  4. MQTT log levels & log rotation
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
7 Posts 2 Posters 2.6k Views 2 Watching
    Trying to set log level for MQTT to the lowest possible, is it in practise level 4? Also, would like to set maximum size and log rotation, but the following setup in logging.yaml did not work:
    MQTTController:
        level: 4
        streams:
          - type: file
            maxsize: 2
            keep: 2
    Using the latest build (23010).
      MQTTController:
          level: 4
          streams:
            - type: file
              maxsize: 2
              keep: 2
      @tunnus said in MQTT log levels & log rotation:
      Four (4) is the default level, which logs information and more severe messages. The severities are critical (0), error (1), warning (2), notice (3), information (4), and debug levels 5 through 9 inclusive.
      Good on you for showing the config so, but from the posting guidelines:
      ... if you say "I tried to do X but it didn't work", you need to show what you tried to do, and you need to explain what you expected, what happened, and how that didn't meet your expectations
        Okay, if I ask the other way around, so if max size & rotation for the "main" log file is set as shown below, how do you set the same for MQTTController?
        logging:
          default:
            level: 4
            streams:
              - type: console
                level: 0
              - type: file
                maxsize: 2  # megabytes max size
                keep: 5     # copies of old logs
          Just the way you've done it. I'm still wanting some narrative of what you expected to see vs what is happening, because I think just you thinking about how to write that might have led you to solving your own problem.
          I'm pretty sure it's as simple as, you haven't told the configuration what file to send the log to... you need to add a name field in streams for the MQTTController section, so it knows what file name to use for that log stream.
            MQTTController:
              level: 4
              streams:
                - type: file
                  maxsize: 2
                  keep: 2
          If you don't want it to log to a separate file, just the regular reactor.log file (i.e. you only want to change MQTTController's log level, not its output destination), then remove the entire streams section from your MQTTController section, so it's just:
            MQTTController:
              level: 4
            I thought you wouldn't have to specify a name for the file as so far MQTT controller has logged to a file "mqtt-topics.log"
              Now I have the following configuration, but the file grows over 4 MB (does not rotate)
              MQTTController:
                  level: 4
                  streams:
                    - type: file
                      maxsize: 4
                      keep: 2
              Just realized I have "log_topics" in reactor.yaml's mqtt section which may or may not interfere with this logging setup?
                MQTTController:
                    level: 4
                    streams:
                      - type: file
                        maxsize: 4
                        keep: 2
                @tunnus topic logging is separate. Remember that 4MB is 4,194,304 bytes, not 4,000,000. The last message logged before rotation may cause the file to be slightly larger.
                  163.6k
