  3. Vera firmware update
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
17 Posts 5 Posters 5.1k Views 6 Watching
    ahhh I am trying to remember.... (I nuked my vera and it has become very non vera, much more like a ramips openwrt router)
    I had a script to run on cron to copy the content of the current firmware info file into the firmware latest file.
    I think you are plenty capable of reproducing it:
    The files name is self explanatory and are stored in the /etc/cmh folder. All you need to do is
    cp /etc/cmh/version /etc/cmh/version_latest
    and put that in /etc/crontab/* to run every hour or so. Verify the file names too because this is all out of memory.
    • DesTD Offline
      DesTD Offline
      DesT
      Move to zway + openLuup 😉
        Cheers!
          Ok even better:
          this will disable the automated version checking from the vera:
          edit /www/cgi-bin/cmh/get_version
          and add "return" after the bracket of line 24.
          Now you only need to copy the "version" file once.
          This script runs once a day.
            Your memory is correct 🙂
            ...or very nearly. Actually version_latest 😉
              Interestingly altering the get-version file seems to throw a bit of a cureveball in terms of not thinking you're logged in.
                Uhh I think I even hacked that back then... Since I had removed my vera from my account for ages to prevent errant cmh reloads signals sent from their servers, I could never be logged in. So I hacked the webserver to assume that I always am. I am surprised the two would be related though. Let me see how I did this.
                Probably best to stick with the crontab way for now. It is the least intrusive.
                  Can anyone remind me the trick to stop Vera nagging me about the firmware 'upgrade' that's available. Apart from the move to OpenLuup 😉
                  @CatmanV2 said in Vera firmware update:
                  So that’s only an issue if you use Vera’s own interface, yes? I really can’t remember the last time I needed to do that, since I always ran (indeed, still run) AltUI as my everyday interface to Vera.
                    @akbooer said in Vera firmware update:
                    Force of habit. Fair point, though. Plus the alerts....
                      While looking into SFTPing into my vera I found out that in order to save some minute storage space, they removed SFTP from the vera firmware. You could connect with SSH, SCP but not SFTP. I highlighted this before in the old place but I didn't know how. I just fixed it.
                      So basically dropbear lacks an sftp server and this tiny program is fairly easy to add back.:
                      You just need to install the openssl-sftp-server package and get it launched right after dropbear at startup.
                      I vaguely remember to have forced the webserver to act as if it was logged by editing the /www/cgi/js/interface.js file and changing the value of "this.userAuthenticated" to 1 from !1.
                        OK, cheers. No real panic 🙂
                        • Black CatB Offline
                          Black CatB Offline
                          Black Cat
                          There was a script that did that.
                          I used it so it wasn't a myth. .
                          I've searched for it endlessly but suspect it was removed for reasons unknown.
                          aka Zedrally
                          • Black CatB Black Cat
                            @Black-Cat
                            It is more than likely one of my technical posts they deleted without telling me.
                            It is this:
                            os.execute("cat /etc/cmh/version > /etc/cmh/version_latest")
                            This needs to be run every day though so you could potentially put in a timer triggered scene instead of my crontab idea.
                            There are so many ways to do this... I think this would be the easiest.
                              Black CatB Offline
                              Black Cat
                              @rafale77 said in Vera firmware update:
                              @Black-Cat
                              It is this:
                              No it wasn't this one. The one I used was and os.execute, but only needed to be run once. It worked flawlessly until I ran an update. Probably the only thing that did run without constant attention.
                              aka Zedrally
                                @Black-Cat
                                It is this:
                                @Black-Cat
                                Then I don't know.
                                Another way to make it permanent (until the next upgrade) is to run this:
                                os.execute("sed  -i 's/upgradeAvailable=1/upgradeAvailable=0/g' /www/cgi-bin/cmh/get_version.sh|cat /etc/cmh/version > /etc/cmh/version_latest")
                                Black CatB 1 Reply Last reply
                                  @Black-Cat
                                  Then I don't know.
                                  Black CatB Offline
                                  Black CatB Offline
                                  Black Cat
                                  @Black-Cat
                                  Then I don't know.
                                  That could be it, however, it's a moot point if you have updated to the latest (&Last) FW version.
                                  aka Zedrally
                                    163.8k
