  3. Goodbye Brothers in crime!
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
iCOMEN boiler switch
5 Posts 5 Posters 992 Views 5 Watching
    sender
    Hi @ll, last days I migrated my last zwave device from Vera to zwave js in homeassistant. Out of 150 devices 1 did not go well initially but reinterviewing did it directly. Most work was to find the ex and inclusion procedure, 3 times, click, clack, whatever. I must admit that Vera is Lighting fast!!!!! With only 3 devices left, those were my under the floor switches I had to do last.
    Now I am totally gone from Vera, altui, luup, etc. There's nothing more left for me on this forum. And since it was one of my "routine sites" reading I will save a few minutes a day skipping it.
    I thank you all for all the kind help, warm words and laughter about the ezlo flop :-).
    I hooe you all will be safe and healthy and whish you all the best!
    I will stay on the homeassistant forum.
    Goodbye!
    wmarcolinW 1 Reply Last reply
      Goodbye, and good luck (in the very best of ways.)
      AK
      • S sender
        Goodbye!
        @sender
        I am on this path but going to Hubitat.
          Those of us who once stood atop the old Forum leaderboard(s) will always be brothers in arms. I made the leap away from Vera to Hubitat last month and could not be happier.
          Seeing less of anyone in a home automation forum can only be considered good news, no? :-}
            Shouldn't this topic be set to "SOLVED"? 😉 Good luck with Hass, and not in the ironic way.
              99.7k
            • Next Release?
