  4. Deprecated Features
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
Possible feature request 2?
Copying a global reaction
Deprecated Features
13 Posts 3 Posters 1.3k Views 4 Watching
    Since the project is evolving, there will always be something somewhere that is being deprecated, so I thought it might be handy to have a list. I'll try to keep this post up-to-date:
    • The list() function in expressions; remains for portability from Reactor for Vera. Replacement is [ item, item, ... ] syntax (direct array declaration).
    • The Interval condition in relative to condition TRUE mode. On Reactor for Vera, this functionality has long been supplanted by the pulse output mode (under Condition Options). But, I neglected to formally deprecate that feature in Reactor for Vera (so far; I will for 3.9). It is officially deprecated in MSR, and remains only for portability of rules imported from Reactor.
    Note: all deprecated features will be removed from a future release, so the intent is that this list motivates action on your part to replace any use of the deprecated feature with its replacement. The date at which any function is finally removed will be published once scheduled; if no date is posted, the feature is deprecated, but will remain and a date will be planned later.
    K 1 Reply Last reply
      Would I be correct in mentioning that:
      lookup( list , index )
      is also being replaced by:
      array[ index ]
        Hmmm.... there is no lookup() function in LuaXP or Reactor for Vera. Array member access syntax is the same for both Reactor for Vera (LuaXP) and MSR (lexpjs): array[ index ].
          Wow, you're right. I think Daylight Savings Time brain fog had me thinking of Google Sheets formulae, lol! Probably meant CHOOSE( ) for picking indexed item from a list.
          Delete!!
            Ah, yes, OK... that's very different in lexpjs/MSR: first item in array-of-objects with match-expression
            rain=[ { date: 1234, rainfall: 10 }, { date: 4567, rainfall: 11 } ],
            first entry in rain with entry.rainfall > 10
            would return { date: 4567, rainfall: 11 }
            Another possibility would be each entry in rain: entry.rainfall > 10 ? entry : null which would return an array of all matching entries.
            Clarification:
            each ... in ...: ... is an iterator; it loops over each member of the given object, performing the given expression; an array of result values is constructed, but nulls are not put in the array.
            first ... in ... with ... is a search; it works similar to each but stops at the first thing where the expression result is "truthy" (boolean true or can be coerced to that).
            Both work on arrays or objects/dictionaries.
              UPDATE: The advice shown below is NOT required as of Build 21074+ of MSR.
              In furtherance of the first..in..with construct, let me forewarn users that the non-optional boolean-expression may require parentheses. For example, working off the following object (defined in Expressions):
              houseModes := {home:{hm:1,ac:"home"},away:{hm:2,ac:"away"},sleep:{hm:3,ac:"sleep"},smart1:{hm:4,ac:"smart1"}}
              you would look up the first element matching a value of 1 in key 'hm' using:
              first mode in houseModes with (mode.hm == 1)   // trailing boolean grouped
              // returns array or object
              Without this encapsulation, the entire statement may be evaluated as a boolean, resulting in a trival always-false condition:
              first mode in houseModes with mode.hm == 1   // boolean ungrouped
              // always returns boolean value of FALSE (since null !== 1)
              Likewise, if you wish to reference a nested key within the resulting object, another outer set of parentheses would be required, as follows:
              (first mode in houseModes with (mode.hm == 1)).ac
              // returns "home"
              which, in turn, is functionally equivalent to:
              first mode in houseModes with (mode.hm == 1) ? mode.ac : "no match"
              // returns "home" since 1st object matched expression
              This latter formulation is likely preferred since it handles null situations more gracefully:
              first mode in houseModes with (mode.hm == 5) ? mode.ac : "no match"
              // returns "no match" (string) since test yielded (null)
              (edited)
                I'm not getting this example. Maybe shows the value for hM as well, so we can see what's being tested?
                  I just amended the example above for clarity.
                    I see. That's just a precedence issue, confirmed. I can fix that easily.
                      K Offline
                      K Offline
                      kfxo
                      @toggledbits Should prob add Reset Latch. From the Manual:
                      "Reactor for Vera offered a variety of ways to unlatch a condition, but this was often abused and caused more problems and confusion than it was worth. MSR only unlatches conditions under the conditions described above, and the Reset Latch action is not available."
                        NOTE TO @toggledbits the official docs (e.g. http://[MSR_IP]/docs/Expressions-%26-Variables/#expression-language-syntax) reference FIRST .. OF .. WITH (instead of IN), leaving me scratching my head as to which is the correct syntax.
                        EDIT: The correct keyword is 'in', not 'of'.
                          Fixed in 21307 docs. Could/should have been in Mantis?
                          LibraSunL 1 Reply Last reply
                            @toggledbits said in Deprecated Features:
                            Technically yes, it was among the very 1st three things I reported to you, but as "notes" in Github rather than Mantis (which wasn't yet on my radar at the time). Thanks!
                              2.0k
                              3.8k
                              3.3k
