  3. Import vera most important topics
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
iCOMEN boiler switch
9 Posts 6 Posters 1.8k Views 3 Watching
    sender
    Since the takeover of Vera by a company ezlo and its so called leader which has nothing with the vera brand and product I fear the fact that a lot of information may get lost after the final rebranding of the company will kick in precious data from the current forum is lost. Is it an option to copy that information in this forum?
    • DesTD Offline
      DesTD Offline
      DesT
      Pretty sure it's not possible except if each "owner" want to copy/paste a bunch of data!
        Indeed it is part of the intent. When I saw that a number of my purely technical informational posts were discretely deleted even if it may not have been completely intentional... I thought that the information had to be kept elsewhere. Call me stupid but I sometimes go back to my old posts to figure out how I did certain things... old age you know... And indeed I am going to slowly try to move some of my old posts here and expand on them.
        • DesTD Offline
          DesTD Offline
          DesT
          Just to make sure, feel free to use the forum for your own "personal" note if you want... I don't mind creating some private section on a per-user basis if you want to keep some note here without being public in a thread!
            sender
            Tina Sieber  /  Feb 10, 2017  /  Windows
            Save and Backup Websites for Offline Reading With HTTrack
            Yes, you can download an entire website for offline browsing. With your website backup, you can access online resources, even when you don't have internet. We show you how to set up HTTrack.
              There are a number of webcrawl type products which might perform such a task. The issue, I suspect, is that it'll be 'all or nothing' and I further suspect that the contents of the forum are the IP of the forum owner which may cause issues should it be reproduced here.
                Thinking about it, I don't think we should be importing posts without the consent of their authors so... I am rewriting, resharing a compacted version of my posts.😀
                  mrFarmer
                  Hi Rene here. Nice to see familiar posters here. I claim zero copyrights on my stuff, so use what is found useful. 🙂
                    Hi Rene, thanks for that...
                    AK
                    • Next Release?
                      1.0k
