0
        +-- jquery-ui-dist@1.13.1
        +-- jquery@3.6.0
        +-- js-yaml@3.14.1
        +-- minimist@0.0.10 extraneous
        +-- node-fetch@2.6.7
        +-- node-stream-zip@1.15.0 extraneous
        +-- node-windows@1.0.0-beta.6 extraneous
        +-- nodemailer@6.7.2
        +-- optimist@0.6.1 extraneous
        +-- qs@6.10.3
        +-- serve-static@1.14.2
        +-- uuid@8.3.2
        +-- wordwrap@0.0.3 extraneous
        +-- ws@7.5.7
        `-- xml@0.0.12 extraneous
          That is the correct list. From what you posted, it looks like you are somehow installing the wrong version of node-windows. The latest version is known not to work, and the developer is too busy to fix it, so the beta.6 is the required version. Make sure you are following the installation instructions to the letter (which do specify that particular beta6 version). This is all confirmed to work, I believe @wmarcolin can confirm, as I went through this with him a couple of weeks ago when we discovered the deficiency in node-windows.
          To make sure everything is well and truly cleared out before doing the upgrade, make sure you uninstall any existing Reactor service, then remove completely the package dependencies directory, and then make sure there is no global version of node-windows installed:
          cd \path\to\reactor
          node tools\install_reactor_windows_service.js -u .
          del /s /f node_modules
          npm rm -g node-windows
          Then do the full upgrade install.
          node-windows also creates a daemon directory in the Reactor directory when it attempts to start the service, and places its startup log files there. That would be another place to check for useful messages (particularly the .wrapper.log file).
          I've enhanced the upgrade instructions for Windows to more thoroughly document the steps needed while node-windows needs to be installed in a downgraded state.
            cd \path\to\reactor
            W Offline
            W Offline
            wokwon
            @toggledbits Thank you for the info and I'll try this later on and report back.
            • W Offline
              W Offline
              wokwon
              So, following:
              cd \path\to\reactor
              npm uninstall node-windows
              npm uninstall -g node-windows
              npm install -g node-windows@1.0.0-beta.6
              npm link node-windows
              ...extract the Reactor.zip over the old directory...
              node tools\install_reactor_windows_service.js -i .
              I'm now running fine with Reactor (Multi-hub) stable-22136.
              Thank you @toggledbits for your support and amazing product.
              Bonus is the SSL now works too (CertifytheWeb with LetsEncrypt will renew it and drop the key files in the correct location). That means I can have Reactor as a tab in the Hass sidebar (previously https Hass --> http reactor would not work).
              Ractor.yaml:
              99a5f802-c3e4-4bfa-9a29-975de1da4d28-image.png CertifyTheWeb:
              621270ab-242f-47c4-a7ee-d547ce9eb4cf-image.png Browser:
              MatohlM 1 Reply Last reply
                164.6k
