  3. Connected Home Over IP. (CHIP)
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
8 Posts 6 Posters 1.7k Views 6 Watching
    Yet another attempt to create the one standard to rule them all. "The ring of power".
    Josh Hendrickson  /  Jan 2, 2020  /  Features,Explainers
    What Is "Project Connected Home Over IP" for Smart Homes?
    Amazon, Apple, Google, and ZigBee want to change the backbone of the smart home with CHIP. Here's what that means for you.
    I am very skeptical about this. I don't feel it is needed and I think it will only add to the confusion but I am probably not a typical consumer. Thoughts? It seems to want to do the same thing as what a lot of us have already achieved through open source but commercializing it. It's not so different from Apple's HomeKit.
      @rafale77 said in Connected Home Over IP. (CHIP):
      but I am probably a typical consumer.
      ...Er... NO!
        edited... it was a typo as you guessed... 👅
          I'm nothing like as much expert as you guys, but I see this might be helpful for newbies with limited desire to make stuff work, but so many drawbacks
            If I understand this right, they are not replacing the radios, but the communication protocol? if so, one can still have the advantages wrt. battery consumption from i.e zigbee, and it may even reduce cost on z-wave units - not having to use the proprietary z-wave chip? if so, i can't see the downside, as they claim to now wanting to replace the existing, but to simplify use of them.
            It's still just a concept, so in any case it'll be a few years until something materializes..
              I think they’re trying to build a common language for interoperability. I think it’s a good approach, since now we’re stuck to every vendor doing its things and ironically the only open local protocol is made by apple, ie HomeKit.
                mrFarmer
                With this many captains on the ship; I'll guess it will mature in a pace much like 5G, 5-10 years. As with all these things, including zwave, it all works like a charm if all you buy is from the same vendor. But anything to make it simpler to integrate and pair a device to your setup is welcome I suppose.
                  I can see the potential value of it but indeed it sounds a lot like HomeKit trying to create an IP protocol to get all the others to play together. Probably a little better standardized than MQTT (in terms of messages and topics) to make it more user friendly. I have had no problems mixing and matching brands on z-wave with a handful of exceptions: a couple of brands trying to go a little too exotic on their z-wave implementations. It isn't so clear also whether this will be purely local or cloud based. As of today, my single largest source of reliability issues come from the cloud... Some of the amazon echos occasionally going out of whack and it's a recent problem.
                    125.7k
