  4. Import question
Import question
12 Posts 3 Posters 3.2k Views 3 Watching
    Tarkus
    Is the import feature supported by stock Vera or only open loop or is it both?
      Luup Reactor's configuration format is the same for both Vera and openLuup, so the importer would be expected to perform identically on configurations from either platform.
        Tarkus
        Ok, so I a a bit confused. When you say make sure reactor is running are you speaking vera legacy reactor or MSR as well? When I execute node app.js to run MSR I no longer have the $ prompt at the end of the MSR log displayed. Do I issue the command from there? It If control c it kills the MSR session. Also the syntax, do you need <> and just the path of the backup file, or the filename as well? I left the name reactor-config-backup.json and I copied it into the tools folder as suggested in the doc. Sorry like I said I need some lessons in linux.
          Good to ask these question; it helps clarify what needs to be in the instructions.
          1. You should start Reactor (MSR) using the background-support script. This is done by typing nohup ./app.sh & on the command line, while inside the reactor directory. This will start Reactor in the background and keep it running, in a similar fashion to how openLuup is kept running a script. You can restart Reactor by type pkill node on the command line. You can quit Reactor by typing pkill -QUIT node.
          2. Reactor on the Vera or openLuup does not need to be running when the import is happening.
          3. Once you have MSR up and running in the background, your command line is free to run the importer. Be sure to run the importer from the reactor directory as well (I've tried to be consistent about this): node tools/import_reactor_backup.js <path-to-import-file> <vera-id> The <vera-id> I refer to here is the string that follows the id in the controllers section your reactor.yaml configuration file; it's vera by default, unless you changed it.
          4. Once the import completes, restart MSR (pkill node) and then refresh your browser window. You should see a list of Rule Sets that corresponds to your ReactorSensors. Each Rule Set will contain a number of rules that the importer determined were necessary to express the Luup Reactor logic in MSR logic.
          Make sure you read the "Getting Started" page in the docs, which highlights some of the differences between Vera Reactor and MSR, and will give you the new terms and definitions for things.
            Tarkus
            Yes I did notice no lua as a difference. I will probably need to move some of my activity lua into vera scenes and handle it that way. Is lua going to be added or not in the forecast? I run some lua that has some conditional logic in it on its own. Will take a look at the import per your instruction a bit later. Thanks
              Even if I implemented Lua, none of the Luup things often used with Lua from Vera for would be there. I may do something like condition action groups in the (not near) future, as that seems to be a common thread in Run Lua actions.
                Tarkus
                Ok, Import was successful. I will work around the lua with scenes for now. I only have it in a few spots. Condition action groups would be useful.
                  sebby
                  having some issues importing, my guess is that my reactors on vera are a complete disaster, but thought i would ask:
                  /opt/reactor # node tools/import_reactor_backup.js tools/reactor-config-backup_so.json vera
                  Fetching current rulesets...
                  Pass 1: Translating...
                  ReactorSensor 182 RS-AUTO HOME MODE
                  Creating ruleset for ReactorSensor 182 RS-AUTO HOME MODE
                  Creating rule rule-182
                  (node:3881) UnhandledPromiseRejectionWarning: TypeError: (node.data.value || "").split is not a function
                  at fixConditions1 (/opt/reactor/tools/import_reactor_backup.js:94:53)
                  at /opt/reactor/tools/import_reactor_backup.js:44:13
                  at fixConditions1 (/opt/reactor/tools/import_reactor_backup.js:41:35)
                  (Use node --trace-warnings ... to show where the warning was created)
                  (node:3881) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
                  (node:3881) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
                  /opt/reactor # node --trace-warnings tools/import_reactor_backup.js tools/reactor-config-backup_so.json vera
                  (node:3898) UnhandledPromiseRejectionWarning: TypeError: (node.data.value || "").split is not a function
                  at emitUnhandledRejectionWarning (internal/process/promises.js:168:15)
                  at processPromiseRejections (internal/process/promises.js:247:11)
                  at processTicksAndRejections (internal/process/task_queues.js:94:32)
                  (node:3898) TypeError: (node.data.value || "").split is not a function
                  (node:3898) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
                  at emitDeprecationWarning (internal/process/promises.js:180:11)
                  at processPromiseRejections (internal/process/promises.js:249:13)
                    Open a PR in Mantis and post your Vera Reactor backup file as an attachment to it.
                      sebby
                      ok, done. very low priority as I'd rather you spend time polishing the builds than dealing with my clusterf**k.
                        sebby
                        FYI, the new release worked like a charm, than you
                          You're still going to have your work cut out for you. There's a lot of things MSR does differently. Expressions are high on that list.
                            159.9k
