  4. MSR under reverse proxy?
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
11 Posts 2 Posters 3.7k Views 2 Watching
    It uses document.location.hostname (Javascript DOM), so it's already doing what you ask, it seems. Open the console log. It logs the URL it's trying to open.
    The server also logs connection attempts to reactor.log, and will note any conflict with the allows_ips list, if you've configured that.
      I'm currently out of my home network, so no access to logs. But, Javascript's console is giving me this error:
      ClientAPI.js:324 API: starting Reactor client API
      ClientAPI.js:228 API: opening ws://msr.mydomain:8111/wsapi
      ClientAPI.js:278 API: attempting ws connection to ws://msr.mydomain:8111/wsapi
      ClientAPI.js:280 API: got socket 1639471421927```
      So, it's definitely trying to reach port 8111 on ws:// protocol. I'm using Synology Reverse Proxy to temporary get access to the web UI restricting by domain name and IP address and it's a very easy way to get access (in theory) when on the road (I'm using it with Vera as well).
        OK. This doesn't show an error. Was there one? What it does show is the URL it's trying to connect to (does that seem right under the circumstances? Can that name resolve?) and a socket attempt and success. These will usually be followed by API: connected to and API: initial structure loaded, if the WebSocket negotation/conversion is successful. I have no experience with this proxy, so I have no idea if it would even support WS connections.
        You might look at these to see if there's any help there:
        https://mlohr.com/websockets-for-synology-dsm/
        Synology Inc.
        What can I do if I see
        Synology Knowledge Center offers comprehensive support, providing answers to frequently asked questions, troubleshooting steps, software tutorials, and all the technical documentation you may need.
        May 26, 2020
        Synology DSM Reverse Proxy
        ⚠ This guide has been migrated from our website and might be outdated. Feel free to edit this guide to update it, and to remove this message after that. Synology NAS is the perfect companion to running Home Assistant. But by default, the DSM Reverse Proxy does not configure its NGINX settings to...
          Synology Inc.
          May 26, 2020
          @toggledbits I've already mapped websockets, but the problem is that it's trying to reach ws:// under 8111. Code is obfuscated, but I guess this line is probably writing the port as well
          var _0x577573 = _0x36251f(0x107) + document[_0x36251f(0xd9)][_0x36251f(0x13b)] + _0x36251f(0x11f);
          Looking at logs, it's writing:
          so it's something related to the port being added. I'm still out of home network, but I'll definitely look at logs when I'll be back.
            Per my earlier post, it's using document.location.hostname. What's the URL that's showing in your browser when you access Reactor through the proxy? Does it change the port from 8111 to something else?
              @toggledbits nope, it's msr.mydomain:80 or 443 (I've tried both). So strange.
                No worries, that's an easy fix. If I use document.location.host rather than document.location.hostname, it will include the port if it's other than the standard. That will be in the next build.
                  wow, thanks! I'll update tomorrow and test from the office!
                    So, it's working, but only under HTTP. When under HTTPS, it tries to connect to ws:// instead of wss:// and it's failing. It's OK for me, since it's a private DNS and a reverse proxy, and I'm usually using it while in office to avoid the use of VPN. Thanks again for the quick fix!
                      I'll look into that.
                        162.9k
