  4. Accessing VOI from MSR
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
20 Posts 5 Posters 2.7k Views 5 Watching
    Has anyone succeeded in sending a VOI command from MSR to an ezlo or vera controller? I'm looking for the shortest route to Alexa control from MSR, and open to all suggestions.
      Vera controllers don't support VOI.
      You'd have to create a scene on the Ezlo controller with an action to send a VOI command to the voice assistant.
      Then in MSR you'd have to call that Ezlo scene to run via a HTTP request.
      See my Idiot's guide to Ezlo HTTP Server API on the Vera forum for how to send http commands to an Ezlo hub to initiate running a scene
      That is your only and shortest route as far as I can see.
        I seem to recall someone describing an Alexa plug-in for the Vera which I never tried out. Which has me wondering if it could serve the same purpose although probably not as direct or robust as the ezlo-based route you describe.
          Ask @therealdb that's his plugin.
          I dont use it as I have Google Home and Chromecast devices.
          If his plugin can send text commands to the Alexa voice assistant via a Vera hub? To then perform some action on Alexa and thus with any connected devices?
          Then maybe there is some way to initiate that also from MSR?
            My plugin can do anything local. Plus, it will always work 😬
            I’ve been running it since almost 3 years. Tts, Alexa routines (ie to control dnd, music, weather, alarms) and direct commands. It’s always working. Look at my signature to get it.
            cw-kidC LibraSunL 2 Replies Last reply
              Will do, eagerly so. Thanks!
                It's great. I really must get the OAuth done....
                  @therealdb said in Accessing VOI from MSR:
                  When you going to do a plugin for Google Home 😁
                    @cw-kid google has closed all the local apis. But if you found something to use, I’ll take a look.
                      @therealdb Google suck sometimes. Why don't they have any local APIs.
                        @cw-kid
                        @cw-kid said in Accessing VOI from MSR:
                        Good question. This move was actually the first thing that got me to remove everything google from my house from devices to browsers, search engines, email service etc... They actually did initially offer a local API but removed it for the philips hue as an example. Their strategy is to collect as much data as possible from us, customers since we are actually not their customers as part of their business model. We are their products. They are forcing people to rely on their cloud. Alexa is much better in that sense that though it is shifting to favor cloud centered environment, they have kept their local APIs open. That being said all of these cloud based environment have some major downsides: latency, reliability, privacy. I am gradually moving to local voice processing as well with homekit and it seems to turn out being a bit of a project.
                        @LibraSun, what devices are you looking to control? There has to be better, more direct ways to do it than to go through the amazon cloud...
                          I'm getting mixed messages here, though, so allow me to inquire before I proceed with installing VeraAlexa plug-in...
                          On GitHub, the readme states to the contrary...
                          "On Vera only TTS is implemented."
                          but later suggests:
                          "When jq package is installed [such as with Vera f/w 7.32], the plug-in will automatically switch to the avanced version."
                          It also include this proviso, which is unclear to me:
                          "only accounts with MFA disabled"
                          So, which of the following functionalities will my Vera Plus actually enjoy once I install the plug-in [under 7.31], and which will only happen after upgrading to 7.32 firmware?
                          • Text-to-Speech (TTS) over Alexa/Echo
                          • Announcements to Groups
                          • Text-to-Command ("VOI") from Vera
                          (SORRY IF I'M BEING OBTUSE... it's not intentional, lol)
                          • Libra
                            Vera 7.31 will only get tts. Maybe written commands, I’ve not tested it.
                              ...and what does "MFA disabled" mean in this context?
                                @librasun presumably that's referring to your Amazon account and 2 factor authentication, needs to be disabled.
                                  Ah, thanks for explaining. Could not figure out the meaning of "MFA" but now get it: "Multi-Factor Authentication" 🙂
                                    I have to update the doc, since I have MFA on my account, with Authenticator app and oath tool in place wonderfully working together. But this definitely requires openluup.
                                      I double checked and spoken commands are available even if jq is not installed:
                                      -- execute a spoken command on Bedroom device
                                      luup.call_action("urn:bochicchio-com:serviceId:VeraAlexa1",
                                         "RunCommand",
                                         {Command="-e textcommand:'Alexa, I’m leaving' -d 'Bedroom'"}, 666)
                                      I've updated the doc as well.
                                        Sweet!! Thanks. Now, if I could just get VOI to succeed in turning off the screen of my Echo Spot, which so far can only be done in person by voice ("Alexa, turn off the screen").
                                        I've begged Amazon tech support to improve that feature to be responsive to automation, but so far no go.
                                          You should be able to do it via voice commands. I added a specific section in read me and I’ll probably create a specific service in next version.
                                          • Next Release?
