  4. MSR connecting to Ezlo Plus
5 Posts 3 Posters 1.4k Views 3 Watching
  • Tom_DT Offline
    Tom_DT Offline
    Tom_D
    Reactor (Multi-hub) latest-22080-ae7212f
    I am having trouble connecting MSR to a new Ezlo Plus controller.
    I've tried different user names and passwords and triple checked the ID and IP. Not only does it not work but it crashes MSR giving a connection refused error.
    Ezlo Plus:
    Controller ID: 90012863
    Uptime Info: 2d 0h 39m 2s
    Firmware: 2.0.27.1916.1
    Advanced Scenes: 1.36
    reactor.yaml file snippet:
    • id: hubitat
      enabled: true
      implementation: HubitatController
      name: Hubitat Elevation system
      source: "http://192.168...
      dump_all_devices - This is for troubleshooting. Do not enable unless asked.
      dump_all_devices: false
      enabled: true
      implementation: EzloController
      source: "wss://192.168.1.131:17000" # change the IP address
      serial: "90012863" # put your hub's serial # here
      username: "lowercase" # put your username here betw quotes
      password: "?PassWord!" # and password
    • id: weather
      enabled: true
      implementation: OWMWeatherController
    latest-25082-3c348de6
    • Tom_DT Tom_D deleted this topic on
    • Tom_DT Tom_D restored this topic on
    • Tom_DT Offline
      Tom_DT Offline
      Tom_D
      Well, never mind. It must have been a formatting problem. After posting I started over again with a fresh cut and paste from the manual and it all worked.
        Good work, @Tom_D . From the look of it, you were missing the '-' in front of the id: ezlo (compare to the - id: hubitat line). That's important/significant.
        Also, when posting configs and code, try to use a fenced code block to preserve the formatting. It makes things like your issue much more obvious. To start a fenced code block, you put three back-ticks on a line by themselves, then paste your code/config, then another line with just three back-ticks. Looks like this when you type it:
        controllers:
        - id: hubitat
        enabled: true
        - id: ezlo
        enable: true
        And when formatted in the post, it looks like this:
        controllers:
          - id: hubitat
            enabled: true
          - id: ezlo
            enable: true
        Also, check out this tool for editing YAML. Maybe helpful if you're not doing a lot of it.
        Edit and View YAML - Online YAML Tools
        Free, quick and easy online YAML editor. There are no ads or downloads. Simply enter YAML and you can edit it in your browser. Created by developers for developers.
        • Tom_DT Offline
          Tom_DT Offline
          Tom_D
          Thanks for the reply and help.
          The next bit of help I need is in marking this thread solved.
          • Tom_DT Tom_D
            @tom_d Edit the title of your original post by using the meatball menu (three vertical dots) to the right of your signature, next to the Reply Quote.
            *Hubitat C-7 2.5.2.135
            Core 2026.10.1
            MSR: latest-26287-0a7107d5
            • Tom_DT Tom_D marked this topic as a question on
            • Tom_DT Tom_D has marked this topic as solved on
              147.5k
