  4. NUTControlle with influxDB
@toggledbits I pulled the image (well, Watchtower did) and within minutes the whole system went offline. The log looks like it ends with 26143. [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-mkahsmgf/26qq82mw-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lqyfljfi/22f8on0t-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lsb61rw8/24oenqi2-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lrh58he0/rule-lrh58he0:S-1c00gfib-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lrh58he0/1c00dylr-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lrh58he0/1nam9w5u-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-miuh2qqi/22ls4lql-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-kwc6rmci/rule-kwc6rmci:S-1vj8sdfc-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-kwc6rmci/rule-kwc6rmci:S-1qanz01x-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ladyja6a/24lq19p6-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-mk0o8iox/23oy468y-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-miscg2h3/rule-miscg2h3:S-22gmbq1c-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-kxgrfjke/238p0old-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-m7ccsso5/re-m7ccsso5-1r0myjxa-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ladyja6a/19nl9wq2-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ladyja6a/rule-ladyja6a:S-yl3xk9t-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ladyja6a/rule-ladyja6a:S-yl3vv5m-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-ln7j2nqp/re-ln7j2nqp-22mx9lzd-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-ln7j2nqp/22mx87c8-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-licneppy/1mzwe7ht-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ml3194ih/25jqt1j4-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-kxgrg7kf/227hshak-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-reactorexmachina/13ua1p95-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-reactorexmachina/13uagam7-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-grpvl9oypg/rule-grpvl9oypg:R-134x4cbv-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-grpvl9oypg/rule-grpvl9oypg:R-134x2fyl-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-lscjrws1/238p5c22-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lbwr0jvq/1xkczf03-cons [latest-26143]2026-05-31T15:23:44.547Z <Structure:NOTICE> Structure Structure#1 stopped [latest-26143]2026-05-31T15:23:44.547Z <app:NOTICE> Closing APIs... [latest-26143]2026-05-31T15:23:44.547Z <wsapi:NOTICE> wsapi: closing... [latest-26143]2026-05-31T15:23:44.547Z <wsapi:NOTICE> wsapi: disconnecting from "192.168.1.23#82" (1001 service closing) [latest-26143]2026-05-31T15:23:44.548Z <httpapi:NOTICE> HTTP API closing... [latest-26143]2026-05-31T15:23:44.549Z <wsapi:NOTICE> wsapi: server closed [latest-26143]2026-05-31T15:23:44.549Z <httpapi:INFO> HTTP server closed. [latest-26143]2026-05-31T15:23:44.549Z <app:NOTICE> Stopping timers... [latest-26143]2026-05-31T15:23:44.551Z <app:null> Shutdown complete, process ID 1 [latest-26143]2026-05-31T15:23:44.551Z <app:null> Closing logs... [latest-26143]2026-05-31T15:23:44.551Z <default:null> Closing log I can SSH to the VM. Alas, I do not have the previous image for 26143 as I'm a little too quick sometimes on housekeeping.
6 Posts 2 Posters 1.4k Views 2 Watching
  • wmarcolinW Offline
    Hi Patrick,
    I have been using the integration of my UPS with MSR (NUTController-22283) for some months now, and it works very well.
    I would like to evolve a little bit the usage, and I have, at the moment a difficulty, to take the data to influxDB.
    I have also integrated influxDB 1.8 successfully with the MSR, I export the capabilities that I want to use, but the NUT data I have not succeeded, I made several attempts, and I can not send the data, below the configuration that I would like if possible.
            x_nut_ups:
                input_voltage:
                  include: true
                  type: number
                output_voltage:
                  include: true
                  type: number
                battery_charge:
                  include: true
                  type: number
    And I don't succeed, consulting influxDB doesn't show the information:
    > show measurements
    name
    battery_power
    binary_sensor
    humidity_sensor
    motion_sensor
    temperature_sensor
    x_hubitat_extra_attributes
    Could you please give me some guidance on what I am doing wrong?
    I also want to comment if it should appear in the Controller Status widget panel when influxDB is activated.
      There's not enough context in your example for me to definitively help you, but I can see that in all likelihood, your configuration for InfluxDB isn't as described in the documentation and required for InfluxDB to understand your intent.
        Ok, let me put the complete configuration.
        plugins:
          - id: influx
            implementation: InfluxFeed
            enabled: true
            name: InfluxDB Feed 1.8
              influx_url: http://192.168.50.8:8086
              influx_database: Reactor
              influx_username:
              influx_password:
              select_capabilities:
                power_switch: false
                dimming: false
                binary_sensor: true
                motion_sensor: true
                leak_detector: false
                temperature_sensor: true
                humidity_sensor: true
                light_sensor: true
                battery_power: true
                x_hubitat_extra_attributes: true
                x_nut_ups:
                    input_voltage:
                      include: true
                      type: number
                    output_voltage:
                      include: true
                      type: number
                    battery_charge:
                      include: true
                      type: number
        As I mentioned before, the MSR is connecting without any errors with influxDB.
        root@main:/home/wilson/reactor/config# influx -precision rfc3339
        Connected to http://localhost:8086 version 1.8.10
        InfluxDB shell version: 1.8.10
        > use Reactor
        Using database Reactor
        > show measurements
        name
        battery_power
        binary_sensor
        humidity_sensor
        light_sensor
        motion_sensor
        temperature_sensor
        x_nut_ups
        > select * from x_nut_ups
        time                     battery_charge controller entity        input_voltage name      output_voltage
        2022-10-13T00:04:17.939Z 100            nut        nut>TrippLite 122.3         TrippLite 122.9
        2022-10-13T00:04:47.984Z 100            nut        nut>TrippLite 122.3         TrippLite 122.9
        2022-10-13T00:05:38.176Z 100            nut        nut>TrippLite 121.4         TrippLite 122.9
        2022-10-13T00:05:38.177Z 100            nut        nut>TrippLite 121.4         TrippLite 122.9
        2022-10-13T00:06:18.263Z 100            nut        nut>TrippLite 122.3         TrippLite 122.9
        Well, just because I was complaining to the Creator, now it worked without a problem.
        Well, sorry, case closed, but I can assure you that I did several tests. Now an important detail, today I updated the drive from version 22152 to 22283, and I think I had not tested yet with this update.
          Sorry, for an additional query, is it possible to stipulate a condition for saving the data to the database, either by time interval or by changing the attribute's content?
          And sorry if I did not make clear the suggestion that the Controller Status could not appear as the status of activated influxDB.
            The InfluxFeed plugin is not a Controller, so it won't appear on the Controller Status widget.
            It is possible to modify the value being sent to influxdb by adding an expr: key followed by a quoted string containing an expression (shown in the docs). The result of the expression is what will be logged. The current value is available in expression context as the value variable, so expr: "value * value" would send the measurement value as the square of the entity attribute value. However, I personally don't recommend using it. Having a long history with data logging and databases, it has become my preference to always put raw data into the database, as you got it from whatever source, and then use database queries to modify the data. influxdb is capable of doing any kind of transformation in the query from the raw data, and can also build a time series using a specified interval, interpolating as needed (you're probably already doing this by using the mean() function in your queries for graphs, which is an influxdb/grafana default). Also, the expression cannot be used to suppress a value (i.e. prevent it from being sent to influxdb).
            It is not possible to change the InfluxFeed time interval for sending data on the Reactor side, because there isn't one. InfluxFeed sends data whenever the entity is modified. It does not send data at regular timed intervals, and it's not possible to define an interval for sending data. Again, influxdb itself has mechanisms for dealing with this.
            Also, I note in your config that you are logging the entire x_hubitat_extra_attributes capability. This has the potential to send huge amounts of data, and I recommend you use the extended syntax to only log the specific attributes you want.
            wmarcolinW 1 Reply Last reply
              Thanks boss for the master class!! I will change x_hubitat_extra_attributes, you are right, many information I will not use.
                128.0k
