  3. Favorite lightweight linux distro?
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
25 Posts 5 Posters 12.5k Views 5 Watching
  • DesTD Offline
    DesTD Offline
    DesT
    @rafale77 The binary is working, I can start it. I would need to do a test to "upgrade" my real setup!
    • DesTD Offline
      DesTD Offline
      DesT
      @rafale77 Looks like I can be able to do something, I just need to find which file I need to check to make sure I don't override something!
        Thanks, I definitely looked at both Debian and Alpine.
        On Debian, it seems like you all like the hardcore base OS. Any reason not to consider the seemingly lighter offshoots like Elive?
        I am struggling a bit to already see big differences between debian and ubuntu which is based on it but then they each have other distros spawn off of them too... They share the same linux kernels, following different version update strategies. Maybe I am wrong but shouldn't programs and packages compiled on one be able to run on the other?
        For having dug deep into openWRT for example, the shift after chaos calmer to the LEDE branch led to binaries no longer being compatible due to a change in the C library used in the kernel. I don't seem to see anything similar between ubuntu and debian. Merely different apt repository differences?
        @DesT, what is preventing you for example from running the ubuntu build of z-way-server on your debian install?
        @rafale77 said in Favorite lightweight linux distro?:
        None at all
        They might, and probably will. But sometimes they wont't. I can't honestly recall the lat time I found that happening, and I can't also recall the last time I tried to do something on Ubuntu that wouldn't work on Debian (or any of the derivatives) that didn't
        Most of the issues that I used to struggle with were installation methodologies and locations.
        • DesTD DesT
          @DesT
          The files in the folders /opt/z-way-server/config and in /opt/z-way-server/automation/storage are the ones related to your backups in the expertUI and smarthomeUI respectively.
          The plugin files typically don't get overridden but just in case, they are stored in /opt/z-way-server/automation/userModules.
            None at all
            @CatmanV2
            Thanks! I think I will test Elive next! Then maybe Arch(Bang?) or Bohdi.
            ThisHosting.Rocks  /  Jul 3, 2017
            50+ Best Lightweight Linux Distros for 2026 – ThisHosting.Rocks
            The ultimate list of the best lightweight Linux distros. Every distro has (extremely) low hardware requirements and it’s great for old computers.
            Jan 5, 2024  /  Geek List
            25 Best Lightweight Linux Distros To Power Up Your Old Computers in 2024
            Are you owning an old computer or laptop having limited specs to run a powerful operating system? Then lightweight Linux distros would be the perfect choice to resurrect your old buddy.
              I used to love Mint but have no idea what it's like now.
                I am testing the spicier peppermint! 🙂 It's more lightweight and so far I am liking it. The use of the laptop for the home automation controller has the advantage of including a built in UPS... and a screen and keyboard when needed. When I look at what one can get for ~$100 for laptops these days, it's starting to challenge the use of SBCs.
                  I am testing the spicier peppermint! 🙂 It's more lightweight and so far I am liking it. The use of the laptop for the home automation controller has the advantage of including a built in UPS... and a screen and keyboard when needed. When I look at what one can get for ~$100 for laptops these days, it starts challenge the use of SBCs.
                  Yes, but, well, big and prone to overheat if you try and run them with the lid shut. If you run them with the lid open, then dust.....
                    @CatmanV2
                    True! but it also depends on how old the CPU is and what you buy. The Chromebook class of Gemini Lake CPUs have TDP of 8W! From my testing they consume about the same power as a rPi 4 (with the screen off) at peak and run much cooler while offering 3-4X the performance. Yeah they are more expensive but not by much. My N4100 mini PC is one such example... passively cooled and powered by POE. power requirements are even lower than for an rPi4.
                    I am testing a refurb laptop with an i7 8550u 15W-TDP which is now completely passively cooled idling at 34C (ambient of 22C) and needs to be "benchmark stressed" to hit 65C. (ok I admit it, I modded the cooler to get to this result. The laptop offers more room for passive cooling solutions...) Surprisingly as I reported above the peppermint OS made a difference vs. ubuntu which led to my question.
                    I left the laptop on with the lid closed overnight and to the touch, I can't tell that it is on... No warm spot anywhere. With ubuntu server it would slowly creep up and steady at 42-43C which was detectable to the hand.
                      Hehehe. Chromebooks are a bit different I accept. And not what I was thinking about running laptops. Some laptops are fine running with the lid shut. Others not so much 😉
                      • DesTD Offline
                        DesTD Offline
                        DesT
                        I think that a rock64 from pine64 can be a very nice board to run a bunch of "home automation" stuff!
                          For our workloads (web and apps, mainly in cloud), in combination with Kubernets, we regularly use Alpine. it's very lightweight, but you can build an image with exactly the things you need: https://alpinelinux.org/
                          @therealdb
                          I end looking at alpine and turns out the show stopper is musl vs. glibc... the same problem as LEDE vs openWRT so there will be compatibility issues with most of what we run which are compiled with glibc.
                          Moving away from Alpine
                          We have decided to move away from Alpine and here's why
                            @rafale77 I never tried with complex setup, because IOT/web loads have usually few dependencies, but I was always fascinated because of the ability to create a container of few megs and the easy load on the target system.
                              Hmm I’ve been looking at Proxmox and now I am thinking about just load it on the laptop and migrate all my VMs over to it so it would free up my NAS. Quite a fascinating project to run on a dedicated server...
                              • DesTD Offline
                                DesTD Offline
                                DesT
                                Running Proxmox for the last 5 years!
                                  #23
                                  That's what I realized from some of the screenshots you shared... That's another interesting project for me as I am also looking into more AI applications. One interesting one here for better facial recognition:
                                  https://deepstack.cc
                                  Maybe I could even cluster together some mini pcs and laptops...
                                  • DesTD Offline
                                    DesTD Offline
                                    DesT
                                    You need at least 3 machines for a cluster 😉
                                    • DesTD DesT
                                      @DesT
                                      Just installed it on only one node... my passively cooled mini PC on which I used to run my vera emulator... so far I am impressed. The failover server feature will be very useful.
                                        164.5k
