  4. Adding remotes, scene controllers as entities to MSR
31 Posts 4 Posters 13.4k Views 3 Watching
    But, still, I can't for some reason really understand the code and how different parts relate to each other.
    The event section is a filter to look for a specific event. In your version, you have multiple value keys, which is not allowed. Also, you don't want to filter by value, just accept them all and let the response section deal with them. I recommended against using label because it's changeable in ZWave, whereas the property and property_key values are defined by the device and will not change.
    So again, the event section is the filter that determines what incoming event will match, and what will not.
    Once an event matches, the response section determines what to do with it. Each component of the response section is an attribute of an assigned capability and the instructions to set it. In the case of button.state, my version says grab the value from event.data.value, and then, map that value from the device's string to one of Reactor's accepted capability/attribute value. Setting button.since completes the "contract" of the button capability (i.e. makes it work like similar uses of button in other devices and related to other controllers). I'm not sure I can explain it more simply than that.
    It's really just a "if you find this... do this" configuration. The effect is that if a matching button event is detected by the event section, the response section will interpet the value and map it to a Reactor-compatible value to place on the entity attribute button.state, and also update the button.since timestamp. Thus the since timestamp changes every time a button press event is received, but state may not change, because it's possible to press a button once, wait 15 seconds, and press the same button again, which will result in the value single being persistent on the state attribute and not changing. So to detect an event, you have to check both state and since (and this is consistent with all button behavior in Reactor).
    To test button state in a rule, you test button.state for what you want in that rule (equals single, double, triple), and you AND that test with a button.since changes (from any to any). That will send a very short pulse when a matching button press occurs. While testing, to make sure you can see it, add a "sustained for" delay on the changes condition of a few seconds (keep it short), and you'll more easily see what's going on in the status view. Make sure to remove the delay when you're done playing (keeping it will dampen response to buttons when, for example, a single press is done repeatedly within the delay period).
    Example here: https://smarthome.community/assets/uploads/files/1646184651741-cbff18f3-ce2d-4ecd-ae65-2554f77a4a80-image.png
      Andr
      Ok, I understood it at first that I needed to specify more stuff in the event section, like 'value' so it then could be mapped to right command, otherwise it would not be known.
      But nodeid, property and property key is just to filter out right device, all the other data is still there?
      And in that case, I guess that it would work to skip event data and just mapping commands to MSR functions? (Of course nothing else can send 'Keypressed' command because that would be messy)
      • A Andr
        @andr said in Adding remotes, scene controllers as entities to MSR:
        That's right. The event section only filters using the data; it does not modify the data or transform it in any way. Whatever is received in the event structure stays as received.
        I'm not sure what you mean by this. I don't think you want to skip anything. You should filter the incoming events, to make sure that you are handling the right events from the right device. So you need to be specific in the event filter to both the event type and the sending device.
          Andr
          @toggledbits said in Adding remotes, scene controllers as entities to MSR:
          And in that case, I guess that it would work to skip event data and just mapping commands to MSR functions?||
          That was just me trying to understand how stuff is related, not something I would try out.
          For example, in my system there is only one device that are sending "Keypressed3x" and that can not be mixed up with anything else. In that case if I had such uniq string to map to MSR command 'triple' I could skip the filtering in event section?
          Again, this is just for my own curiosa trying to learn something new.
            Andr
            Anyway, some kinds of sucess the last nights 👍
            All buttons are configured and seems to work so far.
            The final reactor.yaml looks like this (just showing the first two buttons as it is just the entity name and 'property key' that differ )
                    "Keyfob_Fyrkant":      # Assign an ID to your entity; each entity must have a unique ID
                      name: Lukas Keyfob Fyrkant   # This is optional but recommended, so you have a friendly name
                      capabilities: ['button']  # define an array of capabilities to be modified by the event
                            event_type: zwave_js_value_notification
                              node_id: 15
                              property: "scene" # Square button
                              property_key: "001"
                            "button.state":  # an attribute that the event modifies.
                              from: "event.data.value"  # dot-reference expression to pull value from event message
                              map:                    # optional, map to modify value
                                KeyPressed: 'single'   # if value is value_in, it is mapped to new_value
                                KeyPressed2x: 'double'
                                KeyPressed3x: 'tripple'
                                KeyHeldDown: 'hold'
                                KeyReleased: 'release'
                            "button.since":  # an attribute that the event modifies.
                              from: "event.context.id"  # dot-reference expression to pull value from event message
                    "Keyfob_Ring":      # Assign an ID to your entity; each entity must have a unique ID
                      name: Lukas Keyfob Ring   # This is optional but recommended, so you have a friendly name
                              node_id: 15
                              property: "scene" # Circle button
                              property_key: "002"
                                KeyPressed3x: 'triple'
                                KeyHeldDown: 'hold'
            A thought that crossed my mind recently, to maybe expand the functions of this little remote in the future.
            Fibaro have built in a possibilty for 6 extra scenes that activates after a sequence of button presses I specify. I have not activated this yet as I don't think I really need it, but what I realised is that it probably quite easy to add a lot of differnt button sequences in MSR as long or short that I want?
            Next part is to get some rules and actions set-up that can use the remote.
              Andr
              wrote on last edited by Andr
              Seems to work like a charm 😁
              Started out with a few rules to let him control a Sonos in his room.
              This one is for starting his favorite playlist, when it not is bedtime and that playlist isn't already playing.
              • C Offline
                C Offline
                christian_fabre
                Thanks ...
                I followed this post and managed to successfully use my HANK SCN04 remote with Reactor and Home Assistant.
                A A 2 Replies Last reply
                • C christian_fabre
                  Thanks ...
                  Andr
                  @christian_fabre
                  Happy to hear that it come to use (and that myself learned a few things on the way)
                  • A Andr
                    No. You must filter. If you don't, every incoming event then causes the response section to act and will likely cause spurious changes of the entity data.
                    • C christian_fabre
                      Thanks ...
                      apocalypsehobby
                      @christian_fabre said in Adding remotes, scene controllers as entities to MSR:
                      Thanks ...
                      @christian_fabre Do you mind sharing the code you used? I have two of the HANK SCN04 as well, and am trying to do the same thing
                        #25
                        I believe that the following is a cleaned-up version of the final code (that which @Andr posted above is not indented properly as shown in these forums and won't work directly, so please use this instead):
                        controllers:
                          - id: hass
                            enabled: true
                            name: Home Assistant
                              source: 'ws://192.168.0.nnn:8123'
                              # The lines above are a guide for indenting only, DO NOT COPY.
                              # --- Start copy/paste from below this line ---
                              event_targets:
                                "hank_XXX_btn_1":
                                  name: "Hank XXX Button 1"
                                  capabilities:
                                    - button
                                  events:
                                    - event:
                                        data:
                                          node_id: XXX  # Put your ZWaveJS node ID here
                                          property: scene
                                          property_key: "001"  #  001=button 1, 002=button 2, etc.
                                      response:
                                        button.since:
                                        button.state:
                                          map:
                                            KeyHeldDown: hold
                                            KeyPressed: single
                                            KeyPressed2x: double
                                            KeyPressed3x: triple
                                            KeyReleased: release
                                "hank_XXX_btn_2":
                                  name: "Hank XXX Button 2"
                                  capabilities:
                                    - button
                                  events:
                                    - event:
                                        data:
                                          property: scene
                                          property_key: "002"  #  001=button 1, 002=button 2, etc.
                                      response:
                                        button.since:
                                        button.state:
                                          map:
                                            KeyHeldDown: hold
                                            KeyPressed: single
                        You need to copy the lines beginning with event_targets: to the end, and paste them into the config section of the controllers entry for your HassController instance. You should change all instances of XXX to the ZWave node ID of your Hank controller. This will give you buttons 1 and 2. To add buttons 3 and 4, just copy-paste either button 1 or button 2 and modify the button number (property_key), entity name, and entity ID. One Reactor entity is created for each button you configure.
                        If you are not well-versed in editing YAML, I suggest you make a backup copy of your config directory before making any changes.
                        • C Offline
                          C Offline
                          christian_fabre
                          # If you have more than one of any type of controller, just copy the section for controller type
                          # and give it new (unique) "id". There is no limit on the number of controllers.
                          controllers:
                            - id: hass
                              enabled: true
                              name: A Home Assistant system
                                source: 'wss://XX.XX.XX.XX:8123'
                                access_token: "YYYYYYYYY"
                                        "Hank_SCN04_bp1":      # Assign an ID to your entity; each entity must have a unique ID
                                         name: Hank_bp1   # This is optional but recommended, so you have a friendly name
                                                 node_id: 12
                                                 property_key: "001"
                                                   KeyPressed: 'appui_court'   # if value is value_in, it is mapped to new_value
                                                   KeyReleased: 'appui_relache'
                                                   KeyHeldDown: 'appui_maintenu'
                                        "Hank_SCN04_bp2":      # Assign an ID to your entity; each entity must have a unique ID
                                         name: Hank_bp2   # This is optional but recommended, so you have a friendly name
                                                 node_id: 12
                                                 property_key: "002"
                                        "Hank_SCN04_bp3":      # Assign an ID to your entity; each entity must have a unique ID
                                         name: Hank_bp3   # This is optional but recommended, so you have a friendly name
                                                 node_id: 12
                                                 property_key: "003"
                                        "Hank_SCN04_bp4":      # Assign an ID to your entity; each entity must have a unique ID
                                         name: Hank_bp4   # This is optional but recommended, so you have a friendly name
                                                 node_id: 12
                                                 property_key: "004"
                          I abruptly attach a copy of my file.
                          I was inspired by the code given in the posts above
                          It works correctly for me.
                            A couple of things:
                            1. The indenting is incorrect. The parser may accept it, for now, but a future upgrade to the parser library may be more strict (I do not write the library, I just include it as a dependency). Use a tool like yamllint to fix it.
                            2. You should not change the values in the map section. The values there are meant to map Hass' values into Reactor's values, and the Reactor-side values you have modified are not valid Reactor values for the button.state attribute. Valid values are defined by Reactor's button capability and include: single, double, triple, 4, 5, hold, release, and long. You should return these to the values originally given, and adjust your condition tests accordingly.
                              controllers:
                                - id: hass
                                  enabled: true
                                    event_targets:
                                      "hank_XXX_btn_1":
                                        capabilities:
                                          - button
                                        events:
                                          - event:
                                              data:
                                                property: scene
                                            response:
                                              button.since:
                                              button.state:
                                                map:
                                                  KeyHeldDown: hold
                                                  KeyPressed: single
                                      "hank_XXX_btn_2":
                                        capabilities:
                                          - button
                                        events:
                                          - event:
                                              data:
                                                property: scene
                                            response:
                                              button.since:
                                              button.state:
                                                map:
                                                  KeyHeldDown: hold
                                                  KeyPressed: single
                              apocalypsehobby
                              @toggledbits wow, thank you.
                              I've successfully added the Hank devices to the reactor.yaml file, along with a couple other remotes. Here are my notes for anyone else on this endeavor.
                              • Hank HKZW-SCN04 has 4 buttons, and from my tests they do not support 2x or 3x clicks/presses.
                              • Minoston MR40Z V1.0 has 4 buttons, and supports all of the presses that you mapped.
                              • Zooz ZEN34 Ver. 1.0 has 2 buttons and supports all the presses that you mapped PLUS it has 4x and 5x presses as well.
                                apocalypsehobby
                                Hey friends - I'm trying this again with another remote, this time the ZB-5001 from RGB Genie.
                                It's not working yet, but I feel like I'm close. The device is successfully populating into MSR as an Entity, but when I press a button on the remote it does not report any changes to MSR.
                                Could you help me check my work?
                                DATA FROM HASSIO_EVENTS.LOG
                                • "endpoint_id" tells which button has been pressed (1-5)
                                • "cluster_id" seems to always stay at 6
                                • "command" shows whether you've pressed the "on" or "off" side of buttons 1-5
                                zha_event {
                                	"id": 1676585189844,
                                	"type": "event",
                                	"event": {
                                		"event_type": "zha_event",
                                		"data": {
                                			"device_ieee": "60:a4:23:ff:fe:65:a3:fb",
                                			"unique_id": "60:a4:23:ff:fe:65:a3:fb:2:0x0006",
                                			"device_id": "516aaf4459a4f4f319a178de36a28dfd",
                                			"endpoint_id": 1,
                                			"cluster_id": 6,
                                			"command": "on",
                                			"args": [],
                                			"params": {}
                                		"origin": "LOCAL",
                                		"time_fired": "2023-02-16T22:07:24.518489+00:00",
                                		"context": {
                                			"id": "01GSE495V6J686X0RGXYZ046CG",
                                			"parent_id": null,
                                			"user_id": null
                                MY BEST ATTEMPT AT THE CODE FOR REACTOR.YAML
                                      event_targets:
                                        "RGBG-Remote-Button-1":
                                          name: "RGBG Remote Button 1"
                                          capabilities:
                                            - button
                                          events:
                                            - event:
                                                event_type: zha_event
                                                data:
                                                  device_id: "516aaf4459a4f4f319a178de36a28dfd"
                                                  endpoint_id: "1"
                                              response:
                                                button.since:
                                                button.state:
                                                  map:
                                                    on: on
                                                    off: off
                                  "It's not working yet" isn't an adequate description of expectation vs observation, but I can tell right off your map is probably wrong.
                                  map:
                                    "on": true
                                    "off": false
                                  The words on and off have special meaning in YAML and must be quoted here. The explicit words true and false for boolean values should be used.
                                  Also, your since value should be put through the time() function, because that attribute is a timestamp, not a string.
                                  If there are other problems, we'd need more narrative description to help lead us in the right direction.
                                  And of course, you've checked the logs for helpful messages, right?
                                  • A apocalypsehobby
                                    zha_event {
                                    	"type": "event",
                                    	"event": {
                                    		"data": {
                                    			"endpoint_id": 1,
                                    			"cluster_id": 6,
                                    			"command": "on",
                                    			"args": [],
                                    			"params": {}
                                    		"origin": "LOCAL",
                                    		"context": {
                                    			"parent_id": null,
                                    			"user_id": null
                                          event_targets:
                                              capabilities:
                                                - button
                                              events:
                                                - event:
                                                    data:
                                                      endpoint_id: "1"
                                                  response:
                                                    button.since:
                                                    button.state:
                                                      map:
                                                        on: on
                                                        off: off
                                    apocalypsehobby
                                    @toggledbits Thank you for helping, and that's more than fair.
                                    I was pressing a button on the remote while viewing the Entity section of MSR, and the virtual device showed no change (the values stayed at "null"). I was expecting them to report on/off and to report the time change.
                                    For others' reference, it is now working with the following code:
                                          event_targets:
                                              capabilities:
                                                - button
                                              events:
                                                - event:
                                                    data:
                                                      unique_id: "60:a4:23:ff:fe:65:a3:fb:1:0x0006"
                                                  response:
                                                    button.since:
                                                      expr: time()
                                                    button.state:
                                                      map:
                                                        "on": true
                                                        "off": false
                                    Same goes for buttons 2-5, just tweak the value of "unique_id". Button 1 it ends with "1:0x0006" and button 2 would end with "2:0x0006", etc.
                                    A caveat to this device is the on/off buttons at the very top send the same signal to HA as the "device 1 on/off" buttons (1:0x0006).
                                    Here's a link to the device: https://rgbgenie.com/?product=rgbgenie-5-zone-remote-and-dimmer-zigbee
                                    • A Andr referenced this topic on
                                    • C cd12172 referenced this topic on
                                    • PablaP Pabla referenced this topic on
                                      160.3k
