  3. First post to say hello
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
iCOMEN boiler switch
34 Posts 12 Posters 8.4k Views 10 Watching
    wrote on last edited by Elcid
    Hi to all, Thought i would join as not to miss out on anygood information that you developers may share here.
    note- The input box for text does not display to well.I can not see what i am typing.
    Android 8 full sreen on tv box using firefox mobile view.
    If i use desktop view everything is ok.
    • DesTD Offline
      DesTD Offline
      DesT
      I will try to do some testing with android! I know that from Android 10 on my phone it's working perfectly!
      ElcidE 1 Reply Last reply
        Welcome, thrice welcome
        • DesTD DesT
          @DesT i like the layout on tv box in mobile view, note it is different on a phone as my screen is not vertical.
          Just noticed the button to move the dividing pane. Now i can see two lines of inputed text.
          Edit-
          Is there a dark mode?
            One more vote for a dark mode! Welcome @Elcid!!
            • HSD99H Offline
              HSD99H Offline
              HSD99
              Hi everyone! I'd like a dark my also.
              • DesTD Offline
                DesTD Offline
                DesT
                I can switch to dark mode, but it will be for everybody!
                  Fight! I mean vote.
                  1 for dark mode.
                  • DesTD Offline
                    DesTD Offline
                    DesT
                    dark mode enabled!
                    • HSD99H Offline
                      HSD99H Offline
                      HSD99
                      Yay dark mode! Many thanks!
                      • K Offline
                        K Offline
                        korttoma
                        Hi you all!
                          Welcome @korttoma and @HSD99, awesome to have you guys here and yay to dark mode too!
                          • HSD99H Offline
                            HSD99H Offline
                            HSD99
                            Thanks for having us!
                              sailhome
                              Thanks for the new forum. I like the dark mode too.
                                Hello all! I couldn't find a copy of my old avatar, so this will have to do.
                                • Black CatB Offline
                                  Black CatB Offline
                                  Black Cat
                                  Dark mode really, sounds sinister. 🙂 Nice to see all of the old friends, now how do I turn dark mode off?
                                  aka Zedrally
                                  HSD99H DesTD 2 Replies Last reply
                                  • Black CatB Black Cat
                                    HSD99H Offline
                                    HSD99H Offline
                                    HSD99
                                    @Black-Cat As I understand it, dark mode is a forum-wide setting, hence the informal voting to turn it on today.
                                      Black CatB Offline
                                      Black Cat
                                      haha, makes our logo invisible....
                                      aka Zedrally
                                      rafale77R DesTD 2 Replies Last reply
                                        DesTD Offline
                                        DesTD Offline
                                        DesT
                                        @Black-Cat let me try to do something about that!
                                          @Black-Cat
                                          Hmm that’s pretty funny. Maybe try to put a white background to your .png?
