  3. New to the forum
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
iCOMEN boiler switch
New to the forum
81 Posts 6 Posters 33.0k Views 6 Watching
  • Q Offline
    Q Offline
    Quixote
    Hi!
    I was tipped off about this forum while bitching about my Vera on the Vera forum, as I had grown accustomed to over the years. I know that's not very nice, but that thing brings out the worst in me (and has even driven me to drink on occasions 😉 )!
    Anyway, how about a little intro in case anyone is actually interested? I did odd jobs, saved up for and built my first PC from components by the time I was 15 (back when you had to know how to get around a DOS prompt and a 120Mb hard drive was a big deal). Within 6 months I had my own BBS up and running. The internet wasn't really a thing back then -- did AOL really count? I only really discovered home automation almost a decade later, again before it had really taken off. Back then I was using X10 because it was still one of the only consumer options and I had no electronics background. Over the years I have experimented with several home automation technologies, 90% of them ending up as useless scrap and a waste of money. Today I feel like not much has changed, but things are moving in the right direction (wide scale adoption -> more money invested in improving tech to try to get us to part with our money, am I right?). I've never really had the funds to go all out or to get the more expensive gear, but I've found some products that have been worth sticking with -- namely my Elk-M1G and one or two other obscure devices. I recently was "renovicted" during the pandemic and decided to move from my modest apartment in the city to a house out in the woods in the middle of nowhere.
    So here I am, with an almost clean slate, looking to set this place up better than ever. The internet access sucks out here, but the house is mine to do what I will with it. I envision a keyless entry system even better than the last one I devised, walls that literally talk and eventually even roboticized structure & furniture (eg. Aquarium lids that rise for maintenance, hidden doors that slide open, a table that transforms into a bar, etc.).
    For the moment, though, I'd like to figure out how to replace this *&$%ing Vera. Funds have been tight lately, but at the moment I have several pieces of hardware I can start with: The Elk (as mentioned), ~20 LIFX bulbs/strips, a handful of Amazon Echos, a few Zwave devices, some IR and audio stuff, the Vera, a few other odds and ends.
    Ultimately, I'd like to set up a low-power system like a NUC or something that will always be on, running automation as well as handling audio (most likely multi-zoned). I built my last PC as a gaming PC, but I can use it to experiment until I'm ready to purchase an HA system.
    Where do I start if I want to learn about OpenLuup? I skimmed through the forums, but they seem quite advanced and are a little beyond my abilities. I do CAD/CAM, not programming, unfortunately!
    Thanks!!
      Welcome! The backstory is interesting, and not so far from some others here, I suspect. Your current situation sounds like a real opportunity (for many things.)
      To the question of openLuup... it should be easy to get going and proceed in small steps. Forums are, of their nature, somewhat daunting, because of the range of interests and expertise discussed.
      Most openLuup users run this under some flavour of Unix, but it does run, at least for some plugins, on Windows. It’s really easy to install, and the key one of its basic requirements is a Lua 5.1 system. Get this going first, then follow the install instructions in the openLuup user guide.
      So, for a start, are you up for Unix/Linux?
      Again, welcome.
      AK
      • Q Offline
        Q Offline
        Quixote
        Thanks for the warm welcome. I'm looking forward to learning as much as I can.
        I've never touched Unix in the past, though I did have a dual boot system once with Ubuntu running. It wasn't too intimidating, but as someone that has been using Microsoft OSes for almost 20 years, I found it difficult to really get used to. I have some minor experience with Lua 5.1 scripting while I was using Girder for some years a while back (not sure if you've ever heard of it, but it was fantastic. Discontinued, unfortunately). What exactly do you mean by a "Lua 5.1 system"? Do you mean just installing a binary?
        Windows would really be great for me since I only have one computer right now and it's running Windows 10. I use it a lot these days for web browsing, streaming, playing music and gaming. I suppose I could sandbox Linux so that I could jump into that system when I want to mess around with OpenLuup? The ultimate would be if I could set stuff up on this system, then transfer everything over to my HA PC once I'm able to invest in something decent. If it's better to use Linux, I'll make the effort.
        Thanks again
        • Q Quixote
          Thanks again
          @quixote said in New to the forum:
          Yes, possibly some extra libraries too.
          So let's give Windows a quick go. All the openLuup learning (and configuration) will be directly transferrable to a Unix system in future, if necessary.
          User Guide is here:
          openLuup/Documentation/openLuup User Guide.pdf at master · akbooer/openLuup
          a pure-Lua open-source emulation of the Vera Luup environment - akbooer/openLuup
            @Quixote, Welcome!
            Your story parallels indeed that of many of us here and I remember your post in the old place if (it is you).
            You should be able to setup openluup and practically anything we discuss here on windows. There could be some differences in setup and command you need to use but it should work.
            • Q Offline
              Q Offline
              Quixote
              Thank you both! That's great! Windows it is then. I will look at the user guide tonight and get started setting everything up in the next couple of days.
              @rafale77, That was most probably me. I had a habit of addressing my Vera problems while sipping on beers, losing track of my consumption and then visiting the forum frustrated and angry. Apologies to anyone I may have offended or if I embarrassed myself. It won't happen here, I can guarantee that. For one thing, I am not being sold something that will cause more headaches than it fixes. I see this as a sort of video game, but a much more constructive use of my time.
              I noticed that you mentioned the use of (local) AI in some posts. That stuff looks super interesting. At one point (about 15 years ago, I think?) I was trying to emulate AI with a chatbot called "UltraHal". It was super primitive -- written in visual basic if I recall correctly, but it could come up with some convincing responses. I had it set up so that I could converse with it, but also control my lights and control my TV, etc.. It would "learn" from your conversations somehow. The thing is, it creeped me out sometimes and I stopped using it after it told me that I "should not buy nice things in case my house burns down" or something to that extent. Anyway, looking forward to seeing what sort of experimental projects you come up with. I have a 2070RTX, so if you need any testing done, let me know (just don't fry my card please).
              • Q Quixote
                @quixote
                It does sound like you 😉
                Yes I am very much invested in making everything work locally. It started from my video doorbell where I thought... if my phone can do face id, why can't my home automation system? So I ended up adding an RTX2070 to my NAS, forked home assistant to implement the best facial detection and recognition I could find and ended up also doing object recognition. I have an RTX3070 on the way to see if I can improve speed and lower power consumption. It's been a lot of fun and a lot of work for someone who doesn't code for a living and did not know python. Not sure what I will do next...
                • Q Offline
                  Q Offline
                  Quixote
                  "...see if I can improve speed and lower power consumption"
                  I'm just picturing this massive heap of discarded airconditioner heatsinks strapped together, surrounded by a network of greenhouse misting hoses and desk-fans, a Frankenstein-ish mad scientist (the doctor, not the monster) pounding a keyboard and screaming, "yes! YES! It IS A SQUIRREL!!!"
                  Joking aside, I have to say that is incredibly impressive. Over the years I've stumbled upon various similar projects that were inspirational, including one that was so good that some military (I think it was US or Israeli) swooped in and scooped it up, apparently. I wish I still had the name of it, but they were working with breakthrough image processing (including facial recognition) and then they just went completely dark. Excuse me, I just need to go check out what that noise was in the back yard... jk 😉
                  • Q Offline
                    Q Offline
                    Quixote
                    I hope it's ok if I ask a few questions while I read the documentation. Sorry if they're dumb. 😕
                    -First and foremost, I see that UPnP is not supported and never will be -- out of curiosity, why is that, and out of concern, does that rule out DLNA as well? If so, is there some other standard that may be used to control readily available media players, including apps like Plex or J River Media player?
                    -Does using port 3480 HTTP mean that no traffic is encrypted, or is that only because all communication is strictly over the LAN? Do I need to start playing with firewall rules?
                    -Would installing a more current version of Lua (above 5.1) break things?
                    -Lastly for tonight, how can I completely wipe my Vera to the point of being a drooling Z-wave zombie? I mean, I have a Zwave lock that I need secure, so not a total zombie, but maybe like a zombie that just does what it's told without fail? I'd like no responsibility to fall on the Vera except as a mindless Zwave translator (ie. dongle style). Possible?
                    • Q Quixote
                      All questions OK.
                      • UPnP – this is more a question of how you access, control, and trigger events in openLuup (or, rather, how you can't) it has nothing to do with what openLuup can do by way of interacting with other things. If there's a Vera plugin for controlling something, it probably works on openLuup (as long as it's not encrypted.)
                      • HTTP on port 3480 – openLuup's built-in server does not do HTTPS, but everything stays on your own LAN. Remote access is another topic (which has been addressed in several ways by others.)
                      • Lua 5.1 – openLuup uses Lua 5.1, because Vera does. Yes, using 5.2 or above, would break things, as it stands, because Lua changed the way that function environments were handled. However, all the dependncies arebuilt into on single function within openLuup that could be changed. I may do this in future as Vera compatibility becomes less of an issue, and to enable further developments.
                      • Vera a drooling zombie – That's exactly the goal of openLuup... and then, to eliminate that hardware entirely. A number of folk here have done just that. See, for example:
                      https://smarthome.community/topic/243/vera-or-not-vera?_=1607082180490
                        My vera is stuck in a cupboard. Ready for burning.
                        Q 1 Reply Last reply
                          Just unplugged mine as well, i held on to it for the geofencing, but the latest "update" to the app ruined it again.
                          Living just fine without it, z-way for z-wave, Zigate for Zigbee and RFXtrx for 433mhz. No need to look back! 🙂
                          @Quixote
                          I see you're considering using Windows to run linux native SW, and mye experience says "Just don't".
                          I tried this with Grafana, and practically all help on issues i had was for linux users, with the standard: "oh, your'e running it on a windows machine? Good luck with that" replies.
                          Linux is pure pain for people growing up in the DOS/Windows world like me (and perhaps you), but once you get to a certain point, its livable. And the open-source community is huge, full of nerds (using the word with absolutely no negative connetations) eager to help!
                            That’s one of the nice things about this forum... we have a variety of opinions and experiences, and we’re happy to discuss the pros and cons. I actually think that you’ll end up with Linux too, but there’s no harm in starting in an environment you’re familiar with.
                            The PC-related issues seem initially to do with installing Lua, and then finally with specific plugins which expect to be running on Linux, rather than openLuup itself. YMMV.
                              Q Offline
                              Q Offline
                              Quixote
                              @catmanv2 said in New to the forum:
                              The Vera abuser formally know as CatmanV2.....
                              The first step to recovery is admitting that you have a problem. 😉
                              The last time my Vera crapped out on me, I was all set to make a video of myself, smashing the thing to little pieces with my sledge-hammer and posting the video on the Vera forum. Fortunately I'm very lazy so by the time I had it in me to get it done, logic and reason had crept in and I started thinking I might be able to find some use for it, even if just as an access point.
                              Thank you akbooer for the clear explanations. I have to say, discovering this place is very exciting -- it's the first time in a while that I've felt like I'm exploring something new that I'm keen about, like when I was a kid and I was learning how to set up my BBS.
                              I'm mostly concerned about the whole Linux thing. As PerH mentioned, it can be a little bit of a learning curve and it often had me feeling pretty helpless. I don't have any aversion to Linux, but I won't be making it my main operating system. The reason for that is not because I'm stubborn, but rather because while I don't spend an inordinate amount of time on gaming, I do enjoy it from time to time and I've spent a small fortune on my gaming rig (especially when you consider that I spent Bitcoin on this damn thing before the price exploded. This is possibly the most expensive gaming system you'll ever come across. 😢) My experience in the past is that Linux and gaming do not mix. I know it's gotten better over the years, but it still can't touch Windows on that front.
                              So I think the question I need to ponder now is, do I poke around with OpenLuup to familiarize myself with it while not getting too serious about anything, then do a proper permanent set up when I can work a HAPC into my budget, or do I just put the whole thing off until I can invest a proper amount of funds into hardware for this? I'm leaning towards playing around with it on my Windows system for now.
                              The reason I was asking about Zombifying my Vera was that I was hoping to make use of it in some way since it has the Zwave radio built in. If I could avoid shelling out another hundred bucks on a Zwave stick for the same functionality, that would be great. Otherwise, if I can gain some sort of advantage by doing so, I will.
                              My initial goals as I see them at this point would be:
                              • To have a single, low-power consumption, always on system that handles whole home audio, all home automation tasks and coordinates all HA systems, including my alarm system (this is important because it's rock solid and I will be using it for mission critical tasks in the future, such as aquarium maintenance and garden irrigation)
                              • To be able to access and control my music (Local sources) using voice commands (using Echo devices), and possibly execute other macros in the same way.
                              So the second PC will be purchased at some point and it looks like it will have to be Linux. The thing that concerns me is the transition that will need to happen when that becomes a reality.
                              I purchased J River Media Center some time ago, and I believe they have a Linux version, so that's one less thing to worry about.
                              Hopefully I won't need to print out all of the scripts, etc. I put together until then and then re-enter everything when the time comes.
                              Forgive me if I've been prattling on -- I think I'm mostly just talking to myself here. 😆
                              • Q Offline
                                Q Offline
                                Quixote
                                Sorry, one more question:
                                It seems that the Lua for Windows that is available for download on Github incorporates Lua 5.1.5. Is that still considered Version 5.1, or do I need to search for another source?
                                Thanks for all the help, everyone!
                                  If you just want to experiment, install windows subsystem for linux. My dev pc is a Windows machine but thanks to WSL I have a true Linux environment running side by side on Windows. That’s what I’m using to develop for openluup (and for my Linux dev needs in general).
                                  • Q Quixote
                                    @quixote
                                    Great introduction. The background can really help when we’re giving suggestions.
                                    It’s not the case that you need massively capable hardware to run openLuup. The most popular platform is, perhaps, Raspberry Pi, and even then it only uses a few 10s of Mbytes and ~5% cpu. But there are many options, and I’m about to follow a route that others have forged previously to run openLuup under Docker on a Synology NAS... so we’ll all be learning something new over the next few weeks.
                                    Lua 5.1.5 is, indeed, ‘Lua 5.1’, and the best choice. Necessary additional Lua modules may come with your initial installation, or need to be added. There’s a list in the User Guide.
                                    • Q Offline
                                      Q Offline
                                      Quixote
                                      Nice,
                                      ok, well I installed the Linux subsystem, Lua 5.1 and the dependencies.
                                      @therealdb thanks for the suggestion. It seems to be running alright. Any pointers on how I can have this start with Windows? The user guide only mentions scripts for Linux systems in the appendix.
                                        Just search for wsl 2 and you’ll find everything you need.
                                        It’s just going to Windows Store and install your favorite distro, ie Ubuntu.
                                          Q Offline
                                          Q Offline
                                          Quixote
                                          @therealdb Yes, I did that already. I'm just wondering if I need to open the Bash console and start OpenLuup every time I reboot or if I can set it to start with each boot.
                                          Everything seemed to go alright, but when I open AltUI, I immediately get a message box that says "fail". The weather is showing Paris, and I can't control any of my LIFX bulbs that I imported from the Vera using VeraBridge.
                                          Also, the app store is blank. I haven't finished reading the user guide yet though.
                                            100.7k
                                          • Next Release?
