  3. Plugins
  4. Reactor scope issues
Plugins
openweather plugin ?
Plugins
Openluup: Datayours
Plugins
Plugins
zigbee2mqtt and openLuup
Plugins
Plugins
Sonos system alerts truncated
Well pretty sure I didn't change or touch anything! I've turned everything on and off again as one might hope. Excepting a total reboot of the Pi3 that's running all my stuff very reliably in openLuup. It's all been working well for years and now all of sudden 6 second alerts are truncated to about 4 seconds. Occasionally it works as it should. I see this in the log - does it help? 2023-02-20 09:39:06.662 luup_log:0: My Lua ver 0.50 debug: executing scene 63: "Check windows doors" in room: "Watchers" 2023-02-20 09:39:06.663 luup.call_action:: 217.urn:micasaverde-com:serviceId:Sonos1.Alert 2023-02-20 09:39:06.663 luup.call_action:: action will be handled by parent: 214 2023-02-20 09:39:06.663 luup_log:0: My Lua ver 0.50 debug: rest of scene 63 was executed 2023-02-20 09:39:06.663 luup.scenes:: scene 63, Check windows doors, initiated by AltUI 2023-02-20 09:39:06.665 luup_log:214: Sonos: Alert action on device 217 URI "http://redacted:3480/www/sounds/AllClosed.mp3" duration "6" 2023-02-20 09:39:06.758 luup_log:214: Sonos: UPnP_request (Pause, urn:schemas-upnp-org:service:AVTransport:1): status=1 statusMsg=500 result=[<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns="urn:schemas-upnp-org:control-1-0"><errorCode>701</errorCode></UPnPError></detail></s:Fault></s:Body></s:Envelope>] 2023-02-20 09:39:06.759 luup_log:214: stack traceback: ./L_SonosSystem1.lua:265: in function 'error' ./L_SonosUPnP.lua:289: in function <./L_SonosUPnP.lua:169> (tail call): ? ./L_SonosSystem1.lua:3390: in function 'sayOrAlert' ./L_SonosSystem1.lua:3452: in function 'queueAlert' ./L_SonosSystem1.lua:3843: in function <./L_SonosSystem1.lua:3839> (tail call): ? [C]: in function 'pcall' ./openLuup/scheduler.lua:204: in function 'context_switch' ./openLuup/scheduler.lua:366: in function 'dispatch' ./openLuup/scheduler.lua:588: in function 'task_callbacks' ./openLuup/scheduler.lua:699: in function 'start' openLuup/init.lua:354: in main chunk [C]: ? 2023-02-20 09:39:06.888 luup.variable_set:: 214.urn:toggledbits-com:serviceId:SonosSystem1.zoneInfo was: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... now: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... #hooks:0 2023-02-20 09:39:06.895 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.TransportState was: STOPPED now: TRANSITIONING #hooks:0 2023-02-20 09:39:06.901 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentPlayMode was: SHUFFLE_NOREPEAT now: NORMAL #hooks:0 2023-02-20 09:39:06.913 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTransportActions was: Set, Stop, Pause, Play, X_DLNA_SeekTime, Next, X_DLNA_SeekTrackNr now: Set, Stop, Pause, Play, X_DLNA_SeekTime, X_DLNA_SeekTrackNr #hooks:0 2023-02-20 09:39:06.921 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.NumberOfTracks was: 10 now: 1 #hooks:0 2023-02-20 09:39:06.922 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.AVTransportURI was: x-rincon-queue:RINCON_000E58DC7BBE01400#0 now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.929 luup_log:214: Sonos: UPnP_request() "urn:schemas-upnp-org:service:AVTransport:1"#"GetPositionInfo" action took 5.0073010921478s (long) 2023-02-20 09:39:11.932 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackDuration was: 0:02:22 now: 0:00:00 #hooks:0 2023-02-20 09:39:11.933 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackURI was: x-file-cifs://ELEPHANT1/Multimedia/My%20Music/Music%20JP/The%20Smiths/The%20Queen%20Is%20Dead/08%20Vicar%20in%20a%2... now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.934 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackMetaData was: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... now: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... #hooks:0 2023-02-20 09:39:11.936 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentStatus was: Vicar in a Tutu: (The Smiths, The Queen Is Dead) now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTitle was: Vicar in a Tutu now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentArtist was: The Smiths now: #hooks:0 2023-02-20 09:39:11.938 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentAlbum was: The Queen Is Dead now: #hooks:0 Also see these: 2023-02-24 16:12:13.576 openLuup.server:: GET /www/sounds/YouRang.mp3 HTTP/1.1 tcp{client}: 0x17e96f0 2023-02-24 16:12:13.579 openLuup.server:: error 'closed' sending 43102 bytes to tcp{client}: 0x17e96f0 So any clues?
Plugins
Generic support for vacuums
Plugins
Switchboard plugin
Plugins
Plugins
Plugins
B
Plugins
Plugins
This topic has come up before but I haven't seen an answer. Symptom: AltuUI says there is a new update available, so you tell it to do the update but the update does not happen. AltUI remains stuck on it's old version. On other occasions it works OK. So my version is: AltUI v2.49.2546, © 2019 AltUI says this: a newer version #2551 of ALTUI is available, do you want to upgrade ? add scrollable dialog for long boxes bugfix: clock display on safari remote url update ( @olov ) update jquery and bootstrap versions credential to camera device url ( @rafale77 ) ignore Ezlo hub ( @reneboer) Track through the JavaScript and find that this issues the update command: function _triggerAltUIUpgrade(newversion,newtracnum) { var url = '?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version={1}&TracRev={0}'.format(newversion,newtracnum); return _httpGet(url,{}).always( function() { PageMessage.message(_T("Upgrade Request succeeded, a Luup reload will happen"),"success"); }); }; And the url variable equals: url: "?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551" All looks good so far. I manually issue the same url complete with my openLuup ip_address in a local browser. Update fails - looks like AltUI is doing as it should: http://ip_address:3480/data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551 In openLuup I see: 2021-12-06 13:56:14.821 luup_log:3: ALTUI: startupDeferred, called on behalf of device:3 2021-12-06 13:56:14.838 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.Version was: v2.49 now: v2.49 #hooks:0 And then later: 2021-12-06 13:55:58.256 openLuup.server:: GET /data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551 HTTP/1.1 tcp{client}: 0x25712a8 2021-12-06 13:55:58.257 luup.call_action:: 0.urn:micasaverde-com:serviceId:HomeAutomationGateway1.CreatePlugin 2021-12-06 13:55:58.259 luup.call_action:: 4.urn:upnp-org:serviceId:AltAppStore1.update_plugin 2021-12-06 13:55:58.260 luup_log:4: AltAppStore : starting <run> phase... 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : downloading amg0/ALTUI [2551] to trash/AltAppStore/ 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents?ref=2551 2021-12-06 13:55:58.760 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents/blockly?ref=2551 2021-12-06 13:55:59.543 luup_log:4: AltAppStore : getting contents of version: 2551 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine1 was: AltAppStore now: Downloading... #hooks:0 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: now: Alternate UI #hooks:0 2021-12-06 13:55:59.544 luup_log:4: AltAppStore : scheduling <job> phase... 2021-12-06 13:55:59.544 openLuup.requests:: 2021-12-06 13:55:59.545 openLuup.server:: request completed (148 bytes, 1 chunks, 1288 ms) tcp{client}: 0x25712a8 2021-12-06 13:55:59.554 openLuup.server:: request completed (6233 bytes, 1 chunks, 16442 ms) tcp{client}: 0x255e680 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : ...final <job> phase 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : Total size 0.000 (kB) 2021-12-06 13:55:59.555 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: Alternate UI now: Alternate UI 100% #hooks:0 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating icons in icons/ ... 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating device files in ./ ... 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 icon files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 device files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : Alternate UI update completed 2021-12-06 13:55:59.556 openLuup.luup:: device 4 'Alternate App Store' requesting reload 2021-12-06 13:55:59.556 luup.reload:: saving user_data 2021-12-06 13:56:00.262 openLuup.luup:: exiting with code 42 - after 0.3 hours All looks OK. Then I check GitHub. It shows the latest changes to the version 2551. However this page says the latest version is 2550. So I wondering what's going on. Seems the latest version number is not being picked by the installer? (not sure how it works.) Is it possible for openLuup to log a bit more about the version it's trying to install. As this call returns. https://api.github.com/repos/amg0/ALTUI/contents?ref=2551 message "No commit found for the ref 2551" documentation_url "https://docs.github.com/v3/repos/contents/" But this works fine: https://api.github.com/repos/amg0/ALTUI/contents?ref=2550 So it looks like AMG0 doesn't always update the repository with whatever is needed to get this to work (I imagine that's easy to forget). But could openLuup send back a fail result to AltUI and AltUI pick that up? Currently it looks like AltUI always assumes everything went OK. Or somehow; could openLuup log and/or notify the user what went wrong?
Plugins
Reactor: double click action
Plugins
Virtual Pronto Remote plugin
Plugins
openLuup: SmartSwitch plugin
Plugins
Reactor icons for local lan
B
Plugins
openLuup: Tasmota MQTT Bridge
Plugins
AltUi
Plugins
17 Posts 4 Posters 7.3k Views 4 Watching
    I know nothing about MSR, so can't comment on the specifics. I know of nothing that's changed (for quite a while) in openLuup's handling or display of variables that could cause this, and, as you say, other plugins seems to be OK.
    I see from the first log snippet that values have been changed from nil to blank, yet this is not what's shown on the sensor variable screen shot. This is not simply because you haven't refreshed the display? Unlike AltUI, the openLuup console does not use Ajax calls to update itself in real time.
    B Offline
    B Offline
    Buxton
    @akbooer Yes, I tried browser refresh without any change. If you look at the log, you see the variables flopping from nil to empty and then back again to nil.
    @therealdb are you seeing anything like this in your openLuup reactor installation? I'm only seeing this nil behavior with Reactor expression variables.
      @akbooer This isn't MSR, it's the Reactor plugin.
      @Buxton Reactor expressions/variables are not Luup state variables, and they are not presented as such on any device. They live within the ReactorSensor only.
      B Offline
      B Offline
      Buxton
      @toggledbits OK. Does that mean that the log entries as shown above are expected ie. that the flopping (from nil to empty and back again) for reactor expression variables is routine?
      • B Buxton
        @buxton sorry, I’ve moved to MSR and mostly far from *luup.
        B 1 Reply Last reply
          B Offline
          B Offline
          Buxton
          @therealdb Well that's a shame. One more nail in the coffin. I'll probably move to HA as soon as the various versions of the software are consolidated. It's a great platform, but for my needs, it is still too subject to breaking structural changes.
            I suspect it's trying to delete variables it no longer needs. Newer versions of Vera Luup will delete a state variable if you pass nil for the value, but I'm not sure if openLuup does that or not.
            • B Buxton
              @buxton my strategy at the moment is to use my Vera as a Zwave server, with some minor code automations still running on it because moving 4 years of code and scenes is not trivial. But the logic is in MSR and I’m using home assistant to get what I’m missing (ecovacs, nest, bmw, energy dashboard). Honestly, if used liked I’m doing, HASS is very stable, my Vera too and the rest is done by my own system written in C#, that it’s able to talk to them all and orchestrate complex things when in MSR it’s not possible at the moment (ie intercept mqtt messages and parse them to execute complex actions). But I’m confident Patrick will further evolve it.
                B Offline
                B Offline
                Buxton
                @toggledbits Yes, I think that's a large part of the problem as I'm seeing the same behavior with deleted groups in various sensors. The sensor groups flop between nil and empty in the attempt of trying to delete the variable.
                There seems to be a separate issue of the openLuup log not picking up on variables for your various plugins log entries.
                I'm guessing this has to do with assigning the luup log function to a table and then calling a truncated name ie L(...) when writing to the log. So there is some scope issue going on that is different on openLuup from that of a Vera, brought about by a level of abstraction.
                akbooerA toggledbitsT 2 Replies Last reply
                  B Offline
                  B Offline
                  Buxton
                  @therealdb Yes, that's where I'm headed too. Agreed that Hass is very stable. It's just that there are real structural changes being made all the time, and before I sink my time into learning the details of the software, I want to be sure that pretty much everything is final in the engine.
                    @toggledbits said in Reactor scope issues:
                    No, it doesn’t.
                    You can, of course, delete them manually from the console, or just delete the whole device.
                    • B Buxton
                      @buxton said in Reactor scope issues:
                      Sorry, but I have absolutely no idea what this means.
                      • B Buxton
                        I'm with @akbooer on this; I have no idea what it means. I don't know what "picking up on variables" means or what it has to do with the log, as these are completely separate concepts that are only connected through intentional coding, nothing implicit. I don't know what "assigning the luup log function to a table" means... I don't think I do that; certainly not in the Reactor plugin. The L() function, which is a first-class function definition, calls luup.log() directly.
                        I'm not at all clear what your expectations are or what problem you are reporting. The nil issue will be an openLuup peculiarity but will likely only happen when the ReactorSensor starts/restarts (that's when it attempts that cleanup) and is completely benign (although it would be nice if openLuup implemented Vera Luup's functionality here). You can probably make those messages go away yourself by just deleting those variables with nil using openLuup's UI/control panel (delete icons are shown in your screen shot) since Reactor isn't able to on openLuup, but the effect should be the same. If there's another issue you're worried about, I'm not seeing it, at least, not based on what you've explained and posted so far.
                          I can easily do this. I didn’t previously because, originally, Vera didn’t do this, and then, later, it was an undocumented side effect. Finally, IIRC, it was actually endorsed.
                            B Offline
                            B Offline
                            Buxton
                            @toggledbits @akbooer Sorry, I will try to be clearer.
                            " I don't know what "assigning the luup log function to a table" means"
                            In many of Patrick's plugins, he uses a global lua table to hold plugin data and functions. He assigns shorthand names that call common luup functions, then stores those truncated names in the table. Then the first class functions are called from the table. I believe it is this abstraction that is contributing to log entries that show nil values, as direct calls of "luup.log" do not show nil values. The technique should work in openluup, and most often it does, but sometimes it doesn't.
                            Here's an example from the log where it does not work:
                            2022-01-15 14:13:12.551   luup.variable_set:: 258.urn:micasaverde-com:serviceId:HaDevice1.CommFailure was: 0 now: 0 #hooks:0
                            2022-01-15 14:13:12.551   luup.variable_set:: 258.urn:micasaverde-com:serviceId:HaDevice1.CommFailureTime was: 0 now: 0 #hooks:0
                            2022-01-15 14:13:12.551   luup_log:149: Reactor: Starting nil (#nil)
                            2022-01-15 14:13:12.551   luup.variable_set:: 149.urn:toggledbits-com:serviceId:Reactor.Message was: Starting Unused1 now: Starting Basic Functions #hooks:0
                            2022-01-15 14:13:12.552   luup.variable_set:: 265.urn:toggledbits-com:serviceId:ReactorSensor.Invert was: nil now:  #hooks:0
                            2022-01-15 14:13:12.552   luup.variable_set:: 265.urn:toggledbits-com:serviceId:ReactorSensor.Invert was:  now: nil #hooks:0
                            In the log entry "luup_log:149: Reactor: Starting nil (#nil)" the text of the log entry is there "Reactor: Starting", but the variable following the text is nil. This is what I meant by "picking up on variables". The log entries are being displayed, but anything that is a variable is showing as nil. The variables themselves are not actually nil because I can see from program execution that they are doing the job that they're supposed to be doing. It is only in the log entries that they show as nil, at least insofar as what is visible to me.
                            As for using nil to delete a variable, that seems to be understood and is separate from the log problem.
                            I believe that this is a scope problem, thus the title of the post. But I don't believe this is a reactor scope problem in that the same issue does not occur on the Vera itself. So for whatever reason, in openLuup, the scope of the variable being displayed in the log is different from the scope of the log function--that the value of the variable is somehow hidden from the function.
                            This is a problem as it relates to the readability of the log, an annoyance more than anything, so I have no expectations to have it fixed. In my original screenshots, you can see multiple log entries that display as nil, so that's why I brought this to your attention as I felt that if there are scope issues at work with the logging function, then it could be happening elsewhere as well.
                            The only other thing that I would add is that in my startup lua, I call a module in the _G space so that I can access functions in the lua section of Reactor activities. My call is _G.myStartUpLua = require("myStartUpLua") I don't believe that this should have an effect on the log, but perhaps it does.
                            • B Buxton
                              Umm... no, I don't think I do. That actually sounds like something I would very specifically not do. Not a big fan of globals; I only use them where Luup forces me to.
                              Can you post some code that shows what you think that is?
                              Here, for example, is the definition of the log function L() commonly used in Reactor, which is a model/function I use frequently...
                              local function L(msg, ...) -- luacheck: ignore 212
                                  local str
                                  local level = defaultLogLevel or 50
                                  if type(msg) == "table" then
                                      str = tostring(msg.prefix or _PLUGIN_NAME) .. ": " .. tostring(msg.msg or msg[1])
                                      level = msg.level or level
                                  else
                                      str = _PLUGIN_NAME .. ": " .. tostring(msg)
                                  str = string.gsub(str, "%%(%d+)", function( n )
                                          n = tonumber(n, 10)
                                          if n < 1 or n > #arg then return "nil" end
                                          local val = arg[n]
                                          if type(val) == "table" then
                                              return dump(val)
                                          elseif type(val) == "string" then
                                              return string.format("%q", val)
                                          elseif type(val) == "number" and math.abs(val-os.time()) <= 86400 then
                                              return tostring(val) .. "(" .. os.date("%Y-%m-%d.%X", val) .. ")"
                                  luup.log(str, math.max(1,level))
                              --[[ ???dev if level <= 2 then local f = io.open( "/etc/cmh-ludl/Reactor.log", "a" ) if f then f:write( str .. "\n" ) f:close() end end --]]
                                  if level == 0 then if debug and debug.traceback then luup.log( debug.traceback(), 1 ) end error(str, 2) end
                              It's just a plain local function. No global in a table Luup function reassignment magic anything, just a straight function that gets use in a vanilla way:
                              L("Sensor %1 (%2) first run, setting up new instance...", tdev, luup.devices[tdev].description)
                                164.4k
