  4. Sort Array Based on Newly Added Items
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
13 Posts 3 Posters 2.4k Views 3 Watching
    maybe I'm missing something, but if the order is already OK, why are you sorting it? are you trying to get the last or fist ones added? look at https://reactor.toggledbits.com/docs/Expressions-%26-Variables/#arrayobject-handling-functions
    pop/shift should be enough to get the first/last and remove it, or just myArr[0] and myArr[myArr.length] if you want to maintain the current array intact.
    PablaP 1 Reply Last reply
      A review of the documentation for the sort() function will also tell you how to write a custom comparator.
        @therealdb said in Sort Array Based on Newly Added Items:
        I want to get the last ones added.
        To my understanding pop/shift will get the first/last item in the array but if its sorted alphabetically by default it won't get the last item added to the array.
        @toggledbits said in Sort Array Based on Newly Added Items:
        Had a look at that sort() command and did some research but everything I come across only shows how to sort the array in a different way. I don't want to sort the array, I want it to act as a list sort of. As a new item is added it goes to the top of the array.
          The pop, push, shift and unshift are what you need to be looking at, as @therealdb said.
            So I have tried shift since it returns the first element in the array, but the same issue still is happening. Since the array is sorted alphabetically the first element isn't always the latest item that was added to the array. Here's a better explanation:
            Here is a the array of the devices that are not_home.
            My goal is to notify the user that was considered not_home last. In this case the order of devices that were not_home was "Mom_iPhone", "Armans_iPhone" and then "Jas_iPhone". Since "Jas_iPhone" was the last device that was considered not_home I would like to target that device. But when I use the shift command "Armans_iPhone" is the output bc it is first in the array when sorted alphabetically. If I use the pop command the output is "Moms_iPhone", which is still not what I want.
              @pabla said in Sort Array Based on Newly Added Items:
              OK. So which one IS? How do you know? If it's just the last one (really), that's pop(), not shift. That should be clear in the docs.
                In this case the latest item added to the array was "Jas_iPhone" the way I know is because in HA I am manually setting the state of the device_tracker as not_home
                    Sorry, no, the question is, what is the rule by which Reactor is expected to know which one was most recently added? That is, is the order by which the list/array is built in any way deterministic?
                      wrote on last edited by Pabla
                      My overall goal for this rule is to notify the last person that left home if they left a garage open. I have to use HA conditions in my actions because I am using actionable notifications which aren't possible to configure in MSR.
                      Triggers are if any of the devices are not in the Pabla Home zone and any of the 4 garages are left open...
                      It will trigger text to be filled into input_text. The text that will be filled in is the expression of the latest device that was marked as not_home + some editing to make it a service to be used in HA. Then run an automation in HA. (none of this is an issue, all works as expected)
                      I have an expression that identifies any devices that are not_home. Here is where my question comes from: from the array ('away_devices') I would like to select the LAST device that was not_home (not shown currently in the screenshot since I am not sure how to do so). In other words the device that was home last.
                      After that I convert the output to a string, replace/add some characters to output this service name notify.mobile_app_<insert device name>. From there that service is sent to HA to send a notification to the specific device that was last home.
                      In my expressions screenshot I have only one device shown as not_home so you can see the final output of replace.
                      Hopefully this adds some clarity, I didn't want to originally explain the whole rule since its fairly complex and a little hard to explain.
                        @pabla If there's no deterministic order to the list you are building (and it certainly appears that there is not), then you have to use set arithmetic: when not_home changes, you compute the difference between its new value and a copy of its previous value that you've stored. This will give you a new set (array) with the new element(s), and these would be the last ones to leave the house.
                        Here's a simple test rule you can try that demonstrates this. It uses the arrayDifference() function for the array comparison:
                        The last_not_home variable is used to keep a copy of the previous contents of the array, updated every time it changes, after the difference is computed. The difference is stored in new_not_home, so this is where you will find the new element(s) added to the array. You can try this by having your Expressions page open in one window, and this rule's detail open in another, and watch what happens when you change not_home (assumed to be global here).
                          What a brilliant solution! I think that did the trick, the only modifications needed was to make the new_not_home and last_not_home variables global so I can use them in the original rule. Initial testing looks like this did the trick. Thanks again Patrick!
                            163.6k
